- H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
- 01-AAA Configuration Examples
- 02-ACL Configuration Examples
- 03-MPLS over ADVPN Configuration Examples
- 04-ARP Attack Protection Configuration Examples
- 05-BFD Configuration Examples
- 06-Basic BGP Configuration Examples
- 07-BGP Route Attribute-Based Route Selection Configuration Examples
- 08-EAA Monitor Policy Configuration Examples
- 09-GRE with OSPF Configuration Examples
- 10-HoVPN Configuration Examples
- 11-IGMP Configuration Examples
- 12-IPsec Configuration Examples
- 13-IPsec Digital Certificate Authentication Configuration Examples
- 14-IPv6 IS-IS Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 17-IS-IS Configuration Examples
- 18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 19-L2TP over IPsec Configuration Examples
- 20-Multi-Instance L2TP Configuration Examples
- 21-L2TP Multidomain Access Configuration Examples
- 22-MPLS L3VPN Configuration Examples
- 23-MPLS OAM Configuration Examples
- 24-MPLS TE Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-NAT DNS Mapping Configuration Examples
- 27-NetStream Configuration Examples
- 28-NQA Configuration Examples
- 29-NTP Configuration Examples
- 30-OSPFv3 Configuration Examples
- 31-OSPF Configuration Examples
- 32-OSPF Multi-Process Configuration Examples
- 33-OSPF Multi-Instance Configuration Examples
- 34-Portal Configuration Examples
- 35-POS Interace Configuration Examples
- 36-RBAC Configuration Examples
- 37-RMON Configuration Examples
- 38-IPv4 NetStream Sampling Configuration Examples
- 39-SNMP Configuration Examples
- 40-SRv6 Configuration Examples
- 41-SSH Configuration Examples
- 42-Tcl Commands Configuration Examples
- 43-VLAN Configuration Examples
- 44-VRRP Configuration Examples
- 45-VXLAN over IPsec Configuration Examples
- 46-Cloudnet VPN Configuration Examples
- 47-Ethernet Link Aggregation Configuration Examples
- 48-Ethernet OAM Configuration Examples
- 49-Outbound Bidirectional NAT Configuration Examples
- 50-NAT Hairpin in C-S Mode Configuration Examples
- 51-Load Sharing NAT Server Configuration Examples
- 52-BIDIR-PIM Configuration Examples
- 53-Control Plane-Based QoS Policy Configuration Examples
- 54-Scheduling a Task Configuration Examples
- 55-Client-Initiated L2TP Tunnel Configuration Examples
- 56-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 57-Authorized ARP Configuration Examples
- 58-GTS Configuration Examples
- 59-Traffic Policing Configuration Examples
- 60-Traffic Accounting Configuration Examples
- 61-PBR Configuration Examples
- 62-TFTP Client Software Upgrade Configuration Examples
- 63-FTP Client Software Upgrade Configuration Examples
- 64-FTP Server Software Upgrade Configuration Examples
- 65-Routing Policy Configuration Examples
- 66-Software Upgrade from the BootWare Menu Configuration Examples
- 67-Mirroring Configuration Examples
| 63-FTP Client Software Upgrade Configuration Examples | 150.36 KB |
H3C Routers |
FTP Client Software Upgrade |
Introduction
The following information provides an example for upgrading the software version of a distributed router through FTP.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of FTP.
Example: Using the device as an FTP client to upgrade software
As shown in Figure 1, the host is connected to GigabitEthernet 2/0/1 of the router. The router acts as the FTP client and the host acts as the FTP server. Configure the network to meet the following requirements:
· Use FTP to download software upgrade file test.ipe from the FTP server to the FTP client to upgrade the router.
· Use username 123456 and password 123456 to log in to the FTP server.
Analysis
To upgrade both active and standby MPUs of the router, copy the software image file to the root directory on the standby MPU after downloading the file to the active MPU through FTP.
For the router to use the new software version after reboot, specify the software image file to be used at the next boot as the main startup image file.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
When you configure the device as an FTP client to upgrade software, follow these restrictions and guidelines:
· If storage space on the device is not enough for the upgrade, use the delete /unreserved file-url command to delete unnecessary files before performing software upgrade.
· Make sure the username, password, and file name settings for FTP transfer on the host and the router are the same.
Procedures
Configuring the host
# Assign IP address 192.168.100.14/24 to the host. Make sure the host and the router can reach each other. (Details not shown.)
