H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
37-HWPing Configuration Guide
37-HWPing Configuration Guide 113.51 KB
HWPing (pronounced Hua’Wei Ping) is a network diagnostic tool. It is used to test the performance of various protocols running in networks. HWPing provides more functions than the ping command.
The ping command can only use the Internet Control Message Protocol (ICMP) to test the round trip time (RTT) between the local end and a specified destination end for you to judge whether the destination end is reachable.
A HWPing test group is a set of HWPing test parameters. A test group contains several test parameters and is uniquely identified by an administrator name and a test operation tag.
After creating a HWPing test group and configuring the test parameters, you can perform a HWPing test with the test-enable command.
Different from the ping command, HWPing does not display the RTT or timeout status of each packet on the console terminal in real time. To view the statistic results of your HWPing test operation, you need to execute the display hwping command. HWPing also allows you to set parameters for HWPing test groups, start HWPing tests and view statistical test results through a network management device.
ICMP Test
Network diagram
Figure 1-1 Network diagram for the ICMP test
Networking and configuration requirements
A HWPing ICMP test between two switches uses ICMP to test the round trip time (RTT) for packets generated by the HWPing client.
Applicable product matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration procedure
# Enable the HWPing client.
[SwitchA] hwping-agent enable
# Create a HWPing test group, configuring the administrator name as administrator and test operation tag as ICMP.
[SwitchA] hwping administrator icmp
# Configure the test type as ICMP.
[SwitchA-hwping-administrator-icmp] test-type icmp
# Configure the destination IP address as 10.2.2.2.
[SwitchA-hwping-administrator-icmp] destination-ip 10.2.2.2
# Configure the number of probes in one test as 10.
[SwitchA-hwping-administrator-icmp] count 10
# Configure the probe timeout time as 5 seconds.
[SwitchA-hwping-administrator-icmp] timeout 5
# Start the test.
[SwitchA-hwping-administrator-icmp] test-enable
# View the test results.
[SwitchA-hwping-administrator-icmp] display hwping results administrator icmp
[SwitchA-hwping-administrator-icmp] display hwping history administrator icmp
For detailed output description, see the corresponding command manual.
Complete configuration
Configuration on Switch A.
hwping-agent enable
 test-type icmp
 count 10
 timeout 5
Precautions
none
DHCP Test
Network diagram
Figure 1-2 Network diagram for the DHCP test
Perform a HWPing DHCP test between the two switches to test the time required for the HWPing client to obtain an IP address from the DHCP server.
Product series
Software version
Hardware version
S5600 series
Release1602
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
Release1602
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
Release 1602
S3100-52P
l          Configure DHCP Server(Switch B):
Configure DHCP server on Switch B. For specific configuration of DHCP server, refer to the DHCP part of the manual.
l          Configure HWPing Client (Switch A):
# Create a HWPing test group, setting the administrator name to administrator and test tag to DHCP.
[SwitchA] Hwping administrator dhcp
# Configure the test type as dhcp.
[SwitchA-hwping-administrator-dhcp] test-type dhcp
# Configure the source interface, which must be a VLAN interface. Make sure the DHCP server resides on the network connected to this interface.
[SwitchA-hwping-administrator-dhcp] source-interface Vlan-interface 1
# Configure to make 10 probes per test.
[SwitchA-hwping-administrator-dhcp] count 10
# Set the probe timeout time to 5 seconds.
[SwitchA-hwping-administrator-dhcp] timeout 5
# Start the test.
[SwitchA-hwping-administrator-dhcp] test-enable
# Display test results
[SwitchA-hwping-administrator-dhcp] display hwping results administrator dhcp
[SwitchA-hwping-administrator-dhcp] display hwping history administrator dhcp
hwping-agent enable
hwping administrator dhcp
 test-type dhcp
 count 10
 timeout 5
Precautions
You can perform a HWPing DHCP test only when no DHCP client is enabled on any interface. Otherwise, the DHCP Server sends the response to an interface enabled with the DHCP Client rather than to the source interface, thus resulting in HWPing DHCP test failure.
HTTP Test
Network diagram
Figure 1-3 Network diagram for the HTTP test
Perform a HWPing HTTP test between the switch and the HTTP server to test the connectivity and the time required to download a file from the HTTP server after the connection to the server is established.
