H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
36-RBAC Configuration Examples
36-RBAC Configuration Examples 134.80 KB
H3C Routers
Without written permission from our company, no individual or organization may illegally extract, copy, or propagate any part or all of the content of this document in any way.
Overview
This document presents a typical example of using RBAC to control user authority on login devices.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
The following information is provided based on the assumption that you have basic knowledge of RBAC.
Example: Configuring read and write permissions for specific features
As shown in Figure 1, to enhance security of user logins, local AAA authentication is used to authenticate Telnet users on the device. Give Telnet users the following permissions:
·     Allow execution of all read and write type commands related to OSPF.
·     Allow execution of all read-write commands related to file system.
Figure 1 Network diagram
Analysis
·     For a Telnet user to have the permissions, create a local Telnet user and user role role1, then, grant the Telnet users with the user role.
·     Configure user role rules to limit Telnet users to execute read and write commands related to OSPF and file system.
·     To ensure that Telnet users only use the authorized user role, delete the default user role assigned to the user.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
·     After configuring an ISP domain as the default one, you cannot delete the domain. To delete the domain, you must first use the undo domain default enable command to change the domain to a non-default domain.
·     One user role can create multiple rules, each identified by a unique number. Users authorized with this role can execute commands defined by the executable command union of these rules. If the permissions defined by two rules have conflicts, the rule with a higher number takes effect. For example, rule 1 allows executing command A, rule 2 allows executing command B, and rule 3 prohibits executing command A. Thus, rules 2 and 3 take effect, meaning command A is prohibited and command B is allowed.
Procedures
1.     Configure interfaces.
# Configure an IP address for interface GigabitEthernet2/0/1.
<Router> system-view
[Router] interface gigabitethernet 2/0/1
[Router-GigabitEthernet2/0/1] ip address 192.168.1.50 24
[Router-GigabitEthernet2/0/1] quit
2.     Configure the authentication method for Telnet user login.
# Activate the Telnet server function on the device.
[Router] telnet server enable
# Configure Telnet user login with the AAA authentication method on VTY user lines numbered from 0 to 63.
[Router] line vty 0 63
[Router-line-vty0-63] authentication-mode scheme
The command is "quit" on line vty0-63 of the system.
3.     Configure the AAA method for an ISP domain.
# Create ISP domain bbb and authorize login users with local authentication and authorization.
[Router] domain bbb
[Router-isp-bbb] authentication login local
[Router-isp-bbb] authorization login local
[Router-isp-bbb] quit
4.     Configure the password and service type for local user telnetuser.
# Create a local device management user named telnetuser.
[Router] local-user telnetuser class manage
# Set a plaintext password 123456TESTplat&!.
[Router-luser-manage-telnetuser] password simple 123456TESTplat&!
# Specify the service type as Telnet.
[Router-luser-manage-telnetuser] service-type telnet
[Router-luser-manage-telnetuser] quit
5.     Create user role role1 and configure its rules.
# Create user role role1 and enter its view.
[Router] role name role1
# Configure user role rule 1 to allow executing all commands of the read-write type related to OSPF.
[Router-role-role1] rule 1 permit read write feature ospf
# Configure user role rule 2 to allow executing all commands of the read-write type related to file system.
[Router-role-role1] rule 2 permit read write feature filesystem
[Router-role-role1] quit
6.     Configure the authorized user role for the local user.
# Enter view of local user telnetuser.
# Authorize user telnetuser with role role1.
[Router-luser-manage-telnetuser] authorization-attribute user-role role1
# For the user to use only the authorized user role, delete the default user role network-operator.
[Router-luser-manage-telnetuser] undo authorization-attribute user-role network-operator
[Router] quit
1.     View user role information.
# Use the display role command to view the information about user role role1.
<Router> display role name role1
Role: role1
  Description:
  VLAN policy: permit (default)
  Interface policy: permit (default)
  VPN instance policy: permit (default)
  Security zone policy: permit (default)
  Rule    Perm   Type  Scope         Entity
  1       permit RW-   feature       ospf
  2       permit RW-   feature       filesystem
  R:Read W:Write X:Execute
2.     Make the user log in to the device.
Make the user initiate a Telnet connection to the device and enter user name telnetuser@bbb and the correct password at the prompt. Verify that you can log in to the device.
