05-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10205-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
76-Inter-AC Roaming (IPv6) Configuration Examples
H3C Access Controllers
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an inter-AC roaming configuration example.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of IPv6 basics, WLAN access, and WLAN roaming.
Example: Configuring inter-AC roaming
As shown in Figure 1, AP 1 and AP 2 are managed by AC 1 and AC 2, respectively. Clients associated with AC 1 belong to VLAN 200. Clients associated with AC 2 belong to VLAN 400.
Complete the following tasks:
·     Configure all devices to use IPv6 addresses.
·     Configure inter-AC roaming to enable clients to roam between AP 1 and AP 2.
·     Configure VLAN-based user isolation to improve user security and reduce radio resources consumption caused by multicast and broadcast packets.
Figure 1 Network diagram
Table 1 Interface and IPv6 address assignment
Device
IPv6 address
AC 1
VLAN-interface 100
1::1:0:0:2/96
VLAN-interface 200
1::2:0:0:2/96
AC 2
VLAN-interface 100
1::1:0:0:3/96
VLAN-interface 400
1::4:0:0:2/96
Switch
VLAN-interface 100
1::1:0:0:1/96
VLAN-interface 200
1::2:0:0:1/96
VLAN-interface 300
1::3:0:0:1/96
VLAN-interface 400
1::4:0:0:1/96
When you configure inter-AC roaming, follow these restrictions and guidelines:
·     Configure the same SSID, authentication mode, AKE mode, and cipher suite for the service templates to be bound to the APs that are used during WLAN roaming.
·     For successful fast roaming, configure RSN + 802.1X authentication for clients.
·     Add the two ACs to the same mobility group.
·     Use the actual serial ID of an AP to uniquely identify that AP.
Procedures
Configuring AC 1
1.     Configure interfaces on AC 1:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The AC will use this IPv6 address to establish CAPWAP tunnels with APs.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ipv6 address 1::1:0:0:2/96
[AC1-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IPv6 address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC1] vlan 200
[AC1-vlan200] quit
[AC1] interface vlan-interface 200
[AC1-Vlan-interface200] ipv6 address 1::2:0:0:2/96
[AC1-Vlan-interface200] quit
# Create VLAN 400. The AC will use VLAN 400 to forward data of the client after the client roams from AP 2 to AP 1.
<AC1> system-view
[AC1] vlan 400
[AC1-vlan400] quit
# Configure the interface that is connected to the switch as a trunk port, and assign the port to VLAN 100, VLAN 200, and VLAN 400.
