H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
54-Control Plane-Based QoS Policy Configuration Examples
H3C Routers
Introduction
The following information provides examples for applying a QoS policy to the control plane.
A QoS policy applied to the control plane can perform QoS processing such as filtering and rate limiting for the packets sent to the control plane, thus protecting normal packet receiving and sending and maintaining the normal processing status on the control plane.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of applying a QoS policy to the control plane.
Example: Policing the ICMP packets sent to a control plane
As shown in Figure 1, the device might receive a large number of ICMP packets from the Internet, which causes high CPU usage and degraded device performance. Apply a QoS policy to a control plane to police incoming ICMP packets to 640 kbps.
Figure 1 Network diagram
Analysis
By default, the device applies a predefined QoS policy to the control plane. You can use the display qos policy control-plane pre-defined command to display the predefined QoS policy applied to the control plane. Each protocol has a default rate limit value.
Use the if-match command in traffic class view to match ICMP packets, and use the car command in traffic behavior view to set the CIR to 640 kbps.
Software versions used
The configuration examples were created and verified on Release 9141P16 of the MSR5680-X3 router.
Procedures
# Create traffic class ICMP, and configure it to match ICMP packets.
[Device] traffic classifier ICMP
[Device-classifier-ICMP] if-match control-plane protocol icmp
[Device-classifier-ICMP] quit
# Create traffic behavior ICMP, and configure a traffic policing action with the CIR as 640 kbps.
[Device] traffic behavior ICMP
[Device-behavior-ICMP] car cir 640
[Device-behavior-ICMP] quit
# Create QoS policy ICMP, and associate the traffic class with the traffic behavior.
[Device] qos policy ICMP
[Device-qospolicy-ICMP] classifier ICMP behavior ICMP
[Device-qospolicy-ICMP] quit
# Apply the QoS policy to the control plane.
[Device] control-plane slot 0
[Device-cp] qos apply policy ICMP inbound
[Device-cp] quit
# Use the display qos policy control-plane command to display information about the QoS policy applied to the control plane.
[Device] display qos policy control-plane slot 0
Control plane slot 0
  Direction: Inbound
  Policy: ICMP
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: ICMP
     Operator: AND
     Rule(s) :
      If-match control-plane protocol icmp
     Behavior: ICMP
      Committed Access Rate:
        CIR 640 (kbps), CBS 40000 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
        Red packets   : 0 (Packets) 0 (Bytes)
The output shows that the QoS policy has been correctly applied to the control plane.
Configuration files
traffic classifier ICMP operator and
 car cir 640 cbs 40000 ebs 0 green pass red discard yellow pass
qos policy ICMP
Example: Policing the ARP packets sent to a control plane
As shown in Figure 2, the device might receive a large number of ARP packets from the Internet, which causes high CPU usage and degraded device performance. Apply a QoS policy to a control plane to police incoming ARP packets to 1000 kbps.
Figure 2 Network diagram
Analysis
To police ARP packets sent to a control plane, use the if-match command in traffic class view to match ARP packets, and use the car command in traffic behavior view to set the CIR.
Procedures
# Create traffic class ARP, and configure it to match ARP packets.
[Device] traffic classifier ARP
[Device-classifier-ARP] if-match control-plane protocol arp
[Device-classifier-ARP] quit
# Create traffic behavior ARP, and configure a traffic policing action with the CIR as 1000 kbps.
[Device] traffic behavior ARP
[Device-behavior-ARP] car cir 1000
[Device-behavior-ARP] quit
# Create QoS policy ARP, and associate the traffic class with the traffic behavior.
[Device] qos policy ARP
[Device-qospolicy-ARP] classifier ARP behavior ARP
[Device-qospolicy-ARP] quit
[Device-cp] qos apply policy ARP inbound
[Device-cp] quit
  Direction: Inbound
  Policy: ARP
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: ARP
     Matched : 12 (Packets) 552 (Bytes)
     Operator: AND
     Rule(s) :
      If-match control-plane protocol arp
     Behavior: ARP
        CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 12 (Packets) 552 (Bytes)
Configuration files
traffic classifier ARP operator and
 car cir 1000 cbs 62500 ebs 0 green pass red discard yellow pass
qos policy ARP
Related documentation
·     ACL and QoS Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     ACL and QoS Command Reference in H3C MSR5680-X3 Router Command References(V9)
