H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
02-VLAN Configuration Guide
02-VLAN Configuration Guide 67.98 KB
Configuring Port-Based VLAN
The VLAN technology allows you to divide a broadcast LAN into multiple distinct broadcast domains, each as a virtual workgroup. Port-based VLAN is the simplest approach to VLAN implementation. The idea is to assign the ports on a switch to different VLANs, confining the propagation of the packets received on a port within the particular VLAN. Thus, separation of broadcast domains and division of virtual groups are achieved.
Network Diagram
Figure 1-1 Network diagram for port-based VLAN configuration
Networking and Configuration Requirements
In the sample intranet network shown in Figure 1-1, Switch A is connected to the subnet of a department and the subnet for the public servers, and Switch B is connected to the subnet of the other two departments.
To guarantee data security for each department, use VLANs to isolate the four subnets at Layer 2 but configure Layer-3 interfaces on Switch A to enable the hosts of the three departments and the public servers to communicate with each other at Layer 3.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
The S3600-SI/EI series and S5600 series switches can operate as Switch A in Figure 1-1 for forwarding packets at Layer 3 for VLANs. The other models in the table above do not support configuring multiple VLAN interfaces for Layer-3 forwarding, and therefore, they can operate as only Switch B for Layer-2 isolation with VLANs, as shown in Figure 1-1.
Configuration Procedure
l          Configure Switch A
# Create VLAN 10 on Switch A and assign Ethernet 1/0/1 to VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] port Ethernet 1/0/1
[SwitchA-vlan10] quit
# Create VLAN 100 on Switch A and assign Ethernet 1/0/2 to VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 1/0/2
[SwitchA-vlan100] quit
# Create VLAN 101 and VLAN 102 on Switch A.
[SwitchA] vlan 101 to 102
# Create VLAN-interface 10, VLAN-interface 100, VLAN-interface 101, and VLAN-interface 102, and configure an IP address for each of these VLAN-interfaces.
[SwitchA] interface Vlan-interface 10
[SwitchA-Vlan-interface10] ip address 192.168.10.1 24
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 192.168.100.1 24
[SwitchA] interface Vlan-interface 101
[SwitchA-Vlan-interface101] ip address 192.168.101.1 24
[SwitchA] interface Vlan-interface 102
[SwitchA-Vlan-interface102] ip address 192.168.102.1 24
# Configure Ethernet 1/0/3 of Switch A to be a trunk port and to permit the packets carrying the tag of VLAN 101 or VLAN 102 to pass through.
[SwitchA] interface Ethernet 1/0/3
[SwitchA-Ethernet1/0/3] port link-type trunk
[SwitchA-Ethernet1/0/3] port trunk permit vlan 101 102
l          Configure Switch B
# Create VLAN 101 on Switch B, and assign Ethernet 1/0/11 to VLAN 101.
[SwitchB] vlan 101
[SwitchB-vlan101] port Ethernet 1/0/11
[SwitchB-vlan101] quit
# Create VLAN 102 on Switch B, and assign Ethernet 1/0/12 to VLAN 102.
[SwitchB] vlan 102
[SwitchB-vlan102] port Ethernet 1/0/12
[SwitchB-vlan102] quit
# Configure Ethernet 1/0/10 of Switch B to be a trunk port and to permit the packets carrying the tag of VLAN 101 or VLAN 102 to pass through.
[SwitchB] interface Ethernet 1/0/10
[SwitchB-Ethernet1/0/10] port link-type trunk
[SwitchB-Ethernet1/0/10] port trunk permit vlan 101 102
Complete Configuration
l          Configuration on Switch A
vlan 10
vlan 100
vlan 101
vlan 102
 ip address 192.168.10.1 255.255.255.0
 ip address 192.168.100.1 255.255.255.0
 ip address 192.168.101.1 255.255.255.0
 ip address 192.168.102.1 255.255.255.0
interface Ethernet1/0/1
 port access vlan 10
interface Ethernet1/0/2
 port access vlan 100
interface Ethernet1/0/3
 port trunk permit vlan 1 101 102
l          Configuration on Switch B
vlan 101
vlan 102
interface Ethernet1/0/10
interface Ethernet1/0/11
 port access vlan 101
interface Ethernet1/0/12
 port access vlan 201
Precautions
l          After you assign the servers and the workstations to different VLANs, they cannot communicate with each other. For them to communicate, you need to configure a Layer 3 VLAN interface for each of them on the switches.
