H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
08-Port Isolation Configuration Guide
08-Port Isolation Configuration Guide 45.89 KB
Configuring Port Isolation
Port isolation allows you to add a port into an isolation group to isolate Layer-2 and Layer-3 traffic of the port from that of all other ports in the isolation group. While increasing network security, this allows for great flexibility.
Currently, an switch supports only one isolation group; however, the number of Ethernet ports in the isolation group is not limited.
Network Diagram
Figure 1-1 Network diagram for port isolation configuration
Networking and Configuration Requirements
l          PC2, PC3, and PC4 connect to the switch ports Ethernet 1/0/2, Ethernet 1/0/3, and Ethernet 1/0/4 respectively.
l          The switch connects to the Internet through Ethernet 1/0/1.
l          Isolate PC2, PC3, and PC4 from each other.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
# Add Ethernet 1/0/2, Ethernet 1/0/3, and Ethernet 1/0/4 to the isolation group.
<Switch> system-view
[Switch] interface ethernet1/0/2
[Switch-Ethernet1/0/2] port isolate
[Switch-Ethernet1/0/2] quit
[Switch] interface ethernet1/0/3
[Switch-Ethernet1/0/3] port isolate
[Switch-Ethernet1/0/3] quit
[Switch] interface ethernet1/0/4
[Switch-Ethernet1/0/4] port isolate
[Switch-Ethernet1/0/4] quit
[Switch]
# Display information about the ports in the isolation group.
<Switch> display isolate port
 Isolated port(s) on UNIT 1:
 Ethernet1/0/2, Ethernet1/0/3, Ethernet1/0/4
Complete Configuration
interface Ethernet1/0/2
 port isolate
interface Ethernet1/0/3
 port isolate
interface Ethernet1/0/4
 port isolate
Precautions
l          Adding to or removing from an isolation group an aggregated port can cause all other ports in the aggregation group on the device to join or exit the isolation group automatically.
l          After an aggregated port is removed from its aggregation group, all other member ports will still stay in the isolation group that they have joined (if any).
l          Removing an aggregation group does not remove its member ports from the isolation group that they have joined (if any).
l          Adding an isolated port to an aggregation group can cause all the member ports in the aggregation group to join the isolation group automatically.
l          Cross-device port isolation is supported on the S3600 series switches in an IRF fabric. This allows ports on different units to join the same isolation group.
l          For S3600 series switches in an IRF fabric, adding a member port in a cross-device aggregation group to an isolation group does not cause other member ports to join the isolation group automatically.
