H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
03-MPLS over ADVPN Configuration Examples
03-MPLS over ADVPN Configuration Examples 311.99 KB
H3C Routers
Introduction
MPLS over ADVPN refers to running the MPLS protocol on an ADVPN tunnel, establishing MPLS LSP based on the ADVPN tunnel, to achieve intercommunication between MPLS networks located in different places across the ADVPN tunnel.
This document presents the configuration methods for typical MPLS over ADVPN networking, using IPv4 MPLS L3VPN over UDP-encapsulated ADVPN tunnels (full-mesh topology) and IPv6 LDP over GRE-encapsulated ADVPN tunnels (hub-spoke topology) as examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of LDP, MPLS L3VPN, and ADVPN.
Example: Configuring IPv4 MPLS L3VPN over UDP-encapsulated ADVPN
Enterprise branches use dynamic addresses to access the public network, and establish ADVPN tunnels between hub and spoke and between spoke and spoke, forming a full-mesh network. This ensures uninterrupted communication between the branches despite changes in public network addresses.
Meanwhile, the enterprise aims to achieve isolation of different private networks between branches through MPLS L3VPN. To achieve this purpose, it is required to establish MPLS LSPs on the ADVPN tunnels in the public network to enable MPLS VPN traffic to pass through the ADVPN tunnels.
As shown in Figure 1, the specific networking requirements in this example are as follows:
·     CE 1 and CE 2 belong to VPN 1.
·     PE 1 and PE 2 are not only access devices for CEs to access the MPLS L3VPN network, but also spoke devices for the ADVPN network, setting up ADVPN tunnels with the hub.
·     PE 1, PE 2 and Hub act as VAM clients and register their public and private network addresses with the VAM server.
Figure 1 Network diagram
Analysis
To ensure MPLS VPN traffic is transmitted across the ADVPN tunnel, perform the following configuration:
·     Run OSPF on the backbone-facing interfaces of PEs, Device, Hub, and VAM server to ensure IP connectivity between the VAM clients and VAM server.
·     Configure ADVPN on PEs and Hub, and establish ADVPN tunnels encapsulated in UDP between PEs and Hub, and between PE and PE.
·     Configure IPsec on the ADVPN tunnels to ensure secure data transmission.
·     For MPLS L3VPN, an ADVPN tunnel is a virtual link of MPLS L3VPN on the backbone network. To achieve public network routing connectivity for MPLS L3VPN, run OSPF on ADVPN tunnel interfaces and Loopback interfaces of the PE and Hub devices.
·     To establish  LDP LSPs over the ADVPN tunnels, enable MPLS and LDP on the ADVPN tunnel interfaces. The LDP LSPs serve as public network tunnels for MPLS L3VPN.
·     Configure EBGP between PE and CE to exchange private network routes. On the CEs, redistribute direct routes into BGP.
·     Establish MP-IBGP peers between the PEs to exchange BGP VPNv4 routes.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M router.
Data planning
Table 1 Configuration data
Configuration Item
Data
AS number of CE 1
65410
AS number of CE 2
65420
AS numbers of PE 1 and PE 2
100
VAM server address
4.0.0.1
ADVPN tunnel interface address of the hub
10.3.1.1/24
ADVPN tunnel interface address of PE 1 (Spoke 1)
10.3.1.2/24
ADVPN tunnel interface address of PE 2 (Spoke 2).
10.3.1.3/24
Procedures
Configuring the VAM server
Configuring interface IP addresses and unicast routing
# Assign an IP address to the interface.
[Sysname] sysname VAMserver
[VAMserver] interface gigabitethernet 2/0/1
[VAMserver-GigabitEthernet2/0/1] ip address 4.0.0.1 24
[VAMserver-GigabitEthernet2/0/1] quit
# Configure OSPF to achieve network layer connectivity.
[VAMserver] ospf
[VAMserver-ospf-1] area 0
[VAMserver-ospf-1-area-0.0.0.0] network 4.0.0.0 0.0.0.255
[VAMserver-ospf-1-area-0.0.0.0] quit
[VAMserver-ospf-1] quit
# Create ADVPN domain abc.
[VAMserver] vam server advpn-domain abc id 1
# Create hub group 0.
[VAMserver-vam-server-domain-abc] hub-group 0
# Specify the hub IPv4 private address.
[VAMserver-vam-server-domain-abc-hub-group-0] hub private-address 10.3.1.1
# Specify the IPv4 private network address range for spokes in the hub group.
[VAMserver-vam-server-domain-abc-hub-group-0] spoke private-address network 10.3.1.0 255.255.255.0
[VAMserver-vam-server-domain-abc-hub-group-0] quit
# Configure the preshared key of the VAM server as 123456.
[VAMserver-vam-server-domain-abc] pre-shared-key simple 123456
# Configure the VAM server to not authenticate VAM clients.
[VAMserver-vam-server-domain-abc] authentication-method none
# Enable the VAM server for the ADVPN domain.
[VAMserver-vam-server-domain-abc] server enable
[VAMserver-vam-server-domain-abc] quit
Configuring the hub
[Sysname] sysname Hub
[Hub] interface gigabitethernet 2/0/1
[Hub-GigabitEthernet2/0/1] ip address 1.0.0.1 24
[Hub-GigabitEthernet2/0/1] quit
[Hub] ospf
[Hub-ospf-1] area 0
[Hub-ospf-1-area-0.0.0.0] network 1.0.0.0 0.0.0.255
[Hub-ospf-1-area-0.0.0.0] quit
[Hub-ospf-1] quit
Configuring the hub as a VAM client
# Create VAM client Hub.
[Hub] vam client name Hub
# Specify ADVPN domain abc for the VAM client.
[Hub-vam-client-Hub] advpn-domain abc
# Configure the preshared key of the VAM client as 123456.
[Hub-vam-client-Hub] pre-shared-key simple 123456
# Specify the IP address of the VAM server.
[Hub-vam-client-Hub] server primary ip-address 4.0.0.1
# Enable the VAM client.
[Hub-vam-client-Hub] client enable
[Hub-vam-client-Hub] quit
Configuring IPsec
# Configure an IKE profile.
[Hub] ike keychain abc
[Hub-ike-keychain-abc] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[Hub-ike-keychain-abc] quit
[Hub] ike profile abc
[Hub-ike-profile-abc] keychain abc
[Hub-ike-profile-abc] quit
# Configure an IPsec profile.
[Hub] ipsec transform-set abc
[Hub-ipsec-transform-set-abc] encapsulation-mode transport
[Hub-ipsec-transform-set-abc] esp encryption-algorithm des-cbc
[Hub-ipsec-transform-set-abc] esp authentication-algorithm sha1
[Hub-ipsec-transform-set-abc] quit
[Hub] ipsec profile abc isakmp
[Hub-ipsec-profile-isakmp-abc] transform-set abc
[Hub-ipsec-profile-isakmp-abc] ike-profile abc
[Hub-ipsec-profile-isakmp-abc] quit
Configuring the ADVPN tunnel
Create a UDP-mode IPv4 ADVPN tunnel interface named Tunnel1, and configure an IP address for this interface.
