H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
37-RBAC Configuration Examples
37-RBAC Configuration Examples 361.04 KB
H3C Routers
Without written permission from our company, no individual or organization may illegally extract, copy, or propagate any part or all of the content of this document in any way.
Overview·· 1
Prerequisites· 1
Example: Configuring read and write permissions for specific features· 1
Network configuration· 1
Analysis· 1
Software versions used· 1
Restrictions and guidelines· 2
Procedures· 2
Verifying the configuration· 3
Configuration files· 5
Example: Configuring authorization for Telnet users of the RADIUS user role  5
Network configuration· 5
Analysis· 6
Software versions used· 6
Restrictions and guidelines· 6
Procedures· 7
Configuring the device· 7
Configuring the RADIUS server 8
Verifying the configuration· 9
Configuration files· 10
Example: Configuring user permissions in specific VPNs· 11
Network configuration· 11
Analysis· 12
Software versions used· 12
Restrictions and guidelines· 12
Procedures· 12
Device Configuration· 12
Configuring the RADIUS server 13
Verifying the configuration· 14
Configuration files· 15
Example: Modifying user permissions by creating and authorizing a new user role  16
Network configuration· 16
Analysis· 17
Software versions used· 17
Restrictions and guidelines· 17
Procedures· 17
Verifying the configuration· 19
Verifying user permission before the permission change· 19
Verifying user permission after the permission change· 20
Configuration files· 21
Example: Configuring users with the permission to switch between user roles  22
Network configuration· 22
Analysis· 23
Software versions used· 23
Restrictions and guidelines· 23
Procedures· 23
Verifying the configuration· 25
Configuration files· 28
Example: Configuring the flow control permission· 29
Network configuration· 29
Analysis· 30
Software versions used· 30
Restrictions and guidelines· 30
Procedures· 30
Device Configuration· 30
Configuring the RADIUS server 32
Verifying the configuration· 33
Configuration files· 35
Related documentation· 36
Overview
This document presents a typical example of using RBAC to control user authority on login devices.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of RBAC.
As shown in Figure 1, to enhance security of user logins, local AAA authentication is used to authenticate Telnet users on the device. Give Telnet users the following permissions:
·     Allow execution of all read and write type commands related to OSPF.
·     Allow execution of all read-write commands related to file system.
Figure 1 Network diagram
Analysis
·     For a Telnet user to have the permissions, create a local Telnet user and user role role1, then, grant the Telnet users with the user role.
·     Configure user role rules to limit Telnet users to execute read and write commands related to OSPF and file system.
·     To ensure that Telnet users only use the authorized user role, delete the default user role assigned to the user.
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
·     After configuring an ISP domain as the default one, you cannot delete the domain. To delete the domain, you must first use the undo domain default enable command to change the domain to a non-default domain.
·     One user role can create multiple rules, each identified by a unique number. Users authorized with this role can execute commands defined by the executable command union of these rules. If the permissions defined by two rules have conflicts, the rule with a higher number takes effect. For example, rule 1 allows executing command A, rule 2 allows executing command B, and rule 3 prohibits executing command A. Thus, rules 2 and 3 take effect, meaning command A is prohibited and command B is allowed.
Procedures
1.     Configure interfaces.
# Configure an IP address for interface GigabitEthernet1/0/1.
<Router> system-view
[Router] interface gigabitethernet 1/0/1
[Router-GigabitEthernet1/0/1] ip address 192.168.1.50 24
[Router-GigabitEthernet1/0/1] quit
2.     Configure the authentication method for Telnet user login.
# Activate the Telnet server function on the device.
[Router] telnet server enable
# Configure Telnet user login with the AAA authentication method on VTY user lines numbered from 0 to 63.
[Router] line vty 0 63
[Router-line-vty0-63] authentication-mode scheme
The command is "quit" on line vty0-63 of the system.
3.     Configure the AAA method for an ISP domain.
# Create ISP domain bbb and authorize login users with local authentication and authorization.
[Router] domain bbb
[Router-isp-bbb] authentication login local
[Router-isp-bbb] authorization login local
[Router-isp-bbb] quit
4.     Configure the password and service type for local user telnetuser.
# Create a local device management user named telnetuser.
[Router] local-user telnetuser class manage
# Set a plaintext password 123456TESTplat&!.
[Router-luser-manage-telnetuser] password simple 123456TESTplat&!
