- 05-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
- 01-HTTPS Login Configuration Examples
- 02-SSH Configuration Examples
- 03-License Management Configuration Examples
- 04-AP Association with the AC at Layer 2 Configuration Examples
- 05-AP Association with the AC at Layer 2 (IPv6) Configuration Examples
- 06-Auto AP Configuration Examples
- 07-AP Association with the AC at Layer 3 Configuration Examples
- 08-AP Association with the AC at Layer 3 (IPv6) Configuration Examples
- 09-WEP Encryption Configuration Examples
- 10-PSK Encryption Configuration Examples
- 11-WPA3-SAE PSK Encryption Configuration Examples
- 12-WLAN Access (IPv6) Configuration Examples
- 13-Policy-Based Forwarding with Dual Gateways Configuration Examples
- 14-Scheduled Configuration Deployment by AP Group Configuration Examples
- 15-Inter-AC Roaming with Static Client VLAN Allocation Configuration Examples
- 16-Service Template and Radio Binding Configuration Examples
- 17-Scheduled WLAN Access Services Configuration Examples
- 18-Local Portal Authentication Configuration Examples
- 19-HTTPS-Based Local Portal Authentication Configuration Examples
- 20-Remote Portal Authentication Configuration Examples
- 21-Local Portal Authentication through LDAP Server Configuration Examples
- 22-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
- 23-Local Portal MAC-Trigger Authentication Configuration Examples
- 24-Portal MAC-Trigger Authentication Configuration Examples
- 25-Local Forwarding Mode and Local Portal MAC-Trigger Auth Configuration Examples
- 26-Local Portal Authentication (IPv6) Configuration Examples
- 27-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 28-Remote Portal Authentication (IPv6) Configuration Examples
- 29-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 30-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 31-Portal Fail-Permit Configuration Examples
- 32-Local MAC Authentication Configuration Examples
- 33-Remote MAC Authentication Configuration Examples
- 34-Transparent Auth Through Remote MAC and Portal Auth Configuration Examples
- 35-Remote AP, Remote Portal, and MAC-Trigger Authentication Configuration Examples
- 36-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 37-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 38-Local MAC-And-802.1X Authentication Configuration Examples
- 39-Local 802.1X Authentication Configuration Examples
- 40-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 41-Remote 802.1X Authentication Configuration Examples
- 42-Remote 802.1X Authentication (IPv6) Configuration Examples
- 43-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 44-802.1X Auth with ACL Assignment Through IMC Server Configuration Examples
- 45-802.1X Auth with User Profile Assignment Through IMC Server Configuration Examples
- 46-EAD Authentication Configuration Examples
- 47-EAD Authentication (IPv6) Configuration Examples
- 48-Local Forwarding Mode and Local Portal Authentication Configuration Examples
- 49-Local Forwarding Mode Direct Portal Authentication Configuration Examples
- 50-Local Forwarding Mode Direct Portal Authentication (IPv6) Configuration Examples
- 51-Local Forwarding Configuration Examples
- 52-Wired Port Local Forwarding through Wireless Terminator Configuration Examples
- 53-Remote AP Configuration Examples
- 54-Downlink VLAN Management for Fit-Mode APs Configuration Examples
- 55-WIPS Configuration Examples
- 56-WIPS Countermeasures Against All SSIDs Configuration Examples
- 57-IP Source Guard (IPv4) Configuration Examples
- 58-IP Source Guard (IPv6) Configuration Examples
- 59-Dual-Link Backup Configuration Examples
- 60-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 61-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 62-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 63-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 64-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 65-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 66-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 67-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 68-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 69-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 70-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 71-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
- 72-WLAN Probe Configuration Examples
- 73-Multicast Optimization Configuration Examples
- 74-Client Rate Limiting Configuration Examples
- 75-Inter-AC Roaming Configuration Examples
- 76-Inter-AC Roaming (IPv6) Configuration Examples
- 77-Inter-AC Roaming in Local Forwarding Mode Configuration Examples
- 78-H3C Access Controllers Cooperative Roaming for 802.11v Clients Configuration Examples
- 79-WLAN Load Balancing Configuration Examples
- 80-Static Blacklist Configuration Examples
- 81-Client Quantity Control Configuration Examples
- 82-AP License Synchronization Configuration Examples
- 83-BLE Module iBeacon Transmission Configuration Examples
- 84-Medical RFID Tag Management Configuration Examples
- 85-iBeacon Management Configuration Examples
- 86-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
- 87-Mesh Link Establishment Between Fit APs Configuration Examples
- 88-Auto-DFS and Auto-TPC Configuration Examples
- 89-AP Image Downloading Configuration Examples
- 90-Dual-Uplink Interfaces Configuration Guide
- 91-Internal-to-External Access Through NAT Configuration Examples
- 92-Layer 2 Static Aggregation Configuration Examples
- 93-Layer 2 Multicast Configuration Examples
- 94-Static VLAN Allocation Configuration Examples
- 95-URL Redirection Configuration Examples
- 96-IPv6 URL Redirection Configuration Examples
| 92-Layer 2 Static Aggregation Configuration Examples | 78.99 KB |
H3C Access Controllers |
Layer 2 Static Aggregation |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides Layer 2 static aggregation configuration examples.