[AC1] interface gigabitethernet 1/0/1
[AC1-GigabitEthernet1/0/1] port link-type trunk
[AC1-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
[AC1-GigabitEthernet1/0/1] quit
# Configure the interface that is connected to AP 1 as an access port, and assign the port to VLAN 100.
[AC1] interface gigabitethernet 1/0/2
[AC1-GigabitEthernet1/0/2] port link-type access
[AC1-GigabitEthernet1/0/2] port access vlan 100
[AC1-GigabitEthernet1/0/2] quit
2.     Configure 802.1X authentication:
# Set the EAP message handling method to EAP.
[AC1] dot1x authentication-method eap
# Create a RADIUS scheme named office and enter its view.
[AC1] radius scheme office
# Specify the server at 1::3:0:0:2 as the primary authentication server.
[AC1-radius-office] primary authentication ipv6 1::3:0:0:2
# Specify the server at 1::3:0:0:2 as the primary accounting server.
[AC1-radius-office] primary accounting ipv6 1::3:0:0:2
# Set the shared key to 12345678 for secure communication with the primary authentication server and accounting server.
[AC1-radius-office] key authentication simple 12345678
[AC1-radius-office] key accounting simple 12345678
# Set the source IPv6 address to 1::1:0:0:2 for outgoing RADIUS packets.
[AC1-radius-office] nas-ip ipv6 1::1:0:0:2
[AC1-radius-office] quit
# Create an ISP domain named office and enter its view.
[AC1] domain office
# Configure the ISP domain to use RADIUS scheme office for authentication, authorization, and accounting of LAN users.
[AC1-isp-office] authentication lan-access radius-scheme office
[AC1-isp-office] authorization lan-access radius-scheme office
[AC1-isp-office] accounting lan-access radius-scheme office
[AC1-isp-office] quit
3.     Configure the wireless service:
# Create service template 1 and enter its view.
[AC1] wlan service-template 1
# Set the SSID to service.
[AC1-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC1-wlan-st-1] vlan 200
# Use the AC to forward client traffic.
[AC1-wlan-st-1] client forwarding-location ac
# Set the AKE mode to 802.1X.
[AC1-wlan-st-1] akm mode dot1x
# Set the authentication mode to 802.1X for wireless clients.
[AC1-wlan-st-1] client-security authentication-mode dot1x
# Specify ISP domain office as the authentication domain for 802.1X clients.
[AC1-wlan-st-1] dot1x domain office
# Specify AES-CCMP as the cipher suite used for frame encryption.
[AC1-wlan-st-1] cipher-suite ccmp
# Enable the RSN IE in beacon and probe responses.
[AC1-wlan-st-1] security-ie rsn
# Enable the service template.
[AC1-wlan-st-1] service-template enable
# Enable snooping DHCPv6 and ND packets.
[AC1-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AC1-wlan-st-1] client ipv6-snooping nd-learning enable
[AC1-wlan-st-1] quit
4.     Configure an AP:
In a large-scale network, configure AP settings in AP group view instead of AP view as a best practice.
# Create an AP named ap1, and specify its model and the serial ID.
[AC1] wlan ap ap1 model WA6320
[AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create AP group group1, and configure a grouping rule by AP name to add AP ap1 to the group.
[AC1] wlan ap-group group1
[AC1-wlan-ap-group-group1] ap ap1
# Bind service template 1 to radio 1, and enable radio 1.
[AC1-wlan-ap-group-group1] ap-model WA6320
[AC1-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template 1
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
[AC1-wlan-ap-group-group1-ap-model-WA6320] quit
5.     Configure WLAN roaming:
# Create mobility group 1.
[AC1] wlan mobility group 1
# Set the source IPv6 address for establishing IACTP tunnels to 1::1:0:0:2.
[AC1-wlan-mg-1] source ipv6 1::1:0:0:2
# Add AC 2 to the mobility group.
[AC1-wlan-mg-1] member ipv6 1::1:0:0:3
# Specify the IP address type as IPv6 for IACTP tunnels.
[AC1-wlan-mg-1] tunnel-type ipv6
# Enable the mobility group.
[AC1-wlan-mg-1] group enable
[AC1-wlan-mg-1] quit
6.     Configure user isolation:
# Enable user isolation for VLAN 200.
[AC1] user-isolation vlan 200 enable
# Specify the MAC address of the gateway for VLAN 200 as a permitted MAC address for VLAN 200.
[AC1] user-isolation vlan 200 permit-mac 000f-e212-7788
7.     Configure a default route:
# Configure a default route for AC 1. Set the next hop to 1::1:0:0:1.
[AC1] ipv6 route-static 0::0 96 1::1:0:0:1
Configuring AC 2
1.     Configure interfaces on AC 2:
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface vlan-interface 100
[AC2-Vlan-interface100] ipv6 address 1::1:0:0:3/96
[AC2-Vlan-interface100] quit
# Create VLAN 200. The AC will use VLAN 200 to forward data of the client after the client roams from AP 1 to AP 2.
<AC2> system-view
[AC2] vlan 200
[AC2-vlan200] quit
# Create VLAN 400 and VLAN-interface 400, and assign an IPv6 address to the VLAN interface. The AC will use VLAN 400 for client access.