[Hub] interface tunnel1 mode advpn udp
[Hub-Tunnel1] ip address 10.3.1.1 255.255.255.0
# Bind the VAM client to the IPv4 ADVPN tunnel interface.
[Hub-Tunnel1] vam client Hub
# Set the OSPF network type to broadcast to establish full-mesh ADVPN tunnels.
[Hub-Tunnel1] ospf network-type broadcast
# Configure the source interface of the IPv4 ADVPN tunnel.
[Hub-Tunnel1] source gigabitethernet 2/0/1
# Apply an IPsec profile to the IPv4 ADVPN tunnel to ensure secure data transmission.
[Hub-Tunnel1] tunnel protection ipsec profile abc
[Hub-Tunnel1] quit
Configuring OSPF to advertise the ADVPN tunnel interface address
# Configure OSPF to advertise the route for the ADVPN tunnel interface address. Make sure to use different OSPF processes to advertise the routes for Tunnel1 and GigabitEthernet 2/0/1.
[Hub] ospf 2
[Hub-ospf-2] area 0
[Hub-ospf-2-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[Hub-ospf-2-area-0.0.0.0] quit
[Hub-ospf-2] quit
Configuring PE 1
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] interface gigabitethernet 2/0/1
[PE1-GigabitEthernet2/0/1] ip address 2.0.0.1 24
[PE1-GigabitEthernet2/0/1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.0.0.0 0.0.0.255
[PE1-ospf-1] quit
Configuring the VAM client
# Create VAM client Spoke1.
[PE1] vam client name Spoke1
[PE1-vam-client-Spoke1] advpn-domain abc
# Configure a preshared key for the VAM client.
[PE1-vam-client-Spoke1] pre-shared-key simple 123456
[PE1-vam-client-Spoke1] server primary ip-address 4.0.0.1
[PE1-vam-client-Spoke1] client enable
[PE1-vam-client-Spoke1] quit
Configuring IPsec
[PE1] ike keychain abc
[PE1-ike-keychain-abc] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[PE1-ike-keychain-abc] quit
[PE1] ike profile abc
[PE1-ike-profile-abc] keychain abc
[PE1-ike-profile-abc] quit
[PE1] ipsec transform-set abc
[PE1-ipsec-transform-set-abc] encapsulation-mode transport
[PE1-ipsec-transform-set-abc] esp encryption-algorithm des-cbc
[PE1-ipsec-transform-set-abc] esp authentication-algorithm sha1
[PE1-ipsec-transform-set-abc] quit
[PE1] ipsec profile abc isakmp
[PE1-ipsec-profile-isakmp-abc] transform-set abc
[PE1-ipsec-profile-isakmp-abc] ike-profile abc
[PE1-ipsec-profile-isakmp-abc] quit
[PE1] interface tunnel1 mode advpn udp
[PE1-Tunnel1] ip address 10.3.1.2 255.255.255.0
[PE1-Tunnel1] vam client Spoke1
# Set the OSPF network type to broadcast to establish full-mesh ADVPN tunnels. Set the DR priority of PE1 to 0 to exclude PE1 from DR/BDR election.
[PE1-Tunnel1] ospf network-type broadcast
[PE1-Tunnel1] ospf dr-priority 0
[PE1-Tunnel1] source gigabitethernet 2/0/1
[PE1-Tunnel1] tunnel protection ipsec profile abc
[PE1-Tunnel1] quit
# Configure OSPF to advertise routes for the ADVPN tunnel interface and Loopback interface. Make sure to use different OSPF processes to advertise the routes for Tunnel1 and GigabitEthernet 2/0/1.
[PE1] ospf 2
[PE1-ospf-2] area 0
[PE1-ospf-2-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[PE1-ospf-2-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[PE1-ospf-2-area-0.0.0.0] quit
[PE1-ospf-2] quit
Configuring an MPLS LSR ID and enabling MPLS and MPLS LDP on nodes
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Tunnel1] mpls enable
[PE1-Tunnel1] mpls ldp enable
[PE1-Tunnel1] quit
Configuring MP-IBGP peering between PE 1 and PE 2 to exchange VPNv4 routes
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-vpnv4] quit
Configuring a VPN instance
# Create VPN instance vpn1 and configure the RD and RT of the VPN instance.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 1:1
[PE1-vpn-instance-vpn1] vpn-target 1:1 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
[PE1-vpn-instance-vpn1] quit
# Bind interface GigabitEthernet 2/0/2 to VPN instance vpn1 and configure an IP address for this interface.
[PE1] interface gigabitethernet 2/0/2
[PE1-GigabitEthernet2/0/2] ip binding vpn-instance vpn1
[PE1-GigabitEthernet2/0/2] ip address 10.1.1.1 24
[PE1-GigabitEthernet2/0/2] quit
Configuring PE 1 to establish EBGP peering with CE 1 to exchange private network routes
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[PE1-bgp-default-vpn1] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.2 32
[PE2-LoopBack0] quit
[PE2] interface gigabitethernet 2/0/1
[PE2-GigabitEthernet2/0/1] ip address 3.0.0.1 24
[PE2-GigabitEthernet2/0/1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.0.0.0 0.0.0.255