# Start the FTP server on the host. This example uses the 3CDaemon FTP server.
Figure 2 Configuring the FTP server
# Perform the following operations to configure the FTP server parameters:
2. Set the username in the Profile filed. This example uses 123456.
3. Click Set/Change user's password to set the password. This example uses 123456.
4. Click
to specify the download path for the FTP server.
5. Click OK.
Figure 3 Configuring the FTP server
Configuring the router
# Assign an IP address to GigabitEthernet 2/0/1 on the router.
<Router> system-view
[Router] interface gigabitethernet 2/0/1
[Router-GigabitEthernet2/0/1] ip address 192.168.100.66 255.255.255.0
[Router-GigabitEthernet2/0/1] quit
[Router] quit
# Verify that the router can ping the FTP server.
<Router> ping 192.168.100.14
PING 192.168.100.14: 56 data bytes, press CTRL_C to break
Reply from 192.168.100.14: bytes=56 Sequence=0 ttl=128 time=2 ms
Reply from 192.168.100.14: bytes=56 Sequence=1 ttl=128 time=1 ms
Reply from 192.168.100.14: bytes=56 Sequence=2 ttl=128 time=1 ms
Reply from 192.168.100.14: bytes=56 Sequence=3 ttl=128 time=1 ms
Reply from 192.168.100.14: bytes=56 Sequence=4 ttl=128 time=1 ms
--- 192.168.100.14 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 1/1/2 ms
# Use username 123456 and password 123456 to log in to the FTP server.
<Router> ftp 192.168.100.14
Connected to 192.168.100.14 (192.168.100.14).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Download upgrade file test.ipe from the FTP server to the active MPU of the router.
ftp> get test.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
70445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
# Copy the upgrade file on the active MPU to the root directory of the standby MPU.
<Router> copy flash:/test.ipe slot1#flash:/test.ipe
Copy flash:/test.ipe to slot1#flash:/test.ipe[Y/N]:y
Copying file flash:/test.ipe to slot1#flash:/test.ipe.
........................................................................ Done.
# Specify upgrade file test.ipe as the main startup image file for the active MPU of the router.
<Router> boot-loader file flash:/test.ipe slot 0 main
Verifying the IPE file and the images......Done.
H3C xxx images in IPE:
test-cmw910-boot-r9141p16.bin
test-cmw910-system-r9141p16.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 0.
Decompressing file test-cmw910-boot-r9141p16.bin to flash:/test-cmw910-boot-r9141p16.bin...............Done.
Decompressing file test-cmw910-system-r9141p16.bin to flash:/test-cmw910-system-r9141p16.bin..............................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
# Specify upgrade file test-old.ipe as the backup startup image file for the active MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 0 backup
This command will set the backup startup software images. Continue? [Y/N]:y
The images that have passed all examinations will be used as the backup startup
# Specify upgrade file test.ipe as the main startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test.ipe slot 1 main
Verifying the IPE file and the images........Done.
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1.
Decompressing file test-cmw910-boot-r9141p16.bin to slot1#flash:/test-cmw910-boot-r9141p16.bin................Done.
Decompressing file test-cmw910-system-r9141p16.bin to slot1#flash:/test-cmw910-system-r9141p16.bin.................................................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify upgrade file test-old.ipe as the backup startup image file for the standby MPU of the router.
<Router> boot-loader file slot1#flash:/test-old.ipe slot 1 backup
# Reboot the device.
<Router> reboot
# Use the display version command to display system version information.
<Router> display version
H3C Comware Software, Version 9.1.063, Release 9141P16
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C xxx uptime is 0 weeks, 0 days, 6 hours, 54 minutes
Last reboot reason : Power on
Boot image: flash:/test-cmw910-boot-r9141p16.bin
Boot image version: 9.1.063, Release 9141P16
Compiled Mar 10 2023 15:00:00
System image: flash:/test-cmw910-system-r9141p16.bin
System image version: 9.1.063, Release 9141P16
# Display the current software images and startup software images on the active MPU of the router.
<Router> display boot-loader slot 0
Software images on slot 0:
Current software images:
Main startup software images:
Backup startup software images:
flash:/test-cmw910-boot-r9141p14.bin
flash:/test-cmw910-system-r9141p14.bin
# Display the current software images and startup software images on the standby MPU of the router.
<Router> display boot-loader slot 1
Software images on slot 1:
Configuration files
interface GigabitEthernet2/0/1
Related documentation
· Fundamentals Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
· Fundamentals Command Reference in H3C SR6608-M Router Command References(V9)
