H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
38-DNS Configuration Guide
38-DNS Configuration Guide 62.29 KB
Static Domain Name Resolution Configuration Guide
Static domain name resolution is based on manually configured domain name-to-IP address mappings. If you telnet a remote device using its name, the local device will look up the corresponding IP address in the static domain name resolution table.
Network Diagram
Figure 1-1 Network diagram for static domain name resolution configuration
Networking and Configuration Requirements
As shown in the above figure, the switch can use static domain name resolution to access host 10.1.1.2 through domain name host.com.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series Ethernet switches
Release 1510, Release 1602
All versions
S5100-SI/EI series Ethernet switches
Release 2200, Release 2201
All versions
S3600-SI/EI series Ethernet switches
All versions
S3100-EI series Ethernet switches
Release 2104, Release 2107
All versions
S3100-C-SI series Ethernet switches
S3100-T-SI series Ethernet switches
Release 0011, Release 2102, Release 2107
All versions
S3100-TP-SI series Ethernet switches
All versions( except S3100-52TP-SI)
S3100-52TP-SI
Release 2106, Release 2107
S3100-52TP-SI
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
# Map host name host.com to IP address 10.1.1.2.
<Switch> system-view
[Switch] ip host host.com 10.1.1.2
# Execute the ping host.com command to verify that Switch can get the IP address 10.1.1.2 of name host.com.
[Switch] ping host.com
  PING host.com (10.1.1.2): 56  data bytes, press CTRL_C to break
    Reply from 10.1.1.2: bytes=56 Sequence=1 ttl=127 time=3 ms
    Reply from 10.1.1.2: bytes=56 Sequence=2 ttl=127 time=3 ms
    Reply from 10.1.1.2: bytes=56 Sequence=3 ttl=127 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=4 ttl=127 time=5 ms
    Reply from 10.1.1.2: bytes=56 Sequence=5 ttl=127 time=3 ms
  --- host.com ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 2/3/5 ms
Complete Configuration
Precautions
None
Dynamic Domain Name Resolution Configuration Guide
Domain Name System (DNS) is a distributed database used by TCP/IP applications to translate domain names into corresponding IP addresses. With DNS, you can use easy-to-remember domain names in some applications and let the DNS server translate them into correct IP addresses.
Network Diagram
Figure 1-2 Network diagram for dynamic domain name resolution configuration
l          Switch serves as a DNS client to access the host at 3.1.1.1/16 through domain name host.
l          The DNS server has the IP address 2.1.1.2/16. The domain name suffix is com.
Product series
Software version
Hardware version
All versions
All versions
All versions
All versions
S3100-52P
S3100-52P
# Enable dynamic domain name resolution.
[Switch] dns resolve
# Specify the DNS server 2.1.1.2.
[Switch] dns server 2.1.1.2
# Configure com as the DNS suffix.
[Switch] dns domain com
Execute the ping host command on Switch. The ping is successful and the corresponding IP address is 3.1.1.1.
[Switch] ping host
 Trying DNS server (2.1.1.2)
  PING host.com (3.1.1.1): 56  data bytes, press CTRL_C to break
    Reply from 3.1.1.1: bytes=56 Sequence=1 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=2 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=3 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=4 ttl=125 time=4 ms
    Reply from 3.1.1.1: bytes=56 Sequence=5 ttl=125 time=5 ms
    0.00% packet loss
    round-trip min/avg/max = 4/4/5 ms
 dns resolve
 dns server 2.1.1.2
 dns domain com
Precautions
l          The routes between the DNS server, Switch, and Host are reachable. Necessary configurations are done on the devices.
l          There is a mapping between domain name host and IP address 3.1.1.1/16 on the DNS server.
