H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
16-Multicast Configuration Guide
16-Multicast Configuration Guide 352.24 KB
Configuring IGMP Snooping
Internet Group Management Protocol Snooping (IGMP Snooping) is a multicast constraint mechanism that runs on access switches to manage and control multicast groups to prevent multicast data from being flooded at the data link layer.
By listening to and analyzing IGMP messages, a Layer 2 device running IGMP Snooping establishes and maintains mappings between ports and multicast groups and forwards multicast data based on these mappings.
Network Diagram
Figure 1-1 Network diagram for IGMP Snooping
Networking and Configuration Requirements
l          As shown in Figure 1-1, Router A connects to a multicast source (Source) through Ethernet 1/0/2, and to Switch A through Ethernet 1/0/1.
l          Run PIM DM and IGMP on Router A. Enable IGMP Snooping on Switch A. Router A is the IGMP querier.
l          The source sends multicast data to multicast group 224.1.1.1. Host A and Host B join multicast group 224.1.1.1.
Application Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
Configuring IP addresses for the interfaces of each device
Configure the IP address and subnet mask for each interface as per Figure 1-1. The detailed configuration steps are omitted here.
Configuring Router A
# Enable IP multicast routing, enable PIM-DM on each interface, and enable IGMP on Ethernet 1/0/1.
[RouterA] multicast routing-enable
[RouterA] interface Ethernet 1/0/1
[RouterA-Ethernet1/0/1] igmp enable
[RouterA-Ethernet1/0/1] pim dm
[RouterA-Ethernet1/0/1] quit
[RouterA] interface Ethernet 1/0/2
[RouterA-Ethernet1/0/2] pim dm
[RouterA-Ethernet1/0/2] quit
Configuring Switch A
# Enable IGMP Snooping globally.
[SwitchA] igmp-snooping enable
  Enable IGMP-Snooping ok.
# Create VLAN 100, assign Ethernet 1/0/1 through Ethernet 1/0/4 to VLAN 100, and enable IGMP Snooping in this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 1/0/1 to Ethernet 1/0/4
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] quit
# View the multicast groups in VLAN 100 on Switch A.
<SwitchA> display igmp-snooping group vlan100
  Total 1 IP Group(s).
  Total 1 MAC Group(s).
  Vlan(id):100.
        Router port(s):
                     Ethernet1/0/1
    IP group(s):the following ip group(s) match to one mac group.
        IP group address: 224.1.1.1
        Host port(s):
                     Ethernet1/0/3          Ethernet1/0/4
    MAC group(s):
        MAC group address: 0100-5e01-0101
        Host port(s): Ethernet1/0/3          Ethernet1/0/4
As shown above, a multicast group entry for 224.1.1.1 has been created on Switch A, with Ethernet 1/0/1 as the router port and Ethernet 1/0/3 and Ethernet 1/0/4 as dynamic member ports. This means that Host A and Host B have joined the multicast group 224.1.1.1.
Complete Configuration
Configuration on Switch A
vlan 100
interface Ethernet1/0/1
 port access vlan 100
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
Precautions
l          Layer 2 and Layer 3 multicast protocols can run on the same switch. However, a Layer 2 multicast protocol cannot run in a VLAN while a Layer 3 multicast protocol is running on the corresponding VLAN interface, and vice versa.
l          Before enabling IGMP Snooping in a VLAN, be sure to enable IGMP Snooping in system view; otherwise the configuration will not succeed.
Configuring IGMP Snooping Only
Network Diagram
Figure 1-2 Network diagram for IGMP Snooping only configuration
Where it is unnecessary or infeasible to build a Layer 3 multicast network, enabling IGMP Snooping on all the devices in the Layer 2 network can implement some multicast functions.
1)        As shown in Figure 1-2, in a Layer 2 only network, Switch C connects to the multicast source through Ethernet 1/0/3. At least one receiver is attached to Switch B and Switch C respectively.
2)        Enable IGMP Snooping on Switch A, Switch B, and Switch C. Switch A acts as the IGMP Snooping querier.
3)        Enable Switch A and Switch B to drop unknown multicast traffic so that multicast traffic for unknown multicast groups are not flooded in the VLAN.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
# Create VLAN 100, assign Ethernet 1/0/1 through Ethernet 1/0/2 to VLAN 100, and enable IGMP Snooping in this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port Ethernet 1/0/1 Ethernet 1/0/2
# Enable IGMP Snooping querier in VLAN 100.
[SwitchA-vlan100] igmp-snooping querier
# Enable dropping unknown multicast packets.
[SwitchA] unknown-multicast drop enable
Configuring Switch B
[SwitchB] igmp-snooping enable
# Create VLAN 100, assign Ethernet 1/0/1 through Ethernet 1/0/3 to VLAN 100, and enable IGMP Snooping in this VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port Ethernet 1/0/1 to Ethernet 1/0/3
[SwitchB-vlan100] igmp-snooping enable
[SwitchB-vlan100] quit
[SwitchB] unknown-multicast drop enable
Configuring Switch C
<SwitchC system-view
[SwitchC] igmp-snooping enable
[SwitchC] vlan 100
[SwitchC-vlan100] port Ethernet 1/0/1 to Ethernet 1/0/3
[SwitchC-vlan100] igmp-snooping enable
As Switch C is not the IGMP Snooping querier, it cannot create forwarding entries for Host A and Host B, and therefore, do not enable the function of dropping unknown multicast packets on Switch C. To avoid impact on the network and on Switch C caused by multicast flooding, it is recommended to enable IGMP Snooping querier on the switch to which the multicast source is directly attached.