# Specify the service type as Telnet.
[Router-luser-manage-telnetuser] service-type telnet
[Router-luser-manage-telnetuser] quit
5.     Create user role role1 and configure its rules.
# Create user role role1 and enter its view.
[Router] role name role1
# Configure user role rule 1 to allow executing all commands of the read-write type related to OSPF.
[Router-role-role1] rule 1 permit read write feature ospf
# Configure user role rule 2 to allow executing all commands of the read-write type related to file system.
[Router-role-role1] rule 2 permit read write feature filesystem
[Router-role-role1] quit
6.     Configure the authorized user role for the local user.
# Enter view of local user telnetuser.
# Authorize user telnetuser with role role1.
[Router-luser-manage-telnetuser] authorization-attribute user-role role1
# For the user to use only the authorized user role, delete the default user role network-operator.
[Router-luser-manage-telnetuser] undo authorization-attribute user-role network-operator
[Router] quit
1.     View user role information.
# Use the display role command to view the information about user role role1.
<Router> display role name role1
Role: role1
  Description:
  VLAN policy: permit (default)
  Interface policy: permit (default)
  VPN instance policy: permit (default)
  Security zone policy: permit (default)
  Rule    Perm   Type  Scope         Entity
  1       permit RW-   feature       ospf
  2       permit RW-   feature       filesystem
  R:Read W:Write X:Execute
2.     Make the user log in to the device.
Make the user initiate a Telnet connection to the device and enter user name telnetuser@bbb and the correct password at the prompt. Verify that you can log in to the device.
C:\Documents and Settings\user> telnet 192.168.1.50
* Copyright (c) 2004-2023 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
login: telnetuser@bbb
Password:
<Router>
3.     Verify the user permissions.
After the Telnet user logs in to the device, perform the following tasks to verify the user permissions:
¡     Execute write commands of OSPF. (This section uses OSPF configuration as an example.)
[Router] ospf 1
[Router-ospf-1] area 0
[Router-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[Router-ospf-1-area-0.0.0.0] quit
[Router-ospf-1] quit
¡     Execute read command of OSPF.
[Router] show ospf
          OSPF Process 1 with Router ID 192.168.1.50
                  OSPF Protocol Information
 RouterID: 192.168.1.50   Router type:
 Route tag: 0
 Ext-community type: Domain ID 0x5, Route Type 0x306, Router ID 0x107
 Domain ID: 0.0.0.0
 Opaque capable
 Isolation: Disabled
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5 50 200
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF calculation count: 0
 RFC 1583 compatible
 Fast-reroute: Remote-lfa Disabled
   Maximum-cost: 4294967295
 Node-Protecing Preference: 40
 Lowest-cost Preference: 20
 Graceful restart interval: 120
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 1   NSSA area count: 0
 ExChange/Loading neighbors: 0
 MPLS segment routing: Disabled
   Segment routing adjacency   : Disabled
   Effective SRGB              : 16000  24000
   Segment routing local block : 15000  15999
   Segment routing tunnel count: 0
 Area: 0.0.0.0          (MPLS TE not enabled)
 Authentication type: None    Area flag: Normal
 SPF scheduled count: 0
¡     Execute the read and write commands of file system. (This section configures the source IP address of FTP packets as an example.)
[Router] ftp client source ip 192.168.0.60
[Router] quit
¡     Verify that you cannot execute commands of the execution type related to filesystem. (This section attempts to enter FTP view as an example.)
<Router> ftp
Permission denied.
Configuration files
line vty 0 63
domain bbb
role name role1
 password hash $h$6$kZw1rKFsAY4lhgUz$+teVLy8gmKN4Mr00VWgXQTB8ai94gKHlrys5OkytGf4
kT+nz5X1ZGASjc282CYAR6A1upH2jbmRoTcfDzZ9Gmw==
 service-type telnet
As shown in Figure 2, the Telnet user's host is connected to the device, and the device is connected to a RADIUS server. Configure the RADIUS server authenticate and authorize Telnet users logging into the device, so that the Telnet users can obtain the following user permissions:
·     Allow users to execute all commands in ISP view.
·     Allow users to execute read and write commands for ARP and RADIUS.
·     Allow users to execute commands related to VLAN creation and commands in VLAN view and allow users to configure only VLANs 10 through 20.
·     Allow users to access interface view and execute commands in interface view, and allow users to configure interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3.
Figure 2 Network diagram
Analysis
·     For Telnet users to execute read and write commands for ARP and RADIUS, create a feature group named feature-group1 and add ARP and RADIUS to the group.
·     To authorize Telnet users to execute requested commands, configure corresponding user role rules and resource control policies.
·     To grant Telnet users the permissions, authorize user role role1 on the RADIUS server.
1.     After configuring an ISP domain as the default one, you cannot delete the domain. To delete the domain, you must first use the undo domain default enable command to change the domain to a non-default domain.
2.     The authorization information from the RADIUS server is sent to the RADIUS client with the authentication response message. Make sure the authentication and authorization methods are the same.