[PE2-ospf-1] quit
# Create VAM client Spoke2.
[PE2] vam client name Spoke2
[PE2-vam-client-Spoke2] advpn-domain abc
[PE2-vam-client-Spoke2] pre-shared-key simple 123456
[PE2-vam-client-Spoke2] server primary ip-address 4.0.0.1
[PE2-vam-client-Spoke2] client enable
[PE2-vam-client-Spoke2] quit
Configuring IPsec
[PE2] ike keychain abc
[PE2-ike-keychain-abc] pre-shared-key address 0.0.0.0 0.0.0.0 key simple 123456
[PE2-ike-keychain-abc] quit
[PE2] ike profile abc
[PE2-ike-profile-abc] keychain abc
[PE2-ike-profile-abc] quit
[PE2] ipsec transform-set abc
[PE2-ipsec-transform-set-abc] encapsulation-mode transport
[PE2-ipsec-transform-set-abc] esp encryption-algorithm des-cbc
[PE2-ipsec-transform-set-abc] esp authentication-algorithm sha1
[PE2-ipsec-transform-set-abc] quit
[PE2] ipsec profile abc isakmp
[PE2-ipsec-profile-isakmp-abc] transform-set abc
[PE2-ipsec-profile-isakmp-abc] ike-profile abc
[PE2-ipsec-profile-isakmp-abc] quit
[PE2] interface tunnel1 mode advpn udp
[PE2-Tunnel1] ip address 10.3.1.3 255.255.255.0
[PE2-Tunnel1] vam client Spoke2
# Set the OSPF network type to broadcast to establish full-mesh ADVPN tunnels. Set the DR priority of PE2 to 0 to exclude PE2 from DR/BDR election.
[PE2-Tunnel1] ospf network-type broadcast
[PE2-Tunnel1] ospf dr-priority 0
[PE2-Tunnel1] source gigabitethernet 2/0/1
[PE2-Tunnel1] tunnel protection ipsec profile abc
[PE2-Tunnel1] quit
[PE2] ospf 2
[PE2-ospf-2] area 0
[PE2-ospf-2-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-2-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[PE2-ospf-2-area-0.0.0.0] quit
[PE2-ospf-2] quit
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Tunnel1] mpls enable
[PE2-Tunnel1] mpls ldp enable
[PE2-Tunnel1] quit
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 1:1
[PE2-vpn-instance-vpn1] vpn-target 1:1 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
[PE2-vpn-instance-vpn1] quit
[PE2] interface gigabitethernet 2/0/2
[PE2-GigabitEthernet2/0/2] ip binding vpn-instance vpn1
[PE2-GigabitEthernet2/0/2] ip address 10.2.1.1 24
[PE2-GigabitEthernet2/0/2] quit
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.2 as-number 65420
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.2 enable
[PE2-bgp-default-vpn1] quit
Configuring Device
Specifying an IP address
[Sysname] sysname Device
[Device] interface gigabitethernet 2/0/1
[Device-GigabitEthernet2/0/1] ip address 1.0.0.2 24
[Device-GigabitEthernet2/0/1] quit
[Device] interface gigabitethernet 2/0/2
[Device-GigabitEthernet2/0/2] ip address 2.0.0.2 24
[Device-GigabitEthernet2/0/2] quit
[Device] interface gigabitethernet 2/0/3
[Device-GigabitEthernet2/0/3] ip address 3.0.0.2 24
[Device-GigabitEthernet2/0/3] quit
[Device] interface gigabitethernet 2/0/4
[Device-GigabitEthernet2/0/4] ip address 4.0.0.2 24
[Device-GigabitEthernet2/0/4] quit
Configuring unicast routing
[Device] ospf
[Device-ospf-1] area 0
[Device-ospf-1-area-0.0.0.0] network 1.0.0.0 0.0.0.255
[Device-ospf-1-area-0.0.0.0] network 2.0.0.0 0.0.0.255
[Device-ospf-1-area-0.0.0.0] network 3.0.0.0 0.0.0.255
[Device-ospf-1-area-0.0.0.0] network 4.0.0.0 0.0.0.255
[Device-ospf-1-area-0.0.0.0] quit
[Device-ospf-1] quit
Configuring CE 1
[Sysname] sysname CE1
[CE1] interface gigabitethernet 2/0/1
[CE1-GigabitEthernet2/0/1] ip address 10.1.1.2 24
[CE1-GigabitEthernet2/0/1] quit
Establishing EBGP peering between PE and CE to redistribute direct routes into BGP.
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
Configuring CE 2
[Sysname] sysname CE2
[CE2] interface gigabitethernet 2/0/1
[CE2-GigabitEthernet2/0/1] ip address 10.2.1.2 24
[CE2-GigabitEthernet2/0/1] quit
[CE2] bgp 65420
[CE2-bgp-default] peer 10.2.1.1 as-number 100
[CE2-bgp-default-ipv4] peer 10.2.1.1 enable
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
Verifying that ADVPN tunnels are established successfully
# Display IPv4 address mapping information for all VAM clients registered with the VAM server. The output shows that Hub, Spoke 1, and Spoke 2 have all registered their address mapping information with the VAM server.
<VAMserver> display vam server address-map
ADVPN domain name: abc
Total private address mappings: 3
Group      Private address  Public address              Type   NAT  Holding time
0          10.3.1.1         1.0.0.1                     Hub    No   0H 43M 43S
0          10.3.1.2         2.0.0.1                     Spoke  No   0H 44M 40S
0          10.3.1.3         3.0.0.1                     Spoke  No   0H 44M 53S
# On PE 1, ping the private network address 10.3.1.3 of PE 2, and it can be pinged successfully.
<PE1> ping 10.3.1.3
Ping 10.3.1.3 (10.3.1.3): 56 data bytes, press CTRL_C to break
56 bytes from 10.3.1.3: icmp_seq=0 ttl=255 time=4.000 ms
56 bytes from 10.3.1.3: icmp_seq=1 ttl=255 time=0.000 ms
56 bytes from 10.3.1.3: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 10.3.1.3: icmp_seq=3 ttl=255 time=0.000 ms
56 bytes from 10.3.1.3: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 10.3.1.3 ---
round-trip min/avg/max/std-dev = 0.000/1.000/4.000/1.549 ms
# Display IPv4 ADVPN tunnel information on Hub, PE 1, and PE 2. The output shows that ADVPN tunnels have been established between hub and spoke, as well as between spoke and spoke.
