H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
41-SRv6 Configuration Examples
41-SRv6 Configuration Examples 1.14 MB
H3C Routers
SRv6 configuration examples
Introduction· 1
Prerequisites· 1
Software versions used· 1
Example: Configuring IPv4 L3VPN over SRv6 BE ECMP·· 1
Network configuration· 1
Restrictions and guidelines· 2
Procedures· 2
Configuring CE 1· 2
Configuring PE 1· 3
Configuring P 1· 5
Configuring P 2· 5
Configuring PE 2· 6
Configuring CE 2· 8
Verifying the configuration· 8
Configuration files· 9
CE 1· 9
PE 1· 9
P 1· 10
P 2· 11
PE 2· 12
CE 2· 13
Example: Configuring VPN FRR in IPv4 L3VPN over SRv6 BE scenarios· 13
Network configuration· 13
Restrictions and guidelines· 14
Procedures· 14
Configuring CE 1· 14
Configuring PE 1· 15
Configuring PE 2· 17
Configuring PE 3· 19
Configuring CE 2· 20
Verifying the configuration· 21
Configuration files· 22
CE 1· 22
PE 1· 23
PE 2· 24
PE 3· 25
CE 2· 27
Example: Configuring inter-AS IPv4 L3VPN over SRv6 BE·· 27
Network configuration· 27
Procedures· 28
Configuring CE 1· 28
Configuring PE 1· 28
Configuring ASBR 1· 30
Configuring ASBR 2· 31
Configuring PE 2· 32
Configuring CE 2· 34
Verifying the configuration· 34
Configuration files· 36
CE 1· 36
PE 1· 36
ASBR 1· 37
ASBR 2· 38
PE 2· 39
CE 2· 41
Example: Statically configuring IPv4 L3VPN over SRv6 TE Policy· 41
Network configuration· 41
Restrictions and guidelines· 42
Procedures· 42
Configuring CE 1· 42
Configuring PE 1· 43
Configuring P· 45
Configuring PE 2· 46
Configuring CE 2· 48
Verifying the configuration· 48
Configuration files· 50
CE 1· 50
PE 1· 51
P· 52
PE 2· 53
CE 2· 55
Example: Statically configuring inter-AS IPv4 L3VPN over SRv6 TE Policy· 55
Network configuration· 55
Procedures· 56
Configuring CE 1· 56
Configuring PE 1· 57
Configuring ASBR 1· 59
Configuring ASBR 2· 60
Configuring PE 2· 62
Configuring CE 2· 64
Verifying the configuration· 65
Configuration files· 66
CE 1· 66
PE 1· 67
ASBR 1· 68
ASBR 2· 70
PE 2· 71
CE 2· 73
Example: Statically configuring IPv4 EVPN L3VPN over SRv6 TE Policy· 73
Network configuration· 73
Restrictions and guidelines· 74
Procedures· 74
Configuring CE 1· 74
Configuring PE 1· 74
Configuring P· 77
Configuring PE 2· 77
Configuring CE 2· 80
Verifying the configuration· 80
Configuration files· 81
CE 1· 81
PE 1· 82
P· 83
PE 2· 84
CE 2· 86
Example: Configuring IPv6 EVPN L3VPN over SRv6 BE·· 86
Network configuration· 86
Procedures· 87
Configuring CE 1· 87
Configuring PE 1· 88
Configuring P· 89
Configuring PE 2· 90
Configuring CE 2· 91
Verifying the configuration· 92
Configuration files· 93
CE 1· 93
PE 1· 93
P· 95
PE 2· 95
CE 2· 96
Example: Configuring IPv6 EVPN L3VPN over SRv6 BE ECMP·· 97
Network configuration· 97
Restrictions and guidelines· 98
Procedures· 98
Configuring CE 1· 98
Configuring PE 1· 98
Configuring P 1· 100
Configuring P 2· 100
Configuring PE 2· 101
Configuring CE 2· 103
Verifying the configuration· 103
Configuration files· 104
CE 1· 104
PE 1· 104
P 1· 105
P 2· 106
PE 2· 106
CE 2· 108
Example: Configuring FRR in IPv6 EVPN L3VPN over SRv6 BE scenarios· 108
Network configuration· 108
Procedures· 109
Configuring CE 1· 109
Configuring PE 1· 110
Configuring PE 2· 112
Configuring PE 3· 114
Configuring CE 2· 115
Verifying the configuration· 116
Configuration files· 118
CE 1· 118
PE 1· 118
PE 2· 120
PE 3· 121
CE 2· 122
Example: Statically configuring IPv6 EVPN L3VPN over SRv6 TE Policy· 123
Network configuration· 123
Restrictions and guidelines· 124
Procedures· 124
Configuring CE 1· 124
Configuring PE 1· 124
Configuring P· 126
Configuring PE 2· 127
Configuring CE 2· 129
Verifying the configuration· 130
Configuration files· 131
CE 1· 131
PE 1· 132
P· 133
PE 2· 134
CE 2· 135
Example: Configuring EVPN VPWS over SRv6 BE (CE dual-homing) 136
Network configuration· 136
Procedures· 137
Configuring CE 1· 137
Configuring PE 1· 137
Configuring PE 2· 139
Configuring PE 3· 141
Configuring CE 2· 142
Verifying the configuration· 142
Configuration files· 143
CE 1· 143
PE 1· 143
PE 2· 145
PE 3· 146
CE 2· 147
Example: Statically configuring EVPN VPWS over SRv6 TE Policy· 147
Network configuration· 147
Procedures· 148
Configuring CE 1· 148
Configuring PE 1· 148
Configuring PE 2· 150
Configuring P· 152
Configuring CE 2· 153
Verifying the configuration· 153
Configuration files· 154
CE 1· 154
PE 1· 154
P· 155
PE 2· 156
CE 2· 157
Example: Statically configuring EVPN VPLS over SRv6 TE Policy· 158
Network configuration· 158
Procedures· 158
Configuring CE 1· 158
Configuring PE 1· 159
Configuring PE 2· 160
Configuring P· 162
Configuring CE 2· 163
Verifying the configuration· 163
Configuration files· 164
CE 1· 164
PE 1· 164
P· 165
PE 2· 166
CE 2· 167
Related documentation· 168
Introduction
This document provides SRv6 configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of MPLS, EVPN, and SRv6.
This configuration example was created and verified on R9141P16 of the MSR5680-X3 router.
As shown in Figure 1, the carrier network is an IPv6 network, and the private network is an IPv4 network. PE 1, P 1, P 2, and PE 2 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Two equal-cost SRv6 tunnels are established between PE 1 and PE 2 to carry IPv4 L3VPN traffic.
Figure 1 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/1
20.1.1.1/24
PE 1
Loop1
1::1/128
PE 2
Loop1
4::4/128
GE1/0/1
10.1.1.2/24
GE1/0/1
20.1.1.2/24
GE1/0/2
2001::1/96
GE1/0/2
2002::1/96
GE1/0/3
3001::1/96
GE1/0/3
3002::1/96
P 1
Loop1
2::2/128
P 2
Loop1
3::3/128
GE1/0/1
2001::2/96
GE1/0/1
3001::2/96
GE1/0/2
2002::2/96
GE1/0/2
3002::2/96
SRv6 BE ECMP relies on ECMP routes in the network. To ensure successful configuration, you must make an IGP cost plan for links in the network diagram. In this example, all of the links use the default cost value (10).
Procedures
Configuring CE 1
[Sysname] sysname CE1
[CE1] interface gigabitethernet 1/0/1
[CE1-GigabitEthernet1/0/1] ip address 10.1.1.1 24
[CE1-GigabitEthernet1/0/1] quit
[CE1] bgp 200
[CE1-bgp-default] router-id 11.11.11.11
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
Configuring PE 1
# Configure IPv6 IS-IS to achieve PE-P interconnects in the backbone network. Meanwhile, configure BFD for IS-IS. BFD improves the route convergence speed of IS-IS when link status changes occur.
[Sysname] sysname PE1
[PE1] isis 1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ipv6 address 1::1 128
[PE1-LoopBack1] isis ipv6 enable 1
[PE1-LoopBack1] quit
[PE1] interface gigabitethernet 1/0/2
[PE1-GigabitEthernet1/0/2] ipv6 address 2001::1 96
[PE1-GigabitEthernet1/0/2] isis ipv6 enable 1
[PE1-GigabitEthernet1/0/2] isis ipv6 bfd enable
[PE1-GigabitEthernet1/0/2] quit
[PE1] interface gigabitethernet 1/0/3
[PE1-GigabitEthernet1/0/3] ipv6 address 3001::1 96
[PE1-GigabitEthernet1/0/3] isis ipv6 enable 1
[PE1-GigabitEthernet1/0/3] isis ipv6 bfd enable
[PE1-GigabitEthernet1/0/3] quit
# Configure a VPN instance to achieve CE-PE connections.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] quit
[PE1-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet1/0/1] ip address 10.1.1.2 24
# Establish an EBGP peer relationship between the PE and CE 1, and enable the PE to import VPN routes to BGP.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 200
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
# Establish an MP-IBGP peer relationship between the PEs.
[PE1-bgp-default] peer 4::4 as-number 100
[PE1-bgp-default] peer 4::4 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 4::4 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# Specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
# Create a locator that contains the destination address (End.DT4 SID) for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 100:1:: 96 static 8
[PE1-segment-routing-ipv6-locator-abc] quit
[PE1-segment-routing-ipv6] quit
# Enable IS-IS to reference and advertise the created locator.
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator abc
[PE1-isis-1] quit
# Enable the PE to exchange End.DT4 SIDs with PE 2, and enable support for recursing VPN routes to routes that carry End.DT4 SIDs.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 4::4 prefix-sid
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
Configuring P 1
[Sysname] sysname P1
[P1] isis 1
[P1-isis-1] cost-style wide
[P1-isis-1] network-entity 00.0000.0000.0002.00
[P1-isis-1] address-family ipv6 unicast
[P1-isis-1-ipv6] quit
[P1-isis-1] quit
[P1] interface loopback 1
[P1-LoopBack1] ipv6 address 2::2 128
[P1-LoopBack1] isis ipv6 enable 1
[P1-LoopBack1] quit
[P1] interface gigabitethernet 1/0/1
[P1-GigabitEthernet1/0/1] ipv6 address 2001::2 96
[P1-GigabitEthernet1/0/1] isis ipv6 enable 1
[P1-GigabitEthernet1/0/1] isis ipv6 bfd enable
[P1-GigabitEthernet1/0/1] quit
[P1] interface gigabitethernet 1/0/2
[P1-GigabitEthernet1/0/2] ipv6 address 2002::2 96
[P1-GigabitEthernet1/0/2] isis ipv6 enable 1
[P1-GigabitEthernet1/0/2] isis ipv6 bfd enable
[P1-GigabitEthernet1/0/2] quit
Configuring P 2
[Sysname] sysname P2
[P2] isis 1
[P2-isis-1] cost-style wide
[P2-isis-1] network-entity 00.0000.0000.0003.00
[P2-isis-1] address-family ipv6 unicast
[P2-isis-1-ipv6] quit
[P2-isis-1] quit
[P2] interface loopback 1
[P2-LoopBack1] ipv6 address 3::3 128
[P2-LoopBack1] isis ipv6 enable 1
[P2-LoopBack1] quit
[P2] interface gigabitethernet 1/0/1
[P2-GigabitEthernet1/0/1] ipv6 address 3001::2 96
[P2-GigabitEthernet1/0/1] isis ipv6 enable 1
[P2-GigabitEthernet1/0/1] isis ipv6 bfd enable
[P2-GigabitEthernet1/0/1] quit
[P2] interface gigabitethernet 1/0/2
[P2-GigabitEthernet1/0/2] ipv6 address 3002::2 96
[P2-GigabitEthernet1/0/2] isis ipv6 enable 1
[P2-GigabitEthernet1/0/2] isis ipv6 bfd enable
[P2-GigabitEthernet1/0/2] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] isis 1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 00.0000.0000.0004.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ipv6 address 4::4 128
[PE2-LoopBack1] isis ipv6 enable 1
[PE2-LoopBack1] quit
[PE2] interface gigabitethernet 1/0/2
[PE2-GigabitEthernet1/0/2] ipv6 address 2002::1 96
[PE2-GigabitEthernet1/0/2] isis ipv6 enable 1
[PE2-GigabitEthernet1/0/2] isis ipv6 bfd enable
[PE2-GigabitEthernet1/0/2] quit
[PE2] interface gigabitethernet 1/0/3
[PE2-GigabitEthernet1/0/3] ipv6 address 3002::1 96
[PE2-GigabitEthernet1/0/3] isis ipv6 enable 1
[PE2-GigabitEthernet1/0/3] isis ipv6 bfd enable
[PE2-GigabitEthernet1/0/3] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 100:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/0/1] ip address 20.1.1.2 24
[PE2-GigabitEthernet1/0/1] quit
# Establish an EBGP peer relationship between the PE and CE 2, and enable the PE to import VPN routes to BGP.
[PE2] bgp 100
[PE2-bgp-default] router-id 4.4.4.4
[PE2-bgp-default-vpn1] peer 20.1.1.1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 20.1.1.1 enable
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 1
[PE2-bgp-default-vpnv4] peer 1::1 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 4::4
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 96 static 8
[PE2-segment-routing-ipv6-locator-abc] quit
[PE2-segment-routing-ipv6] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc
[PE2-isis-1] quit
# Enable the PE to exchange End.DT4 SIDs with PE 1, and enable support for recursing VPN routes to routes that carry End.DT4 SIDs.
