H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
29-PoE-PoE Profile Configuration Guide
29-PoE-PoE Profile Configuration Guide 98.26 KB
PoE Configuration
Power over Ethernet (PoE)-enabled devices use 10BASE-T, 100BASE-TX and 1000BASE-T twisted pair cables to supply power to powered devices (PD) and implement power supply and data transmission simultaneously.
Network Diagram
Figure 1-1 Network diagram for PoE configuration
Networking and Configuration Requirements
l          Switch A is an S3600 Ethernet switch supporting PoE and Switch B can be PoE powered.
l          The Ethernet 1/0/1 and Ethernet 1/0/2 ports of Switch A are connected to Switch B and an Access Point (AP) respectively; the Ethernet 1/0/8 port is intended to be connected with an important AP.
l          The PSE processing software of Switch A is first upgraded online. The remotely accessed PDs are powered by Switch A.
l          The power consumption of the accessed AP is 2,500 milliwatts, and the maximum power consumption of Switch B is 12,000 milliwatts.
l          It is required to guarantee the power supply to the AP connected to the Ethernet 1/0/8 even when Switch A is under full load.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
S5600 series PoE switches
S5100-EI series
Release 2200, Release2201
S5100-EI series PoE switches
S3600-SI/EI series
S3600-SI/EI series PoE switches
S3100-EI series
Release 2104, Release 2107
S3100-EI series PoE switches
Configuration Procedure
# Upgrade the power processing software.
[SwitchA] poe update refresh 0290_021.s19
Update PoE  board successfully
# Enable the PoE feature on ports Ethernet 1/0/1, Ethernet 1/0/2 and Ethernet 1/0/8.
[SwitchA] interface Ethernet 1/0/1
[SwitchA-Ethernet1/0/1] poe enable
[SwitchA-Ethernet1/0/1] quit
[SwitchA]interface Ethernet 1/0/2
[SwitchA-Ethernet1/0/2] poe enable
[SwitchA-Ethernet1/0/2] quit
[SwitchA] interface Ethernet 1/0/8
[SwitchA-Ethernet1/0/8] poe enable
[SwitchA-Ethernet1/0/8] quit
# Set the maximum power that Ethernet 1/0/1 and Ethernet 1/0/2 can provide for all PDs to 12000 and 2500 milliwatts respectively.
[SwitchA-Ethernet1/0/1] poe max-power 12000
[SwitchA] interface Ethernet 1/0/2
[SwitchA-Ethernet1/0/2] poe max-power 2500
# Set the PoE priority of Ethernet 1/0/8 to critical to guarantee power supply to the device connected to Ethernet 1/0/8.
[SwitchA-Ethernet1/0/8] poe priority critical
# Set the power supply management mode of the switch to auto (The default power supply management mode is auto, and this step can be omitted.).
[SwitchA] poe power-management auto
# Enable the PD compatibility detection function to allow the switch to supply power to the PDs not compliant with the 802.3af standard.
[SwitchA] poe legacy enable
# View the power supply status of all the ports on the switch after the configuration.
[SwitchA] display poe interface
       PORT INDEX      POWER ENABLE   MODE  PRIORITY       STATUS
 Ethernet1/0/1          on   enable  signal  low      Standard PD was detected
 Ethernet1/0/2          on   enable  signal  low      Standard PD was detected
 Ethernet1/0/3          off  enable  signal  low      detection is in process
 Ethernet1/0/4          off  enable  signal  low      detection is in process
 Ethernet1/0/5          off  enable  signal  low      detection is in process
 Ethernet1/0/6          off  enable  signal  low      detection is in process
 Ethernet1/0/7          off  enable  signal  low      detection is in process
 Ethernet1/0/8          on   enable  signal  critical Standard PD was detected
# View the PoE power information of all the ports on the switch.
<SwitchA> display poe interface power
       PORT INDEX       POWER (mW)                PORT INDEX      POWER (mW)
 Ethernet1/0/1           11500             Ethernet1/0/2           2300
 Ethernet1/0/3           0                  Ethernet1/0/4           0
 Ethernet1/0/5           0                  Ethernet1/0/6           0
 Ethernet1/0/7           0                  Ethernet1/0/8           2400
Complete Configuration
 poe legacy enable
interface Ethernet1/0/1
 poe enable
 poe max-power 12000
interface Ethernet1/0/2
 poe enable
 poe max-power 2500
interface Ethernet1/0/8
 poe enable
Precautions
None
A PoE profile is a set of PoE configurations, including multiple PoE features.