3.     One user role can create multiple rules, each identified by a unique number. Users authorized with this role can execute commands defined by the executable command union of these rules. If the permissions defined by two rules have conflicts, the rule with a higher number takes effect. For example, rule 1 allows executing command A, rule 2 allows executing command B, and rule 3 prohibits executing command A. Thus, rules 2 and 3 take effect, meaning command A is prohibited and command B is allowed.
Procedures
1.     Configure interfaces and routes.
# Configure the IP address of interface GigabitEthernet1/0/1. Users will use this address to connect to the device through Telnet.
[Router-GigabitEthernet1/0/1] ip address 192.168.1.50 255.255.255.0
# Configure the IP address of interface GigabitEthernet1/0/2. Devices will use this address to communicate with the server.
[Router] interface gigabitethernet 1/0/2
[Router-GigabitEthernet1/0/2] ip address 10.1.1.2 255.255.255.0
[Router-GigabitEthernet1/0/2] quit
# Configure a default route for Telnet users to reach the RADIUS server.
[Router] ip route-static 0.0.0.0 0.0.0.0 10.1.1.1
# Configure the AAA authentication method used for Telnet user login.
[Router-line-vty0-63] quit
3.     Configure the RADIUS scheme and authentication server.
# Create RADIUS scheme rad.
[Router] radius scheme rad
# Configure the IP address of the primary authentication/authorization server as 10.1.1.1 and the primary accounting server as 10.1.1.1.
[Router-radius-rad] primary authentication 10.1.1.1
[Router-radius-rad] primary accounting 10.1.1.1
# Set the shared key for interaction messages with the authentication/authorization server and the primary accounting server as plaintext aabbcc.
[Router-radius-rad] key authentication simple aabbcc
[Router-radius-rad] key accounting simple aabbcc
[Router-radius-rad] quit
4.     Configure the AAA method for an ISP domain.
# Create ISP domain bbb and configure login users to use the RADIUS authentication, RADIUS authorization, and RADIUS accounting AAA methods.
[Router] domain bbb
[Router-isp-bbb] authentication login radius-scheme rad
[Router-isp-bbb] authorization login radius-scheme rad
[Router-isp-bbb] accounting login radius-scheme rad
5.     Configure the feature group.
# Create feature group group1.
[Router] role feature-group name fgroup1
# Add ARP and RADIUS to the feature group.
[Router-featuregrp-fgroup1] feature arp
[Router-featuregrp-fgroup1] feature radius
[Router-featuregrp-fgroup1] quit
6.     Create user role role1 and configure rules and resource control policies for the user role.
# Create user role role1.
# Configure user role rule 1 to allow users to execute all commands in ISP view.
[Router-role-role1] rule 1 permit command system-view ; domain *
# Configure user role rule 2 to allow users to execute read and write commands of all features in feature group fgroup1.
[Router-role-role1] rule 2 permit read write feature-group fgroup1
# Configure user role rule 3 to allow users to execute VLAN creation commands.
[Router-role-role1] rule 3 permit command system-view ; vlan *
# Configure user role rule 4 to allow users to access interface view and execute commands in interface view.
[Router-role-role1] rule 4 permit command system-view ; interface *
# Enter VLAN policy view and allow users to have permissions to manage VLANs 10 through 20.
[Router-role-role1] vlan policy deny
[Router-role-role1-vlanpolicy] permit vlan 10 to 20
[Router-role-role1-vlanpolicy] quit
# Enter interface policy view, and allow users to have permissions to manage interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3.
[Router-role-role1] interface policy deny
[Router-role-role1-ifpolicy] permit interface gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Router-role-role1-ifpolicy] quit
This section uses iMC PLAT 7.0 (E0202) and iMC UAM 7.0 (E0202) as an example to illustrate basic configuration of the RADIUS server.
1.     Add an access device.
Log in to the IMC management platform, click the User tab, and select User Access Policy > Access Device Management > Access Device in the left navigation pane. Then, click Add.
¡     Specify the authentication and accounting port numbers to 1812 and 1813, respectively.
¡     Set the shared key for authentication and accounting for AC interaction messages as aabbcc and confirm the shared key.
¡     Select Device Management Service as the service type.
¡     Select H3C (General) as the access device type.
¡     Select or manually add the device with IP address 10.1.1.2 as an access device.
¡     Retain the default settings in the other fields and then click OK.
2.     Add a device management user.
Click the User tab, and select Device User > Device User in the navigation pane. Click Add.
¡     Specify the user name, set the password, and confirm the password. In this example, the username is telnetuser@bbb.
¡     Select Telnet as the service type.
¡     Add user role role1.
¡     Add IP addresses of devices to be managed. In this example, the IP address range is 10.1.1.0 to 10.1.1.10.
¡     Click OK.