[AC2] vlan 400
[AC2-vlan400] quit
[AC2] interface vlan-interface 400
[AC2-Vlan-interface400] ipv6 address 1::4:0:0:2/96
[AC2-Vlan-interface400] quit
[AC2] interface gigabitethernet 1/0/1
[AC2-GigabitEthernet1/0/1] port link-type trunk
[AC2-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
[AC2-GigabitEthernet1/0/1] quit
# Configure the interface that is connected to AP 2 as an access port, and assign the port to VLAN 100.
[AC2] interface gigabitethernet 1/0/2
[AC2-GigabitEthernet1/0/2] port link-type access
[AC2-GigabitEthernet1/0/2] port access vlan 100
[AC2-GigabitEthernet1/0/2] quit
[AC2] dot1x authentication-method eap
[AC2] radius scheme office
[AC2-radius-office] primary authentication ipv6 1::3:0:0:2
[AC2-radius-office] primary accounting ipv6 1::3:0:0:2
# Set the shared key to 12345678 in plaintext form for secure authentication communication.
[AC2-radius-office] key authentication simple 12345678
# Set the shared key to 12345678 in plaintext form for secure accounting communication.
[AC2-radius-office] key accounting simple 12345678
# Set the source IPv6 address to 1::1:0:0:3 for outgoing RADIUS packets.
[AC2-radius-office] nas-ip ipv6 1::1:0:0:3
[AC2-radius-office] quit
[AC2] domain office
[AC2-isp-office] authentication lan-access radius-scheme office
[AC2-isp-office] authorization lan-access radius-scheme office
[AC2-isp-office] accounting lan-access radius-scheme office
[AC2-isp-office] quit
[AC2] wlan service-template 1
[AC2-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 400.
[AC2-wlan-st-1] vlan 400
[AC2-wlan-st-1] akm mode dot1x
[AC2-wlan-st-1] client-security authentication-mode dot1x
[AC2-wlan-st-1] dot1x domain office
[AC2-wlan-st-1] cipher-suite ccmp
[AC2-wlan-st-1] security-ie rsn
[AC2-wlan-st-1] service-template enable
[AC2-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AC2-wlan-st-1] client ipv6-snooping nd-learning enable
[AC2-wlan-st-1] quit
4.     Configure an AP:
# Create an AP named ap2, and specify its model and the serial ID.
[AC2] wlan ap ap2 model WA6320
[AC2-wlan-ap-ap2] serial-id 219801A28N819CE0002T
# Create AP group group2, and configure a grouping rule by AP name to add AP ap2 to the group.
[AC2] wlan ap-group group2
[AC2-wlan-ap-group-group2] ap ap2
[AC2-wlan-ap-group-group2] ap-model WA6320
[AC2-wlan-ap-group-group2-ap-model-WA6320] radio 1
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] service-template 1
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] radio enable
[AC2-wlan-ap-group-group2-ap-model-WA6320-radio-1] quit
[AC2-wlan-ap-group-group2-ap-model-WA6320] quit
[AC2] wlan mobility group 1
# Set the source IPv6 address for establishing IACTP tunnels to 1::1:0:0:3.
[AC2-wlan-mg-1] source ipv6 1::1:0:0:3
# Add AC 1 to the mobility group.
[AC2-wlan-mg-1] member ipv6 1::1:0:0:2
[AC2-wlan-mg-1] group enable
[AC2-wlan-mg-1] quit
# Enable user isolation for VLAN 400.
[AC2] user-isolation vlan 400 enable
# Specify the MAC address of the gateway for VLAN 400 as a permitted MAC address for VLAN 400.
[AC2] user-isolation vlan 400 permit-mac 000f-eeee-1212
# Configure a default route for AC 2. Set the next hop to 1::1:0:0:1.
[AC2] ipv6 route-static 0::0 96 1::1:0:0:1
Configuring the switch
1.     Configure interfaces on the switch:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ipv6 address 1::1:0:0:1/96
# Create VLAN 200 and VLAN-interface 200, and assign an IPv6 address to the VLAN interface. The switch will use VLAN 200 to forward client traffic of AC 1.
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ipv6 address 1::2:0:0:1/96
[Switch-Vlan-interface200] quit
# Create VLAN 400 and VLAN-interface 400, and assign an IPv6 address to the VLAN interface. The switch will use VLAN 400 to forward client traffic of AC 2.
