H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
04-Voice VLAN Configuration Guide
04-Voice VLAN Configuration Guide 56.25 KB
Configuring Voice VLAN
The voice VLAN feature improves voice traffic transmission priority and guarantee voice quality by assigning voice traffic to a dedicated VLAN for transmission. This dedicated VLAN is called the voice VLAN. A port is assigned to the voice VLAN in one of the following two modes:
l          In automatic mode, the switch checks the source MAC address of each incoming packet against the voice device OUI address list maintained on the switch. If a match is found, the switch assigns the port to the voice VLAN and tags the packet with the voice VLAN ID automatically. When the port joins the voice VLAN, a voice VLAN aging timer starts. If no voice packets have been received before the timer expires, the port leaves the voice VLAN.
l          In manual mode, you need to manually assign a port to or remove the port from the voice VLAN.
Network Diagram
Figure 1-1 Network diagram for voice VLAN in automatic mode
Networking and Configuration Requirements
As shown in Figure 1-1, the PC is connected to Ethernet 1/0/1 of Switch A through IP phone 1, and IP phone 2 is connected to Ethernet 1/0/2 of Switch A. IP phone 1 sends out voice traffic with the tag of the voice VLAN, while IP phone 2 sends out voice traffic without any VLAN tag. Configure the voice VLAN feature to satisfy the following requirements:
l          VLAN 2 functions as the voice VLAN for transmitting voice traffic, and set the aging timer of the voice VLAN to 100 minutes. VLAN 6 transmits user service data.
l          Ethernet 1/0/1 and Ethernet 1/0/2 can recognize voice traffic automatically. Service data from the PC and voice traffic are assigned to different VLANs and then transmitted to the server and the voice gateway respectively through Switch B.
l          As the OUI address of IP phone 2 is not in the default voice device OUI address list of the switch, add its OUI address 000f-2200-0000 to the voice device OUI address list. In addition, configure its description as IP Phone2.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
# Create VLAN 2 and VLAN 6.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
[SwitchA] vlan 6
[SwitchA-vlan6] quit
# Set the aging timer for the voice VLAN.
[SwitchA] voice vlan aging 100
# Add 000f-2200-0000 to the voice device OUI address list and configure its description as IP Phone2.
[SwitchA] voice vlan mac-address 000f-2200-0000 mask ffff-ff00-0000 description IP Phone2
# Configure VLAN 2 as the voice VLAN and enable the voice VLAN feature globally.
[SwitchA] voice vlan 2 enable
# Set the voice VLAN assignment mode on Ethernet 1/0/1 to automatic. This step is optional, because the default voice VLAN assignment mode is automatic.
[SwitchA] interface Ethernet 1/0/1
[SwitchA-Ethernet1/0/1] voice vlan mode auto
# Configure Ethernet 1/0/1 as a trunk port.
[SwitchA-Ethernet1/0/1] port link-type trunk
# Set VLAN 6 as the default VLAN of Ethernet 1/0/1 and configure Ethernet 1/0/1 to permit the packets of VLAN 6 to pass through. (PC data will be transmitted in the VLAN.)
[SwitchA-Ethernet1/0/1] port trunk pvid vlan 6
[SwitchA-Ethernet1/0/1] port trunk permit vlan 6
# Enable voice VLAN on Ethernet 1/0/1.
[SwitchA-Ethernet1/0/1] voice vlan enable
l          After the configuration is finished, PC data is automatically assigned to the default VLAN of Ethernet 1/0/1 (namely the service VLAN) for transmission. When IP phone traffic arrives at Ethernet 1/0/1, the port automatically permits the voice VLAN and transmits the voice traffic with the voice VLAN tag, so that the IP phone can receive packets normally.
l          You can set Ethernet 1/0/1 as a hybrid or trunk port following the same procedure. In either case, you need to set the service VLAN as the default VLAN. As for voice traffic, when IP phone traffic arrives at the port, the port automatically permits the voice VLAN and transmits the traffic with the voice VLAN tag.
# Set the voice VLAN assignment mode of Ethernet 1/0/2 to manual. The mode must be manual because IP phone 2 can send out only untagged voice traffic.
[SwitchA-Ethernet1/0/1] quit
[SwitchA] interface Ethernet 1/0/2
[SwitchA-Ethernet1/0/2] undo voice vlan mode auto
# Configure Ethernet 1/0/2 to be an access port and permit the voice VLAN.
[SwitchA-Ethernet1/0/2] port access vlan 2
# Enable voice VLAN on Ethernet 1/0/2.
[SwitchA-Ethernet1/0/2] voice vlan enable
l          You can set Ethernet 1/0/2 as a trunk or hybrid port. In either case, configure the voice VLAN as the default VLAN and configure the port to remove the VLAN tag when forwarding traffic with the voice VLAN tag.
l          If traffic from IP phone 2 is tagged, configure Ethernet 1/0/2 as a trunk or hybrid port where the default VLAN cannot be set to VLAN 20 and the packets of VLAN 20 must be sent with the VLAN tag.
Complete Configuration
vlan 1 to 2
vlan 6
interface Ethernet1/0/1
 port trunk permit vlan 1 6
 voice vlan enable
interface Ethernet1/0/2
 port access vlan 2
 voice vlan enable
 voice vlan 2 enable
Precautions
Follow these guidelines when configuring the voice VLAN feature:
l          You cannot assign a port operating in automatic mode to the voice VLAN manually. Therefore, if you configure a VLAN as a voice VLAN and a protocol VLAN at the same time, you will be unable to associate the protocol VLAN with such a port. Refer to VLAN Configuration Guide in this manual for description on protocol VLAN.
l          You cannot set the voice VLAN as the default VLAN on a port operating in automatic voice VLAN assignment mode.
l          The switch supports only one voice VLAN.
l          You cannot enable voice VLAN on a port configured with the Link Aggregation Control Protocol (LACP).
l          Only a static VLAN can be configured as the voice VLAN.
l          When the number of ACL rules applied to a port reaches the upper threshold, enabling voice VLAN on the port will fail. You can use the display voice vlan error-info command to locate such ports.
l          In the voice VLAN operating in security mode, the device allows only the packets whose source address matches a recognizable voice device vendor OUI to pass through. All other packets, including authentication packets such as 802.1x authentication packets, will be dropped. Therefore, you are recommended not to transmit both voice data and service data in the voice VLAN.