Check the reception of multicast stream for multicast group 224.1.1.1 on Host A, and take the following steps to verify the configurations made on the switches.
1)        View the information on Switch B
# View the IGMP packet statistics on Switch B.
<SwitchB> display igmp-snooping statistics
  Received IGMP general query packet(s) number:16.
  Received IGMP specific query packet(s) number:3.
  Received IGMP V1 report packet(s) number:0.
  Received IGMP V2 report packet(s) number:53.
  Received IGMP leave packet(s) number:1.
  Received error IGMP packet(s) number:0.
  Sent IGMP specific query packet(s) number:1.
Switch B has received IGMP general queries from the querier and IGMP reports from receivers.
# View the multicast group information on Switch B.
<Switch B> display igmp-snooping group
  Vlan(id):100.
    Router port(s):Ethernet1/0/1
        IP group address:224.1.1.1
        Host port(s):Ethernet1/0/2
    MAC group(s):
        MAC group address:0100-5e7f-fffe
As shown above, a multicast group entry for the multicast group 224.1.1.1 has been created on Switch B, with Ethernet 1/0/1 as the dynamic router port and Ethernet 1/0/2 as the dynamic member port.
2)        View the information on Switch A
# View the IGMP packet statistics on Switch A.
<SwitchA> display igmp-snooping statistics
  Received IGMP general query packet(s) number:0.
  Received IGMP specific query packet(s) number:0.
Switch A receives IGMP reports from the receivers.
# View the multicast group information on Switch A.
<Switch A> display igmp-snooping group
  Vlan(id):100.
    Router port(s):
        Host port(s):Ethernet1/0/1
    MAC group(s):
As shown above, a multicast group entry for the multicast group 224.1.1.1 has been created on Switch A, with Ethernet 1/0/1 as the dynamic member port. Acting as the IGMP Snooping querier, Switch A does not have a router port.
3)        View the information on Switch C
# View the IGMP packet statistics on Switch C.
<SwitchC> display igmp-snooping statistics
  Received IGMP general query packet(s) number:10.
  Received IGMP V2 report packet(s) number:0.
  Received IGMP leave packet(s) number:.0
  Sent IGMP specific query packet(s) number:0.
Switch C received only IGMP general queries from the querier.
# View the multicast group information on Switch C.
<Switch C> display igmp-snooping group
  Total 0 IP Group(s).
  Total 0 MAC Group(s).
Vlan(id):100.
As shown above, no multicast entries have been created on Switch C. The switch must flood multicast data in the VLAN to allow the multicast data to flow to the receivers downstream. Therefore, do not enable the function of dropping unknown multicast packets on Switch C.
vlan 100
Configuration on Switch B
vlan 100
Configuration on Switch C
vlan 100
Configuring Multicast VLAN
In the traditional multicast-on-demand mode, when users in different VLANs on a Layer 2 device need multicast information, the multicast router needs to forward a separate copy of the multicast data to each of these VLANs. This mode wastes a great deal of bandwidth.
With the multicast VLAN feature, you can configure a VLAN as the multicast VLAN, which can be used to transmit multicast traffic to users in different VLANs. Since multicast packets are transmitted within the multicast VLAN, which is isolated from user VLANs, the bandwidth and security can be guaranteed.
Network Diagram
Figure 1-3 Network diagram for multicast VLAN
Configure the multicast VLAN feature so that Switch A just sends multicast data to VLAN 10 rather than to each VLAN when Host A and Host B attached to Switch B need the multicast data.
The following table describes the device details:
Device
Remarks
Switch A
Layer 3 switch
IP address of VLAN-interface 20 is 168.10.1.1. Ethernet 1/0/1 belongs to VLAN 20 and is connected with the workstation.
IP address of VLAN-interface 10 is 168.10.2.1. Ethernet 1/0/10 belongs to VLAN 10 and is connected with Switch B.
Switch B
Layer 2 switch
VLAN 2 contains Ethernet 1/0/1 and VLAN 3 contains Ethernet 1/0/2. These two ports are connected with Host A and Host B respectively. The default VLAN of Ethernet 1/0/1 is VLAN 2 and the default VLAN of Ethernet 1/0/2 is VLAN 3.
VLAN 10 contains Ethernet 1/0/10, Ethernet 1/0/1 and Ethernet 1/0/2. Ethernet 1/0/10 is connected with Switch A.
VLAN 10 is multicast VLAN. Ethernet 1/0/1 sends packets of VLAN 2 and VLAN 10 without VLAN tags.
Ethernet 1/0/2 sends packets of VLAN 3 and VLAN 10 without VLAN tags.
HostA
User 1
Connected with Ethernet 1/0/1 of Switch B
HostB
User 2
Connected with Ethernet 1/0/2 of Switch B
Configure VLAN 10 as a multicast VLAN so that users in VLAN 2 and VLAN 3 can receive multicast packets through VLAN 10.
