- H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
- 01-AAA Configuration Examples
- 02-ACL Configuration Examples
- 03-MPLS over ADVPN Configuration Examples
- 04-ARP Attack Protection Configuration Examples
- 05-BFD Configuration Examples
- 06-Basic BGP Configuration Examples
- 07-BGP Route Attribute-Based Route Selection Configuration Examples
- 08-EAA Monitor Policy Configuration Examples
- 09-GRE with OSPF Configuration Examples
- 10-HoVPN Configuration Examples
- 11-IGMP Configuration Examples
- 12-IPsec Configuration Examples
- 13-IPsec Digital Certificate Authentication Configuration Examples
- 14-IPv6 IS-IS Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 17-IS-IS Configuration Examples
- 18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 19-L2TP over IPsec Configuration Examples
- 20-Multi-Instance L2TP Configuration Examples
- 21-L2TP Multidomain Access Configuration Examples
- 22-MPLS L3VPN Configuration Examples
- 23-MPLS OAM Configuration Examples
- 24-MPLS TE Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-NAT DNS Mapping Configuration Examples
- 27-NetStream Configuration Examples
- 28-NQA Configuration Examples
- 29-NTP Configuration Examples
- 30-OSPFv3 Configuration Examples
- 31-OSPF Configuration Examples
- 32-OSPF Multi-Process Configuration Examples
- 33-OSPF Multi-Instance Configuration Examples
- 34-Portal Configuration Examples
- 35-POS Interace Configuration Examples
- 36-RBAC Configuration Examples
- 37-RMON Configuration Examples
- 38-IPv4 NetStream Sampling Configuration Examples
- 39-SNMP Configuration Examples
- 40-SRv6 Configuration Examples
- 41-SSH Configuration Examples
- 42-Tcl Commands Configuration Examples
- 43-VLAN Configuration Examples
- 44-VRRP Configuration Examples
- 45-VXLAN over IPsec Configuration Examples
- 46-Cloudnet VPN Configuration Examples
- 47-Ethernet Link Aggregation Configuration Examples
- 48-Ethernet OAM Configuration Examples
- 49-Outbound Bidirectional NAT Configuration Examples
- 50-NAT Hairpin in C-S Mode Configuration Examples
- 51-Load Sharing NAT Server Configuration Examples
- 52-BIDIR-PIM Configuration Examples
- 53-Control Plane-Based QoS Policy Configuration Examples
- 54-Scheduling a Task Configuration Examples
- 55-Client-Initiated L2TP Tunnel Configuration Examples
- 56-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 57-Authorized ARP Configuration Examples
- 58-GTS Configuration Examples
- 59-Traffic Policing Configuration Examples
- 60-Traffic Accounting Configuration Examples
- 61-PBR Configuration Examples
- 62-TFTP Client Software Upgrade Configuration Examples
- 63-FTP Client Software Upgrade Configuration Examples
- 64-FTP Server Software Upgrade Configuration Examples
- 65-Routing Policy Configuration Examples
- 66-Software Upgrade from the BootWare Menu Configuration Examples
- 67-Mirroring Configuration Examples
| 38-IPv4 NetStream Sampling Configuration Examples | 73.10 KB |
H3C Routers |
IPv4 NetStream Sampling |
Introduction
The following information provides examples for configuring IPv4 NetStream sampling on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of samplers and IPv4 NetStream.
Example: Configuring IPv4 NetStream sampling
As shown in Figure 1, the router acts as the gateway to provide external network access. Configure the following settings to collect traffic statistics in the outbound direction on GigabitEthernet 2/0/2 and in the inbound direction on GigabitEthernet 2/0/3 on the router and export the collected data to the NetStream server:
· Configure random sampling in the outbound direction to select one packet randomly from 200 packets on GigabitEthernet 2/0/2.
