H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
35-Information Center Configuration Guide
35-Information Center Configuration Guide 537.84 KB
Table of Contents
1 Information Center Configuration Guide· 1-1
Outputting Log Information to a Unix Log Host 1-1
Network Diagram·· 1-1
Networking and Configuration Requirements· 1-1
Applicable Product Matrix· 1-1
Configuration Procedure· 1-1
Complete Configuration· 1-2
Precautions· 1-3
Outputting Log Information to a Linux Log Host 1-3
Network Diagram·· 1-3
Networking and Configuration Requirements· 1-3
Applicable Product Matrix· 1-3
Configuration Procedure· 1-3
Complete Configuration· 1-4
Precautions· 1-4
Outputting Log and Trap Information to a Log Host Through the Same Channel 1-5
Network Diagram·· 1-5
Networking and Configuration Requirements· 1-5
Applicable Product Matrix· 1-5
Configuration Procedure· 1-5
Complete Configuration· 1-7
Precautions· 1-7
Outputting Log Information to the Console· 1-7
Network Diagram·· 1-7
Networking and Configuration Requirements· 1-7
Applicable Product Matrix· 1-8
Configuration Procedure· 1-8
Complete Configuration· 1-8
Precautions· 1-8
Displaying the Time Stamp with the UTC Time Zone· 1-9
Network Diagram·· 1-9
Networking and Configuration Requirements· 1-9
Applicable Product Matrix· 1-9
Configuration Procedure· 1-9
Complete Configuration· 1-10
Precautions· 1-10
Use of the Facility Argument in Log Information Output 1-10
Network Diagram·· 1-10
Networking and Configuration Requirements· 1-10
Network Requirements Analysis· 1-10
Applicable Product Matrix· 1-11
Configuration Procedure· 1-11
Complete Configuration· 1-11
Precautions· 1-11
Network Diagram
Figure 1-1 Network diagram for outputting log information to a Unix log host
Send log information with severity higher than informational to a Unix log host with an IP address of 202.38.1.10. The information source modules are ARP and IP.
Product series
Software version
Hardware version
S5600 series Ethernet switches
Release 1510, Release 1602
All versions
S5100-SI/EI series Ethernet switches
Release 2200, Release 2201
All versions
S3600-SI/EI series Ethernet switches
All versions
S3100-EI series Ethernet switches
Release 2104, Release 2107
All versions
S3100-C-SI series Ethernet switches
S3100-T-SI series Ethernet switches
Release 0011, Release 2102, Release 2107
All versions
S3100-TP-SI series Ethernet switches
All versions( except S3100-52TP-SI)
S3100-52TP-SI
Release 2106, Release 2107
S3100-52TP-SI
S3100-52P
Release 1500, Release 1602
S3100-52P
l          Configuration on the switch.
# Enable the information center.
<H3C> system-view
[H3C] info-center enable
# By default, the system outputs information of all modules to the loghost channel. To obtain the system information of the ARP and IP modules, you need to disable the output of information of all modules to the log host.
[H3C] undo info-center source default channel loghost
# Set the host with an IP address of 202.38.1.10 to be the log host, set the severity to informational, and the information source modules to ARP and IP.
[H3C] info-center loghost 202.38.1.10 facility local4
[H3C] info-center source arp channel loghost log level informational debug state off trap state off
[H3C] info-center source ip channel loghost log level informational debug state off trap state off
l          Configuration on the log host.
The following configurations were performed on SunOS 4.0 which has similar configurations with the Unix operating systems implemented by other vendors.
# Execute the following commands as a root user.
# mkdir /var/log/H3C
# touch /var/log/H3C/information
# Edit the file /etc/syslog.conf as a root user and add the following selector/action pairs.
# H3C configuration messages
local4.info    /var/log/H3C/information
# After the log file information has been created and the configuration file /etc/syslog.conf has been modified, ensure that the configuration file /etc/syslog.conf is reread by executing the following commands:
# ps -ae | grep syslogd
147
# kill -HUP 147
 info-center source ARP channel 2 trap state off
 info-center source IP channel 2 trap state off
 undo info-center source default channel 2
147
# kill -HUP 147
Precautions
Note the following issues while editing the /etc/syslog.conf file:
l          Comments must be on a separate line and must begin with the # sign.
l          The selector/action pair must be separated with a tab key, rather than a space.
l          No redundant spaces are allowed in the file name.
l          The device name and the accepted severity of log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost and info-center source commands; otherwise the log information may not be output properly to the log host.
Network Diagram
Figure 1-2 Network diagram for outputting log information to a Linux log host
Send log information to a Linux log host with an IP address of 202.38.1.10; Log information with severity higher than errors will be output to the log host; The information source modules are all modules.
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
All versions
S3100-52TP-SI
S3100-52TP-SI
S3100-52P
S3100-52P
<H3C> system-view
# Set the host with an IP address of 202.38.1.10 to be the log host, set the severity to errors, and the information source modules to all modules.
