H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
30-UDP Helper Configuration Guide
30-UDP Helper Configuration Guide 52.81 KB
Table of Contents
1 UDP Helper Configuration Guide· 1-1
Network Diagram·· 1-1
Networking and Configuration Requirements· 1-1
Applicable Product Matrix· 1-1
Configuration Procedure· 1-1
Complete Configuration· 1-2
Precautions· 1-2
Ethernet switches provide the UDP Helper function to relay specified UDP packets. In other words, UDP Helper functions as a relay agent that converts UDP broadcast packets into unicast packets and forwards them to a specified destination server.
With UDP Helper enabled, the device decides whether to forward a received UDP broadcast packet according to the UDP destination port number of the packet.
l          If the destination port number of the packet matches a pre-configured port number on the device, the device modifies the destination IP address in the IP header and then sends the packet to the specified destination server.
l          Otherwise, the device sends the packet to the upper layer protocol for processing.
Network Diagram
Figure 1-1 Network diagram for UDP Helper
PC A resides on network segment 192.168.1.0/24 and PC B on 192.168.10.0/24; they are connected through Switch A and are reachable to each other.
It is required to configure UDP Helper on the switch, so that PC A can find PC B through computer search (Computer search uses broadcasts with the destination UDP port 137).
Product series
Software version
Hardware version
S5600 series Ethernet switches
Release 1510, Release 1602
All versions
S3600-SI/EI series Ethernet switches
All versions
# Enable Switch A to receive directed broadcasts to a directly connected network.
[SwitchA] ip forward-broadcast
# Enable UDP Helper on Switch A.
[SwitchA] udp-helper enable
# Configure the switch to forward broadcasts containing the destination UDP port number 137. (By default, the device, after enabled with UDP Helper, forwards the broadcasts containing the destination UDP port number 137.)
[SwitchA] udp-helper port 137
# Specify the destination server on VLAN-interface 1.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] udp-helper server 192.168.10.2
 udp-helper enable
Precautions
l          On an S3600 series , S5600 series Ethernet switch, the reception of directed broadcast packets to a directly connected network is disabled by default, but this feature must be enabled with the ip forward-broadcast command in system view before you can enable UDP Helper. For details about the ip forward-broadcast command, refer to IP Address and Performance Configuration.
l          You need to enable UDP Helper before specifying any UDP port to match UDP broadcasts; otherwise, error information is displayed. When the UDP helper function is disabled, all the specified UDP ports are disabled, including the default ports.
