H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
H3C Routers
Introduction
The following information provides examples for configuring an ISATAP tunnel and a 6to4 tunnel in combination.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of ISATAP tunneling and 6to4 tunneling.
Example: Configuring an ISATAP tunnel and 6to4 tunnel in combination
As shown in Figure 1, IPv6 is deployed in the headquarters and its branches, and they are connected through an IPv4 network.
·     Configure a 6to4 tunnel to allow the 6to4 networks of the headquarters and the branches to communicate with each other over the IPv4 network.
·     Configure an ISATAP tunnel between Device A and the dual-stack host on the IPv4 network, so the host can access the 6to4 networks of the headquarters.
Figure 1 Network diagram
Table 1 Interface and address assignment
Device
IP address
Device
IP address
Device A
GE2/0/1
2.1.1.1/24
Device B
GE2/0/1
3.1.1.1/24
GE2/0/2
2002:0201:0101:1::1/64
GE2/0/2
2002:0301:0101:1::1/64
GE2/0/3
2002:0201:0101:2::1/64
GE2/0/3
2002:0301:0101:2::1/64
Tunnel 1
3001::1/64
Tunnel 1
3001::2/64
Tunnel 2
2001::5EFE:0201:0101/64
Analysis
·     A 6to4 address is in 2002:IPv4 address::/64 format where the IPv4 address is the destination IP address of the IPv4 packets after 6to4 tunnel encapsulation.
·     The IPv6 prefix of the ISATAP host can be requested from the ISATAP router (Device A). The IPv4 address is used as the interface ID in Prefix:0:5EFE:IPv4-destination-address format. This IPv4 address can be used as the destination address of the ISATAP tunnel.
·     To ensure that hosts in the same network use the same address prefix, disable RA suppression on Device A and Device B, so that the hosts can acquire information such as the address prefix from the RA messages advertised by Device A and Device B.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
Procedures
Before you perform the following configuration, make sure the gateway devices have IPv4 connectivity to each other.
1.     Configure Device A:
# Assign an IP address to interface GigabitEthernet 2/0/1.
[DeviceA] interface gigabitethernet 2/0/1
[DeviceA-GigabitEthernet2/0/1] ip address 2.1.1.1 24
[DeviceA-GigabitEthernet2/0/1] quit
# Assign IP addresses to other interfaces on Device A in the same way. (Details not shown.)
# Create 6to4 tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4 6to4
# Assign an IPv6 address to interface Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Configure the source interface of Tunnel 1 as GigabitEthernet 2/0/1. (The IP address of the source interface will be used as the source IP address of the IPv4 packets after encapsulation.)
[DeviceA-Tunnel1] source gigabitethernet 2/0/1
[DeviceA-Tunnel1] quit
# Configure a static route destined for 2002:0301:0101::/48 with the next hop as Tunnel 1.
[DeviceA] ipv6 route-static 2002:0301:0101:: 48 tunnel 1
# Create ISATAP tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4 isatap
# Assign an IPv6 address to interface Tunnel 2.
[DeviceA-Tunnel2] ipv6 address 2001::5EFE:0201:0101 64
# Configure the source interface of Tunnel 2 as GigabitEthernet 2/0/1. (The IP address of the source interface will be used as the source IP address of the IPv4 packets after encapsulation.)
[DeviceA-Tunnel2] source gigabitethernet 2/0/1
[DeviceA-Tunnel2] quit
# Configure a static route destined for 2001::/16 with the next hop as Tunnel 2.
[DeviceA] ipv6 route-static 2001:: 16 tunnel 2
# Disable RA suppression on Device A, so that the hosts can acquire information such as the address prefix from the RA messages advertised by Device A.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] undo ipv6 nd ra halt
[DeviceA] interface gigabitethernet 2/0/2
[DeviceA-GigabitEthernet2/0/2] undo ipv6 nd ra halt
[DeviceA-GigabitEthernet2/0/2] quit
[DeviceA] interface gigabitethernet 2/0/3
[DeviceA-GigabitEthernet2/0/3] undo ipv6 nd ra halt
[DeviceA-GigabitEthernet2/0/3] quit
2.     Configure Device B:
[DeviceB] interface gigabitethernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] ip address 3.1.1.1 24
[DeviceB-GigabitEthernet2/0/1] quit
# Assign IP addresses to other interfaces on Device B in the same way. (Details not shown.)
[DeviceB] interface tunnel 1 mode ipv6-ipv4 6to4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
# Configure the source interface of the tunnel as GigabitEthernet 2/0/1. (The IP address of the source interface will be used as the source IP address of the IPv4 packets after encapsulation.)