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
Configuring CE 2
[Sysname] sysname CE2
[CE2] interface gigabitethernet 1/0/1
[CE2-GigabitEthernet1/0/1] ip address 20.1.1.1 24
[CE2-GigabitEthernet1/0/1] quit
[CE2] bgp 300
[CE2-bgp-default] router-id 22.22.22.22
[CE2-bgp-default] peer 20.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# On PE 1, execute the display ip routing-table vpn-instance command to view VPN routes. The command output shows that VPN route 20.1.1.1/24 has two output interfaces that can form an ECMP relationship during traffic forwarding.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11       Routes : 11
10.1.1.0/24        Direct  0   0           10.1.1.2        GE1/0/1
10.1.1.0/32        Direct  0   0           10.1.1.2        GE1/0/1
10.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.2        GE1/0/1
20.1.1.0/24        BGP     255 0           200:1::         GE1/0/2
                   BGP     255 0           200:1::         GE1/0/3
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Verify that CE 1 and CE 2 can ping each other.
[CE1] ping -a 10.1.1.1 20.1.1.1
Ping 20.1.1.1 (20.1.1.1) from 10.1.1.1: 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 20.1.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
Configuration files
CE 1
 sysname CE1
 port link-mode route
bgp 200
  import-route direct
PE 1
 sysname PE1
 vpn-target 100:1 import-extcommunity
 vpn-target 100:1 export-extcommunity
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 1::1/128
 isis ipv6 enable 1
 ipv6 address 2001::1/96
 isis ipv6 enable 1
 ipv6 address 3001::1/96
bgp 100
 router-id 1.1.1.1
 peer 4::4 connect-interface LoopBack1
  peer 4::4 enable
   import-route direct
P 1
 sysname P1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 2::2/128
 isis ipv6 enable 1
 ipv6 address 2001::2/96
 isis ipv6 enable 1
 ipv6 address 2002::2/96
P 2
 sysname P2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 3::3/128
 isis ipv6 enable 1
 ipv6 address 3001::2/96
 isis ipv6 enable 1
 ipv6 address 3002::2/96
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 4::4/128
 ip address 20.1.1.2 255.255.255.0
 isis ipv6 enable 1
 ipv6 address 2002::1/96
 isis ipv6 enable 1
 ipv6 address 3002::1/96
bgp 100
 router-id 4.4.4.4
 peer 1::1 connect-interface LoopBack1
  peer 1::1 enable
   import-route direct
CE 2
 sysname CE2
 ip address 20.1.1.1 255.255.255.0
bgp 300
  import-route direct
As shown in Figure 2, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1, PE 2, and PE 3 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. PE 1 establishes an SRv6 tunnel with PE 2 and PE 3 separately. The SRv6 tunnels are used to carry IPv4 L3VPN traffic. CE 2 is dual-homed to PE 2 and PE 3. To achieve rapid VPN route switchover, VPN FRR is enabled for IPv4 L3VPN on PE 1. When the primary path fails, VPN FRR quickly steers VPN traffic to the backup path.
Figure 2 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/1
20.1.1.1/24
Loop0
11.11.11.11/32
GE1/0/2
30.1.1.1/24
PE 1
Loop1
1::1/128
Loop0
22.22.22.22/32
GE1/0/1
10.1.1.2/24
PE 3
Loop1
3::3/128
GE1/0/2
2001::1/96
GE1/0/2
30.1.1.2/24
GE1/0/3
3001::1/96
GE1/0/3
3001::2/96
PE 2
Loop1
2::2/128
GE1/0/1
20.1.1.2/24
GE1/0/2
2001::2/96
After you enable the VPN FRR feature for IPv4 L3VPN over SRv6 BE, this feature can run correctly only after PE 1 learns non-ECMP VPNv4 routes from PE 2 and PE 3. To ensure successful configuration of the VPN FRR feature, you must make an IGP cost plan for links in the network diagram. In this example, all of the links use the default cost value (10).
Procedures
Configuring CE 1
<CE1> system-view
[CE1] sysname CE1
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 11.11.11.11 32
[CE1-LoopBack0] quit
[CE1] bgp 200
Configuring PE 1
# Configure IPv6 IS-IS to achieve PE interconnects in the backbone network.
<PE1> system-view
[PE1] sysname PE1
[PE1] isis 1
[PE1-isis-1] quit
# Configure a VPN instance to connect CE 1 and PE 1.
# Establish an EBGP peer relationship between PE 1 and CE 1, and enable the PE to import VPN routes to BGP.
[PE1] bgp 100
# Establish an MP-IBGP peer relationship between PE 1 and PE 2, and  between PE 1 and PE 3.
[PE1-bgp-default] peer 2::2 as-number 100
[PE1-bgp-default] peer 2::2 connect-interface loopback 1
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 2::2 enable
[PE1-bgp-default-vpnv4] peer 3::3 enable
[PE1] isis 1
[PE1-isis-1] quit
# Enable the PE to exchange End.DT4 SIDs with PE 2 and PE 3, and enable support for recursing VPN routes to routes that carry End.DT4 SIDs.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2::2 prefix-sid
[PE1-bgp-default-vpnv4] peer 3::3 prefix-sid
# Enable VPN FRR, and enable static BFD to detect whether the locator advertised from PE 1 to PE 2 is reachable. If the locator is unreachable (the primary path fails), VPN FRR will steer the related VPN traffic to the backup path.
[PE1] bgp 100
[PE1-bgp-default] primary-path-detect bfd ctrl
[PE1-bgp-default-ipv4-vpn1] pic
[PE1] bfd static ToPE2 peer-ipv6 200:1:: source-ipv6 100:1::
[PE1-bfd-static-session-ToPE2] discriminator local 100
[PE1-bfd-static-session-ToPE2] discriminator remote 200
[PE1-bfd-static-session-ToPE2] quit
Configuring PE 2
<PE2> system-view
[PE2] sysname PE2
[PE2] isis 1
[PE2-isis-1] network-entity 00.0000.0000.0002.00
[PE2-isis-1] quit
[PE2-LoopBack1] ipv6 address 2::2 128
[PE2-GigabitEthernet1/0/2] ipv6 address 2001::2 96
# Configure a VPN instance to connect CE 2 and PE 2.
# Establish an EBGP peer relationship between PE 2 and CE 2, and enable the PE to import VPN routes to BGP.
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
# Establish an MP-IBGP peer relationship between PE 1 and PE 2.
[PE2-segment-routing-ipv6] encapsulation source-address 2::2
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
# Configure a static BFD session that detects whether the locator advertised from PE 2 to PE 1 is reachable.
[PE2] bfd static ToPE1 peer-ipv6 100:1:: source-ipv6 200:1::
[PE2-bfd-static-session-ToPE1] discriminator local 200
[PE2-bfd-static-session-ToPE1] discriminator remote 100
[PE2-bfd-static-session-ToPE1] quit
Configuring PE 3
# Configure IPv6 IS-IS to interconnect the PEs in the backbone network.
<PE3> system-view
[PE3] sysname PE3
[PE3] isis 1
[PE3-isis-1] cost-style wide
[PE3-isis-1] network-entity 00.0000.0000.0003.00
[PE3-isis-1] address-family ipv6 unicast
[PE3-isis-1-ipv6] quit
[PE3-isis-1] quit
[PE3] interface loopback 1
[PE3-LoopBack1] ipv6 address 3::3 128
[PE3-LoopBack1] isis ipv6 enable 1
[PE3-LoopBack1] quit
[PE3] interface gigabitethernet 1/0/3
[PE3-GigabitEthernet1/0/2] ipv6 address 3001::2 96
[PE3-GigabitEthernet1/0/2] isis ipv6 enable 1
[PE3-GigabitEthernet1/0/2] quit
# Configure a VPN instance to connect CE 2 and PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 100:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface gigabitethernet 1/0/2
[PE3-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE3-GigabitEthernet1/0/1] ip address 30.1.1.2 24
[PE3-GigabitEthernet1/0/1] quit
# Establish an EBGP peer relationship between PE 3 and CE 2, and enable the PE to import VPN routes to BGP.
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 30.1.1.1 as-number 300
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv6-vpn1] peer 30.1.1.1 enable
[PE3-bgp-default-ipv6-vpn1] import-route direct
[PE3-bgp-default-ipv6-vpn1] quit
[PE3-bgp-default-vpn1] quit
# Establish an MP-IBGP peer relationship between PE 1 and PE 3.
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 1
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 1::1 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default] quit
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 3::3
[PE3-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 96 static 8
[PE3-segment-routing-ipv6-locator-abc] quit
[PE3-segment-routing-ipv6] quit
[PE3] isis 1
[PE3-isis-1-ipv6] segment-routing ipv6 locator abc
[PE3-isis-1] quit
[PE3] bgp 100
[PE3-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
[PE3-bgp-default-ipv4-vpn1] quit
Configuring CE 2
<CE2> system-view
[CE2] sysname CE2
[CE2] interface gigabitethernet 1/0/2
[CE2-GigabitEthernet1/0/2] ip address 30.1.1.1 24
[CE2-GigabitEthernet1/0/2] quit
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 22.22.22.22 32
[CE2-LoopBack0] quit
[CE2] bgp 300
[CE2-bgp-default] peer 30.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 30.1.1.2 enable
# On PE 1, execute the display ip routing-table vpn-instance vpn1 22.22.22.22 verbose command to view detailed information about VPN route 22.22.22.22. The command output shows that VPN route 22.22.22.22 has primary and backup interfaces. The two interfaces can form an VPN relationship during traffic forwarding.
[PE1] display ip routing-table vpn-instance vpn1 22.22.22.22 verbose
Summary count : 1
 Destination: 22.22.22.22/32
    Protocol: BGP instance default
  Process ID: 0
   SubProtID: 0x1                       Age: 00h32m17s
        Cost: 0                  Preference: 255
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x102                  OrigAs: 300
       NibID: 0x16000003             LastAs: 300
      AttrID: 0x2                  Neighbor: 2::2
       Flags: 0x80010060        OrigNextHop: 200:1::
       Label: NULL              RealNextHop: FE80::62F5:1BFF:FEE0:307
     BkLabel: NULL                BkNextHop: FE80::62F5:20FF:FEC4:408
     SRLabel: NULL                Interface: GigabitEthernet1/0/2
   BkSRLabel: NULL              BkInterface: GigabitEthernet1/0/3
    SIDIndex: NULL                  InLabel: NULL
   Tunnel ID: Invalid           IPInterface: GigabitEthernet1/0/2
 BkTunnel ID: Invalid         BkIPInterface: GigabitEthernet1/0/3
    FtnIndex: 0x0            ColorInterface: N/A
TrafficIndex: N/A          BkColorInterface: N/A
   Connector: N/A                 VpnPeerId: N/A
        Dscp: N/A                       Exp: N/A
  SRTunnelID: Invalid             StatFlags: 0x0
    SID Type: N/A                       SID: 200:1::1:4
       BkSID: 300:1::1:4                NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid                PathID: 0x0
CommBlockLen: 0
  OrigLinkID: 0x0                RealLinkID: 0x0
# Shut down GigabitEthernet 1/0/2 on PE 1 to make the primary path fail, and then verify that CE 1 and CE 2 can ping each other.
