- H3C Fixed Port Campus Switches Configuration Examples-6W104
 - 00-Applicable hardware and software versions
 - 01-Login Management Configuration Examples
 - 02-RBAC Configuration Examples
 - 03-Software Upgrade Examples
 - 04-ISSU Configuration Examples
 - 05-Software Patching Examples
 - 06-Ethernet Link Aggregation Configuration Examples
 - 07-Port Isolation Configuration Examples
 - 08-Spanning Tree Configuration Examples
 - 09-VLAN Configuration Examples
 - 10-VLAN Tagging Configuration Examples
 - 11-DHCP Snooping Configuration Examples
 - 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
 - 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
 - 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
 - 15-GRE with OSPF Configuration Examples
 - 16-OSPF Configuration Examples
 - 17-IS-IS Configuration Examples
 - 18-BGP Configuration Examples
 - 19-Policy-Based Routing Configuration Examples
 - 20-OSPFv3 Configuration Examples
 - 21-IPv6 IS-IS Configuration Examples
 - 22-Routing Policy Configuration Examples
 - 23-IGMP Snooping Configuration Examples
 - 24-IGMP Configuration Examples
 - 25-MLD Snooping Configuration Examples
 - 26-IPv6 Multicast VLAN Configuration Examples
 - 27-ACL Configuration Examples
 - 28-Traffic Policing Configuration Examples
 - 29-GTS and Rate Limiting Configuration Examples
 - 30-Traffic Filtering Configuration Examples
 - 31-AAA Configuration Examples
 - 32-Port Security Configuration Examples
 - 33-Portal Configuration Examples
 - 34-SSH Configuration Examples
 - 35-IP Source Guard Configuration Examples
 - 36-Ethernet OAM Configuration Examples
 - 37-CFD Configuration Examples
 - 38-DLDP Configuration Examples
 - 39-VRRP Configuration Examples
 - 40-BFD Configuration Examples
 - 41-NTP Configuration Examples
 - 42-SNMP Configuration Examples
 - 43-NQA Configuration Examples
 - 44-Mirroring Configuration Examples
 - 45-sFlow Configuration Examples
 - 46-OpenFlow Configuration Examples
 - 47-MAC Address Table Configuration Examples
 - 48-Static Multicast MAC Address Entry Configuration Examples
 - 49-IP Unnumbered Configuration Examples
 - 50-MVRP Configuration Examples
 - 51-MCE Configuration Examples
 - 52-Attack Protection Configuration Examples
 - 53-Smart Link Configuration Examples
 - 54-RRPP Configuration Examples
 - 55-BGP Route Selection Configuration Examples
 - 56-IS-IS Route Summarization Configuration Examples
 - 57-VXLAN Configuration Examples
 - 58-DRNI Configuration Examples
 - 59-IRF 3.1 Configuration Examples
 - 60-PTP Configuration Examples
 - 61-S-MLAG Configuration Examples
 - 62-Puppet Configuration Examples
 - 63-802.1X Configuration Examples
 - 64-MAC Authentication Configuration Examples
 - 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
 - 66-BIDIR-PIM Configuration Examples
 - 67-Congestion Avoidance and Queue Scheduling Configuration Examples
 - 68-Basic MPLS Configuration Examples
 - 69-MPLS L3VPN Configuration Examples
 - 70-MPLS OAM Configuration Examples
 - 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
 - 72-DRNI and EVPN Configuration Examples
 - 73-Multicast VPN Configuration Examples
 - 74-MPLS TE Configuration Examples
 - 75-Control Plane-Based QoS Policy Configuration Examples
 - 76-Priority Mapping and Queue Scheduling Configuration Examples
 - 77-ARP Attack Protection Configuration Examples
 - 78-IRF Software Upgrade Configuration Examples
 - 79-IRF Member Replacement Configuration Examples
 - 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
 - 81-EVPN Multicast Configuration Examples
| 57-VXLAN Configuration Examples | 164.80 KB |
General restrictions and guidelines
Example: Configuring VXLAN Layer 2 forwarding
Setting the system operation mode
Configuring IP addresses for interfaces
Configuring a routing protocol on the transport network
Example: Configuring a centralized VXLAN IP gateway
Configuring basic VXLAN settings
Configuring the centralized VXLAN IP gateway
Introduction
This document provides Virtual eXtensible LAN (VXLAN) configuration examples. VXLAN is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers for multitenant services.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of VXLAN.
