05-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10205-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
17-Scheduled WLAN Access Services Configuration Examples
H3C Access Controllers
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring scheduled WLAN access services.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of DHCP and WLAN access.
Example: Configuring scheduled WLAN access services
As shown in Figure 1, the AC connects to the Layer 2 switch and the Layer 3 switch acts as a DHCP server to assign IP addresses to the AP and the client.
Configure network settings to meet the following requirements:
·     The client accesses the WLAN over VLAN 200.
·     The AC and the AP communicate with each other over VLAN 100.
·     The Layer 2 switch supplies power to the AP through PoE.
·     The AP provides WLAN access services only from 8:00 to 20:00 every day.
Figure 1 Network diagram
Analysis
·     For the Layer 3 switch to act as a DHCP server, enable the DHCP server feature on the switch.
·     For the Layer 2 switch to supply power to the AP, enable the PoE feature on the switch.
·     Create two schedules to enable and disable the WLAN service template on the AC at specific time points.
When you configure a serial ID for the AP, use the serial ID labeled on the AP's rear panel.
Procedures
Configuring the Layer 3 switch
1.     Configure Layer 3 switch interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.168.10.1 to the interface. The switch communicates with the AC over VLAN 100.
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ip address 192.168.10.1 255.255.255.0
[L3 switch-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign IP address 192.168.20.1 to the interface. The client will use this VLAN to access the WLAN.
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ip address 192.168.20.1 255.255.255.0
[L3 switch-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 that connects the switch to the Layer 2 switch to trunk. Remove the port from VLAN 1 and assign the port to VLAN 100 and VLAN 200.
[L3 switch] interface gigabitEthernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[L3 switch-GigabitEthernet1/0/1] quit
2.     Configure the DHCP server feature:
# Enable DHCP server.
[L3 switch] dhcp enable
# Create DHCP address pool 1 for dynamic IP allocation to the AP. Specify 192.168.10.0/24 as the subnet and 192.168.10.1 as the gateway address in the address pool.
[L3 switch] dhcp server ip-pool 1
[L3 switch-dhcp-pool-1] network 192.168.10.0 mask 255.255.255.0
[L3 switch-dhcp-pool-1] gateway-list 192.168.10.1
# Exclude the IP address of VLAN-interface 100 on the AC from dynamic IP allocation in DHCP address pool 1.
[L3 switch-dhcp-pool-1] forbidden-ip 192.168.10.2
[L3 switch-dhcp-pool-1] quit
# Create DHCP address pool 2 for dynamic IP allocation to the client. Specify 192.168.20.0/24 as the subnet and 192.168.20.1 as the gateway address in the address pool, and then specify the address of the DNS server. In this example, the gateway also acts as the DNS server.
[L3 switch] dhcp server ip-pool 2
[L3 switch-dhcp-pool-2] network 192.168.20.0 mask 255.255.255.0
[L3 switch-dhcp-pool-2] gateway-list 192.168.20.1
[L3 switch-dhcp-pool-2] dns-list 192.168.20.1
[L3 switch-dhcp-pool-2] quit
Configuring the AC
1.     Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign IP address 192.168.10.2 to the interface. The AC will establish a CAPWAP tunnel with the AP in this VLAN.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.10.2 255.255.255.0
[AC-Vlan-interface100] quit
# Create VLAN 200. The client will use this VLAN to access the WLAN.
[AC] vlan 200
[AC-vlan200] quit
# Set the link type of GigabitEthernet 1/0/1 that connects the AC to the Layer 2 switch to trunk. Remove the port from VLAN 1 and assign the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure a wireless service:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Set the SSID to service1.
[AC-wlan-st-1] ssid service1
# Specify the AKM mode as PSK, and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-1] akm mode psk
[AC-wlan-st-1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-1] cipher-suite ccmp
[AC-wlan-st-1] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-1] client forwarding-location ac
# Enable service template 1.
[AC-wlan-st-1] quit
3.     Configure AP settings:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA6320
[AC-wlan-ap-officeap] serial-id 209801A28N819CE0002T
[AC-wlan-ap-officeap] quit
# Create AP group group1 and add the AP to the AP group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap officeap
# Bind service template 1 and VLAN 200 to radio 1 in group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC-wlan-ap-group-group1-ap-model-WA6320] quit
[AC-wlan-ap-group-group1] quit
4.     Configure the AC to enable service template 1 at a specific time point.
# Create job officeap_service_enable to enable service template 1.
[AC] scheduler job officeap_service_enable
[AC-job-officeap_service_enable] command 1 system-view
[AC-job-officeap_service_enable] command 2 wlan service-template 1
[AC-job-officeap_service_enable] command 3 service-template enable
[AC-job-officeap_service_enable] command 4 quit
[AC-job-officeap_service_enable] quit
# Create schedule officeap_service_enable and assign job officeap_service_enable to the schedule. The AC will enable service template 1 at 8:00 a.m. every day.