<Hub> display advpn session
Interface         : Tunnel1
Number of sessions: 2
Private address      Public address       Port  Type  State        Holding time
10.3.1.2             2.0.0.1              18001 H-S   Success      0H 41M 35S
10.3.1.3             3.0.0.1              18001 H-S   Success      0H 41M 36S
<PE1> display advpn session
Interface         : Tunnel1
10.3.1.1             1.0.0.1              18001 S-H   Success      0H 44M 7S
10.3.1.3             3.0.0.1              18001 S-S   Success      0H 40M 2S
<PE2> display advpn session
Interface         : Tunnel1
10.3.1.1             1.0.0.1              18001 S-H   Success      0H 48M 41S
10.3.1.2             2.0.0.1              18001 S-S   Success      0H 44M 31S
Verifying that PEs have learned the private network route from the peer and CEs can ping each other
# Execute the display bgp peer vpnv4 command on PEs. The output shows that PE 1 and PE 2 have established a BGP VPNv4 peer relationship.
<PE1> display bgp peer vpnv4
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of peers: 1                 Peers in established state: 1
  * - Dynamically created peer
  2.2.2.2                100       30       26    0       1 00:20:34 Established
<PE2> display bgp peer vpnv4
 BGP local router ID: 2.2.2.2
  1.1.1.1                100       30       35    0       1 00:24:36 Established
# Execute the display bgp routing-table vpnv4 command on PEs. The output shows that the PEs have learned private network routes from the remote CEs through BGP VPNv4.
<PE1> display bgp routing-table vpnv4
               s - suppressed, S - stale, i - internal, e - external,
               a - additional-path
 Total number of routes from all PEs: 1
 Route distinguisher: 1:1(vpn1)
 Total number of routes: 2
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >e 10.1.1.0/24        10.1.1.2        0                     0       65410?
* >i 10.2.1.0/24        2.2.2.2         0          100        0       65420?
<PE2> display bgp routing-table vpnv4
               a - additional-path
* >i 10.1.1.0/24        1.1.1.1         0          100        0       65410?
* >e 10.2.1.0/24        10.2.1.2        0                     0       65420?
# On PEs, display the FIB entries in VPN instance vpn1. The output shows that the outgoing interface for the route to the remote CE is ADVPN tunnel interface Tunnel1, and the remote PE has assigned a private network label to that route.
<PE1> display fib vpn-instance vpn1
Route destination count: 9
Directly-connected host count: 1
Flag:
  R:Relay     F:FRR
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
10.1.1.0/24        10.1.1.1        U        GE2/0/2                         Null
10.1.1.1/32        127.0.0.1       UH       InLoop0                  Null
10.1.1.2/32        10.1.1.2        UH       GE2/0/2                         Null
10.1.1.255/32      10.1.1.1        UBH      GE2/0/2                         Null
10.2.1.0/24        2.2.2.2         UGR      1                        24256
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
255.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
<PE2> display fib vpn-instance vpn1
Flag:
  R:Relay     F:FRR
10.1.1.0/24        1.1.1.1         UGR      1                        24256
10.2.1.0/24        10.2.1.1        U        GE2/0/2                         Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
10.2.1.2/32        10.2.1.2        UH       GE2/0/2                         Null
10.2.1.255/32      10.2.1.1        UBH      GE2/0/2                         Null
# Verify that the CE devices can ping each other.
<CE1> ping 10.2.1.2
Ping 10.2.1.2 (10.2.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.2: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 10.2.1.2: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=2 ttl=253 time=2.000 ms
56 bytes from 10.2.1.2: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 10.2.1.2 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
Configuration files
·     VAM server
 sysname VAMserver
ospf 1
 area 0.0.0.0
interface GigabitEthernet2/0/1
 port link-mode route
 combo enable copper
 ip address 4.0.0.1 255.255.255.0
 pre-shared-key cipher $c$3$4g3dSoFtvWfi8HvmFfTt2RItcU9oDrJnYg==
 server enable
 hub-group 0
  spoke private-address range 10.3.1.0 10.3.1.255
return
·     Hub
 sysname Hub
ospf 1
 area 0.0.0.0
ospf 2
 area 0.0.0.0
 combo enable copper
 ip address 1.0.0.1 255.255.255.0
interface Tunnel1 mode advpn udp
 source GigabitEthernet2/0/1
 vam client Hub
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$MTshF3PbSXutZ6ba3rQ445mP6m1jyPXuMg==
vam client name Hub
 advpn-domain abc
 pre-shared-key cipher $c$3$t3kfwOkdYFK57jEODcpQHf943u+98JdbkA==
 client enable
return
·     PE 1
 sysname PE1
ospf 1
 area 0.0.0.0
ospf 2
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
mpls ldp
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
 combo enable copper
 ip address 2.0.0.1 255.255.255.0
interface GigabitEthernet2/0/2
 combo enable copper
 ospf dr-priority 0
 mpls enable
 mpls ldp enable
 vam client Spoke1
bgp 100
 peer 2.2.2.2 connect-interface LoopBack0
  peer 2.2.2.2 enable
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$D4z85zTTQkoSKg6QcP/yNRcRyYzT5Rci1w==
 advpn-domain abc
 pre-shared-key cipher $c$3$kdGtUDsS34JSBmeagv0gg/+bUzGX1jo/nQ==
 client enable
return
·     PE 2
 sysname PE2
ospf 1
 area 0.0.0.0
ospf 2
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 combo enable copper
 ip address 3.0.0.1 255.255.255.0
 combo enable copper
 ip address 10.2.1.1 255.255.255.0
 ospf dr-priority 0
 mpls enable
 mpls ldp enable
 vam client Spoke2
bgp 100
 peer 1.1.1.1 connect-interface LoopBack0
  peer 1.1.1.1 enable
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$xDmL61HQY2KOy0pQqPpkwXNZD81U77cPow==
 advpn-domain abc
 pre-shared-key cipher $c$3$JmWbOY0L4qmNKYkMvY2ve3/cbDz7lVFuKg==
 client enable
return
·     Device
 sysname Device
ospf 1
 area 0.0.0.0
 combo enable copper
 ip address 1.0.0.2 255.255.255.0
 combo enable copper
 ip address 2.0.0.2 255.255.255.0
interface GigabitEthernet2/0/3
 combo enable copper
 ip address 3.0.0.2 255.255.255.0
interface GigabitEthernet2/0/4
 combo enable copper
 ip address 4.0.0.2 255.255.255.0
return
·     CE 1
 sysname CE1
 combo enable copper
bgp 65410
  import-route direct
return
·     CE 2
 sysname CE2
 combo enable copper
 ip address 10.2.1.2 255.255.255.0
bgp 65420
  import-route direct
return
Example: Configuring IPv6 LDP over GRE-encapsulated ADVPN
Enterprise branches use dynamic addresses to access the public network, and establish ADVPN tunnels between the hub and spokes but not between spokes, forming a hub-spoke network. This ensures uninterrupted communication between branches despite changes in public network addresses.
