H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
10-Port Binding Configuration Guide
10-Port Binding Configuration Guide 27.9 KB
Configuring a Port Binding
Port binding allows the network administrator to bind the MAC and IP addresses of a user to a specific port. After the port binding operation, the switch forwards a packet received from the port only if the source MAC address and IP address carried in the packet have been bound to the port. This improves network security and enhances security monitoring.
Network Diagram
Figure 1-1 Network diagram for port binding configuration
Networking and Configuration Requirements
To prevent the IP address of Host A from being used by a malicious user, bind the MAC address and IP addresses of Host A to Ethernet 1/0/1 on Switch A.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-52P
Release 1602
S3100-52P
Configuration Procedure
# Enter system view.
# Enter Ethernet 1/0/1 port view.
[SwitchA] interface Ethernet1/0/1
# Bind the MAC address and the IP address of Host 1 to Ethernet 1/0/1.
[SwitchA-Ethernet1/0/1] am user-bind mac-addr 0001-0002-0003 ip-addr 10.12.1.1
Complete Configuration
