H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
43-Tcl Commands Configuration Examples
43-Tcl Commands Configuration Examples 85.61 KB
H3C Routers
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved
Introduction
The following information provides an example for using Tcl commands on routers.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of Tcl commands.
Example: Configuring subinterfaces in bulk by using For loop Tcl commands
As shown in Figure 1, the router is connected to the host. Use For loop Tcl commands to create subinterfaces GigabitEthernet 1/0/1.1 to GigabitEthernet 1/0/1.4 for GigabitEthernet 1/0/1, and configure incremental IP addresses and VLAN termination settings with incremental VLAN IDs for the subinterfaces.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
For Tcl commands, you cannot enter a question mark (?) to obtain online help or press Tab to complete an abbreviated command.
Successfully executed Tcl commands are not saved to command history buffers. You cannot use the upper arrow or lower arrow key to obtain executed commands.
During the execution of a loop body, any operation command will not take effect.
Procedures
# Enter Tcl configuration view from user view.
<Router> tclsh
# Enter system view.
<Router-tcl> system-view
# Start a For loop, and predefine the value of variable i as 1.
[Router-tcl] for {set i 1} {$i <= 4} {incr i 1} {
set j [expr $i+99]
# Create subinterfaces with incremental interface numbers for GigabitEthernet 1/0/1 and assign incremental IP addresses to the subinterfaces.
interface gigabitethernet 1/0/1.$i
ip add $i.1.1.1 24
# Configure VLAN termination settings with incremental VLAN IDs for the subinterfaces.
vlan-type dot1q vid $j}
[Router-tcl-GigabitEthernet1/0/1.4] quit
[Router-tcl] quit
<Router-tcl> tclquit
# Display brief information about all interfaces to verify that the subinterface settings have been successfully configured.
<Router> display interface brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
GE1/0/1              UP   UP       192.168.100.65  wangguan
GE1/0/1.1            UP   UP       1.1.1.1
GE1/0/1.2            UP   UP       2.1.1.1
GE1/0/1.3            UP   UP       3.1.1.1
GE1/0/1.4            UP   UP       4.1.1.1
GE1/0/2              ADM  DOWN     --
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
REG0                 DOWN --       --
# Execute the display current-configuration interface command on each interface to verify that the VLAN termination settings have been successfully configured. This example uses GigabitEthernet 1/0/1.1.
<Router> display current-configuration interface gigabitethernet 1/0/1.1
interface GigabitEthernet1/0/1.1
 ip address 1.1.1.1 255.255.255.0
 vlan-type dot1q vid 100
return
Configuration files
For commands on the router:
set j [expr $i+99]
ip address $i.1.1.1 24
Example: Configuring subinterfaces in bulk by using While loop Tcl commands
As shown in Figure 2, the router is connected to the host. Use While loop Tcl commands to create subinterfaces GigabitEthernet 1/0/1.1 to GigabitEthernet 1/0/1.4 for GigabitEthernet 1/0/1, and configure incremental IP addresses and VLAN termination settings with incremental VLAN IDs for the subinterfaces.
Figure 2 Network diagram
You must predefine the value of variables for While loop Tcl commands.
Procedures
<Router> tclsh
# Start a While loop, and predefine the value of variable i as 1.
[Router-tcl] set i 1
1
[Router-tcl] while {$i <= 4} {
set j [expr $i+99]
incr i}
[Router-tcl] quit
GE1/0/2              ADM  DOWN     --
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
REG0                 DOWN --       --
# Execute the display current-configuration interface command on each subinterface to verify that the VLAN termination settings have been successfully configured.
return
Configuration files
While commands on the router:
set i 1
while {$i <= 4} {
set j [expr $i+99]
incr i}
Related documentation
·     Network Programmability Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Network Programmability Command Reference in H3C MSR5680-X3 Router Command References(V9)