1.     View user role and feature group information.
# Use the display role command to view user role information.
Role: role1
  Description:
  VLAN policy: deny
  Permitted VLANs: 10 to 20
  Interface policy: deny
  Permitted interfaces: GigabitEthernet1/0/1 to GigabitEthernet1/0/3
  2       permit RW-   feature-group fgroup1
Password:
<Router>
¡     Execute commands in ISP view.
[Router] domain abc
[Router-isp-abc] authentication login radius-scheme abc
[Router-isp-abc] quit
¡     Execute read and write commands of the RADIUS feature. (Same as the verifying permissions over the ARP feature.)
[Router-radius-rad] primary authentication 2.2.2.2
[Router-radius-rad] display radius scheme rad
¡     Verify that you can manage only VLAN 10 through VLAN 20. (This section creates VLAN 10 and VLAN 30 as an example.)
[Router] vlan 10
[Router-vlan10] quit
[Router] vlan 30
Permission denied.
¡     Verify that you can manage only interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3. (This section uses interface GigabitEthernet 1/0/1 as an example.)
[Router-GigabitEthernet1/0/1] ip address 1.1.1.1 24
¡     Verify that you cannot manage other interfaces. (This section enters interface view of Ten-GigabitEthernet 0/0/9 as an example.)
[Router] interface gigabitethernet 1/0/4
Permission denied.
Configuration files
 ip address 10.1.1.2 24
line vty 0 63
ip route-static 0.0.0.0 0 10.1.1.1
radius scheme rad
 key authentication cipher $c$3$JzDegvL0G5KZIcJhzscTHLA4WasBVh0UOw==
 key accounting cipher $c$3$CdejNYYxvjW0Y+Zydi4rZgBwjYb4h6LKmg==
domain bbb
 feature arp
 feature radius
 role name role1
 vlan policy deny
  permit interface GigabitEthernet1/0/1 to GigabitEthernet1/0/3
As shown in Figure 3, in order to enhance the security of user login, RADIUS server is used to authenticate and authorize Telnet users, granting them the following permissions:
·     Allow the execution of all commands related to predefined feature group L3 in the system.
·     Allow the execution of all commands starting with the display keyword.
·     Allow management only of specific VPN instances, for example, VPN instances vpn1, vpn2, and vpn3.
Figure 3 Network diagram
Analysis
·     To authorize Telnet users to execute requested commands, create user role role1 and configure the user role rules and resource control policies.
Procedures
# Configure an IP address for interface GigabitEthernet1/0/2.
[Router-GigabitEthernet1/0/2] ip address 10.1.1.2 24
[Router] domain bbb
5.     Create user role role1 and configure rules and resource control policies for the user role.
# Configure user role rule 1 to allow users to execute all commands related to predefined feature group L3.
[Router-role-role1] rule 1 permit execute read write feature-group L3
# Configure user role rule 2 to allow users to execute all commands starting with the display keyword.
[Router-role-role1] rule 2 permit command display *
# Enter user role VPN policy view and authorize users with the permission to manage VPN instances vpn1, vpn2, and vpn3.
[Router-role-role1] vpn-instance policy deny
[Router-role-role1-vpnpolicy] permit vpn-instance vpn1 vpn2 vpn3
[Router-role-role1-vpnpolicy] quit
[Router] quit
Log in to the IMC management platform, click the User tab. In the left navigation pane, select User Access Policy > Access Device Management > Access Device. Click Add.
¡     Click OK.
Role: role1
  Description:
  VPN instance policy: deny
  Permitted VPN instances: vpn1, vpn2, vpn3
  1       permit RWX   feature-group L3
Use the display role feature-group command to view feature information in feature group L3. (Details not shown.)
Password:
<Router>
¡     Execute commands in the predefined feature group L3. (This section creates VPN instance vpn1 and set the RD to 22:1 as an example.)
[Router] ip vpn-instance vpn1
[Router-vpn-instance-vpn1] route-distinguisher 22:1
[Router-vpn-instance-vpn1] display this
return
[Router-vpn-instance-vpn1] quit
¡     Verify that you cannot manage other VPN instances. (This section uses VPN instance vpn5 as an example.)
[Router] ip vpn-instance vpn5
Permission denied.
Configuration files
line vty 0 63
radius scheme rad
domain bbb
role name role1
 rule 1 permit read write execute feature-group L3
  permit vpn-instance vpn2
  permit vpn-instance vpn3
As shown in Figure 4, to enhance security of user logins, local AAA authentication is used to authenticate Telnet users on the device. Telnet users telnetuser1 and telnetuser2 use ISP domain bbb to access the network. After successfully logging in to the devices, both users are assigned user role role1, which has the following permissions:
·     Allow the execution of the command to create VLANs.
·     Allow users to manage only VLAN 10 through VLAN 15.
·     Allow users to manage only GigabitEthernet 1/0/1.
The following permissions need to be added to Telnet user telnetuser1:
·     Allow management of VLAN 16 through VLAN 20.