Product series
Software version
Hardware version
S5600 series
All versions
S5100-SI/EI series
All versions
S3600-SI/EI series
All versions
S3100-EI series
All versions
S3100-C-SI series
S3100-T-SI series
All versions
S3100-52P
S3100-52P
Assume that the IP addresses have been configured and the devices have been connected correctly.
1)        Configure Switch A.
# Configure the IP address of VLAN-interface 20 as 168.10.1.1, and enable PIM-DM.
[SwitchA] multicast routing-enable
[SwitchA] vlan 20
[SwitchA–vlan20]port Ethernet1/0/1
[SwitchA-vlan20] quit
[SwitchA] interface Vlan-interface 20
[SwitchA-Vlan-interface20] ip address 168.10.1.1 255.255.255.0
[SwitchA-Vlan-interface20] pim dm
# Create VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
# Configure Ethernet 1/0/10 as a Hybrid port, assign it to VLAN 10, and configure it to send packets of VLAN 10 with the VLAN tag kept.
[SwitchA] interface Ethernet1/0/10
[SwitchA-Ethernet1/0/10] port link-type hybrid
[SwitchA-Ethernet1/0/10] port hybrid vlan 10 tagged
[SwitchA-Ethernet1/0/10] quit
# Configure the IP address of VLAN-interface 10 as 168.10.2.1, and enable PIM-DM and IGMP.
[SwitchA] interface Vlan-interface 10
[SwitchA-Vlan-interface10] ip address 168.10.2.1 255.255.255.0
[SwitchA-Vlan-interface10] igmp enable
[SwitchA-Vlan-interface10] pim dm
2)        Configure Switch B.
# Create VLAN 2, VLAN 3, and VLAN 10, configure VLAN 10 as a multicast VLAN, and enable IGMP Snooping in VLAN 10.
[SwitchB] vlan 2 to 3
Please wait.... Done.
[SwitchB] vlan 10
[SwitchB-vlan10] service-type multicast
[SwitchB-vlan10] igmp-snooping enable
[SwitchB-vlan10] quit
# Configure Ethernet 1/0/10 as a Hybrid port, assign it to VLAN 2, VLAN 3 and VLAN 10, and configure it to send packets of VLAN 2, VLAN 3, and VLAN 10 with the respective VLAN tags kept.
[SwitchB] interface Ethernet1/0/10
[SwitchB-Ethernet1/0/10] port link-type hybrid
[SwitchB-Ethernet1/0/10] port hybrid vlan 2 3 10 tagged
[SwitchB-Ethernet1/0/10] quit
# Configure Ethernet 1/0/1 as a Hybrid port, assign it to VLAN 2 and VLAN 10, and configure it to send packets of VLAN 2 and VLAN 10 without VLAN tags. Configure VLAN 2 as the default VLAN.
[SwitchB-Ethernet1/0/1] port link-type hybrid
[SwitchB-Ethernet1/0/1] port hybrid vlan 2 10 untagged
[SwitchB-Ethernet1/0/1] port hybrid pvid vlan 2
[SwitchB-Ethernet1/0/1] quit
# Configure Ethernet 1/0/2 as a Hybrid port, assign it to VLAN 3 and VLAN 10, and configure it to send packets of VLAN 3 and VLAN 10 without VLAN tags. Configure VLAN 3 as the default VLAN.
[SwitchB] interface Ethernet1/0/2
[SwitchB-Ethernet1/0/2] port link-type hybrid
[SwitchB-Ethernet1/0/2] port hybrid vlan 3 10 untagged
[SwitchB-Ethernet1/0/2] port hybrid pvid vlan 3
[SwitchB-Ethernet1/0/2] quit
interface Vlan-interface10
 igmp enable
 pim dm
interface Vlan-interface20
 pim dm
 port access vlan 20
vlan 1 to 3
vlan 10
 port hybrid vlan 1 to 2 10 untagged
 port hybrid vlan 1 3 10 untagged
 port hybrid vlan 2 to 3 10 tagged
 port hybrid vlan 1 untagged
Precautions
l          A port belongs to one multicast VLAN only.
l          Only Hybrid ports can be connected with receivers.
l          Upon receiving a multicast packet, a router port forwards the packet only to the member ports in the same VLAN. Therefore, the member ports must belong to the same multicast VLAN with the router port.
l          When assigning a router port to a multicast VLAN, be sure to configure it as a trunk port, or a hybrid port that sends packets of the multicast VLAN with the VLAN tag kept; otherwise all the member ports in this multicast VLAN will be unable to receive multicast packets.
Configuring PIM-SM plus IGMP plus IGMP Snooping
PIM-SM is a type of sparse mode multicast protocol. It uses the “pull mode” for multicast forwarding, and is suitable for large- and medium-sized networks with sparsely and widely distributed multicast group members.
