H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
50-Outbound Bidirectional NAT Configuration Examples
H3C Routers
Introduction
The following information provides examples for configuring outbound bidirectional NAT on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring outbound bidirectional NAT
As shown in Figure 1, the router acts as the gateway through which the company accesses the public network. The private network where the Web server resides overlaps with the company private network 192.168.1.0/24. The company has two public IP addresses 202.38.1.2 and 202.38.1.3. Configure NAT to allow the host to access the external Web server by using the server's domain name.
Figure 1 Network diagram
Analysis
·     Configure inbound dynamic NAT ALG to make sure the internal host can reach the Web server. NAT ALG can translate the Web server's IP address in the DNS reply payload to a dynamically assigned public address.
·     Configure outbound dynamic NAT to translate the source IP address of packets from the internal host to a dynamically assigned public address.
·     Add a static route to the public IP address of the external Web server.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
Procedures
# Specify IP addresses for the interfaces on the router.
<Router> system-view
[Router] interface gigabitethernet 1/0/1
[Router-GigabitEthernet1/0/1] ip address 192.168.1.1 24
[Router-GigabitEthernet1/0/1] quit
[Router] interface gigabitethernet 1/0/2
[Router-GigabitEthernet1/0/2] ip address 10.0.1.1 24
[Router-GigabitEthernet1/0/2] quit
# Enable NAT with ALG and DNS.
[Router] nat alg dns
# Configure ACL 2000 to identify packets from subnet 192.168.1.0/24.
[Router] acl number 2000
[Router-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Router-acl-ipv4-basic-2000] quit
# Create address group 1.
[Router] nat address-group 1
# Add address 202.38.1.2 to address group 1.
[Router-nat-address-group-1] address 202.38.1.2 202.38.1.2
[Router-nat-address-group-1] quit
# Create address group 2.
[Router] nat address-group 2
# Add address 202.38.1.3 to address group 2.
[Router-nat-address-group-2] address 202.38.1.3 202.38.1.3
[Router-nat-address-group-2] quit
# Enable inbound NO-PAT on GigabitEthernet 1/0/2 to translate the source IP address in the DNS reply payload into the address in address group 1, and allow reverse translation.
[Router-GigabitEthernet1/0/2] nat inbound 2000 address-group 1 no-pat reversible
# Enable outbound PAT on GigabitEthernet 1/0/2 to translate the source address of outgoing packets into the address in address group 2.
[Router-GigabitEthernet1/0/2] nat outbound 2000 address-group 2
# Configure a static route to 202.38.1.2 with GigabitEthernet 1/0/2 as the output interface and 10.0.1.1 as the next hop.
[Router] ip route-static 202.38.1.2 32 gigabitethernet 1/0/2 10.0.1.1
# Verify that the host can access the Web server by using its domain name. (Details not shown.)
# Execute the display nat all command to display all NAT configuration and statistics.
[Router] display nat all
NAT address group information:
  Totally 2 NAT address groups.
  Address group 1:
  Port range: 1-65535
    Address information:
      Start address         End address
  Address group 2:
  Port range: 1-65535
NAT inbound information:
  Totally 1 NAT inbound rules.
    ACL: 2000
    Address group ID: 1
    Add route: N             NO-PAT: Y  Reversible: Y
    NAT counting: 0
    Config status: Active
NAT outbound information:
  Totally 1 NAT outbound rules.
    ACL: 2000
    Address group ID: 2
    Port-preserved: N        NO-PAT: N  Reversible: N
    NAT counting: 0
NAT logging:
  Log enable          : Disabled
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Disabled
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
  NO-PAT IP usage     : Disabled
NAT mapping behavior:
  Mapping mode: Address and Port-Dependent
  ACL         : ---
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Enabled
  SCCP       : Enabled
  SCTP       : Enabled
  SIP        : Enabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Enabled
Static NAT load balancing:     Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
# Execute the display nat session verbose command to display NAT sessions that are generated when the host accesses the Web server.
[Router] display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.10/1694
  Destination IP/port: 202.38.1.2/8080
  DS-Lite tunnel peer: -
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/1
Responder:
  Source      IP/port: 192.168.1.10/8080
  Destination IP/port: 202.38.1.3/1025
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/2
State: TCP_ESTABLISHED
Application: HTTP
Rule ID: -/-/-
Rule name:
Start time: 2013-08-15 14:53:29  TTL: 3597s
Initiator->Responder:            7 packets        308 bytes
Responder->Initiator:            5 packets        312 bytes
Total sessions found: 1
Configuration files
 port link-mode route
 ip address 10.0.1.1 255.255.255.0
 ip route-static 202.38.1.2 32 GigabitEthernet1/0/2 10.0.1.1
acl number 2000
 rule 0 permit source 192.168.1.0 0.0.0.255
nat address-group 1
nat address-group 2
Related documentation
·     NAT and IPv6 Transition Technologies Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     NAT and IPv6 Transition Technologies Command Reference in H3C MSR5680-X3 Router Command References(V9)
