- H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
- 01-AAA Configuration Examples
- 02-ACL Configuration Examples
- 03-MPLS over ADVPN Configuration Examples
- 04-ARP Attack Protection Configuration Examples
- 05-BFD Configuration Examples
- 06-Basic BGP Configuration Examples
- 07-BGP Route Attribute-Based Route Selection Configuration Examples
- 08-EAA Monitor Policy Configuration Examples
- 09-GRE with OSPF Configuration Examples
- 10-HoVPN Configuration Examples
- 11-IGMP Configuration Examples
- 12-IPsec Configuration Examples
- 13-IPsec Digital Certificate Authentication Configuration Examples
- 14-IPv6 IS-IS Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 17-IS-IS Configuration Examples
- 18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 19-L2TP over IPsec Configuration Examples
- 20-Multi-Instance L2TP Configuration Examples
- 21-L2TP Multidomain Access Configuration Examples
- 22-MPLS L3VPN Configuration Examples
- 23-MPLS OAM Configuration Examples
- 24-MPLS TE Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-NAT DNS Mapping Configuration Examples
- 27-NetStream Configuration Examples
- 28-NQA Configuration Examples
- 29-NTP Configuration Examples
- 30-OSPFv3 Configuration Examples
- 31-OSPF Configuration Examples
- 32-OSPF Multi-Process Configuration Examples
- 33-OSPF Multi-Instance Configuration Examples
- 34-Portal Configuration Examples
- 35-POS Interace Configuration Examples
- 36-RBAC Configuration Examples
- 37-RMON Configuration Examples
- 38-IPv4 NetStream Sampling Configuration Examples
- 39-SNMP Configuration Examples
- 40-SRv6 Configuration Examples
- 41-SSH Configuration Examples
- 42-Tcl Commands Configuration Examples
- 43-VLAN Configuration Examples
- 44-VRRP Configuration Examples
- 45-VXLAN over IPsec Configuration Examples
- 46-Cloudnet VPN Configuration Examples
- 47-Ethernet Link Aggregation Configuration Examples
- 48-Ethernet OAM Configuration Examples
- 49-Outbound Bidirectional NAT Configuration Examples
- 50-NAT Hairpin in C-S Mode Configuration Examples
- 51-Load Sharing NAT Server Configuration Examples
- 52-BIDIR-PIM Configuration Examples
- 53-Control Plane-Based QoS Policy Configuration Examples
- 54-Scheduling a Task Configuration Examples
- 55-Client-Initiated L2TP Tunnel Configuration Examples
- 56-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 57-Authorized ARP Configuration Examples
- 58-GTS Configuration Examples
- 59-Traffic Policing Configuration Examples
- 60-Traffic Accounting Configuration Examples
- 61-PBR Configuration Examples
- 62-TFTP Client Software Upgrade Configuration Examples
- 63-FTP Client Software Upgrade Configuration Examples
- 64-FTP Server Software Upgrade Configuration Examples
- 65-Routing Policy Configuration Examples
- 66-Software Upgrade from the BootWare Menu Configuration Examples
- 67-Mirroring Configuration Examples
| 59-Traffic Policing Configuration Examples | 100.05 KB |
H3C Routers |
Introduction
The following information provides examples for configuring traffic policing.
The typical application of traffic policing is to supervise the specification of certain traffic entering a network and limit it within a reasonable range, or to "discipline" the extra traffic. In this way, the network resources and the interests of the carrier are protected.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of traffic policing.
Example: Configuring traffic policing
As shown in Figure 1, a company accesses the Internet over VPN. The uplink bandwidth is 60 Mbps. All endpoints use the device as the gateway. Configure traffic policing to limit traffic to the Internet as follows:
· Limit HTTP traffic to the Internet to 40 Mbps (15 Mbps for 25 hosts in the R&D Dept and 25 Mbps for 40 hosts in the Marketing Dept).
· Limit mail traffic from the mail server to 2 Mbps.
