H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
21-ARP Configuration Guide
21-ARP Configuration Guide 82.74 KB
ARP Attack Detection and Packet Rate Limit Configuration Example
Network Diagram
Figure 1-1 ARP attack detection and packet rate limit configuration
Networking and Configuration Requirements
As shown in Figure 1-1, Ethernet 1/0/1 of Switch A connects to DHCP Server; Ethernet 1/0/2 connects to Client A, Ethernet 1/0/3 connects to Client B. Ethernet 1/0/1, Ethernet 1/0/2 and Ethernet 1/0/3 belong to VLAN 1.
l          Enable DHCP snooping on Switch A and specify Ethernet 1/0/1 as the DHCP snooping trusted port.
l          Enable ARP attack detection in VLAN 1 to prevent ARP man-in-the-middle attacks, and specify Ethernet 1/0/1 as the ARP trusted port.
l          Enable the ARP packet rate limit function on Ethernet 1/0/2 and Ethernet 1/0/3 of Switch A, so as to prevent Client A and Client B from attacking Switch A through ARP traffic.
l          Enable the port state auto recovery function on the ports of Switch A, and set the recovery interval to 200 seconds.
l          Configuration Procedure
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series Ethernet switches
Release 1602
All versions
S3600-SI/EI series Ethernet switches
Release 1602
All versions
S3100-EI series Ethernet switches
Release 2104, Release 2107
All versions
S3100-52P
Release 1602
S3100-52P
Configuration procedure
# Enable DHCP snooping on Switch A.
[SwitchA] dhcp-snooping
# Specify Ethernet 1/0/1 as the DHCP snooping trusted port and the ARP trusted port.
[SwitchA] interface Ethernet1/0/1
[SwitchA-Ethernet1/0/1] dhcp-snooping trust
[SwitchA-Ethernet1/0/1] arp detection trust
[SwitchA-Ethernet1/0/1] quit
# Enable ARP attack detection on all ports in VLAN 1.
[SwitchA] vlan 1
[SwitchA-vlan1] arp detection enable
# Enable the ARP packet rate limit function on Ethernet 1/0/2, and set the maximum ARP packet rate allowed on the port to 20 pps.
[SwitchA] interface Ethernet1/0/2
[SwitchA-Ethernet1/0/2] arp rate-limit enable
[SwitchA-Ethernet1/0/2] arp rate-limit 20
[SwitchA-Ethernet1/0/2] quit
# Enable the ARP packet rate limit function on Ethernet 1/0/3, and set the maximum ARP packet rate allowed on the port to 50 pps.
[SwitchA] interface Ethernet1/0/3
[SwitchA-Ethernet1/0/3] arp rate-limit enable
[SwitchA-Ethernet1/0/3] arp rate-limit 50
[SwitchA-Ethernet1/0/3] quit
# Configure the port state auto recovery function, and set the recovery interval to 200 seconds.
[SwitchA] arp protective-down recover enable
[SwitchA] arp protective-down recover interval 200
Complete Configuration
vlan 1
 dhcp-snooping trust
 arp detection trust
 arp rate-limit 20
 arp rate-limit 50
 dhcp-snooping
Precautions
l          You need to enable DHCP snooping and configure DHCP snooping trusted ports on the switch before configuring the ARP attack detection function.
l          You need to enable the port state auto-recovery feature before you can configure the port state auto-recovery interval.
l          Generally, the uplink port of a switch is configured as a trusted port.
l          You are not recommended to configure ARP attack detection or ARP packet rate limit function on the ports of a fabric or an aggregation group.
Proxy ARP Configuration Example
Network diagram
Figure 1-2 Network diagram for proxy ARP
Network requirements
l          Host A belongs to VLAN 1, and the IP address of Host A is 192.168.10.100/16, Host D belongs to VLAN 2, and the IP address of Host D is 192.168.20.100/16.
l          The IP address of VLAN-interface 1 is 192.168.10.99/24, and that of VLAN-interface 2 is 192.168.20.99/24.
l          Enable proxy ARP on VLAN-interface 1 and VLAN-interface 2 to realize the communication between Host A and Host D.
Product series
Software version
Hardware version
Release 1602
All versions
Release 1602
All versions
# Configure the IP address of VLAN-interface 1 to be 192.168.10.99/24, and enable proxy ARP on VLAN-interface 1.
<Switch> system-view
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
[Switch-Vlan-interface1] arp proxy enable
[Switch-Vlan-interface1] quit
# Configure the IP address of VLAN-interface 2 to be 192.168.20.99/24, and enable proxy ARP on VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
[Switch-Vlan-interface2] arp proxy enable
[Switch-Vlan-interface2] quit
interface Vlan-interface1
 arp proxy enable
interface Vlan-interface2
 arp proxy enable
Precautions
None
Proxy ARP Configuration in Port Isolation Application
Network diagram
Figure 1-3 Network diagram for Proxy ARP configuration in port isolation application
l          Switch A is connected to Switch B through Ethernet 1/0/1.
l          Ethernet 1/0/2 and Ethernet 1/0/3 on Switch B belong to the same VLAN but are assigned to the port isolation group. The two ports are connected to Host A and Host B respectively.
l          Configure proxy ARP on Switch A to enable Host A and Host B isolated at Layer 2 to communicate with each other at Layer 3.
Product series
Software version
Hardware version
Release 1602
All versions
Release 1602
All versions
1)        Configure Switch B
# Add Ethernet 1/0/1, Ethernet 1/0/2 and Ethernet 1/0/3 to VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] port ethernet 1/0/1
[SwitchB-vlan2] port ethernet 1/0/2
[SwitchB-vlan2] port ethernet 1/0/3
[SwitchB-vlan2] quit
# Disable Host A and Host B from communicating with each other at Layer 2.
For details about port isolation, refer to the part discussing port isolation.
[SwitchB] interface ethernet 1/0/2
[SwitchB-Ethernet1/0/2] port isolate
[SwitchB-Ethernet1/0/2] quit
[SwitchB] interface ethernet 1/0/3
[SwitchB-Ethernet1/0/3] port isolate
[SwitchB-Ethernet1/0/3] quit
2)        Configure Switch A
# Configure the IP address of VLAN-interface 2 to be 192.168.10.100/24.
[SwitchA] vlan 2
[SwitchA-vlan2] port ethernet 1/0/1
[SwitchA-vlan2] quit
[SwitchA-Vlan-interface2] ip address 192.168.10.100 255.255.0.0
# Configure proxy ARP on VLAN-interface 2, enabling Host A and Host B to communicate at Layer 3.
[SwitchA-Vlan-interface2] arp proxy enable
1)        Configuration on Switch B
vlan 2
 port access vlan 2
 port access vlan 2
 port isolate
 port access vlan 2
 port isolate
2)        Configuration on Switch A
vlan 2
 arp proxy enable
 port access vlan 2
Precautions
