H3C Low-End Ethernet Switches Configuration Guide(V1.01)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration ExamplesH3C Low-End Ethernet Switches Configuration Guide(V1.01)
Table of Contents
Related Documents
19-MAC Authentication Configuration Guide
19-MAC Authentication Configuration Guide 45.89 KB
Configuring MAC Authentication
MAC authentication provides a way for authenticating users based on ports and MAC addresses, without requiring any client software to be installed on the hosts. Once detecting a new MAC address, a switch with MAC authentication configured will initiate the authentication process. During authentication, the user does not need to enter any username and password manually.
MAC authentication can be implemented locally or by a RADIUS server.
 After determining the authentication mode, you can select one of the following username types as required:
l          MAC address, where the MAC address of a user serves as the username for authentication (you can use the mac-authentication authmode usernameasmacaddress usernameformat command to set the MAC address format).
l          Fixed username, where the same username and password preconfigured on the switch are used to authenticate all users. In addition, the number of concurrent users is limited with this username type. This username type is not recommended.
Network Diagram
Figure 1-1 Network diagram for configuring local MAC authentication
Networking and Configuration Requirements
As illustrated in Figure 1-1, a supplicant is connected to the switch through port Ethernet 1/0/2.
l          MAC authentication is required on port Ethernet 1/0/2 to control user access to the Internet.
l          All users belong to domain aabbcc.net. The authentication is performed locally and the MAC address of the PC (00-0d-88-f6-44-c1) is used as both the username and password.
Applicable Product Matrix
Product series
Software version
Hardware version
S5600 series
Release 1510, Release1602
All versions
S5100-SI/EI series
Release 2200, Release2201
All versions
S3600-SI/EI series
All versions
S3100-EI series
Release 2104, Release 2107
All versions
S3100-C-SI series
S3100-T-SI series
Release 0011, Release 2102, Release 2107
All versions
S3100-52P
Release 1500, Release 1602
S3100-52P
Configuration Procedure
# Enable MAC authentication for port Ethernet 1/0/2.
<H3C> system-view
[H3C] mac-authentication interface Ethernet 1/0/2
# Specify the MAC authentication username type as MAC address and the MAC address format as with-hyphen.
[H3C] mac-authentication authmode usernameasmacaddress usernameformat with-hyphen
# Create a local user account.
l          Specify the username and password.
[H3C] local-user 00-0d-88-f6-44-c1
[H3C-luser-00-0d-88-f6-44-c1] password simple 00-0d-88-f6-44-c1
l          Set the service type to lan-access.
[H3C-luser-00-0d-88-f6-44-c1] service-type lan-access
[H3C-luser-00-0d-88-f6-44-c1] quit
# Create an ISP domain named aabbcc.net.
[H3C] domain aabbcc.net
New Domain added.
# Configure domain aabbcc.net to perform local authentication.
[H3C-isp-aabbcc.net] scheme local
[H3C-isp-aabbcc.net] quit
# Specify aabbcc.net as the ISP domain for MAC authentication.
[H3C] mac-authentication domain aabbcc.net
# Enable MAC authentication globally.
After configuring the above command, your MAC authentication configuration will take effect immediately, and Only the user with the MAC address of 00-0d-88-f6-44-c1 is allowed to access the Internet through port Ethernet 1/0/2. Note that enabling authentication globally is usually the last step in configuring access control related features. Otherwise, valid users may be denied access to the networks because of incomplete configuration.
Complete Configuration
 domain default enable aabbcc.net
 MAC-authentication
 MAC-authentication domain aabbcc.net
 MAC-authentication authmode usernameasmacaddress usernameformat with-hyphen #
domain aabbcc.net
Precautions
l          You cannot configure the maximum number of MAC addresses that can be learnt on a MAC authentication enabled port, or enable MAC authentication on a port that is configured with the maximum number of MAC addresses that can be learnt.
l          You cannot configure port security on a MAC authentication enabled port, or enable MAC authentication on a port that is configured with port security.