· Limit the FTP traffic from the branch to 10 Mbps.
Analysis
To perform traffic policing on different traffic types, define traffic classes to match them. In this example, use ACLs to match packets of different protocols or types and associate different traffic classes with different traffic policing actions.
Software versions used
This configuration example was created and verified on Release 9141P16 of the SR6608-M router.
Procedures
1. Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 2/0/1.
[Device] interface gigabitethernet 2/0/1
[Device-GigabitEthernet2/0/1] ip address 200.1.1.2 24
[Device-GigabitEthernet2/0/1] quit
2. Limit the uplink HTTP traffic from the R&D Dept:
# Create IPv4 advanced ACL 3000, and configure a rule to match the uplink HTTP traffic from the R&D Dept (traffic with destination TCP port 80).
[Device] acl number 3000
[Device-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80 source 192.168.1.0 0.0.0.255
# Create traffic class rd_http, and use ACL 3000 as a match criterion.
[Device] traffic classifier rd_http
[Device-classifier-rd_http] if-match acl 3000
[Device-classifier-rd_http] quit
# Create traffic behavior rd_http, and configure a traffic policing action with the CIR as 15 Mbps.
[Device] traffic behavior rd_http
[Device-behavior-rd_http] car cir 15360
[Device-behavior-rd_http] quit
# Create QoS policy rd_http, and associate the traffic class with the traffic behavior.
[Device] qos policy rd_http
[Device-qospolicy-rd_http] classifier rd_http behavior rd_http
[Device-qospolicy-rd_http] quit
# Apply QoS policy rd_http to the inbound direction of interface GigabitEthernet 2/0/3.
[Device] interface gigabitethernet 2/0/3
[Device-GigabitEthernet2/0/3] qos apply policy rd_http inbound
[Device-GigabitEthernet2/0/3] quit
3. Limit the uplink HTTP traffic from the Marketing Dept:
# Create IPv4 advanced ACL 3001, and configure a rule to match the uplink HTTP traffic from the Market Dept.
[Device] acl number 3001
[Device-acl-ipv4-adv-3001] rule permit tcp destination-port eq 80 source 192.168.2.0 0.0.0.255
# Create traffic class mkt_http, and use ACL 3001 as a match criterion.
[Device] traffic classifier mkt_http
[Device-classifier-mkt_http] if-match acl 3001
[Device-classifier-mkt_http] quit
# Create traffic behavior mkt_http, and configure a traffic policing action with the CIR as 25 Mbps.
[Device] traffic behavior mkt_http
[Device-behavior-mkt_http] car cir 25600
[Device-behavior-mkt_http] quit
# Create QoS policy mkt_http, and associate the traffic class with the traffic behavior.
[Device] qos policy mkt_http
[Device-qospolicy-mkt_http] classifier mkt_http behavior mkt_http
[Device-qospolicy-mkt_http] quit
# Apply QoS policy mkt_http to the inbound direction of interface GigabitEthernet 2/0/4.
[Device] interface gigabitethernet 2/0/4
[Device-GigabitEthernet2/0/4] qos apply policy mkt_http inbound
[Device-GigabitEthernet2/0/4] quit
4. Limit the mail traffic from the mail server:
# Create IPv4 advanced ACL 3002, and configure a rule to match the mail traffic from the mail server.
[Device] acl number 3002
[Device-acl-ipv4-adv-3002] rule permit tcp destination-port eq smtp source 192.168.10.1 0.0.0.0