As a best practice, do not configure multiple VXLAN tunnels to use the same source and destination IP addresses.
Link aggregation group membership is mutually exclusive with Ethernet service instance-to-VSI mappings on a Layer 2 interface. Do not map a VSI to an Ethernet service instance on a Layer 2 interface if the interface is in a Layer 2 aggregation group.
Ethernet service instance bindings of VSIs are mutually exclusive with QinQ and VLAN mapping on a Layer 2 Ethernet interface or Layer 2 aggregate interface. Do not configure these features simultaneously on the same interface. Otherwise, the features cannot take effect.
Do not configure VLAN mapping, QinQ, or MAC-based VLAN on a Layer 2 Ethernet interface or Layer 2 aggregate interface that acts as the outgoing interface for traffic of VXLAN tunnels. Otherwise, the features cannot take effect.
As shown in Figure 1:
· Configure VXLAN 10 as a unicast-mode VXLAN on Switch A, Switch B, and Switch C to provide Layer 2 connectivity for the VMs across the network sites.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10.
Analysis
To ensure that the switches in the transport network can reach one another, configure a routing protocol on the switches to advertise routes for interfaces, including the loopback interfaces. In this example, OSPF is used.
To assign Switch A, Switch B, and Switch C to a VXLAN network, create VXLAN tunnels on the switches and assign the tunnels to the VXLAN.
To assign the customer traffic of a VLAN to a VXLAN, you must perform the following tasks:
· Create an Ethernet service instance on the interface that receives the traffic.
· Configure the Ethernet service instance to match the VLAN.
· Map the Ethernet service instance to the VSI on which the VXLAN is created.
    Hardware  |
    Software version  |
   S6812 switch series S6813 switch series  |
   Release 6615Pxx, Release 6628Pxx  |
   S6550XE-HI switch series  |
   Release 6008 and later, Release 8106Pxx  |
   S6525XE-HI switch series  |
   S5850 switch series  |
   Not supported  |
   S5570S-EI switch series  |
   Not supported  |
   S5560X-EI switch series  |
   Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx  |
   S5560X-HI switch series  |
   S5500V2-EI switch series  |
   MS4520V2-30F switch  |
   MS4520V2-30C switch MS4520V2-54C switch  |
   MS4520V2-28S switch MS4520V2-24TP switch  |
   Release 63xx, Release 65xx  |
   S6520X-HI switch series S6520X-EI switch series  |
   S6520X-SI switch series S6520-SI switch series  |
   S5000-EI switch series  |
   MS4600 switch series  |
   ES5500 switch series  |
   S5560S-EI switch series S5560S-SI switch series  |
   Not supported  |
   S5500V3-24P-SI switch S5500V3-48P-SI switch  |
   Not supported  |
   S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)  |
   Not supported  |
   S5170-EI switch series  |
   Not supported  |
   S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series  |
   Not supported  |
   S5120V2-SI switch series S5120V2-LI switch series  |
   Not supported  |
   S5120V3-EI switch series  |
   Not supported  |
   S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch  |
   Not supported  |
   S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)  |
   Not supported  |
   S5120V3-LI switch series  |
   Not supported  |
   S3600V3-EI switch series  |
   Not supported  |
   S3600V3-SI switch series  |
   Not supported  |
   S3100V3-EI switch series S3100V3-SI switch series  |
   Not supported  |
   S5110V2 switch series  |
   Not supported  |
   S5110V2-SI switch series  |
   Not supported  |
   S5000V3-EI switch series S5000V5-EI switch series  |
   Not supported  |
   S5000E-X switch series S5000X-EI switch series  |
   Not supported  |
   E128C switch E152C switch E500C switch series E500D switch series  |
   Not supported  |
   MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series  |
   Not supported  |
   WS5850-WiNet switch series  |
   Not supported  |
   WS5820-WiNet switch series WS5810-WiNet switch series  |
   Not supported  |
   WAS6000 switch series  |
   Not supported  |
   IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series  |
   Not supported  |
Execute the undo vxlan ip-forwarding command on each VTEP to enable Layer 2 forwarding for VXLANs on the VTEPs.
