H3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Configure & DeployConfiguration ExamplesH3C MSR5680-X3 Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
14-IPv6 IS-IS Configuration Examples
14-IPv6 IS-IS Configuration Examples 109.60 KB
H3C Routers
Introduction
This document provides IPv6 IS-IS configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPv6 IS-IS.
Example: Configuring IPv6 IS-IS
As shown in Figure 1, the company's headquarters and the branch run IPv6 IS-IS. The partner runs OSPFv3.
Configure the routers to meet the following requirements:
·     The Marketing department can reach the F&A department, the branch, and the partner.
·     The F&A department and the branch cannot reach each other, and the branch does not have a route to the F&A department.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To reduce traffic for Router A and Router B, configure them as Level-1 routers to allow communication only between the Marketing department and the Finance department.
·     Configure Router C to use a prefix list to advertise only network 3001:1::/64 to Level-2, so that the branch does not have a route to the Finance department.
·     Configure route redistribution between IPv6 IS-IS and OSPFv3 on Router D to allow communication between the Marketing department and the partner.
Software versions used
This configuration example was created and verified on R9141P16 of the MSR5680-X3 device.
Procedures
Configuring Router A
# Configure an IPv6 address for GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] ipv6 address 2001:1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IPv6 IS-IS.
[RouterA] isis 1
[RouterA-isis-1] is-level level-1
[RouterA-isis-1] network-entity 10.3001.0001.0001.00
[RouterA-isis-1] address-family ipv6 unicast
[RouterA-isis-1-ipv6] quit
[RouterA-isis-1] quit
[RouterA–GigabitEthernet1/0/1] isis ipv6 enable 1
[RouterA–GigabitEthernet1/0/1] quit
[RouterA–GigabitEthernet1/0/2] isis ipv6 enable 1
[RouterA–GigabitEthernet1/0/2] quit
Configuring Router B
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] ipv6 address 2001:2::1 64
[RouterB] isis 1
[RouterB-isis-1] is-level level-1
[RouterB-isis-1] network-entity 10.3001.0002.0001.00
[RouterB-isis-1] address-family ipv6 unicast
[RouterB-isis-1-ipv6] quit
[RouterB-isis-1] quit
[RouterB–GigabitEthernet1/0/1] isis ipv6 enable 1
[RouterB–GigabitEthernet1/0/1] quit
[RouterB–GigabitEthernet1/0/2] isis ipv6 enable 1
[RouterB–GigabitEthernet1/0/2] quit
Configuring Router C
<RouterC> system-view
[RouterC-GigabitEthernet1/0/1] ipv6 address 2001:1::2 64
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.2001.0010.0001.00
[RouterC-isis-1] address-family ipv6 unicast
[RouterC-isis-1-ipv6] quit
[RouterC-isis-1] quit
[RouterC–GigabitEthernet1/0/1] isis ipv6 enable 1
[RouterC–GigabitEthernet1/0/1] quit
[RouterC–GigabitEthernet1/0/2] isis ipv6 enable 1
[RouterC–GigabitEthernet1/0/2] quit
[RouterC] interface gigabitethernet 1/0/3
[RouterC–GigabitEthernet1/0/3] isis ipv6 enable 1
[RouterC–GigabitEthernet1/0/3] quit
# Configure IPv6 route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 3001:1::/64 to Level-2.
[RouterC] ipv6 prefix-list 1 permit 3001:1:: 64
[RouterC] isis 1
[RouterC-isis-1-ipv6] import-route isisv6 level-1 into level-2 filter-policy prefix-list 1