·     Allow management of interfaces GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3.
Figure 4 Network diagram
Analysis
·     To grant Telnet user telnetuser1 permissions without changing the permissions of Telnet user telnetuser2, create user role role2 and assign it to Telnet user telnetuser1.
·     To enable Telnet user telnetuser1 to execute required commands, configure user role rules and resource control policies.
·     You can authorize a user with multiple user roles. Users with multiple roles can access a set of functions and resources allowed by each role they have.
·     If you authorize a new role to an online user, the new role takes effect after the user comes online again.
Procedures
[Router] domain bbb
4.     Configure the password and service type for local user telnetuser1 and telnetuser2.
# Create local user telnetuser1.
[Router] local-user telnetuser1 class manage
[Router-luser-manage-telnetuser1] password simple 123456TESTplat&!
[Router-luser-manage-telnetuser1] service-type telnet
[Router-luser-manage-telnetuser1] quit
# Create local user telnetuser2.
[Router] local-user telnetuser2 class manage
[Router-luser-manage-telnetuser2] password simple 123456TESTplat&!
[Router-luser-manage-telnetuser2] service-type telnet
[Router-luser-manage-telnetuser2] quit
# Configure user role rule 1 to allow users to execute all commands starting with the display keyword.
[Router-role-role1] rule 1 permit command display *
# Configure user role rule 2 to allow executing the command to enter VLAN view.
[Router-role-role1] rule 2 permit command system-view ; vlan *
# Configure user role rule 3 to allow entering interface view and executing commands in interface view.
[Router-role-role1] rule 3 permit command system-view ; interface *
# Enter user role VLAN policy view, and allow users to have permissions to manage VLAN 10 through VLAN 15.
[Router-role-role1-vlanpolicy] permit vlan 10 to 15
# Enter user role interface policy view and allow users to have the permission to manage GigabitEthernet 1/0/1.
6.     Authorize user roles to Telnet users.
# Enter user view of local user telnetuser1.
# Assign role role1 to user telnetuser1.
[Router-luser-manage-telnetuser1] authorization-attribute user-role role1
[Router-luser-manage-telnetuser1] undo authorization-attribute user-role network-operator
# Enter user view of local user telnetuser2.
# Assign role role1 to user telnetuser2.
[Router-luser-manage-telnetuser2] authorization-attribute user-role role1
[Router-luser-manage-telnetuser2] undo authorization-attribute user-role network-operator
7.     Create user role role2 and configure its rules.
# Create user role role2 and enter its view.
[Router] role name role2
# Configure user role rule 1 to allow entering interface view and executing commands in interface view.
[Router-role-role2] rule 1 permit command system-view ; interface *
8.     Configure a VLAN resource control policy for user role role2.
# Enter user role VLAN policy view, and allow users to have permissions to manage VLAN 16 through VLAN 20.
[Router-role-role2] vlan policy deny
[Router-role-role2-vlanpolicy] permit vlan 16 to 20
[Router-role-role2-vlanpolicy] quit
# Enter user role interface policy view and allow users to have the permission to manage GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3.
[Router-role-role2] interface policy deny
[Router-role-role2-ifpolicy] permit interface gigabitethernet 1/0/2 to gigabitethernet 1/0/3
[Router-role-role2-ifpolicy] quit
[Router-role-role2] quit
9.     Assign a user role to user telnetuser1.
# Assign role role2 to user telnetuser1.
[Router-luser-manage-telnetuser1] authorization-attribute user-role role2
[Router] quit
Role: role1
  Description:
  VLAN policy: deny
  Permitted VLANs: 10 to 15
Make the user initiate a Telnet connection to the device and enter user name telnetuser1@ and the correct password at the prompt. Verify that you can log in to the device.
login: telnetuser1@bbb
Password:
<Router>
¡     Verify that you can create VLAN 15.
[Router] vlan 15
[Router-vlan15] quit
¡     Verify that you cannot create VLAN 20.
[Router] vlan 20
Permission denied.
¡     Verify that you can manage GigabitEthernet 1/0/1.
[Router] quit
# View information about user role role2.
<Router> display role name role2
Role: role2
  Description:
  VLAN policy: deny
  Permitted VLANs: 16 to 20
  Permitted interfaces: GigabitEthernet1/0/2-GigabitEthernet1/0/3
Password:
<Router>
¡     Verify that you can create VLAN 16.
[Router] vlan 16
[Router-vlan16] quit
¡     Verify that you can manage GigabitEthernet 1/0/2.
[Router-GigabitEthernet1/0/2] ip address 2.2.2.2 24
¡     Verify that you cannot manage other interfaces. (This section enters interface view of GigabitEthernet1/0/5 as an example.)
[Router] interface gigabitethernet 1/0/5
Permission denied.