· Configure fixed sampling in the inbound direction to select the first packet from 100 packets on GigabitEthernet 2/0/3.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
Procedures
# Create sampler samplerin in fixed mode and set the rate to 100. The first packet of 100 packets is selected.
[Device] sampler samplerin mode fixed packet-interval 100
# Create sampler samplerout in random mode and set the rate to 200. One packet from 200 packets is selected.
[Device] sampler samplerout mode random packet-interval 200
# Enable IPv4 NetStream to use sampler samplerin to collect statistics for the inbound traffic on GigabitEthernet 2/0/3.
[Device] interface gigabitethernet 2/0/3
[Device-GigabitEthernet2/0/3] ip address 10.0.0.1 24
[Device-GigabitEthernet2/0/3] ip netstream inbound
[Device-GigabitEthernet2/0/3] ip netstream sampler samplerin inbound
[Device-GigabitEthernet2/0/3] quit
#Enable IPv4 NetStream to use sampler samplerout to collect statistics for the outbound traffic on GigabitEthernet 2/0/2.
[Device] interface gigabitethernet 2/0/2
[Device-GigabitEthernet2/0/2] ip address 192.168.0.1 24
[Device-GigabitEthernet2/0/2] ip netstream outbound
[Device-GigabitEthernet2/0/2] ip netstream sampler samplerout outbound
[Device-GigabitEthernet2/0/2] quit
# Specify an IP address for GigabitEthernet 2/0/1.
[Device] interface gigabitethernet 2/0/1
[Device-GigabitEthernet2/0/1] ip address 192.168.1.1 24
[Device-GigabitEthernet2/0/1] quit
# Specify destination address 192.168.1.2 and UDP port 5000 for NetStream data export.
[Device] ip netstream export host 192.168.1.2 5000
# Execute the display sampler command to display configuration information for sampler samplerin and sampler samplerout.
[Device] display sampler
Sampler name: samplerout
Mode: random; Packet-interval: 200
Sampler name: samplerin
Mode: fixed; Packet-interval: 100
# After the router operates for a period of time, use the display ip netstream cache command to view NetStream flow cache configuration and status.
[Device] display ip netstream cache
IP NetStream cache information:
Active flow timeout : 30 min
Inactive flow timeout : 30 sec
Max number of entries : 10000
IP active flow entries : 1
MPLS active flow entries : 0
L2 active flow entries : 0
IPL2 active flow entries : 0
IP flow entries counted : 7
MPLS flow entries counted : 0
L2 flow entries counted : 0
IPL2 flow entries counted : 0
Last statistics resetting time : Never
IP packet size distribution (157 packets in total):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .929 .031 .006 .000 .006 .000 .000 .000 .000 .025 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
Protocol Total Packets Flows Packets Active(sec) Idle(sec)
Flows /sec /sec /flow /flow /flow
TCP-other 3 0 0 26 7 30
ICMP 1 0 0 1 0 30
UDP-BOOTP 1 0 0 4 15 30
TCP-Telnet 2 0 0 35 24 30
Type DstIP(Port) SrcIP(Port) Pro ToS If(Direct) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK) Lbl-Exp-S-List
IP 192.168.0.1(23) 192.168.0.2(56839) 6 0 GE2/0/2(I) 1
# Execute the display ip netstream export command to view information about the NetStream data export.
[Device] display ip netstream export
IP export information:
Flow source interface : Not specified
Flow destination VPN instance : Not specified
Flow destination IP address (UDP) : 192.168.1.2 (5000)
Version 5 exported flows number : 0
Version 5 exported UDP datagrams number (failed): 0 (0)
Version 9 exported flows number : 8
Version 9 exported UDP datagrams number (failed): 6 (6)
Configuration files
interface GigabitEthernet2/0/1
port link-mode route
interface GigabitEthernet2/0/2
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet2/0/3
ip address 10.0.0.1 255.255.255.0
Related documentation
· Network Management and Monitoring Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
· Network Management and Monitoring Command Reference in H3C SR6608-M Router Command References(V9)