Configuring Router D
<RouterD> system-view
[RouterD-GigabitEthernet1/0/1] ipv6 address 2001:10::2 64
[RouterD-GigabitEthernet1/0/1] quit
[RouterD] isis 1
[RouterD-isis-1] is-level level-2
[RouterD-isis-1] network-entity 20.2001.0020.0001.00
[RouterD-isis-1] address-family ipv6 unicast
[RouterD-isis-1-ipv6] quit
[RouterD-isis-1] quit
[RouterD–GigabitEthernet1/0/1] isis ipv6 enable 1
[RouterD–GigabitEthernet1/0/1] quit
[RouterD] interface gigabitethernet 1/0/2
[RouterD–GigabitEthernet1/0/2] isis ipv6 enable 1
[RouterD–GigabitEthernet1/0/2] quit
# Configure OSPFv3.
[RouterD] ospfv3 1
[RouterD-ospfv3-1] router-id 4.4.4.4
[RouterD-ospfv3-1] quit
[RouterD–GigabitEthernet1/0/2] ospfv3 1 area 0
# Redistribute OSPFv3 and direct routes into IPv6 IS-IS.
[RouterD] isis 1
[RouterD-isis-1-ipv6] import-route ospfv3
[RouterD-isis-1-ipv6] import-route direct
# Redistribute IPv6 IS-IS and direct routes into OSPFv3.
[RouterD] ospfv3 1
[RouterD-ospfv3-1] import-route isisv6 1
[RouterD-ospfv3-1] import-route direct
Configuring Router E
<RouterE> system-view
[RouterE] interface gigabitethernet 1/0/1
[RouterE-GigabitEthernet1/0/1] ipv6 address 2001:20::2 64
[RouterE-GigabitEthernet1/0/1] quit
# Configure OSPFv3.
[RouterE] ospfv3 1
[RouterE-ospfv3-1] router-id 5.5.5.5
[RouterE-ospfv3-1] quit
[RouterE–GigabitEthernet1/0/1] ospfv3 1 area 0
[RouterE–GigabitEthernet1/0/1] quit
[RouterE] interface gigabitethernet 1/0/2
[RouterE–GigabitEthernet1/0/2] ospfv3 1 area 0
[RouterE–GigabitEthernet1/0/2] quit
# View the IPv6 IS-IS routing table on Router D and verify that the branch can reach the Marketing department, but cannot reach the F&A department.
[RouterD] display isis route ipv6
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:10::                               PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: GE1/0/1
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Next Hop    : FE80::7625:8AFF:FE02:4D13               Interface: GE1/0/1
 Destination : 2001:2::                                PrefixLen: 64
 Destination : 3001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 30
# Verify that the company can communicate with the partner.
·     Display the IPv6 IS-IS routing table on Router C.
[RouterC] display isis route ipv6 level-2
 Next Hop    : Direct                                  Interface: GE1/0/3
 Next Hop    : Direct                                  Interface: GE1/0/2
 Destination : 2001:20::                               PrefixLen: 64
 Flag        : R/L/-                                   Cost     : 20
 Next Hop    : FE80::BAAF:67FF:FE30:3304               Interface: GE1/0/3
 Destination : 3001:200::                              PrefixLen: 64
·     Ping 3001:200::1 from Router C.
[RouterC] ping ipv6 3001:200::1
Ping6(56 data bytes) 2001:10::1 --> 3001:200::1, press CTRL_C to break
56 bytes from 3001:200::1, icmp_seq=0 hlim=63 time=7.230 ms
56 bytes from 3001:200::1, icmp_seq=1 hlim=63 time=3.449 ms
56 bytes from 3001:200::1, icmp_seq=2 hlim=63 time=2.779 ms
56 bytes from 3001:200::1, icmp_seq=3 hlim=63 time=2.652 ms
56 bytes from 3001:200::1, icmp_seq=4 hlim=63 time=2.558 ms
--- Ping6 statistics for 3001:200::1 ---
round-trip min/avg/max/std-dev = 2.558/3.734/7.230/1.776 ms
Configuration files
Router A
isis 1
 is-level level-1
 isis ipv6 enable 1
 ipv6 address 2001:1::1/64
 isis ipv6 enable 1
 ipv6 address 3001:1::1/64
Router B
isis 1
 is-level level-1
 isis ipv6 enable 1
 ipv6 address 2001:2::1/64
 isis ipv6 enable 1
 ipv6 address 3001:2::1/64
Router C
isis 1
 isis ipv6 enable 1
 ipv6 address 2001:1::2/64
 isis ipv6 enable 1
 ipv6 address 2001:2::2/64
 isis ipv6 enable 1
 ipv6 address 2001:10::1/64
 ipv6 prefix-list 1 index 10 permit 3001:1:: 64
Router D
isis 1
 is-level level-2
  import-route direct
  import-route ospfv3 1
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
 import-route direct
 isis ipv6 enable 1
 ipv6 address 2001:10::2/64
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001:20::1/64
Router E
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
 ospfv3 1 area 0
 ipv6 address 2001:20::2/64
 ospfv3 1 area 0
 ipv6 address 3001:200::1/64
Related documentation
·     Layer 3—IP Routing Configuration Guide in H3C MSR5680-X3 Router Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C MSR5680-X3 Router Command References(V9)