[H3C] info-center loghost 202.38.1.10 facility local7
[H3C] info-center source default channel loghost log level errors debug state off trap state off
local7.info    /var/log/H3C/information
# After the log file information has been created and the /etc/syslog.conf file has been modified, execute the following commands to display the process ID of syslogd, terminate a syslogd process, and restart syslogd using the -r option.
147
# kill -9 147
# syslogd -r &
 info-center source default channel 2 log level error trap state off
147
# kill -9 147
# syslogd -r &
Precautions
Ensure that the syslogd process is started with the -r option on a Linux log host.
Network Diagram
Figure 1-3 Network diagram for outputting log and trap information to a log host through the same channel
Send log and trap information with severity higher than informational to the log host through the same channel channel6. The information source module is L2INF (interface management module).
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
All versions
S3100-52TP-SI
S3100-52TP-SI
S3100-52P
S3100-52P
<H3C> system-view
# The system outputs information of all modules through channel6 by default. Therefore, you need to disable the function first.
[H3C] undo info-center source default channel channel6
# Set the host with an IP address of 10.153.116.65 to be the log host, set to send log and trap information with severity higher than informational to the log host through the same channel channel6, and set the information source module to L2INF.
[H3C] info-center loghost 10.153.116.65 channel 6
[H3C] info-center source L2INF channel 6 log level informational state on trap level informational state on debug state off
For the configuration of the log host, see
Configuration Procedure and Configuration Procedure.
The following takes receiving log information through log host software on a Windows operating system as an example:
# The log host software used in this example is TFTPD32, the version of which is as follows:
# Open the TFTPD32 application program on the Windows operating system as shown in the following figure:
1)        Current Directory indicates the directory of the log file syslog.txt. You can click the Browse button to set it. In this example, the directory is D:\Tools\TFTP.
2)        Server interface indicates the IP address of the log host. It is 10.153.116.65 in this example.
3)        Select the syslog server tab.
# The system information with the required severity level will be output to the log host as shown in the following figure:
# After receiving the system information, the log host will save it in the log file syslog.txt under D:\Tools\TFTP. You can view the saved system information as shown in the following figure (the information in the blue colour is the L2INF module trap information received by the log host):
 undo info-center source default channel 6
Precautions
On the Windows operating system, software settings vary with log host software.
Network Diagram
Figure 1-4 Network diagram for outputting log information to the console
Log information with a severity higher than informational will be output to the console, and the information source modules are ARP and IP.
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
All versions
S3100-52TP-SI
S3100-52TP-SI
S3100-52P
S3100-52P
<H3C> system-view
# By default, the system outputs information of all modules to the console. Therefore, to obtain the system information of the ARP and IP modules, you need to disable the output of information of all modules to the console.
[H3C] undo info-center source default channel console
# Set the severity to informational, and the information source modules to ARP and IP.
[H3C] info-center console channel console
[H3C] info-center source arp channel console log level informational debug state off trap state off
[H3C] info-center source ip channel console log level informational debug state off trap state off
# Enable terminal display.
<H3C> terminal monitor
<H3C> terminal logging
 info-center source ARP channel 0 trap state off
 info-center source IP channel 0 trap state off
 undo info-center source default channel 0
Precautions
None
Network Diagram
Figure 1-5 Network diagram for displaying the time stamp with the UTC time zone
l          The switch is in the time zone of GMT+ 08:00:00.
l          The time stamp format of output log information is date.
l          UTC time zone will be added to the output information of the information center.
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
All versions
S3100-52TP-SI
S3100-52TP-SI
S3100-52P
S3100-52P
# Name the local time zone z8 and set it to eight hours ahead of UTC time.
<H3C> clock timezone z8 add 08:00:00
# Set the time stamp format of output log information to date.
<H3C> system-view
[H3C] info-center timestamp loghost date
# Configure to add UTC time to the output information of the information center.
[H3C] info-center timestamp utc
Precautions
None
Network Diagram
Figure 1-6 Network diagram for use of the facility argument in log information output
Multiple switches in a LAN send log information to the same log host. You can know the running status of each switch by displaying log information received.
As multiple switches send log information to the same log host, you can set different values of the facility keyword for each switch to filter information on the log host, thus avoiding failure in recognizing information source (for example, if the two hosts have the same name and the facility keywords are set to the default value local7, you cannot recognize the information source.).
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
All versions
S3100-52TP-SI
S3100-52TP-SI
S3100-52P
S3100-52P
l          Perform the following configurations on Switch A.
[SwitchA]info-center enable
[SwitchA]info-center source default channel loghost log level debugging
[SwitchA]info-center loghost 192.168.0.208 facility local0 channel loghost
l          Perform the same configurations on Switch B, Switch C, Switch D and Switch E, and specify the facility argument as local1, local2, local3 and local4 respectively.
l          You can know the running status of all the devices by filtering information through the facility keyword.
l          Configuration on Switch A.
 info-center source default channel 2 log level debugging
l          Configuration on Switch B, Switch C, Switch D and Switch E.
<Omitted>
Precautions
None
