H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
20-Multi-Instance L2TP Configuration Examples
20-Multi-Instance L2TP Configuration Examples 94.60 KB
H3C Routers
Introduction
The following information provides multi-instance L2TP configuration examples for the router.
The following information applies to Comware 9-based router. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of L2TP.
Example: Configuring multi-instance L2TP
As shown in Figure 1, multiple enterprises share Router C as an LNS, and different enterprise users connect to Router A and Router B separately to communicate with their respective headquarters, Site 1 and Site 2. Configure multi-instance L2TP on Router C so that it can provide L2TP access services to Router A and Router B at the same time. In this way, users from different enterprises can remotely access their respective internal enterprise networks.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
Procedures
Configuring Router C
# Enable L2TP globally.
<RouterC> system-view
[RouterC] l2tp enable
# Configure a local user and set the password.
[RouterC] local-user 1 class network
[RouterC-luser-network-1] password simple 1234
[RouterC-luser-network-1] service-type ppp
[RouterC-luser-network-1] quit
[RouterC] local-user 2 class network
[RouterC-luser-network-2] password simple 1234
[RouterC-luser-network-2] service-type ppp
[RouterC-luser-network-2] quit
# Configure VPN instances vpn1 and vpn2.
[RouterC] ip vpn-instance vpn1
[RouterC-vpn-instance-vpn1] route-distinguisher 100:1
[RouterC-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity [RouterC-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[RouterC-vpn-instance-vpn1] quit
[[RouterC] ip vpn-instance vpn2
[RouterC-vpn-instance-vpn2] route-distinguisher 200:1
[RouterC-vpn-instance-vpn2] vpn-target 200:1 import-extcommunity
[RouterC-vpn-instance-vpn2] vpn-target 200:1 export-extcommunity
[RouterC-vpn-instance-vpn2] quit
# Configure address pools.
[RouterC] ip pool 1 100.0.0.2 100.0.0.100
[RouterC] ip pool 2 101.0.0.2 101.0.0.100
# Create VT interface 1.
[RouterC] interface virtual-template 1
# Configure the VT interface to use PAP for authenticating the peer.
[RouterC-Virtual-Template1] ppp authentication-mode pap
# Configure the interface to allocate addresses from address pool 1 to clients.
[RouterC-Virtual-Template1] remote address pool 1
# Bind the VT interface to VPN instance vpn1.
[RouterC-Virtual-Template1] ip binding vpn-instance vpn1
[RouterC-Virtual-Template1] ip address 100.0.0.1 8
[RouterC-Virtual-Template1] quit
# Create VT interface 2.
[RouterC] interface virtual-template 2
[RouterC-Virtual-Template2] ppp authentication-mode pap
# Configure the interface to allocate addresses from address pool 2 to clients.
[RouterC-Virtual-Template2] remote address pool 2
# Bind the VT interface to VPN instance vpn2.
[RouterC-Virtual-Template2] ip binding vpn-instance vpn2
[RouterC-Virtual-Template2] ip address 101.0.0.1 8
[RouterC-Virtual-Template2] quit
# Create L2TP group 1 in LNS mode.
[RouterC] l2tp-group 1 mode lns
# Configure the local tunnel name as lns-A on the LNS and specify VT interface 1 for receiving calls from the peer named lac-A.
[RouterC-l2tp1] tunnel name lns-A
[RouterC-l2tp1] undo tunnel authentication
[RouterC-l2tp1] allow l2tp virtual-template 1 remote lac-A
[RouterC-l2tp1] quit
[RouterC] l2tp-group 2 mode lns
# Configure the local tunnel name as lns-B on the LNS and specify VT interface 2 for receiving calls from the peer named lac-B.
[RouterC-l2tp2] tunnel name lns-B
[RouterC-l2tp2] undo tunnel authentication
[RouterC-l2tp2] allow l2tp virtual-template 2 remote lac-B
[RouterC-l2tp2] quit
# Assign IP addresses to interfaces and bind interfaces to VPN instances.
[RouterC-GigabitEthernet1/0/1] ip address 1.1.1.3 24
[RouterC] interface gigabitethernet 2/0/2
[RouterC-GigabitEthernet2/0/2] ip binding vpn-instance vpn1
[RouterC-GigabitEthernet2/0/2] ip address 5.0.0.1 8
[RouterC-GigabitEthernet2/0/2] quit
[RouterC] interface gigabitethernet 2/0/3
[RouterC-GigabitEthernet2/0/3] ip binding vpn-instance vpn2
[RouterC-GigabitEthernet2/0/3] ip address 6.0.0.1 8
[RouterC-GigabitEthernet2/0/3] quit
Configuring Router A
[RouterA] l2tp enable
# Configure an L2TP group.
[RouterA] l2tp-group 1 mode lac
# Configure the local tunnel name as lac-A on the LAC and specify LNS IP address 1.1.1.3.
[RouterA-l2tp1] tunnel name lac-A
[RouterA-l2tp1] undo tunnel authentication
[RouterA-l2tp1] lns-ip 1.1.1.3
[RouterA-l2tp1] quit
# Create a virtual-PPP interface. On the interface, configure the PPP username as 1 and password as 1234, and configure the PPP authentication mode as PAP.
