H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
40-SNMP Configuration Examples
40-SNMP Configuration Examples 207.51 KB
H3C Routers
Introduction
This document provides SNMP configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of SNMP.
Example: Configuring SNMPv1 or SNMPv2c
As shown in Figure 1, configure SNMPv1/SNMPv2c to meet the following requirements:
·     The server manages the device and backs up the configuration files of the device as an NMS via SNMPv1/SNMPv2c.
·     The device proactively sends an notification to the NMS when a fault occurs.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 router.
The configuration procedure is the same for SNMPv1 and SNMPv2c. This example uses SNMPv2c.
For the NMS to manage the device, make sure the SNMP settings on the device and the NMS are consistent.
The configuration on the NMS depending on the NMS type. This example uses the IMC PLAT 7.0 (E0202). For detailed configuration on an NMS, see the related manual for the NMS.
Procedures
Configuring the device
# Specify SNMPv2c, and create read-only community readtest and read-write community writetest.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
[Agent] snmp-agent community write writetest
# Configure contact and physical location information for the device.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable the device to send SNMP notifications to the NMS by using community name readtest.
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname readtest v2c
Configuring the NMS
Table 1 Add the device to IMC.
a.     Log in to IMC.
b.     Click the Resource tab.
c.     From the navigation tree, select Resource Management > Add Device.
d.     On the Add Device page, configure the following parameters:
-     Enter 192.168.100.68 in the Host Name/IP field.
-     Use the default values for other parameters.
Figure 2 Adding the device
Table 2 Configure SNMP parameters:
a.     Expand the SNMP Settings section.
b.     Click Configure. Configure the following parameters:
-     Select SNMPv2c from the Parameter Type list.
-     Enter readtest in the Read-Only Community String field.
-     Enter writetest in the Read-Write Community String field.
-     Click OK.
Figure 3 Configuring SNMP parameters
Table 3 Click OK.
The device is successfully added to the IMC, as shown in Table 3Figure 4.
Figure 4 Device added
After the device is added to the IMC, you can configure, manage, and maintain the device from IMC.
Table 4 Verify that the device sends notifications to the NMS when the link state of an interface changes.
a.     Execute the shutdown or undo shutdown command for an idle interface on the device to shut down or bring up the interface.
b.     Log in to the NMS. Navigate to the Alarm > Alarm Browse > All Alarms page and verify that the NMS receives notifications about interface changes from the device.
Figure 5 All alarms displayed on the NMS
Table 5 Back up the configuration files of the device from the NMS.
# Navigate to the Resource > Device View > Agent page, and then click Backup Configuration File at the right.
Figure 6 Backing up configuration files of the device
# Information as follows is displayed if the configuration files are backed up successfully.
Figure 7 Configuration files backed up successfully
Configuration files
 snmp-agent
 snmp-agent trap enable arp
Example: Configuring SNMPv3
As shown in Figure 8, configure SNMPv3 to meet the following requirements:
·     The server manages the device and backs up the configuration files of the device as an NMS via SNMPv3.
·     The device proactively sends alarm information to the NMS when a fault occurs.
Figure 8 Network diagram
For SNMPv3 notifications to be received on the NMS, the security parameter must be an existing SNMPv3 user and the security model on the device and NMS must be consistent.
Procedures
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Create MIB view mibtest, including all objects in the mib-2 (OID 1.3.6.1) subtree.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1
# Create SNMPv3 group managev3group, and specify the authentication with privacy security model for the group. Assign the group read, write, and notification accesses to the mibtest view.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest write-view mibtest notify-view mibtest
# Add user managev3user to SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Configure contact and physical location information for the agent.
# Enable SNMP notifications.
# Specify the NMS at 192.168.100.4 as the trap destination, and set the security authentication parameter to managev3user.
[Agent] snmp-agent target-host trap address udp-domain 192.168.100.4 params securityname managev3user v3 privacy
Configuring the NMS
Table 1 Log in to IMC
Table 2 Add an SNMP template.
a.     Click the System tab.
b.     From the navigation tree, select Resource Management > SNMP Template.
c.     On the SNMP Template page, click Add.
d.     On the Add SNMP Template page, configure the following parameters:
-     Enter SNMPv3 in the Name field.
-     Select SNMPv3 Priv-Aes128 Auth-Sha from the Parameter Type list.
-     Enter managev3user in the Username field.
-     Enter 123456TESTauth&! in the Authentication Password field.
-     Enter 123456TESTencr&! in the Encryption Password field.
-     Click OK.
Figure 9 Adding an SNMP template
Table 3 Add the device to IMC:
a.     Click the Resource tab.
b.     From the navigation tree, select Resource Management > Add Device.
c.     On the Add Device page, configure the following parameters:
Figure 10 Adding the device
Table 4 Configure SNMP parameters:
b.     Click Configure.
c.     Select the Select an Existing Template option.
d.     Select template name SNMPv3.
e.     Click OK.
Figure 11 Selecting an existing template
Table 5 On the Add Device page, click OK.
The device is successfully added to IMC, as shown in Figure 12.
Figure 12 Device added
Configuration files
 snmp-agent
 snmp-agent mib-view included mibtest internet
 snmp-agent usm-user v3 managev3user managev3group cipher authentication-mode sha $c$3$4CcVHVR5z0PUt42S65Q7t5CinLsNC0qt45linidSxj6AdbAipck= privacy-mode aes128 $c$3$u3MpkHY9/mUEWZpDydimSpuDZP6HCeW2p3GmEqHT5Eys5A==
 snmp-agent trap enable radius
Related documentation
·     Network Management and Monitoring Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Network Management and Monitoring Command Reference in H3C MSR5680-X3 Router Command References(V9)