Meanwhile, the enterprise branches hope to forward traffic through IPv6 LDP LSPs. For this purpose, the branches must establish the IPv6 LDP LSPs over the ADVPN tunnels in the public network.
As shown in Figure 2, the specific networking requirements in this example are as follows:
·     Spoke 1 and Spoke 2 establish ADVPN tunnels with Hub.
·     Configure IPv6 LDP on the ADVPN tunnels to establish IPv6 LDP LSPs over the ADVPN tunnels.
·     Spoke 1, Spoke 2 and Hub act as VAM clients to register their public and private network addresses with the VAM server.
Figure 2 Network diagram
Analysis
To establish IPv6 LDP LSPs across ADVPN tunnels, perform the following configuration:
·     Run OSPFv3 on the backbone-facing interfaces of Spokes, Device, Hub, and VAM server to ensure routing connectivity between the VAM clients and VAM server.
·     Configure ADVPN on Spokes and Hub to establish ADVPN tunnels using GRE encapsulation between Spokes and Hub.
·     For IPv6 LDP, an ADVPN tunnel is a virtual link on the backbone network. To enable private network routing between sites and communication between sites through ADVPN tunnels, a routing protocol (OSPFv3 in this example) must be configured on the ADVPN tunnel interfaces on Spoke and Hub devices.
·     To establish IPv6 LDP LSPs over the ADVPN tunnels, enable MPLS and LDP on the ADVPN tunnel interfaces of Spoke and Hub devices.
Data planning
Table 2 Configuration data
Configuration Item
Data
VAM server address
4::1
192:168:3::1/64
ADVPN tunnel interface address of Spoke 1
192:168:3::2/64
ADVPN tunnel interface address of Spoke 2
192:168:3::3/64
Procedures
Configuring interface IPv6 addresses and unicast routing
# Create OSPFv3 process 1 in area 0, and configure the router ID of the node.
[VAMserver] ospfv3
[VAMserver-ospfv3-1] router-id 4.4.4.4
[VAMserver-ospfv3-1] area 0
[VAMserver-ospfv3-1-area-0.0.0.0] quit
[VAMserver-ospfv3-1] quit
# Configure the IPv6 address of the interface and enable OSPFv3 on the interface.
[VAMserver-GigabitEthernet2/0/1] ipv6 address 4::1/64
[VAMserver-GigabitEthernet2/0/1] ospfv3 1 area 0.0.0.0
# Specify the hub IPv6 private address.
[VAMserver-vam-server-domain-abc-hub-group-0] hub ipv6 private-address 192:168:3::1
# Specify the IPv6 private network address range for spokes in the hub group.
[VAMserver-vam-server-domain-abc-hub-group-0] spoke ipv6 private-address network 192:168:: 32
Configuring the hub
[Hub] ospfv3
[Hub-ospfv3-1] router-id 5.5.5.5
[Hub-ospfv3-1] area 0
[Hub-ospfv3-1-area-0.0.0.0] quit
[Hub-ospfv3-1] quit
[Hub-GigabitEthernet2/0/1] ipv6 address 1::1 64
[Hub-GigabitEthernet2/0/1] ospfv3 1 area 0.0.0.0
[Hub-vam-client-Hub] server primary ipv6-address 4::1
Configuring IPsec
[Hub-ike-keychain-abc] pre-shared-key address ipv6 :: 0 key simple 123456
Create a GRE-mode IPv6 ADVPN tunnel interface named Tunnel1, and configure an IPv6 address for this interface.
[Hub] interface tunnel1 mode advpn gre ipv6
[Hub-Tunnel1] ipv6 address 192:168:3::1 64
[Hub-Tunnel1] ipv6 address fe80::1 link-local
# Bind the VAM client to the IPv6 ADVPN tunnel interface.
[Hub-Tunnel1] vam ipv6 client Hub
# Configure OSPF network type as P2MP to form a hub-spoke network, where ADVPN tunnels are established only between hub and spokes, and no ADVPN tunnels are established between spokes.
[Hub-Tunnel1] ospfv3 network-type p2mp
# Configure the source interface of the IPv6 ADVPN tunnel.
[Hub-Tunnel1] quit
Configuring OSPFv3 to advertise the ADVPN tunnel interface address
# Configure OSPFv3 to advertise the route for the ADVPN tunnel interface address. Make sure to use different OSPFv3 processes to advertise the routes for Tunnel1 and GigabitEthernet 2/0/1.