The basic implementation of PIM-SM is as follows:
l          PIM-SM assumes that hosts need multicast data only if they explicitly express their interest in the data. PIM-SM builds and maintains rendezvous point trees (RPT) for multicast traffic delivery. An RPT is rooted at a router in the PIM domain as the common node referred to as rendezvous point (RP), through which the multicast data travels along the RPT and reaches the receivers.
l          When a receiver is interested in the multicast data addressed to a specific multicast group, the last-hop router sends a join message to the RP corresponding to that multicast group. The path along which the message goes hop by hop to the RP forms a branch of the RPT.
l          When a multicast source sends multicast traffic to a multicast group, the first-hop router encapsulates the first packet in a register message, and sends the message to the corresponding RP by unicast. The arrival of this message at the RP triggers the establishment of an SPT rooted at the multicast source. Then, the multicast source sends the multicast traffic along the SPT to the RP. Upon reaching the RP, the multicast traffic flows down the RPT to the receivers.
Network Diagram
Figure 1-4 Network diagram for PIM-SM, IGMP, and IGMP Snooping configuration
Device
IP address
Ports
Switch A
Vlan-int100
10.110.1.1/24
Ethernet1/0/1
Vlan-int101
192.168.1.1/24
Ethernet1/0/2
Vlan-int102
192.168.9.1/24
Ethernet1/0/3
Switch B
Vlan-int200
10.110.2.1/24
Ethernet1/0/1
Vlan-int103
192.168.2.1/24
Ethernet1/0/2
Switch C
Vlan-int200
10.110.2.2/24
Ethernet1/0/1
Vlan-int104
192.168.3.1/24
Ethernet1/0/2
Switch D
Vlanint300
10.110.5.1/24
Ethernet1/0/1
Vlanint101
192.168.1.2/24
Ethernet1/0/2
Vlanint105
192.168.4.2/24
Ethernet1/0/3
Switch E
Vlanint104
192.168.3.2/24
Ethernet1/0/3
Vlanint103
192.168.2.2/24
Ethernet1/0/2
Vlanint102
192.168.9.2/24
Ethernet1/0/1
Vlanint105
192.168.4.1/24
Ethernet1/0/4
Switch F
Vlan100
Ethernet1/0/1, Ethernet1/0/2, Ethernet1/0/3
Requirement Analysis
When users receive VOD information through multicast, the information receiving mode may vary depending on user requirements:
1)        To avoid flooding of the video information at Layer 2, IGMP Snooping needs to be enabled on Switch E, through which Host A and Host B receive the multicast data.
2)        To ensure reliable and stable reception of multicast data, Switch B and Switch C provide link backup for the directly attached stub network N1, which comprises multicast receivers Host C and Host D.
3)        The PIM-SM domain as a single-BSR domain, and OSPF runs in the domain for unicast routing.
Configuration Plan
1)        Switch D connects to the network that comprises the multicast source (Source) through VLAN-interface 300.
2)        Switch A connects to Switch F through VLAN-interface 100, and to Switch D and Switch E through VLAN-interface 101 and VLAN-interface 102 respectively.
3)        Switch B and Switch C connect to stub network N1 through their respective VLAN-interface 200, and to Switch E through VLAN-interface 103 and VLAN-interface 104 respectively.
4)        Both VLAN-interface 105 of Switch D and VLAN-interface 102 of Switch E serve as C-BSRs and C-RPs.
5)        Enable IGMPv2 on VLAN-interface 100 of Switch A. On Switch F, enable IGMP Snooping globally and in VLAN 100. Run IGMPv2 on Switch B and Switch C for group management on stub network N1. Typically, Switch B acts as the querier because its interface on the multi-access subnet has a lower IP address.
Product series
Software version
Hardware version
S3600-EI series
Release 1510, Release 1602
All versions
S5600 series
All versions
Configuring the interface IP addresses and unicast routing protocol for each switch
Configure the IP address and subnet mask for each interface as per Figure 1-4. The detailed configuration steps are omitted here.
Configure OSPF for interoperation among the switches in the PIM-SM domain. Ensure the network-layer interoperation among Switch A, Switch B, Switch C, Switch D and Switch E in the PIM-SM domain and enable dynamic update of routing information among the switches through a unicast routing protocol. The specific configuration steps are omitted here.
Configuring multicast protocols
# Enable IP multicast routing on Switch A, enable PIM-SM on each interface, and run IGMPv2 on VLAN-interface 100.
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] igmp enable
[SwitchA-Vlan-interface102] pim sm
It is necessary to enable IGMP only on interfaces with multicast receivers attached. The default IGMP version is IGMPv2.
The configuration on Switch B and Switch C is similar to that on Switch A. The configuration on Switch D and Switch E is also similar to that on Switch A except that it is not necessary to enable IGMP on the corresponding interfaces on these two switches.
# Configure the group range to be advertised in C-RP-Adv messages and configure a C-BSR and a C-RP on VLAN-interface 105 of Switch D.
<SwitchD> system-view
[SwitchD] acl number 2005
[SwitchD-acl-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[SwitchD-acl-basic-2005] quit
[SwitchD] pim
[SwitchD-pim] c-bsr vlan-interface 105 24 2
[SwitchD-pim] c-rp vlan-interface 105 group-policy 2005 priority 2
[SwitchD-pim] quit
# Configure the group range to be advertised in C-RP-Adv messages and configure a C-BSR and a C-RP on VLAN-interface 102 of Switch E.
