H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
06-Ethernet Interface Basic Configuration Guide
Configuring the Basic Functions of an Ethernet Port
An Ethernet port on an H3C Low-End Ethernet switches can operate in one of the three link types:
l          Access: an access port can belong to only one VLAN and is generally used to connect to a PC.
l          Trunk: a trunk port can belong to multiple VLANs. It can receive/send packets of multiple VLANs and is generally used to connect to a switch.
l          Hybrid: a hybrid port can belong to multiple VLANs. It can receive/send packets of multiple VLANs and can be used to connect to either a switch or a PC.
You can add an Ethernet port to a specified VLAN. After that, the Ethernet port can forward the packets of the specified VLAN, so that the VLAN on this switch can intercommunicate with the same VLAN on the peer switch.
Network Diagram
Figure 1-1 Network diagram for Ethernet port configuration
Networking and Configuration Requirements
l          Switch A and Switch B are connected through the trunk port Ethernet 1/0/1 on each side.
l          Specify VLAN 100 as the default VLAN of Ethernet 1/0/1.
l          Configure Ethernet 1/0/1 to permit the packets of VLAN 2, VLAN 6 through VLAN 50, and VLAN 100 to pass through.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
l          The following provides only the configuration on Switch A. The configuration on Switch B is similar to that on Switch A.
l          This configuration example assumes that VLAN 2, VLAN 6 through VLAN 50, and VLAN 100 have been created.
# Enter Ethernet port view of Ethernet 1/0/1.
[SwitchA] interface ethernet1/0/1
# Configure Ethernet 1/0/1 as a trunk port.
[SwitchA-Ethernet1/0/1] port link-type trunk
# Configure Ethernet 1/0/1 to permit the packets of VLAN 1 through VLAN 3, VLAN 6 through VLAN 50, and VLAN 100 to pass through.
[SwitchA-Ethernet1/0/1] port trunk permit vlan 1 to 3 6 to 50 100
# Configure VLAN 100 as the default VLAN of Ethernet 1/0/1.
[SwitchA-Ethernet1/0/1] port trunk pvid vlan 100
Complete Configuration
interface Ethernet1/0/1
Refer to VLAN Configuration Guide for the use of hybrid ports.
Precautions
Do not configure the port trunk permit vlan all command on a trunk port with GVRP disabled.