[AC] scheduler schedule officeap_service_enable
[AC-schedule-officeap_service_enable] job officeap_service_enable
[AC-schedule-officeap_service_enable] time repeating at 08:00
[AC-schedule-officeap_service_enable] quit
5.     Configure the AC to disable service template 1 at a specific time point.
# Create job officeap_service_disable to disable service template 1.
[AC] scheduler job officeap_service_disable
[AC-job-officeap_service_disable] command 1 system-view
[AC-job-officeap_service_disable] command 2 wlan service-template 1
[AC-job-officeap_service_disable] command 3 undo service-template enable
[AC-job-officeap_service_disable] command 4 quit
[AC-job-officeap_service_disable] quit
# Create schedule officeap_service_disable and assign job officeap_service_disable to the schedule. The AC will disable service template 1 at 20:00 every day.
[AC] scheduler schedule officeap_service_disable
[AC-schedule-officeap_service_disable] job officeap_service_disable
[AC-schedule-officeap_service_disable] time repeating at 20:00
[AC-schedule-officeap_service_disable] quit
[AC] quit
Configuring the Layer 2 switch
# Create VLAN 100 and VLAN 200. The switch will use VLAN 100 to forward traffic between the AC and other devices. The client will use VLAN 200 to access the WLAN.
<L2 switch> system-view
[L2 switch] vlan 100
[L2 switch-vlan100] quit
[L2 switch] vlan 200
[L2 switch-vlan200] quit
# Set the link type of GigabitEthernet 1/0/1 that connects the switch to the AC to trunk. Remove the port from VLAN 1 and assign the port to VLAN 100 and VLAN 200.
[L2 switch] interface gigabitEthernet 1/0/1
[L2 switch-GigabitEthernet1/0/1] port link-type trunk
[L2 switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[L2 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[L2 switch-GigabitEthernet1/0/1] quit
# Set the link type of GigabitEthernet 1/0/2 that connects the switch to the AP to access. Assign the port to VLAN 100 and enable PoE.
[L2 switch] interfac gigabitEthernet 1/0/2
[L2 switch-GigabitEthernet1/0/2] port link-type access
[L2 switch-GigabitEthernet1/0/2] port access vlan 100
[L2 switch-GigabitEthernet1/0/2] poe enable
[L2 switch-GigabitEthernet1/0/2] quit
# Set the link type of GigabitEthernet 1/0/3 that connects the switch to the Layer 3 switch to trunk. Remove the port from VLAN 1 and assign the port to VLAN 100 and VLAN 200.
[L2 switch] interface gigabitEthernet 1/0/3
[L2 switch-GigabitEthernet1/0/3] port link-type trunk
[L2 switch-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[L2 switch-GigabitEthernet1/0/3] port trunk permit vlan 100 200
[L2 switch-GigabitEthernet1/0/3] quit
# Use the display wlan ap all command to view AP information on the AC. If the AP has connected to the AC, the state of the AP is R/M.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 512
Local AP licenses: 512
Server AP licenses: 0
Remaining local AP licenses: 511
Sync AP licenses: 0
                                 AP information
 State : I = Idle,      J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                APID   State   Model             Serial ID
officeap               1      R/M     WA6320            209801A28N819CE0002T
# During the period when the AC is scheduled to provide WLAN services, use the display wlan service-template command to view service template information on the AC. Service template 1 is enabled.
<AC> display wlan service-template 1
Service template name           SSID                                    Status
1                               service1                                Enabled
# During the period when the AC is scheduled to provide WLAN services, use the display wlan client command to view client information on the AC. The client has connected to radio 1 of the AP.
<AC> display wlan client
Total number of clients: 1
MAC address    User name            AP name               R IP address      VLAN
109a-dd9d-fc68 N/A                  officeap              1 192.168.20.2    200
# During the period when the AC is scheduled to not provide WLAN services, use the display wlan service-template command to view service template information on the AC. Service template 1 is disabled.
1                               service1                                Disabled
# During the period when the AC is scheduled to not provide WLAN services, use the display wlan client command to view client information on the AC. No client is online because service template 1 is disabled.
<AC>
Configuration files
·     L3 switch
 dhcp enable
vlan 1
vlan 100
vlan 200
interface Vlan-interface100
interface Vlan-interface200
·     AC
vlan 100
vlan 200
 ssid service1
akm mode psk
 preshared-key pass-phrase cipher $c$3$oLf6pOZ6bxrf25nodjOJKYEfnZ6g6ErccHyQ
 cipher-suite ccmp
 security-ie rsn
 command 4 quit
 command 4 quit
 user-role network-operator
 user-role network-admin
 ap officeap
 ap-model WA6320
  radio 1
   radio enable
  radio 2
·     L2 switch
vlan 100
vlan 200
 poe enable
Related documentation
·     AP and WT Management Command Reference in H3C Access Controllers Command References
·     AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