<SwitchE> system-view
[SwitchE] acl number 2005
[SwitchE-acl-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[SwitchE-acl-basic-2005] quit
[SwitchE] pim
[SwitchE-pim] c-bsr vlan-interface 102 24 1
[SwitchE-pim] c-rp vlan-interface 102 group-policy 2005 priority 1
[SwitchE-pim] quit
# On Switch F, enable IGMP Snooping globally and in VLAN 100.
<SwitchF> system-view
[SwitchF] igmp-snooping enable
[SwitchF] vlan 100
[SwitchF-vlan100] igmp-snooping enable
[SwitchF-vlan100] quit
Check the reception of multicast stream for multicast group 225.1.1.1 on Host A and Host C and verify the configurations made on the switches.
Using the following commands to determine whether Host A and Host C can receive multicast data
# View the PIM neighboring relationships on Switch E.
<SwitchE> display pim neighbor
Neighbor's Address  Interface Name                Uptime    Expires
192.168.9.1         Vlan-interface102               02:47:04  00:01:42
192.168.2.1         Vlan-interface103               02:45:04  00:04:46
192.168.3.1         Vlan-interface104               02:42:24  00:04:45
192.168.4.2         Vlan-interface105               02:43:44  00:05:44
# View the BSR information on Switch E.
<SwitchE> display pim bsr-info
  Current BSR Address: 192.168.4.2
             Priority: 2
          Mask Length: 24
              Expires: 00:01:39
  Local Host is C-BSR: 192.168.9.2
             Priority: 1
          Mask Length: 24
# View the RP information on Switch E.
<SwitchE> display pim rp-info
 PIM-SM RP-SET information:
    BSR is: 192.168.4.2
    Group/MaskLen: 225.1.1.0/24
      RP 192.168.9.2
        Version: 2
        Priority: 1
        Uptime: 00:03:15
        Expires: 00:01:14
      RP 192.168.4.2
        Version: 2
        Priority: 2
        Uptime: 00:04:25
        Expires: 00:01:09
# View the PIM routing table on Switch A.
<SwitchA> display pim routing-table
PIM-SM Routing Table
Total 1 (S,G) entries, 1 (*,G) entries, 0 (*,*,RP) entry
(*, 225.1.1.1), RP 192.168.9.2
    Protocol 0x20: PIMSM, Flag 0x2003: RPT WC NULL_IIF
    Uptime: 00:23:21, never timeout
    Upstream interface: Vlan-interface102, RPF neighbor: 192.168.9.2
    Downstream interface list:
      Vlan-interface100, Protocol 0x1: IGMP, never timeout
(10.110.5.100, 225.1.1.1)
    Protocol 0x20: PIMSM, Flag 0x80004: SPT
    Uptime: 00:03:43, Timeout in 199 sec
Matched 1 (S,G) entries, 1 (*,G) entries, 0 (*,*,RP) entry
The information on Switch B and Switch C is similar to that on Switch A.
# View the PIM routing table on Switch D.
<SwitchD> display pim routing-table
Total 1 (S,G) entry, 0 (*,G) entry, 0 (*,*,RP) entry
    Protocol 0x20: PIMSM, Flag 0x4: SPT
    Uptime: 00:03:03, Timeout in 27 sec
    Upstream interface: Vlan-interface300, RPF neighbor: NULL
      Vlan-interface101, Protocol 0x200: SPT, timeout in 147 sec
      Vlan-interface105, Protocol 0x200: SPT, timeout in 145 sec
Matched 1 (S,G) entry, 0 (*,G) entry, 0 (*,*,RP) entry
# View the PIM routing table on Switch E.
<SwitchE> display pim routing-table
Total 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
(*,225.1.1.1), RP 192.168.9.2
    Uptime: 00:02:34, Timeout in 176 sec
    Upstream interface: Null, RPF neighbor: 0.0.0.0
      Vlan-interface102, Protocol 0x100: RPT, timeout in 176 sec
      Vlan-interface103, Protocol 0x100: SPT, timeout in 135 sec
    Upstream interface: Vlan-interface105, RPF neighbor: 192.168.4.2
      Vlan-interface102, Protocol 0x200: SPT, timeout in 147 sec
      Vlan-interface103, Protocol 0x200: SPT, timeout in 145 sec
Matched 1 (S,G) entry, 1 (*,G) entry, 0 (*,*,RP) entry
# View multicast group entries created by IGMP Snooping on Switch F.
<SwitchF> display igmp-snooping group
  Vlan(id):100.
    Router port(s):Ethernet1/0/2
        IP group address:225.1.1.1
        Host port(s):Ethernet1/0/19
    MAC group(s):
        MAC group address:0100-5e01-0101
# View the multicast group information that contains port information on Switch B.
<SwitchB> display mpm group
  Vlan(id):200.
    Router port(s):
        Host port(s):Ethernet1/0/24
    MAC group(s):
  Vlan(id):103.
    Router port(s):Ethernet1/0/10
As shown above, Host A and Host C can receive multicast data.
Configuring simulated joining
Configure simulated joining on Switch B, thus to prevent the multicast switch from considering that no multicast receiver exists on the subnet due to some reasons and pruning the corresponding path from the multicast forwarding tree.