[RouterA] interface virtual-PPP 1
[RouterA-Virtual-PPP1] ip address ppp-negotiate
[RouterA-Virtual-PPP1] ppp pap local-user 1 password simple 1234
[RouterA-Virtual-PPP1] quit
# Assign an IP address to interface GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] ip address 1.1.1.1 24
# Configure a private network route, so that the packets to the HQ of the company are forwarded through an L2TP tunnel.
[RouterA] ip route-static 5.0.0.0 8 Virtual-PPP 1
# Trigger the LAC to automatically establish an L2TP tunnel.
[RouterA-Virtual-PPP1] l2tp-auto-client l2tp-group 1
Configuring Router B
<RouterB> system-view
[RouterB] l2tp enable
[RouterB] l2tp-group 1 mode lac
# Configure the local tunnel name as lac-B on the LAC and specify LNS IP address 1.1.1.3.
[RouterB-l2tp1] tunnel name lac-B
[RouterB-l2tp1] undo tunnel authentication
[RouterB-l2tp1] lns-ip 1.1.1.3
[RouterB-l2tp1] quit
# Create a virtual-PPP interface. On the interface, configure the PPP username as 2 and password as 1234, and configure the PPP authentication mode as PAP.
[RouterB] interface virtual-PPP 1
[RouterB-Virtual-PPP1] ip address ppp-negotiate
[RouterB-Virtual-PPP1] ppp pap local-user 2 password simple 1234
[RouterB-Virtual-PPP1] quit
[RouterB-GigabitEthernet1/0/1] ip address 1.1.1.2 24
[RouterB] ip route-static 6.0.0.0 8 virtual-PPP 1
[RouterB-Virtual-PPP1] l2tp-auto-client l2tp-group 1
1.     Verify that an IP address in pool 1 is allocated to the virtual-PPP interface on Router A.
[RouterA] display interface brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Aux0                 UP   --       --
GE1/0/1              UP   UP       1.1.1.1
GE1/0/2              ADM  DOWN     11.1.1.1
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
REG0                 DOWN --       --
VPPP1                UP   UP       100.0.0.2
2.     Verify that an IP address in pool 2 is allocated to the virtual-PPP interface on Router B.
[RouterB] display interface brief
Aux0                 UP   --       --
GE1/0/1              UP   UP       1.1.1.2
GE1/0/2              UP   UP       12.1.1.1
InLoop0              UP   UP(s)    --
NULL0                UP   UP(s)    --
REG0                 DOWN --       --
VPPP1                UP   UP       101.0.0.2
3.     Verify that Router A can ping IP address 5.0.0.1 of Router C and the L2TP tunnel has been successfully established.
[RouterA] ping -a 100.0.0.2 5.0.0.1
Ping 5.0.0.1 (5.0.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 5.0.0.1: icmp_seq=0 ttl=128 time=0.452 ms
56 bytes from 5.0.0.1: icmp_seq=1 ttl=128 time=0.625 ms
56 bytes from 5.0.0.1: icmp_seq=2 ttl=128 time=0.673 ms
56 bytes from 5.0.0.1: icmp_seq=3 ttl=128 time=0.687 ms
56 bytes from 5.0.0.1: icmp_seq=4 ttl=128 time=0.679 ms
--- Ping statistics for 5.0.0.1 ---
round-trip min/avg/max/std-dev = 0.452/0.623/0.687/0.088 ms
4.     Verify that Router B can ping IP address 6.0.0.1 of Router C and the L2TP tunnel has been successfully established.
[RouterB] ping 6.0.0.1
Ping 6.0.0.1 (6.0.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 6.0.0.1: icmp_seq=0 ttl=128 time=0.452 ms
56 bytes from 6.0.0.1: icmp_seq=1 ttl=128 time=0.625 ms
56 bytes from 6.0.0.1: icmp_seq=2 ttl=128 time=0.673 ms
56 bytes from 6.0.0.1: icmp_seq=3 ttl=128 time=0.687 ms
56 bytes from 6.0.0.1: icmp_seq=4 ttl=128 time=0.679 ms
--- Ping statistics for 6.0.0.1 ---
Configuration files
·     Router C:
interface Virtual-Template1
 ip address 100.0.0.1 255.0.0.0
interface Virtual-Template2
 ip address 101.0.0.1 255.0.0.0
 port link-mode route
 combo enable copper
 ip address 1.1.1.3 255.255.255.0
 ip address 5.0.0.1 255.0.0.0
 ip address 6.0.0.1 255.0.0.0
 password cipher $c$3$Wf7ut8Li9ryKmOvk53vSKPHvBQHOu8w=
 service-type ppp
 password cipher $c$3$rpUZj85qaeXDflgm1P5af58Kj/maHXM=
 service-type ppp
 tunnel name lns-A
 tunnel name lns-B
l2tp enable
·     Router A:
interface Virtual-PPP1
 ppp pap local-user 1 password cipher $c$3$CYBBKjOoTx2nLdklyFk5zUtfXOKC5f8=
 ip address 1.1.1.1 255.255.255.0
 ip route-static 5.0.0.0 8 Virtual-PPP1
 lns-ip 1.1.1.3
 tunnel name lac-A
l2tp enable
·     Router B:
 ppp pap local-user 2 password cipher $c$3$w9MwmqfWlBN/bbkspWTwTE9V3Zxe6Sk=
 ip address 1.1.1.2 255.255.255.0
ip route-static 6.0.0.0 8 Virtual-PPP1
 lns-ip 1.1.1.3
 tunnel name lac-B
l2tp enable
Related documentation
·     Layer 2—WAN Access Configuration Guide in H3C SR6608-M Router Configuration Guides (V9)
·     Layer 2—WAN Access Command Reference in H3C SR6608-M Router Command References (V9)