[Switch] vlan 400
[Switch-vlan400] quit
[Switch] interface vlan-interface 400
[Switch-Vlan-interface400] ipv6 address 1::4:0:0:1/96
[Switch-Vlan-interface400] quit
# Create VLAN 300 and VLAN-interface 300, and assign an IPv6 address to the VLAN interface. The switch will use VLAN 300 to forward traffic to the RADIUS server.
[Switch] vlan 300
[Switch-vlan300] quit
[Switch] interface vlan-interface 300
[Switch-Vlan-interface300] ipv6 address 1::3:0:0:1/96
[Switch-Vlan-interface300] quit
# Configure the interface that is connected to AC 1 as a trunk port, and assign the port to VLAN 100, VLAN 200, and VLAN 400.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200 400
# Configure the interface that is connected to AC 2 as a trunk port, and assign the port to VLAN 100, VLAN 200, and VLAN 400.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200 400
# Configure the interface that is connected to the RADIUS server as an access port, and assign the port to VLAN 300.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 300
[Switch-GigabitEthernet1/0/3] quit
2.     Configure the DHCPv6 server:
# Enable the DHCPv6 server on VLAN-interface 100, VLAN-interface 200, and VLAN-interface 300, and apply DHCPv6 address pools to the interfaces.
[Switch-Vlan-interface100] ipv6 dhcp select server
[Switch-Vlan-interface100] ipv6 dhcp server apply pool 1
[Switch-Vlan-interface200] ipv6 dhcp select server
[Switch-Vlan-interface200] ipv6 dhcp server apply pool 2
[Switch-Vlan-interface400] ipv6 dhcp select server
[Switch-Vlan-interface400] ipv6 dhcp server apply pool 3
# Disable RA message suppression. Set both the M flag and O flag to 1 in RA advertisements to be sent.
[Switch-Vlan-interface100] undo ipv6 nd ra halt
[Switch-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface100] ipv6 nd autoconfig other-flag
[Switch-Vlan-interface200] undo ipv6 nd ra halt
[Switch-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface200] ipv6 nd autoconfig other-flag
[Switch-Vlan-interface400] undo ipv6 nd ra halt
[Switch-Vlan-interface400] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface400] ipv6 nd autoconfig other-flag
# Configure DHCPv6 address pool 1. Specify the subnet 1::1:0:0:0/96 and configure Option 52.
[Switch] ipv6 dhcp pool 1
[Switch-dhcp6-pool-1] network 1::1:0:0:0/96
[Switch-dhcp6-pool-1] option 52 hex 00010000000000000001000000000010
[Switch-dhcp6-pool-1] quit
# Configure DHCPv6 address pool 2. Specify the subnet 1::2:0:0:0/96 and configure Option 52.
[Switch] ipv6 dhcp pool 2
[Switch-dhcp6-pool-2] network 1::2:0:0:0/96
[Switch-dhcp6-pool-1] option 52 hex 00010000000000000001000000000011
[Switch-dhcp6-pool-2] quit
# Configure DHCPv6 address pool 3. Specify the subnet 1::4:0:0:0/96.
[Switch] ipv6 dhcp pool 3
[Switch-dhcp6-pool-3] network 1::4:0:0:0/96
[Switch-dhcp6-pool-3] quit
Configuring the RADIUS server
In this example, the RADIUS server runs on iMC PLAT 7.1 and iMC EIA 7.1.
1.     Add the ACs to the IMC Platform as access devices:
a.     Log in to IMC.
b.     Click the User tab.
c.     From the navigation tree, select User Access Policy > Access Device Management > Access Device.
d.     Click Add and perform the following tasks:
-     Enter 12345678 in the Shared Key field.
-     Add IPv6 addresses 1::1:0:0:2 and 1::1:0:0:3 to the Device List.
-     Use the default settings for other parameters.
e.     Click OK.
Figure 2 Adding access devices
2.     Add an access policy:
a.     From the navigation tree, select User Access Policy > Access Policy.
b.     Click Add to add an access policy that uses the following settings:
-     Access Policy Name—dot1x.