# Configure Ethernet 1/0/21 as a simulated host to join multicast group 225.1.1.1.
[SwitchB] interface Vlan-interface 200
[SwitchB-Vlan-interface200] igmp host-join 225.1.1.1 port Ethernet 1/0/21
  Vlan(id):200.
    Router port(s):
        Host port(s):Ethernet1/0/21             Ethernet1/0/24
    MAC group(s):
  Vlan(id):103.
As shown above, Ethernet 1/0/21 has become a member port for multicast group 225.1.1.1.
interface Vlan-interface100
 ip address 10.110.1.1 255.255.255.0
 igmp enable
 pim sm
interface Vlan-interface101
 pim sm
interface Vlan-interface102
 ip address 192.168.9.1 255.255.255.0
 pim sm
interface Vlan-interface103
 ip address 192.168.2.1 255.255.255.0
 pim sm
interface Vlan-interface200
 ip address 10.110.2.1 255.255.255.0
 igmp enable
 pim sm
 igmp host-join 225.1.1.1 vlan 1
interface Vlan-interface104
 ip address 192.168.3.1 255.255.255.0
 pim sm
 ip address 10.110.2.2 255.255.255.0
 igmp enable
 pim sm
Configuration on Switch D
acl number 2005
 rule 0 permit source 225.1.1.0 0.0.0.255
 ip address 192.168.1.2 255.255.255.0
 pim sm
interface Vlan-interface105
 ip address 192.168.4.2 255.255.255.0
 pim sm
interface Vlan-interface300
 ip address 10.110.5.1 255.255.255.0
 pim sm
pim
 c-bsr Vlan-interface105 24 2
 c-rp Vlan-interface105 group-policy 2005 priority 2
Configuration on Switch E
acl number 2005
 ip address 192.168.9.2 255.255.255.0
 pim sm
 ip address 192.168.2.2 255.255.255.0
 pim sm
 ip address 192.168.3.2 255.255.255.0
 pim sm
 ip address 192.168.4.1 255.255.255.0
 pim sm
pim
 c-bsr Vlan-interface102 24 1
 c-rp Vlan-interface102 group-policy 2005 priority 1
Configuration on Switch F
vlan 100
Precautions
l          Only one C-BSR can be configured on a Layer 3 switch. Configuration of a C-BSR on another interface overwrites the previous configuration.
l          It is recommended that C-BSRs and C-RPs be configured on Layer 3 switches in the backbone network.
l          If you do not specify a group range for a C-RP, the C-RP will serve all multicast groups when it becomes the RP in the domain; otherwise it will serve the specified group range.
l          You can configure a basic ACL to filter related multicast IP addresses, thus to control the multicast group range that a static RP serves.
l          If you configure a static RP, you must perform the same configuration on all the routers in the PIM-SM domain.
l          If the configured static RP address is the address of an interface in the up state on the local device, the local device will serve as a static RP.
l          When the elected RP works properly, the static RP does not take effect.
l          It is not necessary to enable PIM on the interface that serves as a static RP.
l          Configuring a legal BSR address range can prevent the legal BSR from being replaced maliciously. With a legal BSR address range configured on all Layer 3 switches in the entire network, all these switches will discard bootstrap messages from out of the legal address range, thus to safeguard BSR in the network.
l          To guard against C-RP spoofing, you can configure a legal C-RP address range and the range of multicast groups to be advertised by each C-RP.
Configuring PIM-DM plus IGMP
PIM-DM is a type of dense mode multicast protocol. It uses the “push mode” for multicast forwarding, and is suitable for small-sized networks with densely distributed multicast group members.
The basic implementation of PIM-DM is as follows:
l          PIM-DM assumes that at least one multicast group member exists on each subnet of the network, and therefore multicast data is flooded to all nodes on the network. Then, branches without multicast receivers are pruned from the forwarding tree, leaving only those branches that contain receivers. This “flood and prune” process takes place periodically, that is, pruned branches resume multicast forwarding periodically.
l          When a new receiver on a previously pruned branch joins a multicast group, to reduce the join latency, PIM-DM uses a graft mechanism to resume data forwarding to that branch.
In PIM-DM, the multicast forwarding path is a source tree, with the multicast source as its “root” and multicast group members as its “leaves”. Because the source tree is the shortest path from the multicast source to the receivers, it is also called shortest path tree (SPT).
Network Diagram
Figure 1-5 Network diagram for PIM-DM configuration
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.110.1.1/24
Switch D
Vlan-int300
10.110.5.1/24
Vlan-int103
192.168.1.1/24
Vlan-int103
192.168.1.2/24
Switch B
Vlan-int200
10.110.2.1/24
Vlan-int101
192.168.2.2/24
Vlan-int101
192.168.2.1/24
Vlan-int102
192.168.3.2/24
Switch C
Vlan-int200
10.110.2.2/24
Vlan-int102
192.168.3.1/24
l          Receivers receive multicast VOD information through multicast. The receiver groups of different organizations form two stub networks, and at least one receiver host exists in each stub network. The entire PIM domain operates in the dense mode.
l          Host A and Host C are multicast receivers in the two stub networks.
l          Switch D connects to the network that comprises the multicast source (Source) through VLAN-interface 300.
l          Switch A connects to stub network N1 through VLAN-interface 100, and to Switch D through VLAN-interface 103.
l          Switch B and Switch C connect to stub network N2 through their respective VLAN-interface 200, and to Switch D through VLAN-interface 101 and VLAN-interface 102 respectively.
l          IGMPv2 needs to run between Switch A and N1, and also between Switch B, Switch C, and N2. Typically Switch B acts as the querier.