Configuration files
line vty 0 63
domain bbb
role name role1
 vlan policy deny
role name role2
 vlan policy deny
  permit interface GigabitEthernet1/0/2 to GigabitEthernet1/0/3
 service-type telnet
 password hash TPcgyTQJZShe$h$6$vaSj2xKc8yFiNdfQ$Jzb3PXo2lt4jk KSZqJUVhjP634Wol/
Qx8TLU748IHoeui0w5n/XRzpNqbNnpxikym39gGJCwYw==
 service-type telnet
As shown in Figure 5, to enhance security of user logins, local AAA authentication is used to authenticate Telnet users on the device. Configure user permissions to allow Telnet users logging into the device to switch user roles temporarily without going offline. The current Telnet user is authorized with user role role1. User role role1 has the following permissions:
·     Allow the execution of all commands starting with the super keyword.
·     Allow management of all interface, VLAN, and VPN instance resources.
Configure user role switching for Telnet users to be able to switch to user roles role2 and network-operator. User role role2 has the following permissions:
·     Allow execution of all commands related to the pre-defined feature group L2 in the system.
Figure 5 Network diagram
Analysis
·     By default, the authentication method for user role switchover is local. In this case, the Telnet user authentication method for device login is local AAA authentication. Therefore, configure the authentication method as local for user role switchover.
·     To enable Telnet user telnetuser to switch the user roles, create local user roles role1 and role2, and configure the corresponding user role rules and resource control policies.
·     For security purposes, configure different switchover passwords for Telnet users to switch to different user roles.
·     One user role can create multiple rules, each identified by a unique number. Users authorized with this role can execute commands defined by the executable command union of these rules. If the permissions defined by two rules have conflicts, the rule with a higher number takes effect. For example, rule 1 allows the execution of command A, rule 2 allows the execution of command B, rule 3 prohibits the execution of command A. Therefore, rules 2 and 3 take effect, which prohibits the execution of command A and allows the execution of command B.
·     The user role after switchover only applies to the current login. Upon re-login, the original user role will be restored.
Procedures
[Router] domain bbb
# Configure user role rule 3 to allow users to execute all commands starting with the super keyword.
[Router-role-role1] rule 3 permit command super *
6.     Create user role role2 and configure its rules.
# Configure user role rule 1 to allow users to execute all commands related to predefined feature group L2.
[Router-role-role2] rule 1 permit execute read write feature-group L2
7.     Configure the authorized user role for the local user.
8.     Configure the user role switchover method and passwords.
# Configure Telnet users to use the local authentication method at user role switchover. By default, the authentication method is local.
[Router] super authentication-mode local
# Configure Telnet users to use plaintext password 123456TESTplat&! When the users switch to user role role2.
[Router] super password role role2 simple 123456TESTplat&!
# Configure Telnet users to use plaintext password 987654TESTplat&! When the users switch to user role network-operator.
[Router] super password role network-operator simple 987654TESTplat&!
[Router] quit
Use the display role command to view information about user roles role1, role2, and network-operator.
# Display information about user role role1.
Role: role1
  Description:
"<Router>, please display the role name as 'role2'."
Role: role2
  Description:
  1       permit RWX   feature-group L2
# Display information about user role network-operator.
<Router> display role name network-operator
Role: network-operator
  Description: Predefined network operator role has access to all read commands
on the Router
  sys-1   permit       command       display *
  sys-2   permit       command       xml
  sys-3   deny         command       display history-command all
  sys-4   deny         command       display exception *
  sys-5   deny         command       display cpu-usage configuration
  sys-6   deny         command       display kernel exception *
  sys-7   deny         command       display kernel deadloop *
  sys-8   deny         command       display kernel starvation *
  sys-9   deny         command       display kernel reboot *
  sys-10  deny         command       display memory trace *
  sys-11  deny         command       display kernel memory *
  sys-12  permit       command       system-view ; local-user *
  sys-13  permit       command       system-view ; switchto mdc *
  sys-14  permit R--   xml-element   -
  sys-15  deny         command       display security-logfile summary
  sys-16  deny         command       system-view ; info-center securi
                                     ty-logfile directory *
  sys-17  deny         command       security-logfile save
Use the display role feature-group command to view feature information in feature groups L2 and L3. (Details not shown.)
Password:
<Router>
3.     Verify user permissions before role switchover.
¡     Execute commands related to features in feature group L3. (This section uses VPN instance vpn1 as an example.)
[Router] quit
¡     Verify that you can execute all commands starting with the display keyword. (The system date and time are for illustration only.)
<Router> display clock
09:31:56 UTC Wed 01/01/2014
<Router>
4.     Verify role switchover.
a.     Use the super command in user view to switch to user role role2.
