H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
07-Link Aggregation Configuration Guide
07-Link Aggregation Configuration Guide 46.55 KB
Configuring Link Aggregation
Link aggregation aggregates multiple ports into one logical link, also called an aggregation group.
Link aggregation allows you to increase bandwidth by distributing incoming/outgoing traffic on the member ports in the aggregation group. In addition, it provides reliable connectivity because these member ports can dynamically back up each other.
Network Diagram
Figure 1-1 Network diagram for link aggregation configuration
Networking and Configuration Requirements
Aggregate Ethernet 1/0/1 through 1/0/3 on Switch A into an aggregation group and connect the group to Switch B to balance incoming/outgoing traffic among the member ports.
The example will show you how to configure link aggregation in different aggregation modes.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
The example only provides the configuration on Switch A. Perform the same configuration on Switch B to implement link aggregation.
1)        In manual aggregation mode
# Create manual aggregation group 1.
[SwitchA] link-aggregation group 1 mode manual
# Add Ethernet 1/0/1 through Ethernet 1/0/3 to aggregation group 1.
[SwitchA] interface Ethernet1/0/1
[SwitchA -Ethernet1/0/1] port link-aggregation group 1
[SwitchA -Ethernet1/0/1] quit
[SwitchA] interface Ethernet1/0/2
[SwitchA -Ethernet1/0/2] port link-aggregation group 1
[SwitchA -Ethernet1/0/2] quit
[SwitchA] interface Ethernet1/0/3
[SwitchA-Ethernet1/0/3] port link-aggregation group 1
2)        In static LACP aggregation mode
# Create static aggregation group 1.
[SwitchA] link-aggregation group 1 mode static
[SwitchA-Ethernet1/0/1] port link-aggregation group 1
[SwitchA-Ethernet1/0/1] quit
[SwitchA-Ethernet1/0/2] port link-aggregation group 1
[SwitchA-Ethernet1/0/2] quit
3)        In dynamic LACP aggregation mode
# Enable LACP on Ethernet 1/0/1 through Ethernet 1/0/3.
[SwitchA-Ethernet1/0/1] lacp enable
[SwitchA-Ethernet1/0/2] lacp enable
[SwitchA-Ethernet1/0/3] lacp enable
Complete Configuration
 lacp enable
 lacp enable
 lacp enable
Precautions
l          If static LACP aggregation or manual aggregation is adopted, you are recommended not to cross-connect the aggregation member ports at the two ends to avoid packet loss. For example, if local port 1 is connected to remote port 2, do not connect local port 2 to remote port 1.
l          Dynamic LACP aggregation mode is not recommended in actual networking scenarios.
l          The implementation of static aggregation varies by platform software version. This may result in problems when products using different platform software versions are interconnected through static aggregation groups. Use the display version command to view the platform software version.
l          the S3100-SI series only supports manually-configured aggregation groups.