Product series
Software version
Hardware version
S3600-EI series
All versions
S5600 series
All versions
Configure the IP address and subnet mask for each interface as perFigure 1-5. The detailed configuration steps are omitted here.
Configure OSPF for interoperation among the switches in the PIM-DM domain. Ensure the network-layer interoperation among Switch A, Switch B, Switch C, and Switch D in the PIM-DM domain and enable dynamic update of routing information among the switches via unicast.
Enabling IP multicast routing and enabling PIM-DM on each interface
# Enable IP multicast routing on Switch A, enable PIM-DM on each interface, and enable IGMP on VLAN-interface 100, which connects Switch A to the stub network.
[SwitchA-Vlan-interface100] pim dm
The configuration on Switch B and Switch C is similar to the configuration on Switch A.
# Enable multicast routing on Switch D, and enable PIM-DM on each interface.
[SwitchD] multicast routing-enable
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] pim dm
[SwitchD-Vlan-interface300] quit
[SwitchD-Vlan-interface103] pim dm
[SwitchD] interface vlan-interface 101
[SwitchD-Vlan-interface101] pim dm
[SwitchD-Vlan-interface101] quit
[SwitchD] interface vlan-interface 102
[SwitchD-Vlan-interface102] pim dm
[SwitchD-Vlan-interface102] quit
Carry out the display pim neighbor command to view the PIM neighboring relationships among the switches. For example:
# View the PIM neighboring relationships on Switch D.
[SwitchD] display pim neighbor
192.168.1.1        Vlan-interface1               00:47:08  00:01:39
192.168.2.1        Vlan-interface1               00:48:05  00:01:29
192.168.3.1        Vlan-interface1               00:49:08  00:01:34
Use the display pim routing-table command to view the PIM routing information on the switches. For example:
PIM-DM Routing Table
Total 1 (S,G) entry
    Protocol 0x40: PIMDM, Flag 0xC: SPT NEG_CACHE
    Uptime: 00:00:23, Timeout in 187 sec
    Upstream interface: Vlan-interface103, RPF neighbor: 192.168.1.2
The displayed information on Switch B and Switch C is similar to that on Switch A.
Total 1 (S,G) entry
 ip address 10.110.1.1 255.255.255.0.
 igmp enable
 pim dm
 pim dm
 ip address 192.168.2.1 255.255.255.0.
 pim dm
 igmp enable
 pim dm
 ip address 192.168.3.1 255.255.255.0.
 pim dm
 igmp enable
 pim dm
 ip address 192.168.2.2 255.255.255.0.
 pim dm
 pim dm
 pim dm
 pim dm
Precautions
When deploying a PIM-DM domain, you are recommended to enable PIM-DM on all interfaces of non-border routers.
Configuring Anycast RP Application
Anycast RP enables load balancing and redundancy backup between two or more RPs within a PIM-SM domain by configuring the same IP address for these RPs and establishing MSDP peering relationships between the RPs.
Network Diagram
Figure 1-6 Network diagram for anycast RP configuration
Device
IP address
Device
IP address
Switch A
Vlan-int103
10.110.1.2/24
Switch D
Vlan-int300
10.110.4.1/24
Switch B
Vlan-int100
10.110.2.2/24
Vlan-int102
192.168.3.1
Switch C
Vlan-int103
10.110.1.1/24
Vlan-int101
192.168.1.2/24
Vlan-int100
10.110.2.1/24
Switch F
Vlan-int200
10.110.3.1/24
Vlan-int101
192.168.1.1/24
Vlan-int102
192.168.3.2/24
Loop1
3.3.3.3/32
Loop1
4.4.4.4/32
Loop10
10.1.1.1/32
Loop10
10.1.1.1/32
l          The PIM-SM domain in this example has multiple multicast sources and receivers. OSPF needs to run in the domain to provide unicast routes.
l          The anycast RP application needs to be is configured in the PIM-SM domain, so that the last-hop switch joins the topologically nearest RP.
l          An MSDP peering relationship needs to be set up between Switch C and Switch F.
l          On Switch C and Switch F, the interface Loopback 1 needs to be configured as a C-BSR, and Loopback 10 as a C-RP.
l          The router ID of Switch C is 1.1.1.1, while the router ID of Switch F is 2.2.2.2.
Product series
Software version
Hardware version
S3600-EI series
All versions
S5600 series
All versions
Configure the IP address and subnet mask for each interface as perFigure 1-6. The detailed configuration steps are omitted here.
Configure OSPF for interconnection between the switches. The detailed configuration steps are omitted here.
Enabling IP multicast routing and enabling PIM-SM on each interface
# Enable multicast routing on Switch C, and enable PIM-SM on each interface.
[SwitchC] multicast routing-enable
[SwitchC] interface vlan-interface 103
[SwitchC-Vlan-interface103] pim sm
[SwitchC-Vlan-interface103] quit
[SwitchC-Vlan-interface100] pim sm
[SwitchC] interface Vlan-interface 101
[SwitchC-Vlan-interface101] pim sm
[SwitchC-Vlan-interface101] quit
The configuration on Switch A, Switch B, Switch D, Switch E, Switch F, and Switch G is similar to the configuration on Switch C. The specific configuration steps are omitted here.