[CE1] ping -a 11.11.11.11 22.22.22.22
Ping 22.22.22.22 (22.22.22.22) from 11.11.11.11: 56 data bytes, press CTRL_C to break
56 bytes from 22.22.22.22: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 22.22.22.22: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 22.22.22.22 ---
Configuration files
CE 1
 sysname CE1
 combo enable fiber
interface LoopBack0
 ip address 11.11.11.11 255.255.255.255
bgp 200
  import-route direct
PE 1
 sysname PE1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 combo enable copper
 isis ipv6 enable 1
 combo enable copper
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
 peer 2::2 connect-interface LoopBack1
 peer 3::3 connect-interface LoopBack1
  peer 2::2 enable
  peer 3::3 enable
   pic
   import-route direct
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 combo enable copper
 isis ipv6 enable 1
bgp 100
 router-id 2.2.2.2
  peer 1::1 enable
   import-route direct
PE 3
 sysname PE3
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 ip address 30.1.1.2 255.255.255.0
 combo enable copper
 isis ipv6 enable 1
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
   import-route direct
CE 2
 sysname CE2
interface LoopBack0
 ip address 22.22.22.22 255.255.255.255
 combo enable copper
 combo enable copper
 ip address 30.1.1.1 255.255.255.0
bgp 300
  import-route direct
As shown in Figure 3, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1 and ASBR 1 run in AS 100. PE 2 and ASBR 2 run in AS 200. IS-IS is used for intra-AS IPv6 network interconnectivity within AS 100 and AS 200. A bidirectional inter-AS SRv6 BE path is established between PE 1 and PE 2 to carry IPv4 L3VPN traffic.
Figure 3 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/1
20.1.1.1/24
PE 1
Loop1
1::1/128
PE 2
Loop1
4::4/128
GE1/0/1
10.1.1.2/24
GE1/0/1
20.1.1.2/24
GE1/0/2
101::1/96
GE1/0/2
303::2/96
ASBR 1
Loop1
2::2/128
ASBR 2
Loop1
3::3/128
GE1/0/1
101::2/96
GE1/0/1
303::1/96
GE1/0/2
202::1/96
GE1/0/2
202::2/96
Procedures
Configuring CE 1
[CE1] bgp 65410
Configuring PE 1
# Configure IPv6 IS-IS to achieve PE-ASBR interconnects in the backbone network.
[PE1] isis 1
[PE1-isis-1] quit
[PE1-GigabitEthernet1/0/2] ipv6 address 101::1 96
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
# Establish an MP-EBGP peer relationship between the PEs.
[PE1-bgp-default] peer 4::4 as-number 200
[PE1-bgp-default] peer 4::4 ebgp-max-hop 255
# Establish an MP-IBGP peer relationship between the PE and ASBR 1.
[PE1-bgp-default] address-family ipv6
[PE1-bgp-default-ipv6] peer 2::2 enable
[PE1-bgp-default-ipv6] quit
# Establish an SRv6 BE path between the PEs.
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 10:1:: 96 static 8
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
Configuring ASBR 1
[Sysname] sysname ASBR1
[ASBR1] isis 1
[ASBR1-isis-1] cost-style wide
[ASBR1-isis-1] network-entity 00.0000.0000.0002.00
[ASBR1-isis-1] address-family ipv6 unicast
[ASBR1-isis-1-ipv6] quit
[ASBR1-isis-1] quit
[ASBR1] interface loopback 1
[ASBR1-LoopBack1] ipv6 address 2::2 128
[ASBR1-LoopBack1] isis ipv6 enable 1
[ASBR1-LoopBack1] quit
[ASBR1] interface gigabitethernet 1/0/1
[ASBR1-GigabitEthernet1/0/1] ipv6 address 101::2 96
[ASBR1-GigabitEthernet1/0/1] isis ipv6 enable 1
[ASBR1-GigabitEthernet1/0/1] quit
[ASBR1] interface gigabitethernet 1/0/2
[ASBR1-GigabitEthernet1/0/2] ipv6 address 201::1 96
[ASBR1-GigabitEthernet1/0/2] quit
# Establish an MP-IBGP peer relationship between the ASBR and PE 1.
[ASBR1] bgp 100
[ASBR1-bgp-default] router-id 2.2.2.2
[ASBR1-bgp-default] peer 1::1 as-number 100
[ASBR1-bgp-default] peer 1::1 connect-interface loopback 1
[ASBR1-bgp-default] address-family ipv6
[ASBR1-bgp-default-ipv6] peer 1::1 enable
[ASBR1-bgp-default-ipv6] peer 1::1 next-hop-local
[ASBR1-bgp-default-ipv6] quit
# Enable BGP to redistribute the locator routes advertised by IS-IS and advertise them to ASBR 2.
[ASBR1-bgp-default] peer 202::2 as-number 200
[ASBR1-bgp-default] peer 202::2 ebgp-max-hop 255
[ASBR1-bgp-default-ipv6] peer 202::2 enable
[ASBR1-bgp-default-ipv6] import-route isisv6 1
[ASBR1-bgp-default] quit
# Enable IS-IS to redistribute the locator routes advertised by BGP.
[ASBR1] ipv6 prefix-list as100 index 10 permit 40:: 64
[ASBR1] ipv6 prefix-list as100 index 20 permit 4::4 128
[ASBR1] route-policy as100 permit node 1
[ASBR1-route-policy-as100-1] if-match ipv6 address prefix-list as100
[ASBR1-route-policy-as100-1] quit
[ASBR1] isis 1
[ASBR1-isis-1-ipv6] import-route bgp4+ route-policy as100
[ASBR1-isis-1] quit
Configuring ASBR 2
[Sysname] sysname ASBR2
[ASBR2] isis 1
[ASBR2-isis-1] cost-style wide
[ASBR2-isis-1] network-entity 00.0000.0000.0003.00
[ASBR2-isis-1] address-family ipv6 unicast
[ASBR2-isis-1-ipv6] quit
[ASBR2-isis-1] quit
[ASBR2] interface loopback 1
[ASBR2-LoopBack1] ipv6 address 3::3 128
[ASBR2-LoopBack1] isis ipv6 enable 1
[ASBR2-LoopBack1] quit
[ASBR2] interface gigabitethernet 1/0/1
[ASBR2-GigabitEthernet1/0/1] ipv6 address 303::1 96
[ASBR2-GigabitEthernet1/0/1] isis ipv6 enable 1
[ASBR2-GigabitEthernet1/0/1] quit
[ASBR2] interface gigabitethernet 1/0/2
[ASBR2-GigabitEthernet1/0/2] ipv6 address 202::2 96
[ASBR2-GigabitEthernet1/0/2] quit
# Establish an MP-IBGP peer relationship between the ASBR and PE 2.
[ASBR2] bgp 200
[ASBR2-bgp-default] router-id 3.3.3.3
[ASBR2-bgp-default] peer 4::4 as-number 200
[ASBR2-bgp-default] peer 4::4 connect-interface loopback 1
[ASBR2-bgp-default] address-family ipv6
[ASBR2-bgp-default-ipv6] peer 4::4 enable
[ASBR2-bgp-default-ipv6] peer 4::4 next-hop-local
[ASBR2-bgp-default-ipv6] quit
# Enable BGP to redistribute the locator routes advertised by IS-IS and advertise them to ASBR 1.
[ASBR2-bgp-default] peer 202::1 as-number 100
[ASBR2-bgp-default] peer 202::1 ebgp-max-hop 255
[ASBR2-bgp-default-ipv6] peer 202::1 enable
[ASBR2-bgp-default-ipv6] import-route isisv6 1
[ASBR2-bgp-default] quit
[ASBR2] ipv6 prefix-list as200 index 10 permit 10:: 64
[ASBR2] ipv6 prefix-list as200 index 20 permit 1::1 128
[ASBR2] route-policy as200 permit node 1
[ASBR2-route-policy-as200-1] if-match ipv6 address prefix-list as200
[ASBR2-route-policy-as200-1] quit
[ASBR2] isis 1
[ASBR2-isis-1-ipv6] import-route bgp4+ route-policy as200
[ASBR2-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-GigabitEthernet1/0/2] ipv6 address 303::2 96
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 20.1.1.1 as-number 65420
[PE2-bgp-default] peer 1::1 ebgp-max-hop 255
# Establish an MP-IBGP peer relationship between the PE and ASBR 2.
[PE2-bgp-default] peer 3::3 as-number 200
[PE2-bgp-default] peer 3::3 connect-interface LoopBack1
[PE2-bgp-default] address-family ipv6
[PE2-bgp-default-ipv6] peer 3::3 enable
[PE2-bgp-default-ipv6] quit
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 40:: 96 static 8
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
Configuring CE 2
[CE2] bgp 65420
[CE2-bgp-default] peer 20.1.1.2 as-number 200
# Execute the display bgp routing-table vpnv4 command on each PE to view the BGP VPNv4 routes received from the peer PE, and verify that the routes advertised by the peer PE have the SID attribute.
Use PE 1 as an example:
[PE1] display bgp routing-table vpnv4 20.1.1.0 24
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP routing table information of 20.1.1.0/24:
 Rely nexthop    : FE80::3419:41FF:FE28:331
 Original nexthop: 4::4
 Out interface   : GigabitEthernet1/0/2
 Route age       : 00h07m07s
 OutLabel        : 3
 Ext-Community   : <RT: 100:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : End.DT4 SID <40::1:2>
 AS-path         : 200
 Origin          : incomplete
 Source type     : local
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel policy   : NULL
 Rely tunnel IDs : N/A
# Execute the display ip routing-table vpn-instance command on each PE to view IPv4 routing table information, and verify that each PE has a route destined for the remote CE and the next hop of the route is the End.DT4 SID of the route.
20.1.1.0/24        BGP     255 0           40::            GE1/0/2
[CE1] ping 20.1.1.1
Ping 20.1.1.1 (20.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=3.000 ms
56 bytes from 20.1.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 20.1.1.1: icmp_seq=2 ttl=253 time=3.000 ms
56 bytes from 20.1.1.1: icmp_seq=3 ttl=253 time=3.000 ms
round-trip min/avg/max/std-dev = 2.000/2.600/3.000/0.490 ms
Configuration files
CE 1
 sysname CE1
bgp 65410
  import-route direct
PE 1
 sysname PE1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 101::1/96
bgp 100
 router-id 1.1.1.1
  peer 4::4 enable
  peer 2::2 enable
   import-route direct
 locator abc ipv6-prefix 10:: 96 static 8
ASBR 1
 sysname ASBR1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 101::2/96
 ipv6 address 202::1/96
bgp 100
 router-id 2.2.2.2
  network 10:: 64
  peer 1::1 enable
  peer 202::2 enable
ASBR 2
 sysname ASBR2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 303::1/96
 ipv6 address 202::2/96
bgp 200
 router-id 3.3.3.3
  network 40:: 64
  peer 4::4 enable
  peer 202::1 enable
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 303::2/96
bgp 200
 router-id 4.4.4.4
  peer 1::1 enable
  peer 3::3 enable
   import-route direct
CE 2
 sysname CE2
bgp 65420
  import-route direct
As shown in Figure 4, the carrier network is an IPv6 network, and the private network is an IPv4 network. PE 1, P, and PE 2 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Two SRv6 TE policies are established for IPv4 L3VPN traffic forwarding and returning between PE 1 and PE 2. On PE 1 and PE 2, a routing policy is used to set the color attribute of VPNv4 routes, steering VPN traffic to the specified SRv6 TE policies.
Figure 4 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/2
20.1.1.1/24
Loop0
11.11.11.11/32
Loop0
22.22.22.22/32
PE 1
Loop1
1::1/128
P
Loop1
2::2/128
GE1/0/1
10.1.1.2/24
GE1/0/1
3001::2/96
GE1/0/2
2001::1/96
GE1/0/2
2001::2/96
PE 2
Loop1
3::3/128
GE1/0/1
3001::1/96
GE1/0/2
30.1.1.2/24
If various tunnels exist in the network, such as SRv6 TE policies and SR-MPLS TE policies, and those tunnels have the same color value, you must use a routing policy to set the color attribute of the related routes. Meanwhile, you must configure a tunnel policy to ensure that the specified SRv6 TE policy is preferred during tunnel selection.