Features of PoE profile:
l          Various PoE profiles can be created. PoE policy configurations applicable to different user groups are saved in the corresponding PoE profiles. These PoE profiles can be applied to the ports used by the corresponding user groups.
l          When users connect a PD to a PoE-profile-enabled port, the PoE configurations in the PoE profile will be enabled on the port.
Network Diagram
Figure 1-2 Network diagram for PoE profile configuration
Switch A is an S3600 Ethernet switch supporting PoE. Ethernet 1/0/1 through Ethernet 1/0/10 of Switch A are used by users of group A, whom have the following requirements:
l          The PoE function can be enabled on all ports in use.
l          Signal mode is used to supply power.
l          The PoE priority for Ethernet 1/0/1 through Ethernet 1/0/5 is critical, whereas the PoE priority for Ethernet 1/0/6 through Ethernet 1/0/10 is high.
l          The maximum power for Ethernet 1/0/1 through Ethernet 1/0/5 is 3000 milliwatts, whereas the maximum power for Ethernet 1/0/6 through Ethernet 1/0/10 is 15400 milliwatts.
Based on the above requirements, two PoE profiles are made for users of group A.
l          Apply PoE profile 1 for Ethernet 1/0/1 through Ethernet 1/0/5;
l          Apply PoE profile 2 for Ethernet 1/0/6 through Ethernet 1/0/10.
Product series
Software version
Hardware version
S5600 series
S5100-EI series
S3600-SI/EI series
S3100-EI series
# Create Profile1 and enter PoE profile view.
[SwitchA] poe-profile Profile1
# In Profile1, add the PoE policy configuration applicable to Ethernet 1/0/1 through Ethernet 1/0/5 for users of group A.
[SwitchA-poe-profile-Profile1] poe enable
[SwitchA-poe-profile-Profile1] poe mode signal
[SwitchA-poe-profile-Profile1] poe priority critical
[SwitchA-poe-profile-Profile1] poe max-power 3000
[SwitchA-poe-profile-Profile1] quit
# Create Profile2 and enter PoE profile view.
[SwitchA] poe-profile Profile2
# In Profile2, add the PoE policy configuration applicable to Ethernet 1/0/6 through Ethernet 1/0/10 for users of group A.
[SwitchA-poe-profile-Profile2] poe enable
[SwitchA-poe-profile-Profile2] poe mode signal
[SwitchA-poe-profile-Profile2] poe priority high
[SwitchA-poe-profile-Profile2] poe max-power 15400
[SwitchA-poe-profile-Profile2] quit
# Apply the configured Profile1 to Ethernet 1/0/1 through Ethernet 1/0/5.
[SwitchA] apply poe-profile Profile1 interface Ethernet1/0/1 to Ethernet1/0/5
# Apply the configured Profile2 to Ethernet 1/0/6 through Ethernet 1/0/10.
[SwitchA] apply poe-profile Profile2 interface Ethernet1/0/6 to Ethernet1/0/10
 poe enable
 poe max-power 3000
 poe enable
 poe priority high
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/7
interface Ethernet1/0/9
interface Ethernet1/0/10
Precautions
1)        When the apply poe-profile command is used to apply a PoE profile to a port, some PoE features can be applied successfully while some cannot. PoE profiles are applied to H3C low-end PoE switches according to the following rules:
l          When the apply poe-profile command is used to apply a PoE profile to a port, the PoE profile is applied successfully as long as one PoE feature in the PoE profile is applied properly. When the display current-configuration command is used for query, it is displayed that the PoE profile is applied properly to the port.
l          If one or more features in the PoE profile are not applied properly on a port, the switch will prompt explicitly which PoE features in the PoE profile are not applied properly on which ports.
l          The display current-configuration command can be used to query which PoE profile is applied to a port. However, the command cannot be used to query which PoE features in a PoE profile are applied successfully.
2)        If you cannot apply a PoE profile to a PoE port, it may be due to the following reasons:
l          Some of the PoE features in the PoE profile have been configured through other modes;
l          Some of the PoE features in the PoE profile are not compliant with the configuration requirements for PoE ports;
l          Another PoE profile has been applied to this PoE port.
You can solve the problem in the following ways:
l          In the first case, you can solve the problem by removing the original configurations.
l          In the second case, you need to modify some configurations in the PoE profile.
In the third case, you need to remove the application of the undesired PoE profile from the PoE port.