Procedures
# Set the system operation mode to VXLAN on Switch A, Switch B, and Switch C. This step uses Switch A as an example. This step is not applicable to S6550XE-HI and S6525XE-HI switch series.
[SwitchA] switch-mode 1
Reboot device to make the configuration take effect.
[SwitchA] quit
<SwitchA> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
# Configure IP addresses for interfaces on Switch A.
[SwitchA] vlan 11
[SwitchA-vlan11] port gigabitethernet 1/0/2
[SwitchA-vlan11] quit
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] quit
# Configure IP addresses for interfaces on other switches in the same way the IP addresses are configured on Switch A. (Details not shown.)
# Configure OSPF to advertise routes for Switch A.
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure OSPF to advertise routes for Switch B.
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# Configure OSPF to advertise routes for Switch C.
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
# Configure OSPF to advertise routes for Switch D.
[SwitchD] ospf 1 router-id 4.4.4.4
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
Configuring VXLAN settings
Configuring Switch A
# Enable L2VPN.
[SwitchA] l2vpn enable
# Enable Layer 2 forwarding for VXLANs. This step is not applicable to S6550XE-HI and S6525XE-HI switch series.
[SwitchA] undo vxlan ip-forwarding
# Create VSI vpna and VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna-vxlan10] quit
[SwitchA-vsi-vpna] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 1.
[SwitchA-Tunnel1] quit
# Create a VXLAN tunnel to Switch C. The tunnel interface name is Tunnel 2.
[SwitchA] interface tunnel 2 mode vxlan
[SwitchA-Tunnel2] source 1.1.1.1
[SwitchA-Tunnel2] destination 3.3.3.3
[SwitchA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-vxlan10] tunnel 1
[SwitchA-vsi-vpna-vxlan10] tunnel 2
# On GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 2.
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchA-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-GigabitEthernet1/0/1-srv1000] quit
[SwitchA-GigabitEthernet1/0/1] quit
Configuring Switch B
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] undo vxlan ip-forwarding
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna-vxlan10] quit
[SwitchB-vsi-vpna] quit
# Create a VXLAN tunnel to Switch A. The tunnel interface name is Tunnel 1.
[SwitchB] interface tunnel 1 mode vxlan
[SwitchB-Tunnel1] source 2.2.2.2
[SwitchB-Tunnel1] destination 1.1.1.1
[SwitchB-Tunnel1] quit
[SwitchB] interface tunnel 2 mode vxlan
[SwitchB-Tunnel2] source 2.2.2.2
[SwitchB-Tunnel2] destination 3.3.3.3
[SwitchB-Tunnel2] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-vxlan10] tunnel 1
[SwitchB-vsi-vpna-vxlan10] tunnel 2
[SwitchB-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchB-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-GigabitEthernet1/0/1-srv1000] quit
Configuring Switch C
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] undo vxlan ip-forwarding
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna-vxlan10] quit
[SwitchC-vsi-vpna] quit
[SwitchC] interface tunnel 1 mode vxlan
[SwitchC-Tunnel1] source 3.3.3.3
[SwitchC-Tunnel1] destination 1.1.1.1
[SwitchC-Tunnel1] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 2.
[SwitchC] interface tunnel 2 mode vxlan
[SwitchC-Tunnel2] source 3.3.3.3
[SwitchC-Tunnel2] destination 2.2.2.2
[SwitchC-Tunnel2] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-vxlan10] tunnel 1
[SwitchC-vsi-vpna-vxlan10] tunnel 2
[SwitchC] interface gigabitethernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] port link-type trunk
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchC-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchC-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchC-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-GigabitEthernet1/0/1] quit
1. Verify the VXLAN settings on the VTEPs. This example uses Switch A.
# Verify that the VXLAN tunnel interfaces on the VTEP are in up state.
[SwitchA] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 3.3.3.3
# Verify that the VXLAN tunnels have been assigned to the VXLAN, and the VXLAN tunnels and Ethernet service instances are in up state.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
ACs:
AC Link ID State Type
GE1/0/1 srv1000 0 Up Manual
# Verify that the VTEP has learned the MAC addresses of remote VMs.
[SwitchA] display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
cc3e-5f9c-6cdb Dynamic vpna Tunnel1 Aging
cc3e-5f9c-23dc Dynamic vpna Tunnel2 Aging
--- 2 mac address(es) found ---
2. Verify that VM 1, VM 2, and VM 3 can ping each other. (Details not shown.)
Configuration files
· Switch A:
undo vxlan ip-forwarding ( Not applicable to S6550XE-HI and S6525XE-HI switch series.)