Procedures
Configuring CE 1
<CE1> system-view
[CE1] sysname CE1
[CE1] bgp 200
Configuring PE 1
<PE1> system-view
[PE1] sysname PE1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Create an MP-IBGP peer relationship between PE 1 and PE 2.
# Enable support for recursing routes that guide traffic forwarding between PE 1 and PE 2 to SRv6 TE Policy.
[PE1-segment-routing-ipv6-locator-abc] opcode 1 end
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering
# Configure an SRv6 TE policy.
[PE1-segment-routing-ipv6] traffic-engineering
[PE1-srv6-te] srv6-policy locator abc
[PE1-srv6-te] segment-list s1
[PE1-srv6-te-sl-s1] index 10 ipv6 200:1::1
[PE1-srv6-te-sl-s1] index 20 ipv6 300:1::1
[PE1-srv6-te-sl-s1] quit
[PE1-srv6-te] policy p1
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 3::3
[PE1-srv6-te-policy-p1] candidate-paths
[PE1-srv6-te-policy-p1-path] preference 10
[PE1-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE1-srv6-te-policy-p1-path-pref-10] quit
[PE1-srv6-te-policy-p1-path] quit
[PE1-srv6-te-policy-p1] quit
[PE1-srv6-te] quit
# Configure a routing policy to steer VPN service traffic to the specified SRv6 TE policy. Meanwhile, configure a tunnel policy to ensure that the SRv6 TE policy is preferred during tunnel selection.
[PE1] route-policy a permit node 10
[PE1-route-policy-a-10] apply extcommunity color 00:10
[PE1-route-policy-a-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 3::3 route-policy a import
[PE1] tunnel-policy a
[PE1-tunnel-policy-a] select-seq srv6-policy load-balance-number 1
[PE1-tunnel-policy-a] quit
[PE1-vpn-instance-vpn1] tnl-policy a
Configuring P
<P> system-view
[P] sysname P
[P] isis 1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 00.0000.0000.0002.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 1
[P-LoopBack1] ipv6 address 2::2 128
[P-LoopBack1] isis ipv6 enable 1
[P-LoopBack1] quit
[P] interface gigabitethernet 1/0/2
[P-GigabitEthernet1/0/2] ipv6 address 2001::2 96
[P-GigabitEthernet1/0/2] isis ipv6 enable 1
[P-GigabitEthernet1/0/2] quit
[P] interface gigabitethernet 1/0/1
[P-GigabitEthernet1/0/1] ipv6 address 3001::2 96
[P-GigabitEthernet1/0/1] isis ipv6 enable 1
[P-GigabitEthernet1/0/1] quit
# Configure a locator and enable IS-IS to advertise the locator.
[P] segment-routing ipv6
[P-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 96 static 8
[P-segment-routing-ipv6-locator-abc] opcode 1 end
[P-segment-routing-ipv6-locator-abc] quit
[P-segment-routing-ipv6] quit
[P] isis 1
[P-isis-1-ipv6] segment-routing ipv6 locator abc
[P-isis-1] quit
Configuring PE 2
<PE2> system-view
[PE2] sysname PE2
[PE2] isis 1
[PE2-isis-1] network-entity 00.0000.0000.0003.00
[PE2-isis-1] quit
[PE2-LoopBack1] ipv6 address 3::3 128
[PE2-GigabitEthernet1/0/1] ipv6 address 3001::1 96
[PE2-GigabitEthernet1/0/1] isis ipv6 enable 1
[PE2-GigabitEthernet1/0/2] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/0/2] ip address 20.1.1.2 24
[PE2] bgp 100
[PE2-bgp-default] router-id 3.3.3.3
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 96 static 8
[PE2-segment-routing-ipv6-locator-abc] opcode 1 end
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering
[PE2-segment-routing-ipv6] traffic-engineering
[PE2-srv6-te] srv6-policy locator abc
[PE2-srv6-te] segment-list s1
[PE2-srv6-te-sl-s1] index 10 ipv6 200:1::1
[PE2-srv6-te-sl-s1] index 20 ipv6 100:1::1
[PE2-srv6-te-sl-s1] quit
[PE2-srv6-te] policy p1
[PE2-srv6-te-policy-p1] color 10 end-point ipv6 1::1
[PE2-srv6-te-policy-p1] candidate-paths
[PE2-srv6-te-policy-p1-path] preference 10
[PE2-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE2-srv6-te-policy-p1-path-pref-10] quit
[PE2-srv6-te-policy-p1-path] quit
[PE2-srv6-te-policy-p1] quit
[PE2-srv6-te] quit
[PE2] route-policy a permit node 10
[PE2-route-policy-a-10] apply extcommunity color 00:10
[PE2-route-policy-a-10] quit
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 route-policy a import
[PE2] tunnel-policy a
[PE2-tunnel-policy-a] select-seq srv6-policy load-balance-number 1
[PE2-tunnel-policy-a] quit
[PE2-vpn-instance-vpn1] tnl-policy a
Configuring CE 2
<CE2> system-view
[CE2] sysname CE2
[CE2-GigabitEthernet1/0/2] ip address 20.1.1.1 24
[CE2] bgp 300
# On PE 1, execute the display segment-routing ipv6 te policy command to display detailed SRv6 TE policy information. The command output shows that the Status field for the SRv6 TE policy is Up.
[PE1] display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 End-point: 3::3
 Name from BGP:
 BSID:
  Mode: Dynamic             Type: Type_2              Request state: Succeeded
  Current BSID: 100:1::1:0  Explicit BSID: -          Dynamic BSID: 100:1::1:0
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Up
 Up time: 2021-11-17 16:21:17
 Down time: 2021-11-17 15:54:22
 Hot backup: Not configured
 Statistics: Not configured
  Statistics by service class: Not configured
 Drop-upon-invalid: Disabled
 BFD trigger path-down: Disabled
 SBFD: Not configured
 BFD Echo: Not configured
 Forwarding index: 2150629377
 Service-class: -
 Rate-limit: -
 Encapsulation mode: -
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1          BGP paths: 0          PCEP paths: 0
 Candidate paths:
  Preference : 10
   CPathName:
   Instance ID: 0          ASN: 0          Node address: 0.0.0.0
   Peer address:  ::
   Optimal: Y              Flags: V/A
   Explicit SID list:
    ID: 1                     Name: s1
    Weight: 1                 Forwarding index: 2149580802
    State: Up                 State(-): -
Active path MTU: 1428 bytes
# On PE 1, execute the display ip routing-table vpn-instance vpn1 22.22.22.22 verbose command to view detailed information about VPN route 22.22.22.22. The command output shows that VPN route 22.22.22.22/32 uses SRv6 TE policy p1 as the output interface.
Summary count : 1
  Process ID: 0
   SubProtID: 0x1                       Age: 00h30m45s
      AttrID: 0x5                  Neighbor: 3::3
       Flags: 0x80010060        OrigNextHop: 3::3
       Label: NULL              RealNextHop: FE80::6033:29FF:FEAE:307
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: p1
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: 0x80300001        IPInterface: GigabitEthernet1/0/2
 BkTunnel ID: Invalid         BkIPInterface: N/A
        Dscp: N/A                       Exp: N/A
  SRTunnelID: 0x80300001          StatFlags: 0x0
    SID Type: N/A                       SID: 300:1::1:0
       BkSID: N/A                       NID: Invalid
    FlushNID: 0x80300001              BkNID: Invalid
CommBlockLen: 0
Configuration files
CE 1
 sysname CE1
 combo enable fiber
interface LoopBack0
bgp 200
  import-route direct
PE 1
 sysname PE1
isis 1
 cost-style wide
tunnel-policy a
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 combo enable copper
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 3::3 enable
   import-route direct
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
P
 sysname P
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 isis ipv6 enable 1
 combo enable copper
 isis ipv6 enable 1
  opcode 1 end
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 combo enable copper
 isis ipv6 enable 1
 combo enable copper
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
   import-route direct
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
CE 2
 sysname CE2
interface LoopBack0
 combo enable copper
bgp 300
  import-route direct
As shown in Figure 5, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1 and ASBR 1 run in AS 100. PE 2 and ASBR 2 run in AS 200. IS-IS is used for intra-AS IPv6 network interconnectivity within AS 100 and AS 200. An inter-AS SRv6 TE policy is statically configured between PE 1 and PE 2 to carry IPv4 L3VPN traffic.
Figure 5 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/1
20.1.1.1/24
PE 1
Loop1
1::1/128
PE 2
Loop1
4::4/128
GE1/0/1
10.1.1.2/24
GE1/0/1
20.1.1.2/24
GE1/0/2
1001::1/96
GE1/0/2
2002::1/96
ASBR 1
Loop1
2::2/128
ASBR 2
Loop1
3::3/128
GE1/0/1
1001::2/96
GE1/0/1
2002::2/96
GE1/0/2
3003::1/96
GE1/0/2
3003::2/96
Procedures
Configuring CE 1
[CE1] bgp 65410
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1-GigabitEthernet1/0/2] ipv6 address 1001::1 96
[PE1] bgp 100
[PE1-segment-routing-ipv6-locator-abc] opcode hex ::10 end-x interface gigabitethernet 1/0/2 nexthop 1001::2 no-psp
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator abc auto-sid-disable
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-srv6-te-sl-s1] index 1 ipv6 100:1::100
[PE1-srv6-te-sl-s1] index 2 ipv6 200:1::100
[PE1-srv6-te-sl-s1] index 3 ipv6 300:1::100
[PE1-srv6-te] policy policy1
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 4::4
[PE1-srv6-te] quit
[PE1] route-policy as100 permit node 10
[PE1-route-policy-as100-10] apply extcommunity color 00:10
[PE1-route-policy-as100-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 4::4 route-policy as100 import
[PE1] tunnel-policy as100
[PE1-tunnel-policy-as100] select-seq srv6-policy load-balance-number 1
[PE1-tunnel-policy-as100] quit
[PE1-vpn-instance-vpn1] tnl-policy as100
Configuring ASBR 1
[ASBR1] isis 1
[ASBR1-isis-1] quit
[ASBR1-GigabitEthernet1/0/1] ipv6 address 1001::2 96
[ASBR1-GigabitEthernet1/0/2] ipv6 address 3003::1 96
[ASBR1] bgp 100
[ASBR1-bgp-default] peer 3003::2 as-number 200
[ASBR1-bgp-default] peer 3003::2 ebgp-max-hop 255
[ASBR1-bgp-default-ipv6] peer 3003::2 enable
# Configure SRv6 BGP EPE and specify a static SRv6 SID for ASBR 2.
[ASBR1] segment-routing ipv6
[ASBR1-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 96 static 8
[ASBR1-segment-routing-ipv6-locator-abc] opcode hex ::20 end-x interface GigabitEthernet1/0/1 nexthop 1001::1
[ASBR1-segment-routing-ipv6-locator-abc] quit
[ASBR1-segment-routing-ipv6] quit
[ASBR1] bgp 100
[ASBR1-bgp-default] segment-routing ipv6 egress-engineering locator abc
[ASBR1-bgp-default] peer 3003::2 egress-engineering srv6 static-sid no-psp-usp 200:1::100
