H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
01-AAA Configuration Examples
01-AAA Configuration Examples 164.13 KB
H3C Routers
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Overview
The following information provides examples for configuring an AAA server to authenticate and authorize Telnet and SSH users.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This assumes that you have basic knowledge of AAA.
Example: Configuring HWTACACS authentication and authorization for Telnet users
Network requirements
As shown in Figure 1, configure the following:
·     Use the HWTACACS server to authorize and authenticate Telnet users logging into the device. The login username is user@bbb and the password is aabbcc.
·     Allow users to execute all the display commands related to system functions and resources.
Figure 1 Network diagram
Analysis
·     For the HWTACACS server to identify users, add Telnet usernames and passwords on the server.
·     In this example, users must pass AAA authentication to log in to the device. You must set the authentication method for Telnet users to scheme.
·     For the HWTACACS server to perform authorization and authentication, configure the HWTACACS scheme on the device and specify the servers for authorization and authentication. Apply the configuration to the ISP domain of Telnet users.
·     To securely transmit user passwords between the device and HWTACACS server and to check the integrity of responses packets on the device, you must set the shared key for interaction messages on both the device and the HWTACACS server.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 router.
Procedures
This section uses HWTACACS server ACS 4.0 to illustrate basic configuration of HWTACACS.
Adding a device management user
# Log in to the HWTACACS management platform. Click User-Setup in the left navigation pane.
·     Enter username user@bbb.
·     Click Add/Edit.
Figure 2 User creation interface
Configuring a device management user
# Edit a user.
·     Set the user password to aabbcc.
·     Select group Group 1 for the user.
·     Click Submit.
Figure 3 User password configuration
Configuring the network
# In the left navigation pane, click Network Configuration. Specify a name in the AAA Client Hostname field. In this example, the name is Device.
·     Specify the IP address of device interface that connects the device to the HWTACACS server as 10.1.1.2 in the AAA Client IP Address field.
·     Enter the shared key for communication between the HWTACACS server and the device as imc in the Key field. Make sure the key is the same as the keys configured for authentication and authorization in the HWTACACS scheme.
·     Select TACACS+ (Cisco IOS) in the Authenticate Using field.
·     Click Submit+Apply.
Figure 4 Network configuration interface
Setting up the group
# In the left navigation pane, click Group Setup. Select Group 1 (the same group selected for the device management user) and then click Edit Settings.
·     Select Shell (exec).
·     Select Custom attributes and enter roles="network-operator" in the text box for users to execute all the display commands related to system functions and resources.
·     Click Submit.
Figure 5 Selecting the group
Figure 6 Group configuration interface
Configuring the device
# Configure an IP address for interface GigabitEthernet 1/0/2.
[Device-GigabitEthernet1/0/2] ip address 192.168.57.12 255.255.255.0
# Configure an IP address for interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 10.1.1.2 255.255.255.0
# Enable Telnet server on the device.
[Device] telnet server enable
# Configure the Telnet user login interface to use the scheme method.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
[Device-line-vty0-63] quit
# Configure HWTACACS scheme hwtac.
[Device] hwtacacs scheme hwtac
# Set the IP address of the primary authentication, authorization, and accounting server to 10.1.1.1, and the port number to 49. The TCP port for HWTACACS authentication, authorization, and account is 49.
[Device-hwtacacs-hwtac] primary authentication 10.1.1.1 49
[Device-hwtacacs-hwtac] primary authorization 10.1.1.1 49
[Device-hwtacacs-hwtac] primary accounting 10.1.1.1 49
# Set the plaintext shared key for packet exchanging with the authorization, accounting, and account servers to imc.
[Device-hwtacacs-hwtac] key authentication simple imc
[Device-hwtacacs-hwtac] key authorization simple imc
[Device-hwtacacs-hwtac] key accounting simple imc
[Device-hwtacacs-hwtac] quit
# Create ISP domain bbb and configure login users to use the HWTACAS authentication, authorization, and accounting AAA methods.
[Device] domain bbb
[Device-isp-bbb] authentication login hwtacacs-scheme hwtac
[Device-isp-bbb] authorization login hwtacacs-scheme hwtac
[Device-isp-bbb] accounting login hwtacacs-scheme hwtac
[Device-isp-bbb] quit
Verify that Telnet users can pass authentication with username user@bbb and password aabbcc, and obtain user role network-operator after authentication. Verify that the users can execute display commands for all functions and resources of the system.