C:\Documents and Settings\user> telnet 192.168.1.50
* Copyright (c) 2004-2023 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
login: telnetuser@bbb
Password:
<Router>
3.     Verify the user permissions.
After the Telnet user logs in to the device, perform the following tasks to verify the user permissions:
¡     Execute write commands of OSPF. (This section uses OSPF configuration as an example.)
[Router] ospf 1
[Router-ospf-1] area 0
[Router-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[Router-ospf-1-area-0.0.0.0] quit
[Router-ospf-1] quit
¡     Execute read command of OSPF.
[Router] show ospf
          OSPF Process 1 with Router ID 192.168.1.50
                  OSPF Protocol Information
 RouterID: 192.168.1.50   Router type:
 Route tag: 0
 Ext-community type: Domain ID 0x5, Route Type 0x306, Router ID 0x107
 Domain ID: 0.0.0.0
 Opaque capable
 Isolation: Disabled
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5 50 200
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF calculation count: 0
 RFC 1583 compatible
 Fast-reroute: Remote-lfa Disabled
   Maximum-cost: 4294967295
 Node-Protecing Preference: 40
 Lowest-cost Preference: 20
 Graceful restart interval: 120
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 1   NSSA area count: 0
 ExChange/Loading neighbors: 0
 MPLS segment routing: Disabled
   Segment routing adjacency   : Disabled
   Effective SRGB              : 16000  24000
   Segment routing local block : 15000  15999
   Segment routing tunnel count: 0
 Area: 0.0.0.0          (MPLS TE not enabled)
 Authentication type: None    Area flag: Normal
 SPF scheduled count: 0
¡     Execute the read and write commands of file system. (This section configures the source IP address of FTP packets as an example.)
[Router] ftp client source ip 192.168.0.60
[Router] quit
¡     Verify that you cannot execute commands of the execution type related to filesystem. (This section attempts to enter FTP view as an example.)
<Router> ftp
Permission denied.
Configuration files
line vty 0 63
domain bbb
role name role1
 password hash $h$6$kZw1rKFsAY4lhgUz$+teVLy8gmKN4Mr00VWgXQTB8ai94gKHlrys5OkytGf4
kT+nz5X1ZGASjc282CYAR6A1upH2jbmRoTcfDzZ9Gmw==
 service-type telnet
Example: Configuring user permissions in specific VPNs
As shown in Figure 2, in order to enhance the security of user login, RADIUS server is used to authenticate and authorize Telnet users, granting them the following permissions:
·     Allow the execution of all commands related to predefined feature group L3 in the system.
·     Allow the execution of all commands starting with the display keyword.
·     Allow management only of specific VPN instances, for example, VPN instances vpn1, vpn2, and vpn3.
Figure 2 Network diagram
Analysis
·     To authorize Telnet users to execute requested commands, create user role role1 and configure the user role rules and resource control policies.
·     To grant Telnet users the permissions, authorize user role role1 on the RADIUS server.
1.     After configuring an ISP domain as the default one, you cannot delete the domain. To delete the domain, you must first use the undo domain default enable command to change the domain to a non-default domain.
2.     The authorization information from the RADIUS server is sent to the RADIUS client with the authentication response message. Make sure the authentication and authorization methods are the same.
3.     One user role can create multiple rules, each identified by a unique number. Users authorized with this role can execute commands defined by the executable command union of these rules. If the permissions defined by two rules have conflicts, the rule with a higher number takes effect. For example, rule 1 allows executing command A, rule 2 allows executing command B, and rule 3 prohibits executing command A. Thus, rules 2 and 3 take effect, meaning command A is prohibited and command B is allowed.
Procedures
Device Configuration
1.     Configure interfaces and routes.
# Configure an IP address for interface GigabitEthernet2/0/2.
[Router] interface gigabitethernet 2/0/2
[Router-GigabitEthernet2/0/2] ip address 10.1.1.2 24
[Router-GigabitEthernet2/0/2] quit
# Configure a default route for Telnet users to reach the RADIUS server.
[Router] ip route-static 0.0.0.0 0.0.0.0 10.1.1.1
[Router-line-vty0-63] quit
3.     Configure the RADIUS scheme and authentication server.
# Create RADIUS scheme rad.
[Router] radius scheme rad
# Configure the IP address of the primary authentication/authorization server as 10.1.1.1 and the primary accounting server as 10.1.1.1.
