H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
12-DLDP Configuration Guide
12-DLDP Configuration Guide 36.39 KB
Configuring DLDP
Sometimes, unidirectional links may appear in networks. On a unidirectional link, one end can receive packets from the other end but the other end cannot.
Unidirectional links can be caused by fiber cross-connection or fiber cut (including single-fiber cut and lack of a fiber connection).
They can cause problems such as spanning tree topology loops.
You can use the Device Link Detection Protocol (DLDP) to monitor the link status of optical fiber cables and copper twisted pairs such as super category 5 twisted pairs. Once detecting a unidirectional link, DLDP shuts down the port or ask you to do so depending on your configuration.
Network Diagram
Figure 1-1 Network diagram for DLDP configuration
Networking and Configuration Requirements
l          Switch A and Switch B are connected through two pairs of fibers. The connecting ports are operating in mandatory full duplex mode at 1000 Mbps. Both of the switches support DLDP.
l          Configure DLDP to automatically disconnect the detected unidirectional link.
l          After the fibers are connected correctly, the port shut down by DLDP restores automatically.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series Ethernet switches
Release 1510, Release 1602
All versions
S5100-SI/EI series Ethernet switches
Release 2200, Release 2201
All versions
S3600-SI/EI series Ethernet switches
All versions
S3100-EI series Ethernet switches
Release 2104, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
l          Configure Switch A
# Configure the ports to work in mandatory full duplex mode at 1000 Mbps.
[SwitchA] interface GigabitEthernet 1/1/3
[SwitchA-GigabitEthernet1/1/3] duplex full
[SwitchA-GigabitEthernet1/1/3] speed 1000
[SwitchA-GigabitEthernet1/1/3] quit
[SwitchA] interface GigabitEthernet 1/1/4
[SwitchA-GigabitEthernet1/1/4] duplex full
[SwitchA-GigabitEthernet1/1/4] speed 1000
[SwitchA-GigabitEthernet1/1/4] quit
# Enable DLDP globally.
[SwitchA] dldp enable
# Set the interval for sending DLDP packets to 15 seconds.
[SwitchA] dldp interval 15
# Configure DLDP to operate in enhanced mode.
[SwitchA] dldp work-mode enhance
# Configure DLDP to shut down a port automatically once a unidirectional link is detected on it.
[SwitchA] dldp unidirectional-shutdown auto
# Set the DelayDown timer to five seconds.
[SwitchA] dldp delaydown-timer 5
# Display the DLDP state.
[SwitchA] display dldp 1
# Restore the ports brought down by DLDP.
[SwitchA] dldp reset
l          Configure Switch B
The configuration on Switch B is the same as that on Switch A.
Complete Configuration
l          Configuration on Switch A
dldp interval 15
interface Gigabitethernet 1/1/3
 duplex full
 speed 1000
 dldp enable
interface Gigabitethernet 1/1/4
 duplex full
 speed 1000
 dldp enable
l          Configuration on Switch B
Precautions
1)        When enabling DLDP on two connected devices, make sure that they are using the same software version. Otherwise, DLDP may malfunction.
2)        When optical fibers are cross-connected, two or three ports are in the disable state, and the remaining ports are in the inactive state.
3)        DLDP in the enhanced mode can identify unidirectional links caused by fiber cross-connection or fiber cut.
4)        DLDP in the normal mode can identify only unidirectional links caused by fiber cross-connection.