area 0.0.0.0
vlan 2
vlan 11
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface11
ip address 11.1.1.1 255.255.255.0
port link-mode bridge
port trunk permit vlan 1 to 2
xconnect vsi vpna
port access vlan 11
interface Tunnel1 mode vxlan
source 1.1.1.1
destination 2.2.2.2
interface Tunnel2 mode vxlan
source 1.1.1.1
destination 3.3.3.3
return
· Switch B:
area 0.0.0.0
vlan 2
vlan 12
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
interface Vlan-interface12
ip address 12.1.1.2 255.255.255.0
xconnect vsi vpna
port access vlan 12
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
return
· Switch C:
area 0.0.0.0
vlan 2
vlan 13
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
interface Vlan-interface13
ip address 13.1.1.3 255.255.255.0
xconnect vsi vpna
port access vlan 13
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Switch D:
area 0.0.0.0
vlan 11
vlan 12
vlan 13
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 11.1.1.4 255.255.255.0
ip address 12.1.1.4 255.255.255.0
ip address 13.1.1.4 255.255.255.0
port access vlan 11
port access vlan 12
port access vlan 13
return
As shown in Figure 2:
· Configure VXLAN 10 and VXLAN 20 as unicast-mode VXLANs on Switch A, Switch B, and Switch C.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10 or VXLAN 20. Make sure VM 1 and VM 3 belong to VXLAN 10 and VM 2 and VM 4 belong to VXLAN 20.
· Configure a centralized VXLAN IP gateway on Switch C to provide gateway services for VXLAN 10 and VXLAN 20.
Analysis
To assign Switch A, Switch B, and Switch C to VXLANs, create VXLAN tunnels on the switches and assign the tunnels to the VXLANs.
To assign the customer traffic of a VLAN to a VXLAN on Switch A or Switch B, you must perform the following tasks:
For Switch C to provide centralized VXLAN IP gateway services for VXLANs, you must perform the following tasks:
· Create a VSI interface for each VXLAN on the switch.
· Assign an IP address to each VSI interface.
· Specify the VSI interfaces as the gateway interfaces for VXLANs.
For Layer 3 nodes in the transport network to reach the VMs, configure a routing protocol on Switch C to advertise routes for VSI interfaces and VLAN-interface 100. In this example, OSPF is used.
    Hardware  |
    Software version  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
   Not supported  |
Procedures
[SwitchA] quit
<SwitchA> reboot
.......DONE!
[Y/N]:y
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 1/0/2
[SwitchA-vlan20] quit
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# Configure IP addresses for interfaces on other devices in the same way the IP addresses are configured on Switch A. (Details not shown.)
[SwitchA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
# Enable L2VPN.
[SwitchA] vsi vpna
# Create VSI vpnb and VXLAN 20.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan10] quit
[SwitchA-vsi-vpnb] quit
[SwitchA] vsi vpna
# Assign Tunnel 1 and Tunnel 2 to VXLAN 20.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb-vxlan20] tunnel 1
[SwitchA-vsi-vpnb-vxlan20] tunnel 2
[SwitchA-vsi-vpnb-vxlan20] quit
# On GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 10.
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 10 11
[SwitchA-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
# On GigabitEthernet 1/0/1, configure Ethernet service instance 2000 to match VLAN 11.
[SwitchA-GigabitEthernet1/0/1] service-instance 2000
[SwitchA-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 11
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchA-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchA-GigabitEthernet1/0/1-srv2000] quit