l          After you telnet to an Ethernet port on a switch to make configuration, do not remove the port from its current VLAN. Otherwise, your Telnet connection will be disconnected.
Configuring Protocol-Based VLAN
Protocol-based VLAN, or protocol VLAN, is another approach to VLAN implementation other than port-based VLAN. With protocol VLAN, the switch compares each packet received without a VLAN tag against the protocol templates based on the encapsulation format and the specified field. If a match is found, the switch tags the packet with the corresponding VLAN ID. Thus, the switch can assign packets to a VLAN by protocol.
Network Diagram
Figure 1-2 Network diagram for protocol-based VLAN configuration
Configure the switch to automatically assign IP packets and Appletalk packets of the workroom to different VLANs, ensuring that the workstations can communicate with their respective servers properly.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-52P
S3100-52P
# Create VLAN 100 and assign Ethernet1/0/11 to VLAN 100.
[H3C] vlan 100
[H3C-vlan100] port Ethernet 1/0/11
# Create VLAN 200 and assign Ethernet 1/0/12 to VLAN 200.
[H3C-vlan100] quit
[H3C] vlan 200
[H3C-vlan200] port Ethernet 1/0/12
# Configure protocol templates and bind them to ports.
Create a protocol template for VLAN 200 to carry Appletalk and a protocol template for VLAN 100 to carry IP.
[H3C-vlan200] protocol-vlan at
[H3C-vlan200] quit
[H3C] vlan 100
[H3C-vlan100] protocol-vlan ip
Create a user-defined protocol template for VLAN 100 to carry ARP for IP communication, assuming that Ethernet_II encapsulation is used.
[H3C-vlan100] protocol-vlan mode ethernetii etype 0806
Configure Ethernet 1/0/10 to be a hybrid port and to remove the outer VLAN tag when forwarding packets of VLAN 100 and VLAN 200.
[H3C-vlan100] quit
[H3C] interface Ethernet 1/0/10
[H3C-Ethernet1/0/10] port link-type hybrid
[H3C-Ethernet1/0/10] port hybrid vlan 100 200 untagged
Bind Ethernet 1/0/10 to protocol template 0 and protocol template 1 of VLAN 100, and protocol template 0 of VLAN 200.
When configuring a protocol template, you can assign a number to the template. If you fail to do that, the system automatically assigns the lowest available number to the template. Thus, in this configuration example, the two protocol templates for VLAN 100 are automatically numbered 0 and 1, and the protocol template for VLAN 200 is numbered 0.
[H3C-Ethernet1/0/10] port hybrid protocol-vlan vlan 100 0 to 1
[H3C-Ethernet1/0/10] port hybrid protocol-vlan vlan 200 0
vlan 100
 protocol-vlan 0 ip
 protocol-vlan 1 mode ethernetii etype 0806
vlan 200
 protocol-vlan 0 at
 port hybrid vlan 1 100 200 untagged
 port hybrid protocol-vlan vlan 100 1
 port access vlan 200
Precautions
l          At present, the S3100 series support only the standard templates of AppleTalk and IP, the standard template of IPX encapsulated in Ethernet II format, and the user-defined templates matching the Ethernet II encapsulation format. Protocol templates matching 802.2/802.3 encapsulation formats and their extended encapsulation formats are not supported on the S3100 series currently.
l          Because IP depends on ARP for address resolution in Ethernet, you are recommended to configure the IP and ARP templates in the same VLAN and associate them with the same port to prevent communication failure.