[Device-acl-ipv4-adv-3002] quit
# Create traffic class email, and use ACL 3002 as a match criterion.
[Device] traffic classifier email
[Device-classifier-email] if-match acl 3002
[Device-classifier-email] quit
# Create traffic behavior email, and configure a traffic policing action with the CIR as 2 Mbps.
[Device] traffic behavior email
[Device-behavior-email] car cir 2048
[Device-behavior-email] quit
# Create QoS policy email&ftp, and associate the traffic class with the traffic behavior.
[Device] qos policy email&ftp
[Device-qospolicy-email&ftp] classifier email behavior email
[Device-qospolicy-email&ftp] quit
5. Limit the FTP traffic from the branch:
# Create IPv4 basic ACL 2001, and configure a rule to match the FTP traffic from the branch.
[Device] acl number 2001
[Device-acl-ipv4-basic-2001] rule permit source 192.168.10.2 0.0.0.0
[Device-acl-ipv4-basic-2001] quit
# Create traffic class ftp, and use ACL 2001 as a match criterion.
[Device] traffic classifier ftp
[Device-classifier-ftp] if-match acl 2001
[Device-classifier-ftp] quit
# Create traffic behavior ftp, and configure a traffic policing action with the CIR as 10 Mbps.
[Device] traffic behavior ftp
[Device-behavior-ftp] car cir 10240
[Device-behavior-ftp] quit
# Associate the traffic class with the traffic behavior in QoS policy email&ftp.
[Device-qospolicy-email&ftp] classifier ftp behavior ftp
# Apply QoS policy email&ftp to the inbound direction of interface GigabitEthernet 2/0/1.
[Device-GigabitEthernet2/0/1] qos apply policy email&ftp outbound
# Use the display qos policy interface command to displays information about QoS policies applied to interfaces.
[Device] display qos policy interface
Interface: GigabitEthernet2/0/1
Direction: Outbound
Policy: email&ftp
Classifier: default-class
Matched : 0 (Packets) 0 (Bytes)
5-minute statistics:
Forwarded: 0/0 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: email
Operator: AND
Rule(s) :
If-match acl 3002
Behavior: email
Committed Access Rate:
CIR 2048 (kbps), CBS 128000 (Bytes), EBS 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 0 (Packets) 0 (Bytes)
Classifier: ftp
Operator: AND
Rule(s) :
If-match acl 2001
Behavior: ftp
CIR 10240 (kbps), CBS 640000 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: GigabitEthernet2/0/3
Direction: Inbound
Policy: rd_http
Matched : 313 (Packets) 29916 (Bytes)
Forwarded: 0/719 (pps/bps)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: rd_http
Operator: AND
Rule(s) :
If-match acl 3000
Behavior: rd_http
CIR 15360 (kbps), CBS 960000 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: GigabitEthernet2/0/4
Direction: Inbound
Policy: mkt_http
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: mkt_http
Operator: AND
Rule(s) :
If-match acl 3001
Behavior: mkt_http
CIR 25600 (kbps), CBS 1600000 (Bytes), EBS 0 (Bytes)
Green action : pass
Configuration files
traffic classifier email operator and
if-match acl 3002
traffic classifier ftp operator and
if-match acl 2001
traffic classifier mkt_http operator and
if-match acl 3001
traffic classifier rd_http operator and
if-match acl 3000
car cir 2048 cbs 128000 ebs 0 green pass red discard yellow pass
car cir 10240 cbs 640000 ebs 0 green pass red discard yellow pass
car cir 25600 cbs 1600000 ebs 0 green pass red discard yellow pass
car cir 15360 cbs 960000 ebs 0 green pass red discard yellow pass
qos policy mkt_http
qos policy rd_http
interface GigabitEthernet2/0/1
port link-mode route
combo enable copper
ip address 200.1.1.2 255.255.255.0
interface GigabitEthernet2/0/2
combo enable copper
ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet2/0/3
combo enable copper
interface GigabitEthernet2/0/4
combo enable copper
ip address 192.168.2.1 255.255.255.0
acl number 2001
rule 0 permit source 192.168.10.2 0
acl number 3000
rule 0 permit tcp source 192.168.1.0 0.0.0.255 destination-port eq www
acl number 3001
rule 0 permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
acl number 3002
rule 0 permit tcp source 192.168.10.1 0 destination-port eq smtp
Related documentation
· ACL and QoS Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
· ACL and QoS Command Reference in H3C SR6608-M Router Command References(V9)