# Enable L2VPN.
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan10] quit
[SwitchB-vsi-vpnb] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb-vxlan20] tunnel 1
[SwitchB-vsi-vpnb-vxlan20] tunnel 2
[SwitchB-vsi-vpnb-vxlan20] quit
# On GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 12.
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 12 13
[SwitchB-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 12
# On GigabitEthernet 1/0/1, configure Ethernet service instance 2000 to match VLAN 13.
[SwitchB-GigabitEthernet1/0/1] service-instance 2000
[SwitchB-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 13
[SwitchB-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchB-GigabitEthernet1/0/1-srv2000] quit
# Enable L2VPN.
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] vxlan 20
[SwitchC-vsi-vpnb-vxlan10] quit
[SwitchC-vsi-vpnb] quit
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb-vxlan20] tunnel 1
[SwitchC-vsi-vpnb-vxlan20] tunnel 2
[SwitchC-vsi-vpnb-vxlan20] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] gateway vsi-interface 2
# Configure OSPF to advertise routes for the VSI interfaces and VLAN-interface 100.
[SwitchC] ospf 2 router-id 3.3.3.3
[SwitchC-ospf-2] area 0
[SwitchC-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] quit
[SwitchC-ospf-2] quit
# Verify that the VXLAN tunnel interfaces are in up state.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Bandwidth: 64 kbps
# Verify that the VXLAN tunnels have been assigned to their respective VXLANs, and the VXLAN tunnels and Ethernet service instances are in up state.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
GE1/0/1 srv2000 0 Up Manual
2. Verify the configuration on the VXLAN IP gateway:
[SwitchC] display interface tunnel
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
# Verify that the VSI interfaces are in up state.
[SwitchC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Internet Address: 10.1.1.1/24 (primary)
IP packet frame type: Ethernet II, hardware address: 0000-fc00-458d
IPv6 packet frame type: Ethernet II, hardware address: 0000-fc00-458d
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
Internet Address: 10.1.2.1/24 (primary)
# Verify that the VXLAN tunnels have been assigned to VXLANs 10 and 20, VSI-interface 1 is the gateway interface of VSI vpna, and VSI-interface 2 is the gateway interface of VSI vpnb.
[SwitchC] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flooding proxy
Tunnel1 0x5000002 Up Manual Disabled
Tunnel2 0x5000003 Up Manual Disabled
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
# Verify that Switch C has created ARP entries for the VMs.
[SwitchC] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI name Interface Aging Type
10.1.1.11 0000-1234-0001 vpna Tunnel1 20 D
10.1.1.12 0000-1234-0002 vpna Tunnel2 19 D
# Verify that Switch C has created FIB entries for the VMs.
[SwitchC] display fib 10.1.1.11
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
10.1.1.11/32 10.1.1.11 UH Vsi1 Null
3. Verify the network connectivity for VMs:
# Verify that VM 1, VM 2, VM 3, and VM 4 can ping each other. (Details not shown.)
# Verify that VM 1, VM 2, VM 3, VM 4, and VLAN-interface 100 (100.1.1.1) on Switch C can ping each other. (Details not shown.)
Configuration files
· Switch A:
area 0.0.0.0
vlan 10
vlan 11
vlan 20
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface20
ip address 20.1.1.1 255.255.255.0
port trunk permit vlan 1 10 to 11
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 20
source 1.1.1.1
destination 2.2.2.2
source 1.1.1.1
destination 3.3.3.3
· Switch B:
area 0.0.0.0
vlan 12
vlan 13
vlan 30
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface30
ip address 30.1.1.2 255.255.255.0
port trunk permit vlan 1 12 to 13
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 30
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
· Switch C:
area 0.0.0.0
area 0.0.0.0
vlan 40
vlan 100
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface40
ip address 40.1.1.3 255.255.255.0
interface Vlan-interface100
ip address 100.1.1.1 255.255.255.0
port access vlan 40
port access vlan 100
interface Vsi-interface1
interface Vsi-interface2
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Switch D:
area 0.0.0.0
vlan 20
vlan 30
vlan 40
interface LoopBack0
ip address 20.1.1.4 255.255.255.0
ip address 30.1.1.4 255.255.255.0
ip address 40.1.1.4 255.255.255.0
port access vlan 20
port access vlan 30
port access vlan 40
return