[Hub] ospfv3 2
[Hub-ospfv3-2] router-id 5.5.5.5
[Hub-ospfv3-2] area 0
[Hub-ospfv3-2-area-0.0.0.0] quit
[Hub-ospfv3-2] quit
[Hub-Tunnel1] ospfv3 2 area 0.0.0.0
[Hub-Tunnel1] quit
# Enable MPLS and MPLS LDP, and configure all IPv6 routes to trigger the establishment of IPv6 LDP LSPs.
[Hub] mpls lsr-id 5.5.5.5
[Hub] mpls ldp
[Hub-ldp] ipv6 lsp-trigger all
[Hub-ldp] quit
# Enable MPLS and MPLS LDP on interface Tunnel1, and configure LDP transport address as the address of Tunnel1.
[Hub-Tunnel1] mpls enable
[Hub-Tunnel1] mpls ldp ipv6 enable
[Hub-Tunnel1] mpls ldp transport-address 192:168:3::1
[Hub-Tunnel1] quit
Configuring Spoke 1
[Sysname] sysname Spoke1
[Spoke1] ospfv3
[Spoke1-ospfv3-1] router-id 1.1.1.1
[Spoke1-ospfv3-1] area 0
[Spoke1-ospfv3-1-area-0.0.0.0] quit
[Spoke1-ospfv3-1] quit
# Assign an IPv6 address to interface GigabitEthernet 2/0/1 and enable OSPFv3 on the interface.
[Spoke1] interface gigabitethernet 2/0/1
[Spoke1-GigabitEthernet2/0/1] ipv6 address 2::1 64
[Spoke1-GigabitEthernet2/0/1] ospfv3 1 area 0.0.0.0
[Spoke1-GigabitEthernet2/0/1] quit
# Assign an IPv6 address to interface GigabitEthernet 2/0/2.
[Spoke1] interface gigabitethernet 2/0/2
[Spoke1-GigabitEthernet2/0/2] ipv6 address 192:168:1::1 64
[Spoke1-GigabitEthernet2/0/2] quit
[Spoke1] vam client name Spoke1
[Spoke1-vam-client-Spoke1] advpn-domain abc
[Spoke1-vam-client-Spoke1] pre-shared-key simple 123456
[Spoke1-vam-client-Spoke1] server primary ipv6-address 4::1
[Spoke1-vam-client-Spoke1] client enable
[Spoke1-vam-client-Spoke1] quit
Configuring IPsec
[Spoke1] ike keychain abc
[Spoke1-ike-keychain-abc] pre-shared-key address ipv6 :: 0 key simple 123456
[Spoke1-ike-keychain-abc] quit
[Spoke1] ike profile abc
[Spoke1-ike-profile-abc] keychain abc
[Spoke1-ike-profile-abc] quit
[Spoke1] ipsec transform-set abc
[Spoke1-ipsec-transform-set-abc] encapsulation-mode transport
[Spoke1-ipsec-transform-set-abc] esp encryption-algorithm des-cbc
[Spoke1-ipsec-transform-set-abc] esp authentication-algorithm sha1
[Spoke1-ipsec-transform-set-abc] quit
[Spoke1] ipsec profile abc isakmp
[Spoke1-ipsec-profile-isakmp-abc] transform-set abc
[Spoke1-ipsec-profile-isakmp-abc] ike-profile abc
[Spoke1-ipsec-profile-isakmp-abc] quit
[Spoke1] interface tunnel1 mode advpn gre ipv6
[Spoke1-Tunnel1] ipv6 address 192:168:3::2 64
[Spoke1-Tunnel1] ipv6 address FE80::3 link-local
[Spoke1-Tunnel1] vam ipv6 client Spoke1
[Spoke1-Tunnel1] ospfv3 network-type p2mp
[Spoke1-Tunnel1] source gigabitethernet 2/0/1
# Apply an IPsec profile to the IPv6 ADVPN tunnel to ensure secure data transmission.
[Spoke1-Tunnel1] tunnel protection ipsec profile abc
[Spoke1-Tunnel1] quit
# Configure OSPFv3 to advertise the route for the ADVPN tunnel interface address. Make sure the OSPFv3 process for advertising the routes of Tunnel1 and GigabitEthernet 2/0/2 is different from that for advertising the route of GigabitEthernet 2/0/1.
[Spoke1] ospfv3 2
[Spoke1-ospfv3-2] router-id 1.1.1.1
[Spoke1-ospfv3-2] area 0
[Spoke1-ospfv3-2-area-0.0.0.0] quit
[Spoke1-ospfv3-2] quit
[Spoke1-Tunnel1] ospfv3 2 area 0.0.0.0
[Spoke1-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
[Spoke1] mpls lsr-id 1.1.1.1
[Spoke1] mpls ldp
[Spoke1-ldp] ipv6 lsp-trigger all
[Spoke1-ldp] quit
# Enable MPLS and MPLS LDP on interface Tunnel1, and configure LDP transport address as the address of the interface.
[Spoke1-Tunnel1] mpls enable
[Spoke1-Tunnel1] mpls ldp ipv6 enable
[Spoke1-Tunnel1] mpls ldp transport-address 192:168:3::2
Configuring Spoke 2
[Sysname] sysname Spoke2
[Spoke2] ospfv3
[Spoke2-ospfv3-1] router-id 2.2.2.2
[Spoke2-ospfv3-1] area 0
[Spoke2-ospfv3-1-area-0.0.0.0] quit
[Spoke2-ospfv3-1] quit
[Spoke2] interface gigabitethernet 2/0/1
[Spoke2-GigabitEthernet2/0/1] ipv6 address 3::1 64
[Spoke2-GigabitEthernet2/0/1] ospfv3 1 area 0.0.0.0
[Spoke2-GigabitEthernet2/0/1] quit
[Spoke2] interface gigabitethernet 2/0/2
[Spoke2-GigabitEthernet2/0/2] ipv6 address 192:168:2::1 64
[Spoke2-GigabitEthernet2/0/2] quit
[Spoke2] vam client name Spoke2
[Spoke2-vam-client-Spoke2] advpn-domain abc
[Spoke2-vam-client-Spoke2] pre-shared-key simple 123456
[Spoke2-vam-client-Spoke2] server primary ipv6-address 4::1
[Spoke2-vam-client-Spoke2] client enable
[Spoke2-vam-client-Spoke2] quit
Configuring IPsec
[Spoke2] ike keychain abc
[Spoke2-ike-keychain-abc] pre-shared-key address ipv6 :: 0 key simple 123456
[Spoke2-ike-keychain-abc] quit
[Spoke2] ike profile abc
[Spoke2-ike-profile-abc] keychain abc
[Spoke2-ike-profile-abc] quit
[Spoke2] ipsec transform-set abc
[Spoke2-ipsec-transform-set-abc] encapsulation-mode transport
[Spoke2-ipsec-transform-set-abc] esp encryption-algorithm des-cbc
[Spoke2-ipsec-transform-set-abc] esp authentication-algorithm sha1
[Spoke2-ipsec-transform-set-abc] quit