Product series
Software version
Hardware version
S5600 series
Release1602
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
Release1602
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
Release 1602
S3100-52P
l          Configure HTTP Server:
Use Windows 2003 Server as the HTTP server. For HTTP server configuration, refer to the related instruction on Windows 2003 Server configuration.
# Create a HWPing test group, setting the administrator name to administrator and test tag to HTTP.
[SwitchA] Hwping administrator http
# Configure the test type as http.
[SwitchA-hwping-administrator-http] test-type http
# Configure the IP address of the HTTP server as 10.2.2.2.
[SwitchA-hwping-administrator-http] destination-ip 10.2.2.2
[SwitchA-hwping-administrator-http] count 10
# Set the probe timeout time to 30 seconds.
[SwitchA-hwping-administrator-http] timeout 30
# Start the test.
[SwitchA-hwping-administrator-http] test-enable
[SwitchA-hwping-administrator-http] display hwping results administrator http
[SwitchA-hwping-administrator-http] display hwping history administrator http
hwping-agent enable
hwping administrator http
 test-type http
 count 10
 timeout 30
Precautions
none
TCP Test (Tcpprivate Test) on the Specified Ports
Network diagram
Figure 1-4 Network diagram for the Tcpprivate test
Perform a HWPing Tcpprivate test to test time required to establish a TCP connection between this end (Switch A) and the specified destination end (Switch B), with the port number set to 8000.
Product series
Software version
Hardware version
S5600 series
Release1602
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
Release1602
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
Release 1602
S3100-52P
l          Configure HWPing Server (Switch B):
# Enable the HWPing server and configure the IP address and port to listen on.
[SwitchB] hwping-server enable
[SwitchB] hwping-server tcpconnect 10.2.2.2 8000
# Create a HWPing test group, setting the administrator name to administrator and test tag to tcpprivate.
[SwitchA] Hwping administrator tcpprivate
# Configure the test type as tcpprivate.
[SwitchA-hwping-administrator-tcpprivate] test-type tcpprivate
# Configure the IP address of the HWPing server as 10.2.2.2.
[SwitchA-hwping-administrator-tcpprivate] destination-ip 10.2.2.2
# Configure the destination port on the HWPing server.
[SwitchA-hwping-administrator-tcpprivate] destination-port 8000
[SwitchA-hwping-administrator-tcpprivate] count 10
[SwitchA-hwping-administrator-tcpprivate] timeout 5
# Start the test.
[SwitchA-hwping-administrator-tcpprivate] test-enable
# Display test results.
[SwitchA-hwping-administrator-tcpprivate] display hwping results administrator tcpprivate
[SwitchA-hwping-administrator-tcpprivate] display hwping history administrator tcpprivate
l          Configuration on Switch B.
l          Configuration on Switch A.
hwping-agent enable
hwping administrator tcpprivate
 count 10
 timeout 5
Precautions
none
DNS Test
Network diagram
Figure 1-5 Network diagram for the DNS test
Perform a HWPing DNS test between the switch and the DNS server to test the time required from the client sends a DNS request to it receives a resolution result from the DNS server.
Product series
Software version
Hardware version
S5600 series
Release1602
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
Release1602
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
Release 1602
S3100-52P
l          Configure DNS Server:
Use Windows 2003 Server as the DNS server. For DNS server configuration, refer to the related instruction on Windows 2003 Server configuration.
# Create a HWPing test group, setting the administrator name to administrator and test tag to dns.
[SwitchA] hwping administrator dns
# Configure the test type as dns.
[SwitchA-hwping-administrator-dns] test-type dns
# Configure the IP address of the DNS server as 10.2.2.2.
[SwitchA-hwping-administrator-dns] dns-server 10.2.2.2
# Configure to resolve the domain name www.test.com.
[SwitchA-hwping-administrator-dns] dns resolve-target www.test.com
[SwitchA-hwping-administrator-dns] count 10
[SwitchA-hwping-administrator-dns] timeout 5
# Start the test.
[SwitchA-hwping-administrator-dns] test-enable
[SwitchA-hwping-administrator-dns] display hwping results administrator dns
[SwitchA-hwping-administrator-dns] display hwping history administrator dns
hwping-agent enable
 test-type dns
 count 10
 timeout 5
Precautions
none
