H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
39-Access Management Configuration Guide
39-Access Management Configuration Guide 106.79 KB
Configuring Access Management
The access management function is designed to control user accesses on access switches. It allows you to control the access of hosts to external networks.
The idea is to bind a range of IP addresses to a port by configuring an access management IP address pool on the port. A host connected to the port can access external networks only when its IP address is contained in the address pool.
Note that for the hosts connected to a port configured with no access management IP address pool to access external networks normally, you must make sure that the IP addresses of the hosts are not in the access management IP address pool of any other port (if any) on the switch.
Network Diagram
Figure 1-1 Network diagram for access management configuration
Networking and Configuration Requirements
Client PCs access the Internet through Switch A. The IP addresses of PCs belonging to organization 1 are in the range of 202.10.20.1/24 to 202.10.20.20/24, the IP address of PC 2 is 202.10.20.100/24, and the IP address of PC 3 is 202.10.20.101/24.
l          Permit all the PCs of organization 1 to access the Internet through Ethernet 1/0/1 on Switch A. Ethernet 1/0/1 carries VLAN 1. The IP address assigned to the interface of VLAN 1 is 202.10.20.200/24.
l          PCs that do not belong to organization 1, such as PC 2 and PC 3, are not allowed to access the Internet through Ethernet 1/0/1 on Switch A.
Applicable Product Matrix
Product series
Software version
Hardware version
S3600-SI/EI series Ethernet switches
Release 1510, Release 1602
All versions
S5600 series Ethernet switches
All versions
Configuration Procedure
# Enable access management on Switch A.
[SwitchA] am enable
# Configure the IP address of VLAN-interface 1 as 202.10.20.200/24.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 202.10.20.200 24
# Configure an access management IP address pool for Ethernet 1/0/1.
[SwitchA] interface Ethernet 1/0/1
[SwitchA-Ethernet1/0/1] am ip-pool 202.10.20.1 20
Complete Configuration
 am enable
interface Vlan-interface1
 ip address 202.10.20.200 255.255.255.0
interface Ethernet1/0/1
Precautions
l          The IP addresses in the access management IP address pool configured for a port must be on the same segment as the VLAN-interface IP address of the VLAN to which the port belongs.
l          If the access management IP address pool to be configured for a port contains an IP address in a static ARP entry of another port, the system will ask you to delete the ARP entry to ensure that the access management IP address pool can take effect.
l          To allow only the hosts bound with a port and with their IP addresses in the access management IP address pool of the port to access external networks, configure static ARP entries only for IP addresses in the address pool.
Configuring Access Management with Port Isolation
Network Diagram
Figure 1-2 Network diagram for access management and port isolation configuration
Client PCs are connected to the Internet through Switch A. The IP address range for organization 1 is 202.10.20.1/24 to 202.10.20.20/24; and the IP address ranges for organization 2 are 202.10.20.25/24 to 202.10.20.50/24 and 202.10.20.55/24 to 202.10.20.65/24.
l          PCs of organization 1 are allowed to access the Internet through Ethernet 1/0/1 of Switch A.
l          PCs of organization 2 are allowed to access the Internet through Ethernet 1/0/2 of Switch A.
l          Both Ethernet 1/0/1 and Ethernet 1/0/2 belong to VLAN 1, and the IP address of VLAN-interface 1 is 202.10.20.200/24.
l          PCs of organization 1 are isolated from those of organization 2 at Layer 2.
Product series
Software version
Hardware version
All versions
All versions
[SwitchA] am enable
# Add Ethernet 1/0/1 to the isolation group.
[SwitchA-Ethernet1/0/1] port isolate
[SwitchA-Ethernet1/0/1] quit
# Configure an access management IP address pool for Ethernet 1/0/2.
[SwitchA] interface Ethernet 1/0/2
[SwitchA-Ethernet1/0/2] am ip-pool 202.10.20.25 26 202.10.20.55 11
# Add Ethernet 1/0/2 to the isolation group.
[SwitchA-Ethernet1/0/2] port isolate
[SwitchA-Ethernet1/0/2] quit
 am enable
 port isolate
interface Ethernet1/0/2
 port isolate
Precautions
Refer to section Precautions for details.