[Spoke2] ipsec profile abc isakmp
[Spoke2-ipsec-profile-isakmp-abc] transform-set abc
[Spoke2-ipsec-profile-isakmp-abc] ike-profile abc
[Spoke2-ipsec-profile-isakmp-abc] quit
[Spoke2] interface tunnel1 mode advpn gre ipv6
[Spoke2-Tunnel1] ipv6 address 192:168:3::3/64
[Spoke2-Tunnel1] ipv6 address fe80::4 link-local
[Spoke2-Tunnel1] vam ipv6 client Spoke2
[Spoke2-Tunnel1] ospfv3 network-type p2mp
[Spoke2-Tunnel1] source gigabitethernet 2/0/1
[Spoke2-Tunnel1] tunnel protection ipsec profile abc
[Spoke2-Tunnel1] quit
[Spoke2] ospfv3 2
[Spoke2-ospfv3-2] router-id 2.2.2.2
[Spoke2-ospfv3-2] area 0
[Spoke2-ospfv3-2-area-0.0.0.0] quit
[Spoke2-ospfv3-2] quit
[Spoke2-Tunnel1] ospfv3 2 area 0.0.0.0
[Spoke2-GigabitEthernet2/0/2] ospfv3 2 area 0.0.0.0
[Spoke2] mpls lsr-id 2.2.2.2
[Spoke2] mpls ldp
[Spoke2-ldp] ipv6 lsp-trigger all
[Spoke2-ldp] quit
[Spoke2-Tunnel1] mpls enable
[Spoke2-Tunnel1] mpls ldp ipv6 enable
[Spoke2-Tunnel1] mpls ldp transport-address 192:168:3::3
Configuring Device
[Device] ospfv3
[Device-ospfv3-1] router-id 3.3.3.3
[Device-ospfv3-1] area 0
[Device-ospfv3-1-area-0.0.0.0] quit
[Device-ospfv3-1] quit
[Device-GigabitEthernet2/0/1] ipv6 address 1::2 64
[Device-GigabitEthernet2/0/1] ospfv3 1 area 0.0.0.0
[Device-GigabitEthernet2/0/2] ipv6 address 2::2 64
[Device-GigabitEthernet2/0/2] ospfv3 1 area 0.0.0.0
[Device-GigabitEthernet2/0/3] ipv6 address 3::2 64
[Device-GigabitEthernet2/0/3] ospfv3 1 area 0.0.0.0
[Device-GigabitEthernet2/0/4] ipv6 address 4::2 64
[Device-GigabitEthernet2/0/4] ospfv3 1 area 0.0.0.0
Configuring CE 1
[CE1] ospfv3 2
[CE1-ospfv3-2] router-id 6.6.6.6
[CE1-ospfv3-2] area 0
[CE1-ospfv3-2-area-0.0.0.0] quit
[CE1-ospfv3-2] quit
[CE1-GigabitEthernet2/0/1] ipv6 address 192:168:1::2 64
[CE1-GigabitEthernet2/0/1] ospfv3 2 area 0.0.0.0
Configuring CE 2
[CE2] ospfv3 2
[CE2-ospfv3-2] router-id 7.7.7.7
[CE2-ospfv3-2] area 0
[CE2-ospfv3-2-area-0.0.0.0] quit
[CE2-ospfv3-2] quit
[CE2-GigabitEthernet2/0/1] ipv6 address 192:168:2::2 64
[CE2-GigabitEthernet2/0/1] ospfv3 2 area 0.0.0.0
# Display IPv6 address mapping information for all VAM clients registered with the VAM server. The output shows that Hub, Spoke 1, and Spoke 2 have all registered their address mapping information with the VAM server.
<VAMserver> display vam server ipv6 address-map
0          192:168:3::1          1::1                   Hub    No   0H 48M 45S
0          192:168:3::2          2::1                   Spoke  No   0H 42M 54S
0          192:168:3::3          3::1                   Spoke  No   0H 48M 1S
# Display IPv6 ADVPN tunnel information on Hub, Spoke 1, and Spoke 2. The output shows that ADVPN tunnels have been established between the hub and spokes, but no ADVPN tunnels have been established between the spokes.
<Hub> display advpn ipv6 session
Interface         : Tunnel1
192:168:3::2         2::1                 --    H-S   Success      0H 38M 22S
192:168:3::3         3::1                 --    H-S   Success      0H 43M 30S
<Spoke1> display advpn ipv6 session
Interface         : Tunnel1
Number of sessions: 1
192:168:3::1         1::1                 --    S-H   Success      0H 34M 26S
<Spoke2> display advpn ipv6 session
Interface         : Tunnel1
192:168:3::1         1::1                 --    S-H   Success      0H 45M 17S
Verifying that LDP LSPs are established between the hub and spokes successfully
# Execute the display mpls ldp peer command on the hub and spokes. The output shows that the hub and spokes have established LDP peer relationships.
<Hub> display mpls ldp peer
VPN instance: public instance
Total number of peers: 2
Peer LDP ID             State         Role     GR   Auth      KA Sent/Rcvd
1.1.1.1:0               Operational   Passive  Off  None      93/93
2.2.2.2:0               Operational   Passive  Off  None      92/92
<Spoke1> display mpls ldp peer
5.5.5.5:0               Operational   Active   Off  None      78/78
<Spoke2> display mpls ldp peer
5.5.5.5:0               Operational   Active   Off  None      99/99
# Execute the display mpls lsp ipv6 command on the hub and spokes. The output shows that the hub and spokes have established IPv6 LDP LSPs. The outgoing interfaces of the IPv6 LDP LSPs is Tunnel1, which is an ADVPN tunnel interface. For example, the IPv6 LDP LSP with the FEC prefix of 192:168:2::/64 from Spoke 1 to Spoke 2 is as follows:
1.     On Spoke 1, the LSP's outgoing label is 24118 and outgoing interface is ADVPN tunnel interface Tunnel1.
2.     On Hub, the LSP's incoming label is 24118, outgoing label is 24123, and outgoing interface is ADVPN tunnel interface Tunnel1.
3.     On Spoke 2, the LSP's incoming label is 24123 and outgoing label is empty, indicating that after popping the label from a packet, the packet is forwarded to CE 2 through the direct route.