Configuration files
 port link-mode route
line vty 0 63
 user-role network-operator
 key authentication cipher $c$3$6ps2/dT38b2K2MDCMCDGYxrvyJNR+/jiKw==
 key authorization cipher $c$3$xEldxJraE8Yof3rHHlVIgyCIb/uLlrZbgg==
 key accounting cipher $c$3$kySCJbNA8DSs+l3HCqxunl8SE4me3vue5g==
 domain bbb
Example: Configuring RADIUS authentication and authorization for SSH users
As shown in Figure 7, configure the following:
·     Use the RADIUS server to authorize and authenticate Telnet users logging into the device. The login username is hello@bbb and the password is aabbcc.
·     Configure usernames sent by the device to the RADIUS server to carry domain names. The server uses the domain names to differentiate services provided to users.
Figure 7 Network diagram
Analysis
·     For the RADIUS server to identify users, add usernames and passwords on the server.
·     In this example, users must pass AAA authentication to log in to the device. You must set the authentication method for SSH users to scheme.
·     For the RADIUS server to perform authorization and authentication, configure the RADIUS scheme on the device and specify the servers for authorization and authentication. Apply the configuration to the ISP domain of SSH users.
·     To securely transmit user passwords between the device and RADIUS  server and to check the integrity of responses packets on the device, you must set the shared key for interaction messages on both the device and the RADIUS server.
Procedures
Configuring the RADIUS server
This document uses iMC PLAT 7.0 (E0102) and iMC EIA 7.0 (E0201) as an example to illustrate basic configuration of the in the example RADIUS server.
Adding an access device
Log in to the IMC management platform, click the User tab, and select User Access Policy > Access Device Management > Access Device in the left navigation pane. Then, click Add.
·     Set the shared key for authentication and authorization interaction messages with the device as expert.
·     Set the port numbers for authentication and accounting to 1812 (UDP port number of RADIUS server for authentication) and 1813 (UDP port number of RADIUS server for accounting).
·     Select Device Management Service as the service type.
·     Select H3C (General) as the access device type.
·     Select or manually add the device with IP address 10.1.1.2 as an access device.
·     Retain the default settings in the other fields and then click OK.
Adding a user
# Click the User tab, and select Device User > Device User in the navigation pane. Click Add.
·     Entering the HDM username and password. In this example, the username is hello@bbb.
·     Select SSH as the service type.
·     Enter user role name network-operator.
·     Add IP addresses of devices to be managed. In this example, the IP address range is 10.1.1.1 to 10.1.1.255.
·     Click OK.
Make sure the IP address range includes the IP address of the access device.
[Device-GigabitEthernet1/0/2] ip address 192.168.1.70 255.255.255.0
# Generate RSA and DSA key pairs.
[Device] public-key local create rsa
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
[Device] public-key local create dsa
Generating Keys...
# Enable the SSH server feature.
[Device] ssh server enable
# Configure SSH users to log in with the AAA authentication method.
# Create RADIUS scheme rad.
[Device] radius scheme rad
# Configure the IP address of the primary authentication server as 10.1.1.1 and the port number as 1812.
[Device-radius-rad] primary authentication 10.1.1.1 1812
# Configure the IP address of the primary accounting server as 10.1.1.1 and the port number as 1813.
[Device-radius-rad] primary accounting 10.1.1.1 1813
 # Set the plaintext shared key for packet exchanging with the accounting and account servers to expert.
[Device-radius-rad] key authentication simple expert
[Device-radius-rad] key accounting simple expert
# Configure the device to include domain names in usernames sent to the RADIUS server.
[Device-radius-rad] user-name-format with-domain
[Device-radius-rad] quit
# Create ISP domain bbb and configure login users to use the RADIUS authentication, authorization, and accounting AAA methods.
[Device] domain bbb
[Device-isp-bbb] authentication login radius-scheme rad
[Device-isp-bbb] authorization login radius-scheme rad
[Device-isp-bbb] accounting login radius-scheme rad
Make a user send an SSH connection request to the device. Verify that the user can pass authentication with username hello@bbb and password aabbcc, and obtain user role network-operator after authentication. Verify that the users can execute display commands for all functions and resources of the system.
Configuration files
line vty 0 63
 ssh server enable
radius scheme rad
 key authentication cipher $c$3$63G7LzIQElGq4aFGTiYQafU+loQxS/cbLg==
 key accounting cipher $c$3$tUIVlyGISJ5X/yiTFWrmh8nyjBIF+1LFzQ==
domain bbb
Related documentation
·     Security Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Security Command Reference in H3C MSR5680-X3 Router Command References(V9)
