H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
11-MAC Address Table Management Configuration Guide
The S3600 series provide the MAC address table management function. Through configuration commands, you can add/modify/remove a MAC address, set the aging time for dynamic MAC addresses, and set the maximum number of MAC addresses an Ethernet port can learn.
Network Diagram
Figure 1-1 Network diagram for MAC address table management configuration
Networking and Configuration Requirements
Server is connected to Switch through port Ethernet 1/0/2.  Configure a static MAC address containing the Server MAC address on Switch, so that Switch can unicast rather than broadcast packets destined for Server through Ethernet 1/0/2.  Port Ethernet 1/0/10 is connected with a network management server (NMS). For network management security, configure Ethernet 1/0/10 to permit the access of this NMS only.
l          The Server MAC address is 000f-e20f-dc71.
l          Port Ethernet 1/0/2 belongs to VLAN 10.
l          The NMS MAC address is 0014-222c-aa69.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
# Add ports Ethernet 1/0/5 and Ethernet 1/0/2 to VLAN 10.
[Sysname] vlan 10
[Sysname-vlan]
# Add a static MAC address entry.
[Sysname] mac-address static 000f-e20f-dc71 interface Ethernet 1/0/2 vlan 1
# Set the aging time of dynamic MAC address entries on Switch to 500 seconds.
# Display the MAC address table configuration in system view.
[Sysname] display mac-address interface Ethernet 1/0/2
MAC ADDR          VLAN ID STATE   PORT INDEX       AGING TIME(s)
000f-e20f-dc71    1       Static  Ethernet1/0/2    NOAGED
00e0-fc17-a7d6    1       Learned Ethernet1/0/2    AGING
00e0-fc5e-b1fb    1       Learned Ethernet1/0/2    AGING
00e0-fc55-f116    1       Learned Ethernet1/0/2    AGING
# Disable Ethernet 1/0/10 from learning MAC addresses dynamically, and add a static MAC address entry. So that port Ethernet 1/0/10 can only send packets destined for the NMS, and other hosts cannot communicate through this port.
[Sysname] interface Ethernet 1/0/10
[Sysname-Ethernet1/0/10] port access vlan 10
[Sysname-Ethernet1/0/10] mac-address max-mac-count 0
[Sysname-Ethernet1/0/10] mac-address static 0014-222c-aa69 vlan 10
Complete Configuration
interface Ethernet1/0/2
 port access vlan 10
 mac-address static 000f-e20f-dc71 vlan 1
interface Ethernet1/0/10
 port access vlan 10
Precautions
l          When you add a MAC address entry, the port specified by the interface keyword must belong to the VLAN specified by the vlan keyword in the command. Otherwise, the entry will not be added.
l          If the VLAN specified by the vlan argument is a dynamic VLAN, after a static MAC address is added, it will become a static VLAN.
