H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
68-Mirroring Configuration Examples
68-Mirroring Configuration Examples 433.00 KB
H3C Routers
Copyright © 2024 H3C Technologies Co., Ltd. All rights reserved..
Introduction
The following information provides mirroring configuration examples.
The following information is provided based on the assumption that you have basic knowledge of mirroring.
Example: Configuring local port mirroring
As shown in Figure 1, the departments of a company use IP addresses on different subnets. The R&D department uses subnet 10.1.1.0/24, and the marketing department uses subnet 12.1.1.0/24. Configure local port mirroring, so that the data monitoring device can monitor the traffic from the R&D department and marketing department to Internet and the traffic between the two departments.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
·     For a local mirroring group to take effect, you must configure mirroring source ports and monitor ports for the group. Make sure each monitor port is not the member port of any other mirroring group.
·     The packets received on the monitor port include the packets copied from the mirroring ports and the packets from other ports. Use monitor ports only for port mirroring, so the data monitoring devices analyze only the mirrored packets copied from mirroring source ports.
Procedures
# Assign IP address 10.1.1.1 to GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 10.1.1.1 24
# Assign IP addresses to other interfaces as shown in Figure 1 in the same way. (Details not shown.)
# Create a local mirroring group.
[DeviceA] mirroring-group 1 local
# Configure the local mirroring group to mirror the incoming packets of interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceA] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 gigabitethernet 1/0/2 inbound
# Configure interface GigabitEthernet 1/0/3 as the monitor port.
[DeviceA] mirroring-group 1 monitor-port gigabitethernet 1/0/3
# Display information about mirroring group 1 on Device A.
[DeviceA] display mirroring-group 1
Mirroring group 1:
    Type: Local
    Status: Active
    Keep-link-header: No
    Mirroring port:
        GigabitEthernet1/0/1  Inbound
        GigabitEthernet1/0/2  Inbound
    Monitor port: GigabitEthernet1/0/3
# Ping 56.56.56.6 from a host at 10.1.1.2 in the R&D department. Capture the packets on the data monitoring device, as shown in Figure 2.
Figure 2 Packets captured by Wireshark
The captured packets show that the local port mirroring function takes effect. The data monitoring device can successfully monitor the specified traffic.
Configuration files
 mirroring-group 1 mirroring-port inbound
 ip address 12.1.1.1 255.255.255.0
 port link-mode bridge
 undo stp enable
interface GigabitEthernet1/0/4
 port link-mode route
 ip address 56.56.56.5 255.255.255.0
Related documentation
·     Network Management and Monitoring Configuration Guide in H3C MSR5680-X3 Router Configuration Guides (V9)
·     Network Management and Monitoring Command Reference in H3C MSR5680-X3 Router Command References (V9)