[ASBR1] ipv6 prefix-list as100 index 10 permit 400:1:: 64
[ASBR1] isis 1
[ASBR1-isis-1] quit
Configuring ASBR 2
[ASBR2] isis 1
[ASBR2-isis-1] quit
[ASBR2-GigabitEthernet1/0/1] ipv6 address 2002::2 96
[ASBR2-GigabitEthernet1/0/2] ipv6 address 3003::2 96
[ASBR2] bgp 200
[ASBR2-bgp-default] peer 3003::1 as-number 100
[ASBR2-bgp-default] peer 3003::1 ebgp-max-hop 255
[ASBR2-bgp-default-ipv6] peer 3003::1 enable
# Configure SRv6 BGP EPE and specify a static SRv6 SID for ASBR 1.
[ASBR2] segment-routing ipv6
[ASBR2-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 96 static 8
[ASBR2-segment-routing-ipv6-locator-abc] opcode hex ::10 end-x interface GigabitEthernet1/0/1 nexthop 2002::1
[ASBR2-segment-routing-ipv6-locator-abc] quit
[ASBR2-segment-routing-ipv6] quit
[ASBR2] bgp 200
[ASBR2-bgp-default] segment-routing ipv6 egress-engineering locator abc
[ASBR2-bgp-default]  peer 3003::1 egress-engineering srv6 static-sid no-psp-usp 300:1::200
[ASBR2] ipv6 prefix-list as200 index 10 permit 100:1:: 64
[ASBR2] isis 1
[ASBR2-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 200
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 400:1:: 96 static 8
[PE1-segment-routing-ipv6-locator-abc] opcode hex ::20 end-x interface GigabitEthernet1/0/2 nexthop 2002::2 no-psp
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc auto-sid-disable
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-srv6-te-sl-s1] index 1 ipv6 400:1::200
[PE2-srv6-te-sl-s1] index 2 ipv6 300:1::200
[PE2-srv6-te-sl-s1] index 3 ipv6 200:1::200
[PE2-srv6-te] policy policy1
[PE2-srv6-te-policy-p1] binding-sid ipv6 400:1::1
[PE2-srv6-te] quit
[PE2] route-policy as200 permit node 10
[PE2-route-policy-as200-10] apply extcommunity color 00:10
[PE2-route-policy-as200-10] quit
[PE2] bgp 200
[PE2-bgp-default-vpnv4] peer 1::1 route-policy as200 import
[PE2] tunnel-policy as200
[PE2-tunnel-policy-as200] select-seq srv6-policy load-balance-number 1
[PE2-tunnel-policy-as200] quit
[PE2-vpn-instance-vpn1] tnl-policy as200
Configuring CE 2
[CE2] bgp 65420
Name/ID: policy1/0
 Color: 10
 End-point: 4::4
 Name from BGP:
 BSID:
  Mode: Explicit            Type: Type_2              Request state: Succeeded
  Current BSID: 100:1::1    Explicit BSID: 100:1::1   Dynamic BSID: -
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Up
 Up time: 2021-11-27 16:26:20
 Down time: 2021-11-27 16:25:55
 Service-class: -
 Rate-limit: -
 Candidate paths:
  Preference : 10
   CPathName:
   Peer address:  ::
   Explicit SID list:
    ID: 1                     Name: s1
# On PE 1, execute the display ip routing-table vpn-instance vpn1 command to view detailed information about VPN route 20.1.1.0/24. The command output shows that VPN route 20.1.1.0/24 uses SRv6 TE policy p1 as the output interface.
20.1.1.0/24        BGP     255 0           4::4            policy1
[CE1] ping 20.1.1.1
Configuration files
CE 1
 sysname CE1
bgp 65410
  import-route direct
PE 1
 sysname PE1
 tnl-policy as100
isis 1
 cost-style wide
tunnel-policy as100
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 1001::1/96
bgp 100
 router-id 1.1.1.1
  peer 4::4 enable
  peer 2::2 enable
   import-route direct
  opcode hex ::10 end-x interface GigabitEthernet1/0/2 nexthop 1001::2 no-psp
 traffic-engineering
  segment-list s1
  policy policy1
   binding-sid ipv6 100:1::1
   candidate-paths
    preference 10
ASBR 1
 sysname ASBR1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 1001::2/96
 ipv6 address 3003::1/96
bgp 100
 router-id 2.2.2.2
  peer 1::1 enable
  peer 3003::2 enable
ASBR 2
 sysname ASBR2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 ipv6 address 3003::2/96
bgp 200
 router-id 3.3.3.3
  peer 4::4 enable
  peer 3003::1 enable
 ipv6 prefix-list as200 index 30 permit 1::1 128
PE 2
 sysname PE2
 tnl-policy as200
isis 1
 cost-style wide
tunnel-policy as200
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 200
 router-id 4.4.4.4
  peer 1::1 enable
  peer 3::3 enable
   import-route direct
 traffic-engineering
  segment-list s1
  policy policy1
   candidate-paths
    preference 10
     explicit segment-list astoas
CE 2
 sysname CE2
bgp 65420
  import-route direct
As shown in Figure 6, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1, P, and PE 2 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Two SRv6 TE policies are statically configured between PE 1 and PE 2 to carry IPv4 EVPN L3VPN traffic. On PE 1 and PE 2, a routing policy is used to set the color attribute of EVPN routes, steering IPv4 EVPN L3VPN traffic to the specified SRv6 TE policies.
Figure 6 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10.1.1.1/24
CE 2
GE1/0/2
20.1.1.1/24
PE 1
Loop1
1::1/128
PE 2
Loop1
3::3/128
GE1/0/1
10.1.1.2/24
GE1/0/1
20.1.1.2/24
GE1/0/2
1001::1/96
GE1/0/2
2001::1/96
P
Loop1
2::2/128
GE1/0/1
1001::2/96
GE1/0/2
2001::2/96
Procedures
Configuring CE 1
[CE1] bgp 200
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Establish an BGP EVPN peer relationship between the PEs.
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 3::3 enable
[PE1-bgp-default-evpn] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc evpn
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE1-srv6-te] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 3::3 route-policy a import
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P-GigabitEthernet1/0/2] ipv6 address 1001::2 96
[P-GigabitEthernet1/0/1] ipv6 address 2001::2 96
[P] isis 1
[P-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-GigabitEthernet1/0/2] ipv6 address 2001::1 96
[PE2] bgp 100
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1::1 enable
[PE2-bgp-default-evpn] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc evpn
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE2-srv6-te] quit
[PE2] bgp 100
[PE2-bgp-default-evpn] peer 1::1 route-policy a import
Configuring CE 2
[CE2] bgp 300
Name/ID: p1/0
 Color: 10
 End-point: 3::3
 Name from BGP:
 BSID:
  Current BSID: 100:1::1:3  Explicit BSID: -          Dynamic BSID: 100:1::1:3
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Up
 Up time: 2021-11-23 19:31:35
 Down time: 2021-11-23 19:27:37
 Service-class: -
 Rate-limit: -
 Candidate paths:
  Preference : 10
   CPathName:
   Peer address:  ::
   Explicit SID list:
    ID: 1                     Name: s1
# On PE 1, execute the display ip routing-table vpn-instance vpn1 20.1.1.0 24 command to view detailed information about VPN route 20.1.1.0/24. The command output shows that VPN route 20.1.1.0/24 uses SRv6 TE policy p1 as the output interface.
[PE1] display ip routing-table vpn-instance vpn1 20.1.1.0 24
Summary count : 1
20.1.1.0/24        BGP     255 0           3::3            p1
[CE1] ping 20.1.1.1
Ping 20.1.1.1 (20.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=2.000 ms
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
Configuration files
CE 1
 sysname CE1
bgp 200
  import-route direct
PE 1
 sysname PE1
 tnl-policy a
isis 1
 cost-style wide
tunnel-policy a
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 3::3 enable
   import-route direct
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
P
 sysname P
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
  opcode 1 end
PE 2
 sysname PE2
 tnl-policy a
isis 1
 cost-style wide
tunnel-policy a
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
   import-route direct
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
CE 2
 sysname CE2
bgp 300
  import-route direct
As shown in Figure 7, the core network is an IPv6 network, and the private network is also an IPv6 network. Within the core network, EVPN L3VPN over SRv6 BE is deployed between PE devices, using SRv6 tunnels to transmit VPN traffic.
·     Both CE 1 and CE 2 run in VPN 1.
·     PE 1 and CE 1 establish an EBGP peer relationship to  exchange VPN routing information. PE 2 and CE 2 establish an EBGP peer relationship to  exchange VPN routing information.
·     The PEs within the same autonomous system run IS-IS for IPv6 network connectivity, and use MP-IBGP to exchange EVPN routing information.
Figure 7 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
1000::1/96
CE 2
GE1/0/1
3000::1/96
PE 1
Loop1
1::1/128
PE 2
Loop1
3::3/128
GE1/0/1
1000::2/96
GE1/0/1
3000::2/96
GE1/0/2
2001::1/96
GE1/0/2
2002::1/96
P
Loop1
2::2/128
GE1/0/1
2001::2/96
GE1/0/2
2002::2/96
Procedures
Configuring CE 1
[CE1-GigabitEthernet1/0/1] ipv6 address 1000::1 96
[CE1] bgp 200
[CE1-bgp-default] peer 1000::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 1000::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1-GigabitEthernet1/0/1] ipv6 address 1000::2 96
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 1000::1 as-number 200
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] peer 1000::1 enable
[PE1-bgp-default-ipv6-vpn1] import-route direct
[PE1-bgp-default-ipv6-vpn1] quit
# Specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
# Create a locator that contains the destination address (End.DT6 SID) for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
[PE1-segment-routing-ipv6] locator evpn ipv6-prefix 1:2:: 96 static 16
[PE1-segment-routing-ipv6-locator-evpn] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator evpn
[PE1-isis-1] quit
# Enable the PE to exchange End.DT6 SIDs with PE 2, and enable support for recursing VPN routes to routes that carry End.DT6 SIDs.
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 locator evpn evpn
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P-GigabitEthernet1/0/2] ipv6 address 2002::2 96
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-GigabitEthernet1/0/1] ipv6 address 3000::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 3000::1 as-number 300
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] peer 3000::1 enable
[PE2-segment-routing-ipv6] locator evpn ipv6-prefix 3:4:: 96 static 16
[PE2-segment-routing-ipv6-locator-evpn] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator evpn
[PE2-isis-1] quit
# Enable the PE to exchange End.DT6 SIDs with PE 1, and enable support for recursing VPN routes to routes that carry End.DT6 SIDs.
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 locator evpn evpn
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring CE 2
[CE2-GigabitEthernet1/0/1] ipv6 address 3000::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 3000::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 3000::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
# Execute the display bgp l2vpn evpn command on each PE to display detailed information about the routes received from the peer PE, and verify that the routes received from the peer PE carry the SID attribute.
[PE1] display bgp l2vpn evpn [5][0][96][3000::]/176
 BGP routing table information of [5][0][96][3000::]/176:
 Rely nexthop    : FE80::A06E:DBFF:FEFC:316
 Original nexthop: 3::3
 Route age       : 00h00m29s
 OutLabel        : 3
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : End.DT6 SID <3:4::1:4>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 Source type     : local
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 IP prefix       : 3000::/96
 Gateway address : ::
 MPLS label      : 3
 Re-orignination : Disable
[CE1] ping ipv6 3000::1
Ping6(56 data bytes) 1000::1 --> 3000::1, press CTRL_C to break
56 bytes from 3000::1, icmp_seq=0 hlim=62 time=3.000 ms
56 bytes from 3000::1, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=3 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=4 hlim=62 time=2.000 ms
--- Ping6 statistics for 3000::1 ---
round-trip min/avg/max/std-dev = 2.000/2.200/3.000/0.400 ms
Configuration files
CE 1
 sysname CE1
 ipv6 address 1000::1/96
bgp 200
  import-route direct
  peer 1000::2 enable
PE 1
 sysname PE1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 1000::2/96
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 3::3 enable
   import-route direct
   peer 1000::1 enable
P
 sysname P
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 3000::2/96
 isis ipv6 enable 1
bgp 100
 router-id 2.2.2.2
  peer 1::1 enable
   import-route direct
   peer 3000::1 enable
CE 2
 sysname CE2
 ipv6 address 3000::1/96
bgp 300
  import-route direct
  peer 3000::2 enable
As shown in Figure 8, the core network is an IPv6 network, and the private network is also an IPv6 network. PE 1, P 1, P 2, and PE 2 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Bidirectional SRv6 BE paths are established between PE 1 and PE 2 to carry IPv6 EVPN L3VPN traffic. To make full use of network resources, those SRv6 BE paths are used for load balancing during traffic forwarding between PE 1 and PE 2.
Figure 8 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
1000::1/96
CE 2
GE1/0/1
4000::1/96
PE 1
Loop1
1::1/128
PE 2
Loop1
4::4/128
GE1/0/1
1000::2/96
GE1/0/1
4000::2/96
GE1/0/2
2001::1/96
GE1/0/2
2002::1/96
GE1/0/3
3001::1/96
GE1/0/3
3002::1/96
P 1
Loop1
2::2/128
P 2
Loop1
2::2/128
GE1/0/1
2001::2/96
GE1/0/1
3001::2/96
GE1/0/2
2002::2/96
GE1/0/2
3002::2/96
Procedures
Configuring CE 1
[CE1] bgp 200
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 4::4 enable
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 4::4 advertise encap-type srv6
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
Configuring P 1
[P1] isis 1
[P1-isis-1] quit
[P1-LoopBack1] quit
Configuring P 2
[P2] isis 1
[P2-isis-1] quit
[P2-LoopBack1] ipv6 address 2::2 128
[P2-LoopBack1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-GigabitEthernet1/0/1] ipv6 address 4000::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 4000::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 4000::1 enable
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
Configuring CE 2
[CE2-GigabitEthernet1/0/1] ipv6 address 4000::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 4000::2 as-number 100
[CE2-bgp-default-ipv6] peer 4000::2 enable
# Execute the display ipv6 routing-table vpn-instance command to view VPN routes. The command output shows that VPN route 4000::1/96 has two output interfaces that can form an ECMP relationship during traffic forwarding.