<Router> super role2
Password:
User privilege role is role2, and only those commands that authorized to the rol
e can be used.
b.     After switching to user role role2, verify that you can execute all commands related to features in feature group L2. (This section creates VLAN 10 as an example.)
[Router] vlan 10
[Router] quit
c.     After switching to user role role2, verify that you cannot execute commands related to features not in feature group L2. (This section uses switchover to user role network-operator as an example.)
<Router> super network-operator
Permission denied.
d.     After switchover to user role role2, verify that you cannot execute commands starting with the display keyword. (The system date and time are for illustration only.)
Permission denied.
e.     Verify that you can execute all commands starting with the super command after the Telnet user relogs in to the device. (This section switches the user role to network-operator as an example.)
Password:
<Router>
Password:
User privilege role is network-operator, and only those commands that authorized
 to the role can be used.
<Router>
Configuration files
line vty 0 63
 super password role role2 hash $h$6$D0kjHFktkktzgR5g$e673xFnIcKytCj6EDAw+pvwgh3
/ung3WNWHnrUTnXT862B+s7PaLfKTdil8ef71RBOvuJvPAZHjiLjrMPyWHQw==
 super password role network-operator hash $h$6$3s5KMmscn9hJ6gPx$IcxbNjUc8u4yxwR
m87b/Jki8BoPAxw/s5bEcPQjQj/cbbXwTVcnQGL91WOd7ssO2rX/wKzfyzAO5VhBTn9Q4zQ==
domain bbb
role name role1
role name role2
 rule 1 permit read write execute feature-group L2
 service-type telnet
As shown in Figure 6, traffic between department A and department B is separated by allocating different VLANs to each department for internal use. To enhance network security in various department networks, use a RADIUS server to authenticate and authorize Telnet users. The specific requirements are as follows: Network administrators from department A and department B use usernames admin-departA and admin-departB, respectively, for authentication.
Network administrator admin-departA of department A has the following network management permissions:
·     Configure flow control policies.
·     Cannot manage interfaces or VPN resources.
·     Can manage only VLANs 100 through VLAN 199.
Network administrator admin-departB of department B has the following network management permissions:
·     Can manage only VLANs 200 through VLAN 299.
Figure 6 Network diagram
Analysis
·     Create user role departA-resource and configure user role rules to allow executing QoS and ACL commands. Configure resource control policies for the users to manage only VLANs 100 through 199 and forbid users to manage interfaces or VPN resources.
·     Create user role departB-resource and configure user role rules to allow executing QoS and ACL commands. Configure resource control policies for the users to manage only VLANs 200 through 299 and forbid users to manage interfaces or VPN resources.
·     Configure the RADIUS server to authorize user role departA-resource for network administrators of department A, and departB-resource for network administrators of department B.
Procedures
1.     Configure interface addresses and the routing protocol.
[Router-GigabitEthernet1/0/2] ip address 20.1.1.2 24
# Configure OSPF to ensure network interconnectivity.
[Router] ospf 1
[Router-ospf-1] area 0.0.0.0
[Router-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[Router-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
2.     Enable Telnet server on the device and configure the RADIUS scheme and ISP domain.
[Router] domain bbb
3.     Configure user role departA-resource on the device.
# Create user role departA-resource, configure user role rules, allow users to execute all commands related to features QoS and ACL.
[Router] role name departA-resource
[Router-role-departA-resource] rule 1 permit read write execute feature qos
[Router-role-departA-resource] rule 2 permit read write execute feature acl
# Configure the VLAN resource control policy and grant operation permission only for VLANs 100 through 199.
[Router-role-departA-resource] vlan policy deny
[Router-role-departA-resource-vlanpolicy] permit vlan 100 to 199
[Router-role-departA-resource-vlanpolicy] quit
# Configure interface and VPN resource access policies to prohibit access to all interfaces and VPN resources.
[Router-role-departA-resource] interface policy deny
[Router-role-departA-resource-ifpolicy] quit
[Router-role-departA-resource] vpn-instance policy deny
[Router-role-departA-resource-vpnpolicy] quit
[Router-role-departA-resource] quit
4.     Configure user role departB-resource on device.
# Create user role departB-resource and configure the user role rules to allow executing all commands related to features QoS and ACL.
[Router] role name departB-resource
[Router-role-departB-resource] rule 1 permit read write execute feature qos
[Router-role-departB-resource] rule 2 permit read write execute feature acl
# Configure the VLAN resource control policy and grant operation permission only for VLANs 200 through 299.
[Router-role-departB-resource] vlan policy deny
[Router-role-departB-resource-vlanpolicy] permit vlan 200 to 299
[Router-role-departB-resource-vlanpolicy] quit
[Router-role-departB-resource] interface policy deny
[Router-role-departB-resource-ifpolicy] quit
[Router-role-departB-resource] vpn-instance policy deny
[Router-role-departB-resource-vpnpolicy] quit
[Router-role-departB-resource] quit
[Router] quit
¡     Select or manually add the device with IP address 20.1.1.2 as an access device.
