H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
57-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
H3C Routers
Introduction
The following information provides LAC-auto-initiated L2TP tunnel configuration examples.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of L2TP.
Example: Configuring an LAC-auto-initiated L2TP tunnel
As shown in Figure 1, Host accesses the network on the right of the LNS through an L2TP tunnel. Establish an LAC-auto-initiated L2TP tunnel between the LAC and LNS.
Figure 1 Network diagram
Analysis
To create an L2TP tunnel on the LNS after receiving a valid tunnel setup request from the LAC, enable tunnel authentication on both the LNS and LAC, and configure parameters such as PPP users and Virtual-Template interfaces.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
Procedures
Configuring the LNS
# Assign IP addresses to interfaces.
<LNS> system-view
[LNS] interface gigabitethernet 1/0/1
[LNS-GigabitEthernet1/0/1] ip address 10.1.0.1 255.255.255.0
[LNS-GigabitEthernet1/0/1] quit
[LNS] interface gigabitethernet 1/0/2
[LNS-GigabitEthernet1/0/2] ip address 3.3.3.2 255.255.255.0
[LNS-GigabitEthernet1/0/2] quit
# Configure a local user named pc of the network type, set the password to hello, and set the service type to PPP.
[LNS] local-user pc class network
[LNS-luser-network-pc] password simple hello
[LNS-luser-network-pc] service-type ppp
[LNS-luser-network-pc] quit
# Create VT interface 1, and assign IP address 192.168.0.20/24 to the VT interface. Configure the PPP authentication method as PAP on the VT interface, and specify the VT interface to allocate address 192.168.0.2 to the PPP user.
[LNS] interface virtual-template 1
[LNS-Virtual-Template1] ip address 192.168.0.20 255.255.255.0
[LNS-Virtual-Template1] ppp authentication-mode pap
[LNS-Virtual-Template1] remote address 192.168.0.2
[LNS-Virtual-Template1] quit
# Configure domain system to perform local authentication for the PPP user.
[LNS] domain system
[LNS-isp-system] authentication ppp local
[LNS-isp-system] quit
# Enable L2TP, and create L2TP group 1 in LNS mode.
[LNS] l2tp enable
[LNS] l2tp-group 1 mode lns
# Configure the local tunnel name as lns on the LNS and specify VT interface 1 for receiving calls from the peer named LAC.
[LNS-l2tp1] tunnel name lns
[LNS-l2tp1] allow l2tp virtual-template 1 remote lac
# Enable tunnel authentication, and set the tunnel authentication key to aabbcc.
[LNS-l2tp1] tunnel authentication
[LNS-l2tp1] tunnel password simple aabbcc
[LNS-l2tp1] quit
# Configure a private network route for accessing the LAC, so that the packets to the PPP user are forwarded through the L2TP tunnel.
[LNS] ip route-static 10.2.0.0 24 192.168.0.2
Configuring the LAC
# Enable L2TP.
<LAC> system-view
[LAC] l2tp enable
[LAC] interface gigabitethernet 1/0/1
[LAC-GigabitEthernet1/0/1] port link-mode route
[LAC-GigabitEthernet1/0/1] ip address 10.2.0.1 255.255.255.0
[LAC-GigabitEthernet1/0/1] quit
[LAC] interface gigabitethernet 1/0/2
[LAC-GigabitEthernet1/0/2] port link-mode route
[LAC-GigabitEthernet1/0/2] ip address 3.3.3.1 255.255.255.0
[LAC-GigabitEthernet1/0/2] quit
# Create L2TP group 1 in LAC mode.
[LAC] l2tp-group 1 mode lac
# Configure the local tunnel name as LAC, and specify LNS IP address 3.3.3.2.
[LAC-l2tp1] tunnel name lac
[LAC-l2tp1] lns-ip 3.3.3.2
[LAC-l2tp1] tunnel authentication
[LAC-l2tp1] tunnel password simple aabbcc
[LAC-l2tp1] quit
# Create interface virtual-PPP 1. On the interface, configure the PPP username as pc and password as hello, and configure the PPP authentication mode as PAP.
[LAC] interface Virtual-PPP 1
[LAC-Virtual-PPP1] ip address ppp-negotiate
[LAC-Virtual-PPP1] ppp pap local-user pc password simple hello
[LAC-Virtual-PPP1] quit
# Configure a private network route, so that the packets to the external network are forwarded through the L2TP tunnel.
[LAC] ip route-static 10.1.0.0 24 Virtual-PPP 1
# Trigger the LAC to initiate an L2TP tunnel setup request automatically, and use the tunnel parameters configured in L2TP group 1 when setting up the tunnel.
[LAC] interface Virtual-ppp1
[LAC-Virtual-PPP1] l2tp-auto-client l2tp-group 1
# On the LNS, execute the display l2tp session command to display the established L2TP sessions.
[LNS] display l2tp session
LocalSID    RemoteSID    LocalTID    State
9400        1            36406       Established
# On the LNS, execute the display l2tp tunnel command to view the established L2TP tunnels.
[LNS] display l2tp tunnel
LocalTID RemoteTID State        Sessions RemoteAddress   RemotePort RemoteName
36406    13        Established  1        3.3.3.1         1701       lac
Configuration files
·     LNS:
 ip address 10.1.0.1 255.255.0.0
 password cipher $c$3$tUCIDRzQtW17DGjt8zjletI9YfXQnNf3
 service-type ppp
 tunnel name lns
 tunnel password cipher $c$3$B09LxThNxJFm5UL+stnd3gnPNLffshOzMg==
l2tp enable
·     LAC:
interface Virtual-PPP1
 ppp pap local-user pc password cipher $c$3$5VijMUTzyEreI02qAkTT3jliyHnJYg86
 ip route-static 10.1.0.0 24 Virtual-PPP1
 lns-ip 3.3.3.2
 tunnel name lac
 tunnel password cipher $c$3$ZQaYutqU2rIW/2+D+jaDn+5fsDtE3YXs6A==
l2tp enable
Related documentation
·     Layer 2—WAN Access Configuration Guide in H3C MSR5680-X3 Router Configuration Guides (V9)
·     Layer 2—WAN Access Command Reference in H3C MSR5680-X3 Router Command References (V9)