[Router-radius-rad] primary authentication 10.1.1.1
[Router-radius-rad] primary accounting 10.1.1.1
# Set the shared key for interaction messages with the authentication/authorization server and the primary accounting server as plaintext aabbcc.
[Router-radius-rad] key authentication simple aabbcc
[Router-radius-rad] key accounting simple aabbcc
[Router-radius-rad] quit
4.     Configure the AAA method for an ISP domain.
# Create ISP domain bbb and configure login users to use the RADIUS authentication, RADIUS authorization, and RADIUS accounting AAA methods.
[Router] domain bbb
[Router-isp-bbb] authentication login radius-scheme rad
[Router-isp-bbb] authorization login radius-scheme rad
[Router-isp-bbb] accounting login radius-scheme rad
5.     Create user role role1 and configure rules and resource control policies for the user role.
# Configure user role rule 1 to allow users to execute all commands related to predefined feature group L3.
[Router-role-role1] rule 1 permit execute read write feature-group L3
# Configure user role rule 2 to allow users to execute all commands starting with the display keyword.
[Router-role-role1] rule 2 permit command display *
# Enter user role VPN policy view and authorize users with the permission to manage VPN instances vpn1, vpn2, and vpn3.
[Router-role-role1] vpn-instance policy deny
[Router-role-role1-vpnpolicy] permit vpn-instance vpn1 vpn2 vpn3
[Router-role-role1-vpnpolicy] quit
[Router] quit
Configuring the RADIUS server
This section uses iMC PLAT 7.0 (E0202) and iMC UAM 7.0 (E0202) as an example to illustrate basic configuration of the RADIUS server.
1.     Add an access device.
Log in to the IMC management platform, click the User tab. In the left navigation pane, select User Access Policy > Access Device Management > Access Device. Click Add.
¡     Specify the authentication and accounting port numbers to 1812 and 1813, respectively.
¡     Set the shared key for authentication and accounting for AC interaction messages as aabbcc and confirm the shared key.
¡     Select Device Management Service as the service type.
¡     Select H3C (General) as the access device type.
¡     Select or manually add the device with IP address 10.1.1.2 as an access device.
¡     Retain the default settings in the other fields and then click OK.
2.     Add a device management user.
Click the User tab, and select Device User > Device User in the navigation pane. Click Add.
¡     Specify the user name, set the password, and confirm the password. In this example, the username is telnetuser@bbb.
¡     Select Telnet as the service type.
¡     Add user role role1.
¡     Add IP addresses of devices to be managed. In this example, the IP address range is 10.1.1.0 to 10.1.1.10.
¡     Click OK.
1.     View user role and feature group information.
# Use the display role command to view user role information.
Role: role1
  Description:
  VPN instance policy: deny
  Permitted VPN instances: vpn1, vpn2, vpn3
  1       permit RWX   feature-group L3
Use the display role feature-group command to view feature information in feature group L3. (Details not shown.)
Password:
<Router>
¡     Execute commands in the predefined feature group L3. (This section creates VPN instance vpn1 and set the RD to 22:1 as an example.)
[Router] ip vpn-instance vpn1
[Router-vpn-instance-vpn1] route-distinguisher 22:1
[Router-vpn-instance-vpn1] display this
return
[Router-vpn-instance-vpn1] quit
¡     Verify that you cannot manage other VPN instances. (This section uses VPN instance vpn5 as an example.)
[Router] ip vpn-instance vpn5
Permission denied.
Configuration files
line vty 0 63
ip route-static 0.0.0.0 0 10.1.1.1
radius scheme rad
 key authentication cipher $c$3$JzDegvL0G5KZIcJhzscTHLA4WasBVh0UOw==
 key accounting cipher $c$3$CdejNYYxvjW0Y+Zydi4rZgBwjYb4h6LKmg==
domain bbb
role name role1
 rule 1 permit read write execute feature-group L3
  permit vpn-instance vpn2
  permit vpn-instance vpn3
Related documentation
·     Fundamentals Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     Fundamentals Command Reference in H3C SR6608-M Router Command References(V9)
