H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
36-PPP Configuration Examples
36-PPP Configuration Examples 97.85 KB
H3C Routers
Introduction
The following information provides PPP protocol-related configuration examples.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
This document assumes that you have basic knowledge of PPP, MP, PPPoE, and DHCP.
Example: Configuring MP+CHAP
As shown in Figure 1, Serial 2/0/0:0 and Serial 2/0/1:0 of Device A are connected to Serial 2/0/0:0 and Serial 2/0/1:0 of Device B, respectively. Set up an MP link in MP-group mode. Each PPP link uses CHAP for authentication.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
·     Make sure the username and password for CHAP authentication are the same on both ends.
·     After a serial interface is configured, you must use the undo shutdown command to bring up the interface.
·     When creating a PPP user, you must specify the network option after the class keyword in the local-user command.
Procedures
Configuring Device A
1.     Create a local user for Device B, and set the service type to PPP for the local user.
[DeviceA] local-user userb class network
[DeviceA-luser-network-userb] password simple hello
[DeviceA-luser-network-userb] service-type ppp
[DeviceA-luser-network-userb] quit
2.     Configure serial interface Serial 2/0/0:0, and use the default ISP domain system to perform CHAP authentication for Device B.
[DeviceA] interface serial 2/0/0:0
[DeviceA-Serial2/0/0:0] link-protocol ppp
[DeviceA-Serial2/0/0:0] ppp authentication-mode chap domain system
[DeviceA-Serial2/0/0:0] quit
3.     Configure serial interface Serial 2/0/1:0, and use the default ISP domain system to perform CHAP authentication for Device B.
[DeviceA] interface serial 2/0/1:0
[DeviceA-Serial2/0/1:0] link-protocol ppp
[DeviceA-Serial2/0/1:0] ppp authentication-mode chap domain system
[DeviceA-Serial2/0/1:0] quit
4.     In the default ISP domain system, configure PPP users to use local authentication.
[DeviceA] domain system
[DeviceA-isp-system] authentication ppp local
5.     Create an MP-group interface, and assign an IP address to it.
[DeviceA] interface mp-group 2/0/0
[DeviceA-MP-group2/0/0] ip address 1.1.1.1 24
[DeviceA-MP-group2/0/0] quit
6.     Assign serial interface Serial 2/0/0:0 to MP-group 1, and bring up the interface.
[DeviceA-Serial2/0/0:0] ppp mp mp-group 2/0/0
[DeviceA-Serial2/0/0:0] shutdown
[DeviceA-Serial2/0/0:0] undo shutdown
7.     Assign serial interface Serial 2/0/1:0 to MP-group 1, and bring up the interface.
[DeviceA] interface Serial 2/0/1:0
[DeviceA-Serial2/0/1:0] ppp mp mp-group 2/0/0
[DeviceA-Serial2/0/1:0] shutdown
[DeviceA-Serial2/0/1:0] undo shutdown
Configuring Device B
1.     Configure serial interface Serial 2/0/0:0, and enable PPP encapsulation on the interface. Configure the username and password for CHAP authentication on the interface.
[DeviceB] interface serial 2/0/0:0
[DeviceB-Serial2/0/0:0] link-protocol ppp
[DeviceB-Serial2/0/0:0] ppp chap user userb
[DeviceB-Serial2/0/0:0] ppp chap password simple hello
[DeviceB-Serial2/0/0:0] quit
2.     Configure serial interface Serial 2/0/1:0, and enable PPP encapsulation on the interface. Configure the username and password for CHAP authentication on the interface.
[DeviceB] interface Serial 2/0/1:0
[DeviceB-Serial2/0/1:0] link-protocol ppp
[DeviceB-Serial2/0/1:0] ppp chap user userb
[DeviceB-Serial2/0/1:0] ppp chap password simple hello
[DeviceB-Serial2/0/1:0] quit
3.     Create an MP-group interface, and assign an IP address to it.
[DeviceB] interface mp-group 2/0/0
[DeviceB-Mp-group1] ip address 1.1.1.2 24
[DeviceB-Mp-group1] quit
4.     Assign serial interface Serial 2/0/0:0 to MP-group 1, and bring up the interface.
[DeviceB-Serial2/0/0:0] ppp mp mp-group 2/0/0
[DeviceB-Serial2/0/0:0] shutdown
[DeviceB-Serial2/0/0:0] undo shutdown
5.     Assign serial interface Serial 2/0/1:0 to MP-group 1, and bring up the interface.
[DeviceB-Serial2/0/1:0] ppp mp mp-group 2/0/0
[DeviceB-Serial2/0/1:0] shutdown
[DeviceB-Serial2/0/1:0] undo shutdown
1.     Display the MP information of Device A.
[DeviceA] display ppp mp
Template: MP-group2/0/0
max-bind: 16, fragment: enabled, min-fragment: 128
  Master link: MP-group2/0/0, Active members: 2, Bundle Multilink
  Peer's endPoint descriptor: MP-group2/0/0
  Sequence format: long (rcv)/long (sent)
  Bundle Up Time: 2014/07/22  16:51:40:835
  0 lost fragments, 5 reordered, 0 unassigned, 0 interleaved
  Sequence: 4 (rcv)/5 (sent)
  Active member channels: 2 members
        Serial2/0/0:0                 Up-Time:2014/07/22  16:51:40:836
        Serial2/0/1:0                 Up-Time:2014/07/22  16:51:53:542
2.     Display information about interface MP-group 2/0/0 on Device A.
[DeviceA] display interface mp-group 2/0/0
MP-group2/0/0
Current state: UP
Line protocol state: UP
Description: MP-group2/0/0 Interface
Bandwidth: 128kbps
Maximum Transmit Unit: 1500
Hold timer: 10 seconds
Internet Address is 1.1.1.1/24 Primary
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 128000 bps
Last 300 seconds input rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Last 300 seconds output rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Input: 8 packets, 466 bytes, 0 drops
Output: 8 packets, 456 bytes, 0 drops
3.     Ping the peer IP address from Device A.
[DeviceA] ping 1.1.1.2
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=25.749 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=25.751 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=25.521 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=25.512 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=25.599 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms
<DeviceA>%Jul 22 17:08:22:460 2014 DeviceA PING/6/PING_STATISTICS: Ping statisti
cs for 1.1.1.2: 5 packets transmitted, 5 packets received, 0.0% packet loss, rou
nd-trip min/avg/max/std-dev = 25.512/25.626/25.751/0.105 ms.
Configuration files
·     Device A:
interface Serial2/0/0:0
 ppp mp MP-group2/0/0
interface Serial2/0/1:0
interface MP-group2/0/0
 ip address 1.1.1.1 255.255.255.0
local-user 123 class network
 password cipher $c$3$5ulb/vg58eiBIm5EnilnsZ2cS2Cmwg==
 service-type ppp
·     Device B:
 ppp chap password cipher $c$3$4kD4T3bLZ/lngijhEKIS70/oTbNSkw==
 ppp chap user 123
 ppp chap password cipher $c$3$mVlcV3W+YQBgmxKePKpZV9tTcaFhXg==
 ppp chap user 123
 ip address 1.1.1.2 255.255.255.0
Related documentation
·     Layer 2—WAN Access Configuration Guide in H3C MSR5680-X3 Router Configuration Guides (V9)
·     Layer 2—WAN Access Command Reference in H3C MSR5680-X3 Router Command References (V9)