Configuring the IP addresses of interface Loopback 1, Loopback 10, C-BSR, and C-RP
# Configure different Loopback 1 addresses and identical Loopback 10 address on Switch C and Switch F, configure a C-BSR on each Loopback 1 and configure a C-RP on each Loopback 10.
[SwitchC] interface loopback 1
[SwitchC-LoopBack1] ip address 3.3.3.3 255.255.255.255
[SwitchC-LoopBack1] pim sm
[SwitchC-LoopBack1] quit
[SwitchC] interface loopback 10
[SwitchC-LoopBack10] ip address 10.1.1.1 255.255.255.255
[SwitchC-LoopBack10] pim sm
[SwitchC-LoopBack10] quit
[SwitchC] pim
[SwitchC-pim] c-bsr loopback 1 24
[SwitchC-pim] c-rp loopback 10
[SwitchC-pim] quit
The configuration on Switch F is similar to the configuration on Switch C.
# View the PIM routing information on Switch C.
[SwitchC] display pim routing-table
Total 1 (S,G) entries, 0 (*,G) entry, 0 (*,*,RP) entry
    Uptime: 00:00:08, Timeout in 203 sec
    Upstream interface: Vlan-interface1, RPF neighbor: NULL
    Downstream interface list: NULL
Matched 1 (S,G) entries, 0 (*,G) entry, 0 (*,*,RP) entry
As shown above, the multicast source has been registered on Switch C, which is deemed as the RP.
# View the PIM routing information on Switch F.
<Switch F>dis pim routing-table
Total 0 (S,G) entry, 1 (*,G) entries, 0 (*,*,RP) entry
(*, 225.1.1.1), RP 10.1.1.1
    Uptime: 00:00:12, never timeout
      Vlan-interface2, Protocol 0x1: IGMP, never timeout
Matched 0 (S,G) entry, 1 (*,G) entries, 0 (*,*,RP) entry
As shown above, the multicast receiver joins to Switch F, rooted at which an RPT has been established.
However, the RP for the multicast source is different from the RP for the multicast receiver, so the multicast receiver cannot receive multicast data yet. Anycast RP needs to be configured on these two RPs.
Configuring MSDP peers
# Configure an MSDP peer on Switch C.
[SwitchC] msdp
[SwitchC-msdp] originating-rp Vlan-interface 101
[SwitchC-msdp] peer 192.168.3.2 connect-interface Vlan-interface 101
[SwitchC-msdp] quit
# Configure an MSDP peer on Switch F.
[SwitchF] msdp
[SwitchF-msdp] originating-rp Vlan-interface 102
[SwitchF-msdp] peer 192.168.1.1 connect-interface Vlan-interface 102
[SwitchF-msdp] quit
You can use the display msdp brief command to view the brief information of MSDP peering relationships between the switches.
# View the brief MSDP peer information on Switch C.
[SwitchC] display msdp brief
MSDP Peer Brief Information
  Peer's Address     State     Up/Down time    AS     SA Count   Reset Count
  192.168.3.2        Up        00:48:21        ?      2          0
# View the brief MSDP peer information on Switch F.
[SwitchF] display msdp brief
  192.168.1.1        Up        00:50:22        ?      2          0
After the peering relationship is established, the multicast receiver can receive multicast data from the source.
# View the PIM routing information on Switch C again.
[Switch C] display pim routing-table
    Uptime: 00:00:55, Timeout in 208 sec
      Vlan-interface2, Protocol 0x200: SPT, timeout in 200 sec
# View the PIM routing information on Switch F again.
[SwitchF] display pim routing-table
Total 1 (S,G) entry, 3 (*,G) entries, 0 (*,*,RP) entry
(*, 224.1.1.1), RP 10.1.1.1
    Uptime: 00:25:26, never timeout
(192.168.3.1, 224.1.1.1)
    Uptime: 00:02:56, Timeout in 202 sec
    Upstream interface: Vlan-interface1, RPF neighbor: 192.168.1.1
Matched 1 (S,G) entry, 3 (*,G) entries, 0 (*,*,RP) entry
 pim sm
pim sm
pim sm
interface LoopBack1
 pim sm
interface LoopBack10
 pim sm
pim
 c-bsr LoopBack1 24
 c-rp LoopBack10
msdp
 originating-rp Vlan-interface101
 peer 192.168.3.2 connect-interface Vlan-interface101
pim sm
 ip address 10.110.3.1 255.255.255.0
pim sm
interface LoopBack1
 ip address 4.4.4.4 255.255.255.255
 pim sm
 pim sm
pim
 c-bsr LoopBack1 24
 c-rp LoopBack10
msdp
 originating-rp Vlan-interface102
 peer 192.168.1.1 connect-interface Vlan-interface102
Precautions
Be sure to configure a 32-bit subnet mask (255.255.255.255) for the Anycast RP address, namely configure the Anycast RP address as a host address.
