H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
64-FTP Server Software Upgrade Configuration Examples
H3C Routers
Introduction
The following information provides an example for upgrading the software version of a centralized router through FTP.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of FTP.
Example: Using the device as an FTP server to upgrade software
As shown in Figure 1, the host is connected to GigabitEthernet 2/0/1 of the router. The router acts as the FTP server and the host acts as the FTP client. Configure the network to meet the following requirements:
·     Use FTP to upload software upgrade file test.ipe from the FTP client to the FTP server to upgrade the router.
·     Use username abc and password 123456 to log in to the FTP server.
Figure 1 Network diagram
Analysis
To upgrade both active and standby MPUs of the router, copy the software image file to the root directory on the standby MPU after downloading the file to the active MPU through FTP.
For the router to use the new software version after reboot, specify the software image file to be used at the next boot as the main startup image file.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
When you configure the device as an FTP server to upgrade software, follow these restrictions and guidelines:
·     If storage space on the device is not enough for the upgrade, use the delete /unreserved file-url command to delete unnecessary files before performing software upgrade.
·     Make sure the username, password, and file name settings for FTP transfer on the host and the router are the same.
·     For successful FTP transfer between the router and the host, set the file transfer mode to binary.
Procedures
Configuring the router as the FTP server
# Assign an IP address to GigabitEthernet 2/0/1 on the router.
<Router> system-view
[Router] interface gigabitethernet 2/0/1
[Router-GigabitEthernet2/0/1] ip address 192.168.100.66 255.255.255.0
[Router-GigabitEthernet2/0/1] quit
# Add a local user account. Set the username to abc and the password to 123456.
[Router] local-user abc
[Router-luser-abc] password simple 123456
# Assign the network-admin user role to the user account.
[Router-luser-abc] authorization-attribute user-role network-admin
# Remove the default network-operator user role.
[Router-luser-abc] undo authorization-attribute user-role network-operator
# Assign the FTP service to the user account.
[Router-luser-abc] service-type ftp
[Router-luser-abc] quit
# Enable the FTP server.
[Router] ftp server enable
[Router] quit
Configuring the host
# Assign IP address 192.168.100.14/24 to the host (FTP client). Make sure the FTP client can reach the FTP server. (Details not shown.)
# Use username abc and password 123456 to log in to the FTP server. This example uses Windows Command Prompt.
C:\Documents and Settings\Administrator> ftp 192.168.100.66
Connected to 192.168.100.66.
220 FTP service ready.
User (192.168.100.66:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Access the directory that contains the upgrade file.
ftp> lcd E:\
Local directory now E:\
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
# Upload upgrade file test.ipe to the FTP server.
ftp> put test.ipe
200 PORT command successful
150 Connecting to port 2903
226 File successfully transferred
ftp: 70445056 sent in 1.05Seconds 67282.77Kbytes/sec.
# Verify that the image file is saved on the FTP server.
ftp> ls test.ipe
150 Connecting to port 3391
test.ipe
226 1 matches total
ftp: 24 bytes received in 0.00Seconds 24000.00Kbytes/sec.
# Close the FTP connection.
ftp> bye
Configuring the startup image files on the router
# Copy the software image file on the active MPU to the root directory on the standby MPU
<Router> copy flash:/test.ipe slot1#flash:/test.ipe
Copy flash:/test.ipe to slot1#flash:/test.ipe[Y/N]:y
Copying file flash:/test.ipe to slot1#flash:/test.ipe.
........................................................................ Done.
# Specify upgrade file test.ipe as the main startup image file for the active MPU of the router.
<Router> boot-loader file flash:/test.ipe slot 0 main
Verifying the IPE file and the images......Done.
H3C xxx images in IPE:
  test-cmw910-boot-r9141p16.bin
  test-cmw910-system-r9141p16.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 0.
Decompressing file test-cmw910-boot-r9141p16.bin to flash:/test-cmw910-boot-r9141p16.bin...............Done.
Decompressing file test-cmw910-system-r9141p16.bin to flash:/test-cmw910-system-r9141p16.bin..............................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
# Specify upgrade file test-old.ipe as the backup startup image file for the active MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 0 backup
This command will set the backup startup software images. Continue? [Y/N]:y
The images that have passed all examinations will be used as the backup startup
# Specify upgrade file test.ipe as the main startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test.ipe slot 1 main
Verifying the IPE file and the images........Done.
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file test-cmw910-boot-r9141p16.bin to slot1#flash:/test-cmw910-boot-r9141p16.bin................Done.
Decompressing file test-cmw910-system-r9141p16.bin to slot1#flash:/test-cmw910-system-r9141p16.bin.................................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify upgrade file test-old.ipe as the backup startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 1 backup
# Reboot the device.
<Router> reboot
# Use the display version command to display system version information.
<Router> display version
H3C Comware Software, Version 9.1.063, Release 9141P16
Copyright (c) 2004-2023 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C xxx uptime is 0 weeks, 0 days, 0 hours, 3 minutes
Last reboot reason : User reboot
Boot image: flash:/test-cmw910-boot-r9141p16.bin
Boot image Version 9.1.063, Release 9141P16
  Compiled Jan 15 2023 19:27:12
System image: flash:/test-cmw910-system-r9141p16.bin
System image Version 9.1.063, Release 9141P16
# Display the current software images and startup software images on the active MPU of the router.
<Router> display boot-loader slot 0
Software images on slot 0:
Current software images:
Main startup software images:
Backup startup software images:
  flash:/test-cmw910-boot-r9141p14.bin
  flash:/test-cmw910-system-r9141p14.bin
# Display the current software images and startup software images on the standby MPU of the router.
<Router> display boot-loader slot 1
Software images on slot 1:
Configuration files
interface GigabitEthernet2/0/1
 port link-mode route
local-user abc class manage
 password hash $h$6$YMVbbwFL/vviWcQu$+CuTbYCehNZtZo5RCXiadpYbXYWa2omt5TUtEh3UPCg
3fZjxYCp5WzbuE2GoowVi2YA/BK+mnSZJZqi5jRDuCg==
 service-type ftp
 ftp server enable
Related documentation
·     Fundamentals Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     Fundamentals Command Reference in H3C SR6608-M Router Command References(V9)