<Spoke1> display mpls lsp ipv6 192:168:2:: 64
FEC      : 192:168:2::/64
Protocol : LDP        In-Label : 24118
Out-Label: 24118      Out-Interface: Tun1
Protocol : LDP        In-Label : -
<Hub> display mpls lsp ipv6 192:168:2:: 64
Out-Label: 24123      Out-Interface: Tun1
<Spoke2> display mpls lsp ipv6 192:168:2:: 64
Protocol : LDP        In-Label : 24123
Out-Label: -          Out-Interface: -
Verifying that CEs can communicate with each other through IPv6 LDP LSP
# Enable debugging for MPLS packets on spoke and hub devices. This example uses Spoke 1.
<Spoke1> debugging mpls packet
<Spoke1> terminal debugging
<Spoke1> terminal monitor
# Ping CE 2 from CE 1.
<CE1> ping ipv6 192:168:2::2
Ping6(56 data bytes) 192:168:1::2 --> 192:168:2::2, press CTRL_C to break
56 bytes from 192:168:2::2, icmp_seq=0 hlim=61 time=3.000 ms
56 bytes from 192:168:2::2, icmp_seq=1 hlim=61 time=4.000 ms
56 bytes from 192:168:2::2, icmp_seq=2 hlim=61 time=3.000 ms
56 bytes from 192:168:2::2, icmp_seq=3 hlim=61 time=2.000 ms
56 bytes from 192:168:2::2, icmp_seq=4 hlim=61 time=2.000 ms
--- Ping6 statistics for 192:168:2::2 ---
round-trip min/avg/max/std-dev = 2.000/2.800/4.000/0.748 ms
# During the ping operation, verify that MPLS packet sending, receiving, and processing information is printed on the spoke and hub devices, indicating that the packet is forwarded through MPLS over an IPv6 LDP LSP. This example uses Spoke 1.
<Spoke1>
*Oct 11 11:04:15:032 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS Forward: Receiving IPv6 packet, len = 104, s = 192:168:1::2, d = 192:168:2::2.
PUSH Label=24118, EXP=0, TTL=63.
MPLS Output6: Sending to interface Tun1, PktLen=108, AF=36, Label(s)=24118, EXP=0, TTL=63.
MPLS send result 0.
*Oct 11 11:04:15:035 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS FSInput: Receiving from interface Tun1, PktLen=108, AF=36, Label(s)=24119, EXP=0, TTL=62.
POP Label=24119, EXP=0, TTL=62.
*Oct 11 11:04:15:237 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS FSForward: Receiving IPv6 packet, len = 104, s = 192:168:1::2, d = 192:168:2::2.
MPLS FSOutput6: Sending to interface Tun1, PktLen=108, AF=36, Label(s)=24118, EXP=0, TTL=63.
MPLS send result 0.
*Oct 11 11:04:15:239 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS Input: Receiving from interface Tun1, PktLen=108, AF=36, Label(s)=24119, EXP=0, TTL=62.
*Oct 11 11:04:15:441 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS send result 0.
*Oct 11 11:04:15:443 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
*Oct 11 11:04:15:645 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS send result 0.
*Oct 11 11:04:15:647 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
*Oct 11 11:04:15:847 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
MPLS send result 0.
*Oct 11 11:04:15:849 2023 Spoke1 MPLSFW/7/MPLSFW: -MDC=1;
Configuration files
·     VAM server
 sysname VAMserver
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
 combo enable copper
 pre-shared-key cipher $c$3$OpYSbdgXeyNryePMVEIu/YkmfyL/OsFeNg==
 server enable
 hub-group 0
  spoke ipv6 private-address range 192:168:: 192:168:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
return
·     Hub
 sysname Hub
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
ospfv3 2
 router-id 5.5.5.5
 area 0.0.0.0
 mpls lsr-id 5.5.5.5
mpls ldp
 combo enable copper
 ipv6 address 1::1/64
interface Tunnel1 mode advpn gre ipv6
 mpls enable
 ipv6 address FE80::1 link-local
 ipv6 address 192:168:3::1/64
 vam ipv6 client Hub
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address ipv6 :: 0 key cipher $c$3$T7Q4sF6vhxaDLrThPwGn/xWxdO0yP+MOkA==
vam client name Hub
 advpn-domain abc
 pre-shared-key cipher $c$3$4BBIUe2nuHqNxXJ4M1O2Hv44697+GQOTSg==
 client enable
return
·     Spoke 1
 sysname Spoke1
ospfv3 1
 router-id 1.1.1.1
 area 0.0.0.0
ospfv3 2
 router-id 1.1.1.1
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
mpls ldp
 combo enable copper
 ipv6 address 2::1/64
 combo enable copper
 ipv6 address 192:168:1::1/64
 mpls enable
 ipv6 address 192:168:3::2/64
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address ipv6 :: 0 key cipher $c$3$7cyhmn5VAtBz5E3PnQJvRxUeUE2a4wDDtQ==
 advpn-domain abc
 pre-shared-key cipher $c$3$XkOIAx+EhtRrlRVOCfJhmx5YkLY4figR1w==
 client enable
return
·     Spoke 2
 sysname Spoke2
ospfv3 1
 router-id 2.2.2.2
 area 0.0.0.0
ospfv3 2
 router-id 2.2.2.2
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
mpls ldp
 combo enable copper
 ipv6 address 3::1/64
 combo enable copper
 ipv6 address 192:168:2::1/64
 mpls enable
 ipv6 address FE80::4 link-local
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
ike keychain abc
 pre-shared-key address ipv6 :: 0 key cipher $c$3$Ysgday0kEOAsz7PK2VBkQKXts2w88tNplA==
 advpn-domain abc
 pre-shared-key cipher $c$3$YkiBYd4FdavbYylKBwpRNDzBHCUrotn5NA==
 client enable
return
·     Device
 sysname Device
ospfv3 1
 router-id 3.3.3.3
 area 0.0.0.0
 combo enable copper
 ipv6 address 1::2/64
 combo enable copper
 ipv6 address 2::2/64
 combo enable copper
 ipv6 address 3::2/64
 combo enable copper
 ipv6 address 4::2/64
return
·     CE 1
 sysname CE1
ospfv3 2
 router-id 6.6.6.6
 area 0.0.0.0
 combo enable copper
 ipv6 address 192:168:1::2/64
return
·     CE 2
 sysname CE2
ospfv3 2
 router-id 7.7.7.7
 area 0.0.0.0
 combo enable copper
 ipv6 address 192:168:2::2/64
return
Related documentation
·     MPLS Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     MPLS Command Reference in H3C SR6608-M Router Command References(V9)