[PE1] display ipv6 routing-table vpn-instance vpn1 4000::1 96
Summary count : 1
Destination: 4000::/96                                   Protocol  : BGP4+
NextHop    : 200:1::                                     Preference: 255
Interface  : GE1/0/2                                     Cost      : 0
Interface  : GE1/0/3                                     Cost      : 0
[CE1] ping ipv6 4000::1
Ping6(56 data bytes) 1000::1 --> 4000::1, press CTRL_C to break
56 bytes from 4000::1, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=3 hlim=62 time=1.000 ms
56 bytes from 4000::1, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 4000::1 ---
Configuration files
CE 1
 sysname CE1
bgp 200
  import-route direct
  peer 1000::2 enable
PE 1
 sysname PE1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 4::4 enable
   import-route direct
   peer 1000::1 enable
P 1
 sysname P1
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
P 2
 sysname P2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 4000::2/96
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 4.4.4.4
  peer 1::1 enable
   import-route direct
   peer 4000::1 enable
CE 2
 sysname CE2
 ipv6 address 4000::1/96
bgp 300
  import-route direct
  peer 4000::2 enable
As shown in Figure 9, the core network is an IPv6 network, and the private network is also an IPv6 network. PE 1, PE 2, and PE 3 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Bidirectional SRv6 BE paths are established between PE 1 and PE 2, and between PE 1 and PE 3 to carry IPv6 EVPN L3VPN traffic. To improve network reliability, FRR is enabled for PE 1. When the primary path fails, FRR quickly steers IPv6 EVPN L3VPN traffic to the backup path.
Figure 9 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
1000::1/96
CE 2
GE1/0/1
4000::1/96
PE 1
Loop1
1::1/128
PE 2
Loop1
4::4/128
GE1/0/1
1000::2/96
GE1/0/1
4000::2/96
GE1/0/2
2001::1/96
GE1/0/2
2002::1/96
GE1/0/3
3001::1/96
GE1/0/3
3002::1/96
P 1
Loop1
2::2/128
P 2
Loop1
2::2/128
GE1/0/1
2001::2/96
GE1/0/1
3001::2/96
GE1/0/2
2002::2/96
GE1/0/2
3002::2/96
CE 1
GE1/0/1
1000::1/96
CE 2
GE1/0/1
4000::1/96
Procedures
Configuring CE 1
[CE1] interface loopback 1
[CE1-LoopBack1] ipv6 address 11::11 128
[CE1-LoopBack1] quit
[CE1] bgp 200
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 2::2 enable
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 2::2 advertise encap-type srv6
# Configure FRR.
[PE1-bgp-default-ipv6-vpn1] pic
# Use static BFD to detect whether the related locator route is reachable. If the locator route is unreachable, primary/backup route switchover will be triggered.
[PE1] bfd static test peer-ipv6 200:1:: source-ipv6 100:1:: discriminator local 10 remote 20
[PE1-bfd-static-session-test] bfd multi-hop min-transmit-interval 100
[PE1-bfd-static-session-test] bfd multi-hop min-receive-interval 100
[PE1-bfd-static-session-test] bfd multi-hop detect-multiplier 3
[PE1-bfd-static-session-test] quit
[PE1] bgp 100
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-GigabitEthernet1/0/1] ipv6 address 2001::2 96
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-GigabitEthernet1/0/2] ipv6 address 2002::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2002::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 2002::1 enable
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2] bfd static test peer-ipv6 100:1:: source-ipv6 200:1:: discriminator local 20 remote 10
[PE2-bfd-static-session-test] bfd multi-hop min-transmit-interval 100
[PE2-bfd-static-session-test] bfd multi-hop min-receive-interval 100
[PE2-bfd-static-session-test] bfd multi-hop detect-multiplier 3
[PE2-bfd-static-session-test] quit
Configuring PE 3
[Sysname] sysname PE3
[PE3] isis 1
[PE3-isis-1] quit
[PE3] interface gigabitethernet 1/0/1
[PE3-GigabitEthernet1/0/1] ipv6 address 3001::2 96
[PE3-GigabitEthernet1/0/1] isis ipv6 enable 1
[PE3-vpn-instance-vpn1] route-distinguisher 300:1
[PE3-GigabitEthernet1/0/2] ip binding vpn-instance vpn1
[PE3-GigabitEthernet1/0/2] ipv6 address 3002::2 96
[PE3] bgp 100
[PE3-bgp-default-vpn1] peer 3002::1 as-number 300
[PE3-bgp-default-vpn1] address-family ipv6 unicast
[PE3-bgp-default-ipv6-vpn1] peer 3002::1 enable
[PE3-bgp-default] address-family l2vpn evpn
[PE3-bgp-default-evpn] peer 1::1 enable
[PE3-bgp-default-evpn] quit
[PE3] isis 1
[PE3-isis-1] quit
[PE3] bgp 100
[PE3-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE3-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
[PE3-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring CE 2
[CE2] interface loopback 1
[CE2-LoopBack1] ipv6 address 22::22 128
[CE2-LoopBack1] quit
[CE2-GigabitEthernet1/0/1] ipv6 address 2002::1 96
[CE2-GigabitEthernet1/0/2] ipv6 address 3002::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 2002::2 as-number 100
[CE2-bgp-default] peer 3002::2 as-number 100
[CE2-bgp-default-ipv6] peer 2002::2 enable
[CE2-bgp-default-ipv6] peer 3002::2 enable
# Execute the display ipv6 routing-table vpn-instance verbose command to view VPN routes. The command output shows that VPN route 22::22/128 has a backup output interface.
[PE1] display ipv6 routing-table vpn-instance vpn1 22::22 128 verbose
Summary count : 1
 Destination: 22::22/128
    Protocol: BGP4+ instance default
  Process ID: 0
   SubProtID: 0x8                       Age: 00h27m38s
  FlushedAge: 00h27m38s
     TableID: 0x10a                  OrigAs: 300
       NibID: 0x2600000a             LastAs: 300
      AttrID: 0x0
    BkAttrID: 0x7                  Neighbor: 2::2
       Label: NULL              RealNextHop: FE80::8099:2EFF:FE26:316
     BkLabel: NULL                BkNextHop: FE80::8099:32FF:FEB6:416
     InLabel: 0              ColorInterface: N/A
    SIDIndex: 0            BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: 200:1::1:4
       BkSID: 300:1::1:4
CommBlockLen: 0                    Priority: Low
[CE1] ping ipv6 22::22
Ping6(56 data bytes) 1000::1 --> 22::22, press CTRL_C to break
56 bytes from 22::22, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 22::22, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 22::22, icmp_seq=2 hlim=62 time=1.000 ms
56 bytes from 22::22, icmp_seq=3 hlim=62 time=1.000 ms
56 bytes from 22::22, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 22::22 ---
round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms
# Shut down GigabitEthernet 1/0/2 on PE 1.
[PE1] interface gigabitethernet 1/0/2
[PE1-GigabitEthernet1/0/2] shutdown
[PE1-GigabitEthernet1/0/2] quit
# Execute the display ipv6 routing-table vpn-instance verbose command on PE 1 to view VPN routes. The command output shows that the output interface for VPN route 22::22/128 has been changed to GigabitEthernet 1/0/3.
Summary count : 1
  Process ID: 0
   SubProtID: 0x8                       Age: 01h24m03s
       NibID: 0x26000007             LastAs: 300
      AttrID: 0x3                  Neighbor: 3::3
       Flags: 0x80010060        OrigNextHop: 300:1::
       Label: NULL              RealNextHop: FE80::843:49FF:FE7B:506
     SRLabel: NULL                Interface: GigabitEthernet1/0/3
   Tunnel ID: Invalid           IPInterface: GigabitEthernet1/0/3
        Dscp: N/A                       Exp: N/A
    SID Type: N/A                       SID: 300:1::1:2
CommBlockLen: 0
Configuration files
CE 1
 sysname CE1
bgp 200
 router-id 11.11.11.11
  import-route direct
  peer 1000::2 enable
PE 1
 sysname PE1
isis 1
 cost-style wide
 network-entity 00.0000.0000.0001.00
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 2::2 enable
  peer 3::3 enable
   pic
   import-route direct
   peer 1000::1 enable
PE 2
 sysname PE2
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 2.2.2.2
  peer 1::1 enable
   import-route direct
   peer 2002::1 enable
PE 3
 sysname PE3
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
   undo advertise l2vpn evpn
   import-route direct
   peer 3002::1 enable
CE 2
 sysname CE2
interface LoopBack1
 ipv6 address 22::22/128
bgp 300
  import-route direct
  peer 2002::2 enable
  peer 3002::2 enable
Example: Statically configuring IPv6 EVPN L3VPN over SRv6 TE Policy
As shown in Figure 10, the core network is an IPv6 network, and the private network is also an IPv6 network. PE 1, P, and PE 2 run in the same autonomous system, and they use IS-IS for IPv6 network connectivity. Two SRv6 TE policies are statically configured between PE 1 and PE 2 to carry IPv6 EVPN L3VPN traffic. On PE 1 and PE 2, a routing policy is used to set the color attribute of EVPN routes, steering IPv6 EVPN L3VPN traffic to the specified SRv6 TE policies.
Figure 10 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
100::1/96
CE 2
GE1/0/2
200::1/96
PE 1
Loop1
1::1/128
PE 2
Loop1
3::3/128
GE1/0/1
100::2/96
GE1/0/1
200::2/96
GE1/0/2
1001::1/96
GE1/0/2
2001::1/96
P
Loop1
2::2/128
GE1/0/1
1001::2/96
GE1/0/2
2001::2/96
Procedures
Configuring CE 1
[Sysname] sysname CE1
[CE1] interface gigabitethernet 1/0/1
[CE1-GigabitEthernet1/0/1] ipv6 address 100::1 96
[CE1-GigabitEthernet1/0/1] quit
[CE1] bgp 200
[CE1-bgp-default] router-id 11.11.11.11
[CE1-bgp-default] peer 100::2 as-number 100
[CE1-bgp-default-ipv6] peer 100::2 enable
[CE1-bgp-default] quit
Configuring PE 1
# Configure IPv6 IS-IS to achieve PE-P interconnects in the backbone network.
[Sysname] sysname PE1
[PE1] isis 1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ipv6 address 1::1 128
[PE1-LoopBack1] isis ipv6 enable 1
[PE1-LoopBack1] quit
[PE1-GigabitEthernet1/0/2] isis ipv6 enable 1
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] quit
[PE1-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet1/0/1] ipv6 address 100::2 96
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 100::1 as-number 200
[PE1-bgp-default-ipv6-vpn1] peer 100::1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 100:1:: 96 static 8
[PE1-segment-routing-ipv6-locator-abc] quit
[PE1-segment-routing-ipv6] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE1-srv6-te] quit
[PE1] bgp 100
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P] isis 1
[P-isis-1] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] isis 1
[PE2-isis-1] cost-style wide
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] isis ipv6 enable 1
[PE2-LoopBack1] quit
[PE2] interface gigabitethernet 1/0/2
[PE2-GigabitEthernet1/0/2] isis ipv6 enable 1
[PE2-GigabitEthernet1/0/2] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 100:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet1/0/1] ipv6 address 200::2 96
[PE2-GigabitEthernet1/0/1] quit
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 200::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 200::1 enable
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 1
[PE2-bgp-default] quit
[PE2] segment-routing ipv6
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE2-srv6-te] quit
[PE2-segment-routing-ipv6] quit
[PE2] bgp 100
Configuring CE 2
[CE2-GigabitEthernet1/0/2] ipv6 address 200::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 200::2 as-number 100
[CE2-bgp-default-ipv6] peer 200::2 enable
Name/ID: p1/0
 Color: 10
 End-point: 3::3
 Name from BGP:
 BSID:
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Up
 Service-class: -
 Rate-limit: -
 Candidate paths:
  Preference : 10
   CPathName:
   Peer address:  ::
   Explicit SID list:
    ID: 1                     Name: s1
# On PE 1, execute the display ip routing-table vpn-instance vpn1 200::1 96 command to view detailed information about VPN route 200::1/96. The command output shows that VPN route 200::1/96 uses SRv6 TE policy p1 as the output interface.