[DeviceB-Tunnel1] source gigabitethernet 2/0/1
[DeviceB-Tunnel1] quit
# Configure a static route destined for 2002:0201:0101::/48 with the next hop as Tunnel1.
[DeviceB] ipv6 route-static 2002:0201:0101:: 48 tunnel 1
# Disable RA suppression on Device B, so that the hosts can acquire information such as the address prefix from the RA messages advertised by Device B.
[DeviceB] interface gigabitethernet 2/0/2
[DeviceB-GigabitEthernet2/0/2] undo ipv6 nd ra halt
[DeviceB-GigabitEthernet2/0/2] quit
[DeviceB] interface gigabitethernet 2/0/3
[DeviceB-GigabitEthernet2/0/3] undo ipv6 nd ra halt
[DeviceB-GigabitEthernet2/0/3] quit
3.     Configure the ISATAP host:
Configurations on the ISATAP host vary by operating system. The following configuration is performed on Windows XP.
# Install IPv6.
C:\>ipv6 install
# Specify an IPv4 address for the ISATAP router.
C:\>netsh interface ipv6 isatap set router 2.1.1.1
# Display information about the ISATAP interface.
C:\>ipv6 if 2
Interface 2: Automatic Tunneling Pseudo-Interface
  Guid {48FCE3FC-EC30-E50E-F1A7-71172AEEE3AE}
  does not use Neighbor Discovery
  uses Router Discovery
  routing preference 1
  EUI-64 embedded IPv4 address: 1.1.1.2
  router link-layer address: 2.1.1.1
    preferred global 2001::5efe:1.1.1.2, life 29d23h59m46s/6d23h59m46s (public)
    preferred link-local fe80::5efe:1.1.1.2, life infinite
  link MTU 1500 (true link MTU 65515)
  current hop limit 255
  reachable time 42500ms (base 30000ms)
  retransmission interval 1000ms
  DAD transmits 0
  default site prefix length 48
The host has obtained the prefix 2001::/64 and has automatically generated the global unicast address 2001::5efe:1.1.1.2. The message "uses Router Discovery" indicates that the router discovery feature is enabled on the host.
# Display information about IPv6 routes on the host.
C:\>ipv6 rt
2001::/64 -> 2 pref 1if+8=9 life 29d23h59m43s (autoconf)
::/0 -> 2/fe80::5efe:1.1.1.1 pref 1if+256=257 life 29m43s (autoconf)
# Verify that Host A and Host B can ping each other.
D:\>ping6 -s 2002:0201:0101:1::2 2002:0301:0101:1::2
Pinging 2002:0301:0101:1::2
from 2002:0201:0101:1::2 with 32 bytes of data:
Reply from 2002:0301:0101:1::2: bytes=32 time=13ms
Reply from 2002:0301:0101:1::2: bytes=32 time=1ms
Reply from 2002:0301:0101:1::2: bytes=32 time<1ms
Ping statistics for 2002:0301:0101:1::2:
    Minimum = 0ms, Maximum = 13ms, Average = 3ms
# Verify that the ISATAP host can ping the IPv6 address of Host A.
C:\Documents and Settings\Administrator>pingv6 2002:0201:0101:1::2
Pinging 2002:0201:0101:1::2 with 32 bytes of data:
Reply from 2002:0201:0101:1::2: time=33ms
Reply from 2002:0201:0101:1::2: time=32ms
Ping statistics for 2002:0201:0101:1::2:
 Minimum = 32ms, Maximum = 33ms, Average = 32ms
Configuration files
·     Device A
interface GigabitEthernet2/0/1
 ip address 2.1.1.1 255.255.255.0
interface GigabitEthernet2/0/2
 ipv6 address 2002:201:101:1::1/64
interface GigabitEthernet2/0/3
 ipv6 address 2002:201:101:2::1/64
interface Tunnel1 mode ipv6-ipv4 6to4
 source GigabitEthernet2/0/1
interface Tunnel2 mode ipv6-ipv4 isatap
 ipv6 address 2001::5EFE:201:101/64
 ipv6 route-static 2001:: 16 Tunnel2
 ipv6 route-static 2002:301:101:: 48 Tunnel1
·     Device B
 ip address 3.1.1.1 255.255.255.0
 ipv6 address 2002:301:101:1::1/64
 ipv6 address 2002:301:101:2::1/64
 ipv6 route-static 2002:201:101:: 48 Tunnel1
Related documentation
·     IP Tunneling and Security VPN Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     IP Tunneling and Security VPN Command Reference in H3C SR6608-M Router Command References(V9)