-     Preferred EAP Type—EAP-PEAP.
-     Subtype—EAP-MSCHAPv2. The subtype must match the client authentication method.
Figure 3 Adding an access policy
3.     Add an access service:
a.     From the navigation tree, select User Access Policy > Access Service.
b.     Click Add to add an access service that uses the following settings:
-     Service Name—dot1x.
-     Default Access Policy—dot1x.
Figure 4 Adding an access service
4.     Add an access user:
a.     From the navigation tree, select All Access Users.
b.     Click Add and perform the following tasks:
-     Click Add User to add a user with username user.
-     Set the Account Name to dot1x.
-     Set the Password to dot1x.
-     Select the dot1x service.
Figure 5 Adding an access user
# Enable the client to come online from AP 1. (Details not shown.)
# On AC 1, verify that the client is associated with AP 1.
<AC1> display wlan client verbose
Total number of clients: 1
MAC address                        : 0015-00ba-0428
 IPv4 address                      : N/A
 IPv6 address                      : 1::2:0:0:2
 Username                          : dot1x
 AID                               : 1
 AP ID                             : 1
 AP name                           : ap1
 Radio ID                          : 1
 SSID                              : service
 BSSID                             : 5866-ba71-3960
 VLAN ID                           : 200
 Sleep count                       : 0
 Wireless mode                     : 802.11ac
 Channel bandwidth                 : 40MHz
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 STBC RX capability                : Supported
 STBC TX capability                : Not supported
 LDPC RX capability                : Not supported
 Beamformee STS capability         : 2
 Number of Sounding Dimensions     : 1
 SU beamformee capability          : Supported
 MU beamformee capability          : Not supported
 Block Ack                         : N/A
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode                          : WMM
 Listen interval                   : 250
 RSSI                              : 0
 Rx/Tx rate                        : 0/0
 Authentication method             : Open system
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 User authentication mode          : 802.1X
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : SHA1
 PMF status                        : N/A
 Forwarding policy name            : N/A
 Online time                       : 0days 0hours 0minutes 17seconds
 FT status                         : Inactive
# Move the client toward AP 2 for the client to roam to AP 2.
# On AC 2, verify that the client is associated with AP 2.
<AC2> display wlan client verbose
 IPv4 address                      : N/A
 Username                          : dot1x
 AID                               : 1
 AP ID                             : 1
 AP name                           : ap2
 Radio ID                          : 1
 SSID                              : service
 BSSID                             : 5860-ba71-3960
 VLAN ID                           : 200
 Sleep count                       : 0
 Block Ack                         : N/A
                                     15
                                     48, 54 Mbps
 QoS mode                          : WMM
 RSSI                              : 0
 Rx/Tx rate                        : 0/0
 Security mode                     : RSN
 AKM mode                          : 802.1X
 Cipher suite                      : CCMP
 Roam status                       : Inter-AC roam
 PMF status                        : N/A
# Verify that clients in VLAN 200 and VLAN 400 can access the Internet but cannot access a client in the same VLAN. (Details not shown.)
Configuration files
·     Switch:
dhcp enable
vlan 100
vlan 200
vlan 300
vlan 400
ipv6 dhcp pool 1
ipv6 dhcp pool 2
ipv6 dhcp pool 3
interface Vlan-interface100
interface Vlan-interface200
interface Vlan-interface300
interface Vlan-interface400
·     AC 1:
vlan 100
vlan 200
vlan 400
 ssid service
 vlan 200
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 dot1x domain office
domain office
 ap ap1
 ap-model WA6320
 radio 1
 service-template 1
 radio enable
 tunnel-type ipv6
 group enable
·     AC 2:
vlan 100
vlan 200
vlan 400
 ssid service
 vlan 400
 akm mode dot1x
 cipher-suite ccmp
 security-ie rsn
 dot1x domain office
domain office
ap ap2
ap-model WA6320
radio 1
service-template 1
radio enable
 tunnel-type ipv6
 group enable
Related documentation
·     AP and WT Management Command Reference in H3C Access Controllers Command References
·     AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