[PE1] display ipv6 routing-table vpn-instance vpn1 200::1 96
Summary count : 1
Destination: 200::/96                                    Protocol  : BGP4+
NextHop    : 3::3                                        Preference: 255
Interface  : p1                                          Cost      : 0
[CE1] >ping ipv6 200::1
Ping6(56 data bytes) 100::1 --> 200::1, press CTRL_C to break
56 bytes from 200::1, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=1 hlim=62 time=1.000 ms
56 bytes from 200::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=3 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 200::1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 mss
Configuration files
CE 1
 sysname CE1
 ipv6 address 100::1/96
bgp 200
  import-route direct
  peer 100::2 enable
PE 1
 sysname PE1
 tnl-policy a
isis 1
 cost-style wide
tunnel-policy a
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 100::2/96
 isis ipv6 enable 1
bgp 100
 router-id 1.1.1.1
  peer 3::3 enable
   import-route direct
   peer 100::1 enable
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
P
 sysname P
isis 1
 cost-style wide
interface LoopBack1
 isis ipv6 enable 1
 isis ipv6 enable 1
 isis ipv6 enable 1
  opcode 1 end
PE 2
 sysname PE2
 tnl-policy a
isis 1
 cost-style wide
tunnel-policy a
interface LoopBack1
 isis ipv6 enable 1
 ipv6 address 200::2/96
 isis ipv6 enable 1
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
   import-route direct
   peer 200::1 enable
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
CE 2
 sysname CE2
 ipv6 address 200::1/96
bgp 300
 router-id 22.22.22.22
  import-route direct
  peer 200::2 enable
Example: Configuring EVPN VPWS over SRv6 BE (CE dual-homing)
The user network has two sites. The edge device at Site 1 is CE 1 and the edge device at Site 2 is CE 2. PE 1, PE 2, and PE 3 run OSPFv3 to achieve IPv6 network connectivity. Site 1 is a dual-homed site with CE 1 attached to both PE 1 and PE 2 through link aggregation. Site 2 is a single-homed site with CE 2 attached only to PE 3. CE 1 and CE 2 use an SRv6 tunnel established across the backbone network to achieve Layer 2 communication between Site 1 and Site 2.
Figure 11 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1::1/128
CE 1
RAGG1
100::1/64
N/A
CE 2
100::2/64
10::1/64
PE 3
Loop0
3::3/128
20::1/64
N/A
PE 2
Loop0
2::2/128
10::3/64
N/A
30::3/64
30::2/64
20::2/64
Procedures
Configuring CE 1
# Create Layer 3 aggregate interface 1, set the link aggregation mode to dynamic, and then assign an IP address and subnet mask to the interface.
[CE1] interface route-aggregation 1
[CE1-Route-Aggregation1] link-aggregation mode dynamic
[CE1-Route-Aggregation1] ipv6 address 100::1 64
[CE1-Route-Aggregation1] quit
# Add GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
[CE1-GigabitEthernet1/0/1] port link-aggregation group 1
[CE1] interface gigabitethernet 1/0/2
[CE1-GigabitEthernet1/0/2] port link-aggregation group 1
[CE1-GigabitEthernet1/0/2] quit
Configuring PE 1
# Configure OSPFv3.
[PE1] ospfv3
[PE1-ospfv3-1] router-id 1.1.1.1
[PE1-ospfv3-1] segment-routing ipv6 locator aaa
[PE1-ospfv3-1] area 0
[PE1-ospfv3-1-area-0.0.0.0] quit
[PE1-ospfv3-1] quit
# Configure the Loopback0 interface.
[PE1] interface loopback 0
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] ospfv3 1 area 0
[PE1-LoopBack0] quit
# Enable Layer 2 VPN (L2VPN).
[PE1] l2vpn enable
# Configure GigabitEthernet 1/0/2. This interface is connected to PE 3.
[PE1-GigabitEthernet1/0/2] ipv6 address 10::1/64
[PE1-GigabitEthernet1/0/2] ospfv3 1 area 0
# Configure GigabitEthernet1/0/3. This interface is connected to PE 2.
[PE1] interface gigabitethernet 1/0/3
[PE1-GigabitEthernet1/0/3] ipv6 address 20::1/64
[PE1-GigabitEthernet1/0/3] ospfv3 1 area 0
[PE1-GigabitEthernet1/0/3] quit
# Establish an IBGP peer relationship with PE 2 and PE 3 separately, and then enable route advertisement based on BGP EVPN.
[PE1] bgp 100
[PE1-bgp-default] peer 2::2 connect-interface loopback 0
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
# On  (connected to Site 1), configure an ESI and set the redundancy mode.
PE1] interface
PE1-] esi 1.1.1.1.1
PE1-] evpn redundancy-mode all-active
PE1-] quit
# Create cross-connect group vpna, create an EVPN instance for the cross-connect group, enable the EVPN instance to use SRV6 encapsulation, configure an RD and RTs for the EVPN instance, and then enable SID-based route recursion.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] evpn encapsulation srv6
[PE1-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE1-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE1-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE1-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE1-xcg-vpna-evpn-srv6] quit
# Create cross-connect pw1, bind GigabitEthernet 1/0/1 to the cross-connect, and then create an SRv6 tunnel in the cross-connect to achieve AC-SRv6 tunnel association.
PE1-xcg-vpna] connection pw1
PE1-xcg-vpna-pw1] ac interface
PE1-xcg-vpna-pw1-] quit
PE1-xcg-vpna-pw1] evpn local-service-id 1 remote-service-id 2
PE1-xcg-vpna-pw1-1-2] quit
PE1-xcg-vpna-pw1] segment-routing ipv6 locator aaa
PE1-xcg-vpna-pw1] quit
PE1-xcg-vpna] quit
# Specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
# Configure a locator, which is used for requesting End.DX2 SIDs.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 111:: 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] quit
Configuring PE 2
# Configure OSPFv3.
[PE2] ospfv3
[PE2-ospfv3-1] router-id 2.2.2.2
[PE2-ospfv3-1] segment-routing ipv6 locator aaa
[PE2-ospfv3-1] area 0.0.0.0
[PE2-ospfv3-1-area-0.0.0.0] quit
[PE2-ospfv3-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ipv6 address 2::2 128
[PE2-LoopBack0] ospfv3 1 area 0
[PE2-LoopBack0] quit
[PE2] l2vpn enable
# Configure GigabitEthernet 1/0/3. This interface is connected to PE 1.
[PE2] interface gigabitethernet 1/0/3
[PE2-GigabitEthernet1/0/3] ipv6 address 20::2 64
[PE2-GigabitEthernet1/0/3] ospfv3 1 area 0
[PE2-GigabitEthernet1/0/3] quit
[PE2-GigabitEthernet1/0/2] ipv6 address 30::2 64
[PE2-GigabitEthernet1/0/2] ospfv3 1 area 0
# Establish an IBGP peer relationship with PE 1 and PE 3 separately, and then enable route advertisement based on BGP EVPN.
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default] peer 3::3 as-number 100
[PE2-bgp-default] peer 3::3 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 3::3 enable
[PE2-bgp-default-evpn] peer 3::3 advertise encap-type srv6
# On GigabitEthernet 1/0/1 (connected to Site 1), configure an ESI and set the redundancy mode.
PE2] interface
PE2-] esi 1.1.1.1.1
PE2-] evpn redundancy-mode all-active
PE2-] quit
[PE2] xconnect-group vpna
[PE2-xcg-vpna] evpn encapsulation srv6
[PE2-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE2-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE2-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE2-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE2-xcg-vpna-evpn-srv6] quit
PE2-xcg-vpna] connection pw1
PE2-xcg-vpna-pw1] ac interface
PE2-xcg-vpna-pw1-] quit
PE2-xcg-vpna-pw1] evpn local-service-id 1 remote-service-id 2
PE2-xcg-vpna-pw1-1-2] quit
PE2-xcg-vpna-pw1] segment-routing ipv6 locator aaa
PE2-xcg-vpna-pw1] quit
PE2-xcg-vpna] quit
[PE2-segment-routing-ipv6] encapsulation source-address 2::2
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 222:: 96 static 8
[PE2-segment-routing-ipv6-locator-aaa] quit
Configuring PE 3
# Configure OSPFv3.
[PE3] ospfv3
[PE3-ospfv3-1] router-id 3.3.3.3
[PE3-ospfv3-1] segment-routing ipv6 locator aaa
[PE3-ospfv3-1] area 0
[PE3-ospfv3-1-area-0.0.0.0] quit
[PE3-ospfv3-1] quit
# Configure the LoopBack0 interface.
[PE3] interface loopback 0
[PE3-LoopBack0] ipv6 address 3::3 128
[PE3-LoopBack0] ospfv3 1 area 0
[PE3-LoopBack0] quit
[PE3] l2vpn enable
# Configure GigabitEthernet 1/0/2. This interface is connected to PE 1.
[PE3] interface gigabitethernet 1/0/2
[PE3-GigabitEthernet1/0/2] ipv6 address 10::3 64
[PE3-GigabitEthernet1/0/2] ospfv3 1 area 0
[PE3-GigabitEthernet1/0/2] quit
[PE3] interface gigabitethernet 1/0/3
[PE3-GigabitEthernet1/0/3] ipv6 address 30::3 64
[PE3-GigabitEthernet1/0/3] ospfv3 1 area 0
[PE3-GigabitEthernet1/0/3] quit
# Establish an IBGP peer relationship with PE 1 and PE 2 separately, and then enable route advertisement based on BGP EVPN.
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 0
[PE3-bgp-default] peer 2::2 as-number 100
[PE3-bgp-default] peer 2::2 connect-interface loopback 0
[PE3-bgp-default-evpn] peer 2::2 enable
[PE3-bgp-default-evpn] peer 2::2 advertise encap-type srv6
[PE3-bgp-default] quit
[PE3] xconnect-group vpna
[PE3-xcg-vpna] evpn encapsulation srv6
[PE3-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE3-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE3-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE3-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE3-xcg-vpna-evpn-srv6] quit
[PE3-xcg-vpna] connection pw1
[PE3-xcg-vpna-pw1] ac interface gigabitethernet 1/0/1
[PE3-xcg-vpna-pw1-GigabitEthernet1/0/1] quit
[PE3-xcg-vpna-pw1] evpn local-service-id 2 remote-service-id 1
[PE3-xcg-vpna-pw1-1-2] quit
[PE3-xcg-vpna-pw1] segment-routing ipv6 locator aaa
[PE3-xcg-vpna-pw1] quit
[PE3-xcg-vpna] quit
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 3::3
[PE3-segment-routing-ipv6] locator aaa ipv6-prefix 333:: 96 static 8
[PE3-segment-routing-ipv6-locator-aaa] quit
[PE3-segment-routing-ipv6] quit
Configuring CE 2
[Sysname] sysname CE2
[CE2] interface gigabitethernet 1/0/1
[CE2-GigabitEthernet1/0/1] ipv6 address 100::2 64
[CE2-GigabitEthernet1/0/1] quit
# View L2VPN SRv6 information on PE 1, and verify that an SRv6 tunnel has been established between PE 1 and PE 3.
PE1] display l2vpn peer srv6
Total number of SRv6 Tunnels: 1
1 up, 0 blocked, 0 down
Xconnect-group Name: vpna
   Peer            : 3::3
   Flag            : Main
   State           : Up
   Remote SrvID    : 2
# View L2VPN SRv6 forwarding information on PE 1, and verify that information about the SRv6 tunnel is as expected, such as input SID and output SID.
PE1] display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of SRv6 tunnels: 1, 1 up, 0 blocked, 0 down
Xconnect-group Name : vpna
Connection Name     : pw1
Link ID             : 0x1         Type: BE    State: Up
In SID              : 111::1:0:3
Out SID             : 333::1:0:3
# Verify that CE 1 and CE 2 can ping each other. When the link between CE 1 and PE 1 or between CE 2 and PE 2 fails, CE 1 and CE 2 can still ping each other.