This document applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
This document assumes that you have basic knowledge of H3C Ethernet link aggregation.
Example: Configuring a Layer 2 static aggregation group
On the network shown in Figure 1, perform the following tasks:
· Configure a Layer 2 static aggregation group on the AC and the switch to increase the bandwidth and improve link reliability.
· Enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end.
· Enable VLAN 20 at one end of the aggregate link to communicate with VLAN 20 at the other end.
Procedures
Configuring the AC
1. Configure VLANs:
# Create VLAN 10, and assign port GigabitEthernet 1/0/3 to VLAN 10.
<AC> system-view
[AC] vlan 10
[AC-vlan10] port gigabitethernet 1/0/3
[AC-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/4 to VLAN 20.
[AC] vlan 20
[AC-vlan20] port gigabitethernet 1/0/4
[AC-vlan20] quit
2. Configure a Layer 2 aggregate interface:
# Create Layer 2 aggregate interface Bridge-Aggregation 1.
[AC] interface bridge-aggregation 1
[AC-Bridge-Aggregation1] quit
# Assign port GigabitEthernet 1/0/1 to link aggregation group 1.
[AC-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign port GigabitEthernet 1/0/2 to link aggregation group 1.
[AC] interface gigabitethernet1/0/2
[AC-GigabitEthernet1/0/2] port link-aggregation group 1
[AC-GigabitEthernet1/0/2] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLANs 10 and 20.
[AC-Bridge-Aggregation1] port link-type trunk
[AC-Bridge-Aggregation1] port trunk permit vlan 10 20
Configuring the switch
1. Configure VLANs:
<Switch> system-view
[Switch] vlan 10
[Switch-vlan10] port gigabitethernet 1/0/3
[Switch-vlan10] quit
[Switch] vlan 20
[Switch-vlan20] port gigabitethernet 1/0/4
[Switch-vlan20] quit
[Switch] interface bridge-aggregation 1
[Switch-Bridge-Aggregation1] quit
[Switch-GigabitEthernet1/0/1] port link-aggregation group 1
[Switch-GigabitEthernet1/0/2] port link-aggregation group 1
[Switch-Bridge-Aggregation1] port link-type trunk
[Switch-Bridge-Aggregation1] port trunk permit vlan 10 20
1. Verify that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 on the AC are Selected ports in Layer 2 static aggregation group 1.
<AC> display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H - Expired
Role: P -- Primary, S -- Secondary
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key Role
GE1/0/1 S 32768 2 None
GE1/0/2 S 32768 2 None
2. Verify that the bandwidth for Layer 2 aggregate interface Bridge-Aggregation 1 is the total bandwidth of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 on the AC.
<AC> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 741f-4a05-3db8
Description: Bridge-Aggregation1 Interface
Bandwidth: 2000000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Trunk
VLAN Passing: 1(default vlan), 10
VLAN permitted: 1(default vlan), 10, 20
Trunk port encapsulation: IEEE 802.1q
Last 300 seconds input: 2 packets/sec 308 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
Input (total): 12659 packets, 1290752 bytes
177 unicasts, 9919 broadcasts, 2563 multicasts, 0 pauses
Input (normal): 12659 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, - throttles
0 CRC, - frame, 0 overruns, 0 aborts
- ignored, - parity errors
Output (total): 316 packets, 295765 bytes
307 unicasts, 9 broadcasts, 0 multicasts, 0 pauses
Output (normal): 316 packets, - bytes
Output: 0 output errors, 0 underruns, - buffer failures
- lost carrier, - no carrier
Configuration files
· AC:
vlan 10
vlan20
interface Bridge-Aggregation1
port trunk permit vlan 1 10 20
· Switch:
vlan 10
vlan 20
Related documentation
· Network Connectivity Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
