H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
25-Web Cache Redirection Configuration Guide
25-Web Cache Redirection Configuration Guide 43.84 KB
1  Web Cache Redirection Configuration Guide
Configuring Web Cache Redirection
The Web cache redirection function redirects the packets accessing Web pages to a Web cache server, thus reducing the load on the links between a LAN and the Internet and improving the speed of obtaining information from the Internet.
Network Diagram
Figure 1-1 Network diagram for Web cache redirection configuration
Networking and Configuration Requirements
The network of a company is described as follows:
l          The marketing department uses VLAN 10 and is connected to Ethernet 1/0/1 of the switch. The IP address of the VLAN interface for VLAN 10 is 192.168.1.1/24.
l          The R&D department uses VLAN 20 and is connected to Ethernet 1/0/2 of the switch. The IP address of the VLAN interface for VLAN 20 is 192.168.2.1/24.
l          The administration department uses VLAN 30 and is connected to Ethernet 1/0/3 of the switch. The IP address of the VLAN interface for VLAN 30 is 192.168.3.1/24.
l          The Web cache server belongs to VLAN 40 and is connected to Ethernet 1/0/4 of the switch. The IP address of the VLAN interface for VLAN 40 is 192.168.4.1/24. The IP address and the MAC address of the Web cache server is 192.168.4.2 and 0012-0990-2250.
l          The router is connected to Ethernet 1/0/5 of the switch. The switch accesses the Internet through a router. Ethernet 1/0/5 belongs to VLAN 50 whose VLAN interface is assigned IP address 192.168.5.1/24.
Enable Web cache redirection on the switch to redirect all the HTTP packets of the three departments to the Web cache server, thus reducing the load on the WAN link and improving the speed of obtaining information from the Internet.
Applicable Product Matrix
Product series
Software version
Hardware version
S3600-EI series
Release 1510, Release 1602
All versions
Configuration Procedure
# Create VLAN 10 for the marketing department and configure the IP address of VLAN-interface 10 as 192.168.1.1.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] port Ethernet 1/0/1
[H3C-vlan10] quit
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 192.168.1.1 24
[H3C-Vlan-interface10] quit
# Create VLAN 20 for the R&D department and configure the IP address of VLAN-interface 20 as 192.168.2.1.
[H3C] vlan 20
[H3C-vlan20] port Ethernet 1/0/2
[H3C-vlan20] quit
[H3C] interface Vlan-interface 20
[H3C-Vlan-interface20] ip address 192.168.2.1 24
[H3C-Vlan-interface20] quit
# Create VLAN 30 for the administration department and configure the IP address of VLAN-interface 30 as 192.168.3.1.
[H3C] vlan 30
[H3C-vlan30] port Ethernet 1/0/3
[H3C-vlan30] quit
[H3C] interface Vlan-interface 30
[H3C-Vlan-interface30] ip address 192.168.3.1 24
[H3C-Vlan-interface30] quit
# Create VLAN 40 for the Web cache server and configure the IP address of VLAN-interface 40 as 192.168.4.1.
[H3C] vlan 40
[H3C-vlan40] port Ethernet 1/0/4
[H3C-vlan40] quit
[H3C] interface Vlan-interface 40
[H3C-Vlan-interface40] ip address 192.168.4.1 24
[H3C-Vlan-interface40] quit
# Create VLAN 50 for the switch to connect to the router and configure the IP address of VLAN-interface 50 as 192.168.5.1.
[H3C] vlan 50
[H3C-vlan50] port Ethernet 1/0/5
[H3C-vlan50] quit
[H3C] interface Vlan-interface 50
[H3C-Vlan-interface50] ip address 192.168.5.1 24
[H3C-Vlan-interface50] quit
# Configure Ethernet 1/0/4, the port connected to the Web cache server, as a trunk port, and configure the port to permit the packets of VLAN 40 and VLAN 50 to pass through.
[H3C] interface Ethernet 1/0/4
[H3C-Ethernet1/0/4] port link-type trunk
[H3C-Ethernet1/0/4] port trunk permit vlan 40 50
[H3C-Ethernet1/0/4] quit
# Enable Web cache redirection to redirect all the HTTP packets received from VLAN 10, VLAN 20, and VLAN 30 to the Web cache server.
[H3C] webcache address 192.168.4.2 mac 0012-0990-2250 vlan 40 port Ethernet 1/0/4
[H3C] webcache redirect-vlan 10
[H3C] webcache redirect-vlan 20
[H3C] webcache redirect-vlan 30
Complete Configuration
vlan 10
vlan 20
vlan 30
vlan 40
vlan 50
interface Vlan-interface10
interface Vlan-interface20
 ip address 192.168.2.1 255.255.255.0
interface Vlan-interface30
 ip address 192.168.3.1 255.255.255.0
interface Vlan-interface40
 ip address 192.168.4.1 255.255.255.0
interface Vlan-interface50
 ip address 192.168.5.1 255.255.255.0
interface Ethernet1/0/1
 port access vlan 10
interface Ethernet1/0/2
 port access vlan 20
interface Ethernet1/0/3
 port access vlan 30
interface Ethernet1/0/4
 port trunk permit vlan 1 40 50
interface Ethernet1/0/5
 port access vlan 50
Precautions
When configuring Web cache redirection, consider the following:
l          To ensure the success of Web cache redirection, check that the VLAN-interfaces for all the involved VLANs (VLAN 40, VLAN 10, VLAN 20, and VLAN 30) are up.
l          Do not redirect the HTTP packets destined for VLAN 40 to the Web cache server.
l          Enabling STP can cause Web cache redirection failure.