Configuration files
CE 1
 sysname CE1
interface Route-Aggregation1
 ipv6 address 100::1/64
 port link-mode route
PE 1
 sysname PE1
ospfv3 1
 area 0.0.0.0
interface LoopBack0
 ospfv3 1 area 0.0.0.0
 ipv6 address 1::1/128
 esi 0001.0001.0001.0001.0001
 evpn redundancy-mode single-active
bgp 100
 router-id 1.1.1.1
 peer 2::2 connect-interface LoopBack0
 peer 3::3 connect-interface LoopBack0
  peer 2::2 enable
  peer 3::3 enable
xconnect-group vpna
 connection pw1
  ac interface GigabitEthernet1/0/1
PE 2
 sysname PE2
ospfv3 1
 area 0.0.0.0
interface LoopBack0
 ipv6 address 2::2/128
 ipv6 address 30::2/64
 ipv6 address 20::2/64
bgp 100
 router-id 2.2.2.2
 peer 1::1 connect-interface LoopBack0
  peer 1::1 enable
  peer 3::3 enable
xconnect-group vpna
 connection pw1
PE 3
 sysname PE3
ospfv3 1
 area 0.0.0.0
interface LoopBack0
 ipv6 address 3::3/128
 ipv6 address 10::3/64
 ipv6 address 30::3/64
bgp 100
 router-id 3.3.3.3
  peer 1::1 enable
  peer 2::2 enable
xconnect-group vpna
 connection pw1
CE 2
 sysname CE2
 ipv6 address 100::2/64
Example: Statically configuring EVPN VPWS over SRv6 TE Policy
The user network has two sites. The edge device at Site 1 is CE 1 and the edge device at Site 2 is CE 2. CE 1 and CE 2 are connected to PE 1 and PE 2 via Ethernet interfaces, respectively. An SRv6 PW is deployed in the IPv6 backbone network to provide connectivity between the two CEs. An SRv6 TE policy is deployed in the IGP network and the SRv6 PW will be recursed to that SRv6 TE policy to ensure correct traffic forwarding.
Figure 12 Network diagram
Device
IP address
Device
IP address
CE 1
10::1/64
P
Loop0
3::3/128
PE 1
Loop0
1::1/128
20::2/64
N/A
30::1/64
20::1/64
PE 2
Loop0
2::2/128
CE 2
10::2/64
N/A
30::2/64
Procedures
Configuring CE 1
<CE1> system-view
CE1] interface
CE1-] ipv6 address 10::1 64
CE1-] quit
Configuring PE 1
# Configure OSPFv3, and enable OSPFv3 to advertise SID information.
<PE1> system-view
PE1] ospfv3
PE1-ospfv3-1] area 0.0.0.0
PE1-ospfv3-1] quit
PE1-LoopBack0] quit
PE1] l2vpn enable
# Configure GigabitEthernet 1/0/2, which is connected to the P device.
PE1] interface
PE1-] ipv6 address 20::1 64
PE1-] ospfv3 1 area 0
PE1-] quit
# Establish an IBGP peer relationship with PE 2, and then enable route advertisement based on BGP EVPN.
PE1] bgp 100
PE1-bgp-default] peer 2::2 as-number 100
# Create cross-connect group vpna, create an EVPN instance for the cross-connect group, enable the EVPN instance to use SRV6 encapsulation, configure an RD and RTs for the EVPN instance, and then enable route recursion to SRv6 TE policy tunnels.
PE1-xcg-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
PE1-xcg-vpna] quit
# Configure an SID list.
PE1-segment-routing-ipv6] locator aaa ipv6-prefix 5000:: 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] opcode 1 end
PE1-srv6-te] srv6-policy locator aaa
PE1-srv6-te-sl-s1] index 10 ipv6 6000::1
PE1-srv6-te-sl-s1] index 20 ipv6 7000::1
# Create an SRv6 TE policy, and configure its attributes.
PE1-srv6-te-policy-p1] color 10 end-point ipv6 2::2
# Create a candidate path for the SRv6 TE policy, and then specify the created SID list for that candidate path.
PE1-srv6-te] quit
# Configure color-based traffic steering to SRv6 TE Policy.
PE1-xcg-vpna-evpn-srv6] import route-policy a
PE1-xcg-vpna] quit
Configuring PE 2
<PE2> system-view
PE2] ospfv3
PE2-ospfv3-1] quit
PE2-LoopBack0] quit
PE2] l2vpn enable
PE2] interface
PE2-] ipv6 address 30::2 64
PE2-] ospfv3 1 area 0.0.0.0
PE2-] quit
# Establish an IBGP peer relationship with PE 1, and then enable route advertisement based on BGP EVPN.
PE2] bgp 100
# Create cross-connect group vpna, create an EVPN instance for the cross-connect group, enable the EVPN instance to use SRV6 encapsulation, configure an RD and RTs for the EVPN instance, and then enable route recursion to SRV6 TE policy tunnels.
PE2-xcg-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
PE2-xcg-vpna-pw1] evpn local-service-id 2 remote-service-id 1
PE2-xcg-vpna-pw1-2-1] quit
PE2-xcg-vpna] quit
PE2-segment-routing-ipv6] locator aaa ipv6-prefix 7000:: 96 static 8
PE2-segment-routing-ipv6-locator-aaa] opcode 1 end
[PE2-srv6-te] srv6-policy locator aaa
[PE2-srv6-te-sl-s1] index 10 ipv6 6000::1
[PE2-srv6-te-sl-s1] index 20 ipv6 5000::1
[PE2-srv6-te] quit
PE1-xcg-vpna] quit
Configuring P
# Configure an SRv6 End.SID.
<P> system-view
P-segment-routing-ipv6] locator b ipv6-prefix 6000:: 96 static 8
P-segment-routing-ipv6-locator-b] opcode 1 end
P-segment-routing-ipv6-locator-b] quit
# Configure OSPFv3.
P] ospfv3
P-ospfv3-1] router-id 3.3.3.3
P-ospfv3-1] segment-routing ipv6 locator b
P-ospfv3-1] area 0.0.0.0
P-ospfv3-1-area-0.0.0.0] quit
P-ospfv3-1] quit
# Assign IPv6 addresses to the related interfaces, and then enable OSPFv3 on those interfaces.
P] interface loopback 0
P-LoopBack0] ipv6 address 3::3 128
P-LoopBack0] ospfv3 1 area 0
P-LoopBack0] quit
P] interface
P-] ipv6 address 20::2 64
P-] ospfv3 1 area 0
P-] quit
P] interface
P-] ipv6 address 30::1 64
P-] ospfv3 1 area 0
P-] quit
Configuring CE 2
<CE2> system-view
CE2] interface
CE2-] ipv6 address 10::2 64
CE2-] quit
# View L2VPN SRv6 information on PE 1, and verify that an SRv6 tunnel has been established between PE 1 and PE 2.
   Peer            : 2::2
   Flag            : Main
   State           : Up
   Remote SrvID    : 2
In SID              : 100::1:0:2
Out SID             : 200::1:0:2
Configuration files
CE 1
 sysname CE1
PE 1
 sysname PE1
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
 l2vpn enable
xconnect-group vpna
 connection pw1
interface LoopBack0
bgp 100
  peer 2::2 enable
 locator aaa ipv6-prefix 100:: 96 static 8
  opcode 1 end #
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
P
 sysname P
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
interface LoopBack0
 ipv6 address 30::1/64
  opcode 1 end
PE 2
 sysname PE2
ospfv3 1
 router-id 2.2.2.2
 segment-routing ipv6 locator d
 area 0.0.0.0
 l2vpn enable
xconnect-group vpna
 connection pw1
interface LoopBack0
bgp 100
  peer 1::1 enable
 locator aaa ipv6-prefix 200:: 96 static 8
 locator d ipv6-prefix 7000:: 96 static 8
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
CE 2
 sysname CE1
 ipv6 address 10::2/64
Example: Statically configuring EVPN VPLS over SRv6 TE Policy
The user network has two sites. The edge device at Site 1 is CE 1 and the edge device at Site 2 is CE 2. CE 1 and CE 2 are connected to PE 1 and PE 2 via Ethernet interfaces, respectively. An SRv6 TE policy is deployed in the IGP network and the SRv6 PW will be recursed to that SRv6 TE policy to provide Layer 2 connectivity between the two CEs.
Figure 13 Network diagram
Device
IP address
Device
IP address
CE 1
GE1/0/1
10::1/64
P
Loop0
3::3/128
PE 1
Loop0
1::1/128
GE1/0/1
20::2/64
GE1/0/1
GE1/0/2
30::1/64
GE1/0/2
20::1/64
PE 2
Loop0
2::2/128
CE 2
GE1/0/1
10::2/64
GE1/0/1
GE1/0/2
30::2/64
Procedures
Configuring CE 1
<CE1> system-view
CE1] interface
CE1-] quit
Configuring PE 1
<PE1> system-view
PE1] ospfv3
PE1-ospfv3-1] quit
PE1-LoopBack0] quit
PE1] l2vpn enable
PE1] interface
PE1-] quit
PE1] bgp 100
# Create a VSI and an EVPN instance, enable the EVPN instance to use SRv6 encapsulation, configure an RD and RTs for the EVPN instance, enable route recursion to SRv6 TE policy tunnels, and then apply the specified SRv6 locator to the EVPN instance.
PE1] vsi vpna
PE1-vsi-vpna] evpn encapsulation srv6
PE1-vsi-vpna-evpn-srv6] route-distinguisher 1:1
PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
PE1-vsi-vpna-evpn-srv6] quit
# Bind GigabitEthernet 1/0/1 to the VSI.
PE1] interface
PE1-] xconnect vsi vpna
PE1-] quit
PE1-srv6-te] quit
PE1] vsi vpna
PE1-vsi-vpna-evpn-srv6] import route-policy a
PE1-vsi-vpna] quit
Configuring PE 2
<PE2> system-view
PE2] ospfv3
PE2-ospfv3-1] quit
PE2-LoopBack0] quit
PE2] l2vpn enable
# Configure , which is connected to the P device.
PE2] interface
PE2-] quit
PE2] bgp 100
# Create a VSI and an EVPN instance, enable the EVPN instance to use SRV6 encapsulation, configure an RD and RTs for the EVPN instance, enable route recursion to SRv6 TE policy tunnels, and then apply the specified SRv6 locator to the EVPN instance.
PE2] vsi vpna
PE2-vsi-vpna] evpn encapsulation srv6
PE2-vsi-vpna-evpn-srv6] route-distinguisher 1:1
PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
PE2-vsi-vpna-evpn-srv6] quit
# Bind  to the VSI.
PE2] interface
PE2-] xconnect vsi vpna
PE2-] quit
[PE2-srv6-te] quit
PE2] vsi vpna
PE2-vsi-vpna-evpn-srv6] import route-policy a
PE2-vsi-vpna] quit
Configuring P
<P> system-view
# Configure OSPFv3.
P] ospfv3
P-ospfv3-1] quit
P-LoopBack0] quit
P] interface
P-] ospfv3 1 area 0
P-] quit
P] interface
P-] ospfv3 1 area 0
P-] quit
Configuring CE 2
<CE2> system-view
CE2] interface
CE2-] quit
VSI Name: vpna
   Peer            : 2::2
   Flag            : Main
   State           : Up
# Verify that SRv6 forwarding information on PE 1 is correct.
Total number of VSIs: 1
VSI Name : vpna
Link ID             : 0x9000000   Type: BE    State: Up
In SID   : 100::1:0:1
Out SID  : 200::1:0:0
Configuration files
CE 1
 sysname CE1
PE 1
 sysname PE1
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
 l2vpn enable
vsi vpna
interface LoopBack0
 xconnect vsi vpna
bgp 100
  peer 2::2 enable
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
P
 sysname P
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
interface LoopBack0
  opcode 1 end
PE 2
 sysname PE2
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
 l2vpn enable
vsi vpna
interface LoopBack0
 xconnect vsi vpna
bgp 100
  peer 1::1 enable
  opcode 1 end
 traffic-engineering
  segment-list s1
  policy p1
   candidate-paths
    preference 10
CE 2
 sysname CE1
Related documentation
·     Network Management and Monitoring Configuration Guide Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Network Management and Monitoring Command Reference in H3C MSR5680-X3 Router Command References(V9)