¡     Specify the username, set the password, and confirm the password. In this example, the username is admin-departA@bbb.
¡     Add user role departA-resource.
¡     Add IP addresses of devices to be managed. In this example, the IP address range is 20.1.1.0 to 20.1.1.10.
¡     Click OK.
3.     Click Add and perform the following tasks:
¡     Specify the username, set the password, and confirm the password. In this example, the username is admin-departB@bbb.
¡     Add user role departB-resource.
¡     Click OK.
Use the display role command to view information about user roles departA-resource and departB-resource.
# Display information about user role departA-resource.
<Router> display role name departA-resource
Role: departA-resource
  Description:
  VLAN policy: deny
  Permitted VLANs: 100 to 199
  1       permit RWX   feature       qos
  2       permit RWX   feature       acl
# Display information about user role departB-resource.
<Router> display role name departB-resource
Role: departB-resource
  Description:
  VLAN policy: deny
  Permitted VLANs: 200 to 299
Use the network administrator of department A as an example.
Make the user initiate a Telnet connection to the device and enter user name admin-departA@bbb and the correct password at the prompt. Verify that you can log in to the device.
login: admin-departA@bbb
Password:
<Router>
After successfully logging in to the device as network administrator admin-departA@bbb, verify the user permissions:
¡     Verify that you can execute all commands related to QoS and ACL features. (This section creates advanced ACLs, traffic classification, traffic behavior, and QoS policies, and associates traffic classification and traffic behavior as an example.)
# Create an advanced ACL numbered 3000.
[Router] acl number 3000
# Configure the ACL rule to match all FTP data flows.
[Router-acl-ipv4-adv-3000] rule permit tcp destination-port eq ftp-data
[Router-acl-ipv4-adv-3000] quit
# Create traffic classifier 1 and specify the rule number as 3000.
[Router] traffic classifier 1
[Router-classifier-1] if-match acl 3000
[Router-classifier-1] quit
# Create traffic classifier 1 and set the rate limit value to 2000 kbps.
[Router] traffic behavior 1
[Router-behavior-1] car cir 2000
[Router-behavior-1] quit
# Create QoS policy 1, and associate traffic classifier 1 with traffic behavior 1.
[Router] qos policy 1
[Router-qospolicy-1] classifier 1 behavior 1
[Router-qospolicy-1] quit
¡     Verify that you can manage VLANs 100 through 199. (This section applies QoS policy 1 to the inbound direction of VLANs 100 through 107.)
# Apply QoS policy 1 to the inbound direction of VLAN 100 through VLAN 107 to rate limit upstream traffic for all hosts.
[Router] qos vlan-policy 1 vlan 100 to 107 inbound
¡     Verify that you cannot manage other VLANs. (This section applies QoS policy 1 to the inbound direction of VLANs 200 through 207.)
# Apply QoS policy 1 to the inbound direction of VLAN 200 through VLAN 207 to rate limit upstream traffic for all hosts.
[Router] qos vlan-policy 1 vlan 200 to 207 inbound
Permission denied.
After successfully logging in to the device as network administrator admin-departB@bbb, verify the user permissions:
# Create an advanced ACL numbered 3001.
[Router] acl number 3001
[Router-acl-ipv4-adv-3001] rule permit tcp destination-port eq ftp-data
[Router-acl-ipv4-adv-3001] quit
# Create traffic classifier 2 and specify the rule number as 3001.
[Router] traffic classifier 2
[Router-classifier-2] if-match acl 3001
[Router-classifier-2] quit
# Create traffic classifier 2 and set the rate limit value to 2000 kbps.
[Router] traffic behavior 2
[Router-behavior-2] car cir 2000
[Router-behavior-2] quit
# Create QoS policy 2, and associate traffic classifier 2 with traffic behavior 2.
[Router] qos policy 2
[Router-qospolicy-2] classifier 1 behavior 2
[Router-qospolicy-2] quit
¡     Verify that you can manage VLANs 200 through 299. (This section applies QoS policy 2 to the inbound direction of VLANs 200 through 207.)
[Router] qos vlan-policy 2 vlan 200 to 207 inbound
¡     Verify that you cannot manage other VLANs. (This section applies QoS policy 2 to the inbound direction of VLANs 100 through 107.)
[Router] qos vlan-policy 2 vlan 100 to 107 inbound
Permission denied.
Configuration files
ospf 1
 area 0.0.0.0
line vty 0 63
radius scheme rad
domain bbb
 vlan policy deny
 vlan policy deny
·     Fundamentals Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Fundamentals Command Reference in H3C MSR5680-X3 Router Command References(V9)
