- H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
- 01-AAA Configuration Examples
- 02-ACL Configuration Examples
- 03-MPLS over ADVPN Configuration Examples
- 04-ARP Attack Protection Configuration Examples
- 05-BFD Configuration Examples
- 06-Basic BGP Configuration Examples
- 07-BGP Route Attribute-Based Route Selection Configuration Examples
- 08-EAA Monitor Policy Configuration Examples
- 09-GRE with OSPF Configuration Examples
- 10-HoVPN Configuration Examples
- 11-IGMP Configuration Examples
- 12-IPsec Configuration Examples
- 13-IPsec Digital Certificate Authentication Configuration Examples
- 14-IPv6 IS-IS Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 17-IS-IS Configuration Examples
- 18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 19-L2TP over IPsec Configuration Examples
- 20-Multi-Instance L2TP Configuration Examples
- 21-L2TP Multidomain Access Configuration Examples
- 22-MPLS L3VPN Configuration Examples
- 23-MPLS OAM Configuration Examples
- 24-MPLS TE Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-NAT DNS Mapping Configuration Examples
- 27-NetStream Configuration Examples
- 28-NQA Configuration Examples
- 29-NTP Configuration Examples
- 30-OSPFv3 Configuration Examples
- 31-OSPF Configuration Examples
- 32-OSPF Multi-Process Configuration Examples
- 33-OSPF Multi-Instance Configuration Examples
- 34-Portal Configuration Examples
- 35-POS Interace Configuration Examples
- 36-RBAC Configuration Examples
- 37-RMON Configuration Examples
- 38-IPv4 NetStream Sampling Configuration Examples
- 39-SNMP Configuration Examples
- 40-SRv6 Configuration Examples
- 41-SSH Configuration Examples
- 42-Tcl Commands Configuration Examples
- 43-VLAN Configuration Examples
- 44-VRRP Configuration Examples
- 45-VXLAN over IPsec Configuration Examples
- 46-Cloudnet VPN Configuration Examples
- 47-Ethernet Link Aggregation Configuration Examples
- 48-Ethernet OAM Configuration Examples
- 49-Outbound Bidirectional NAT Configuration Examples
- 50-NAT Hairpin in C-S Mode Configuration Examples
- 51-Load Sharing NAT Server Configuration Examples
- 52-BIDIR-PIM Configuration Examples
- 53-Control Plane-Based QoS Policy Configuration Examples
- 54-Scheduling a Task Configuration Examples
- 55-Client-Initiated L2TP Tunnel Configuration Examples
- 56-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 57-Authorized ARP Configuration Examples
- 58-GTS Configuration Examples
- 59-Traffic Policing Configuration Examples
- 60-Traffic Accounting Configuration Examples
- 61-PBR Configuration Examples
- 62-TFTP Client Software Upgrade Configuration Examples
- 63-FTP Client Software Upgrade Configuration Examples
- 64-FTP Server Software Upgrade Configuration Examples
- 65-Routing Policy Configuration Examples
- 66-Software Upgrade from the BootWare Menu Configuration Examples
- 67-Mirroring Configuration Examples
| 47-Ethernet Link Aggregation Configuration Examples | 79.98 KB |
H3C Routers |
Ethernet Link Aggregation |
Introduction
The following information provides examples for Ethernet link aggregation.
This document applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring a Layer 3 aggregation group
On the network shown in Figure 1, perform the following tasks:
· Configure a Layer 3 aggregation group on both Device A and Device B.
· Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
The Selected state of ports in a static aggregation group is not affected by whether the peer ports are in an aggregation group or in Selected state, Selected ports determined by both ends of the static aggregate link might to be inconsistent. As a best practice, use the dynamic aggregation mode if both ends support static and dynamic link aggregation modes.
Procedures
Configure Device A
# Create a Layer 3 aggregate interface Route-Aggregation 1. (Choose one of the following two methods.)
· Static aggregation mode.
[DeviceA] interface route-aggregation 1
· Dynamic aggregation mode.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
Configure Device B
Configure Device B in the same way Device A is configured. (Details not shown.)
# Use display link-aggregation verbose to display detailed information about the aggregation groups.
· Aggregate group information in static aggregation mode
[DeviceA] display link-aggregation verbose
Port: A -- Auto port
G -- Defaulted, H -- Expired
Aggregation Mode: Static
Port Status Priority Oper-Key
GE2/0/1 S 32768 1
GE2/0/2 S 32768 1
GE2/0/3 S 32768 1
The output shows that the member ports added to the static aggregation group at the local end are all in Selected state, regardless of whether the peer ports are in Selected state.
· Aggregate group information in dynamic aggregation mode
Creation Mode: Manual
Aggregation Mode: Dynamic
Local:
Port Status Priority Oper-Key Flag
GE2/0/1 S 32768 1 {ACDEF}
GE2/0/2 S 32768 1 {ACDEF}
GE2/0/3 S 32768 1 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE2/0/1 1 32768 1 0x8000, 000f-e267-57ad {ACDEF}
GE2/0/2 2 32768 1 0x8000, 000f-e267-57ad {ACDEF}
GE2/0/3 3 32768 1 0x8000, 000f-e267-57ad {ACDEF}
The output shows that the aggregation member ports on both the local and the peer devices are in Selected state. To ensure correct user data forwarding, the devices exchange LACP protocol packets over the dynamic aggregate link to maintain consistency of the aggregation state between their aggregation member ports.
Configuration files
· Device A:
¡ Static aggregation mode.
interface route-aggregation1
¡ Dynamic aggregation mode.
port link-mode route
· Device B:
Configuration files on Device B are similar to Device A.
Related documentation
· H3C SR6608-M Router Configuration Guides (V9)
· H3C SR6608-M Router Command References (V9)
