H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
06-Basic BGP Configuration Examples
06-Basic BGP Configuration Examples 189.63 KB
H3C Routers
Introduction
This document provides basic BGP configuration examples.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of BGP.
Example: Configuring basic BGP
As shown in Figure 1, all routers run BGP. Run EBGP between Router A and Router B, and run IBGP between Router B and Router C so that Router C can access subnet 8.1.1.0/24, which is connected to Router A.
Figure 1 Network diagram
Analysis
To enable Router B to communicate with Router C through loopback interfaces, enable OSPF in AS 65009.
By default, BGP does not advertise local networks. To enable Router C to access subnet 8.1.1.0/24 connected directly to Router A, perform the following tasks:
·     Add network 8.1.1.0/24 to the BGP routing table of Router A.
·     Add networks 3.1.1.0/24 and 9.1.1.0/24 to the BGP routing table of Router B.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
When you configure basic BGP, follow these restrictions and guidelines:
·     Use loopback interfaces to establish IBGP connections to prevent route flapping caused by port state changes.
·     Loopback interfaces are virtual interfaces. Use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
·     The EBGP peers, Router A and Router B, are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so the routers use directly connected interfaces to establish EBGP sessions.
Procedures
Configuring IP addresses for interfaces
# Configure IP addresses for Loopback 0, GigabitEthernet 1/0/1, and GigabitEthernet 1/0/2 on Router A.
[RouterA-LoopBack0] ip address 1.1.1.1 255.255.255.255
[RouterA-LoopBack0] quit
[RouterA-GigabitEthernet1/0/1] port link-mode route
[RouterA-GigabitEthernet1/0/1] ip address 3.1.1.2 255.255.255.0
[RouterA-GigabitEthernet1/0/2] port link-mode route
[RouterA-GigabitEthernet1/0/2] ip address 8.1.1.1 255.255.255.0
# Configure IP addresses for Loopback 0, GigabitEthernet 1/0/1, and GigabitEthernet 1/0/2 on Router B.
<RouterB> system-view
[RouterB-LoopBack0] ip address 2.2.2.2 255.255.255.255
[RouterB-LoopBack0] quit
[RouterB-GigabitEthernet1/0/1] port link-mode route
[RouterB-GigabitEthernet1/0/1] ip address 3.1.1.1 255.255.255.0
[RouterB-GigabitEthernet1/0/2] port link-mode route
[RouterB-GigabitEthernet1/0/2] ip address 9.1.1.1 255.255.255.0
# Configure IP addresses for Loopback 0 and GigabitEthernet 1/0/2 on Router C.
<RouterC> system-view
[RouterC] interface loopback 0
[RouterC-LoopBack0] ip address 3.3.3.3 255.255.255.255
[RouterC-LoopBack0] quit
[RouterC-GigabitEthernet1/0/2] port link-mode route
[RouterC-GigabitEthernet1/0/2] ip address 9.1.1.2 255.255.255.0
Configuring IBGP
1.     Configure Router B.
# Set the router ID of Router B to 2.2.2.2 in BGP view.
[RouterB] bgp 65009
[RouterB-bgp] router-id 2.2.2.2
# Create IBGP peer 3.3.3.3, and then specify Loopback 0 as the source interface for TCP connection to the IBGP peer.
[RouterB-bgp] peer 3.3.3.3 as-number 65009
[RouterB-bgp] peer 3.3.3.3 connect-interface loopback 0
# Create and enter BGP IPv4 unicast address family view, and then enable Router B to exchange IPv4 unicast routing information with peer 3.3.3.3.
[RouterB-bgp] address-family ipv4 unicast
[RouterB-bgp-ipv4] peer 3.3.3.3 enable
[RouterB-bgp-ipv4] quit
[RouterB-bgp] quit
# Configure OSPF settings on Router B.
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
2.     Configure Router C.
# Set the router ID of Router C to 3.3.3.3 in BGP view.
[RouterC] bgp 65009
[RouterC-bgp] router-id 3.3.3.3
# Create IBGP peer 2.2.2.2, and then specify Loopback 0 as the source interface for TCP connection to the IBGP peer.
[RouterC-bgp] peer 2.2.2.2 as-number 65009
[RouterC-bgp] peer 2.2.2.2 connect-interface loopback 0
# Create and enter BGP IPv4 unicast address family view, and then enable Router B to exchange IPv4 unicast routing information with peer 2.2.2.2.
[RouterC-bgp] address-family ipv4 unicast
[RouterC-bgp-ipv4] peer 2.2.2.2 enable
[RouterC-bgp-ipv4] quit
[RouterC-bgp] quit
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 9.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
3.     Verify that Router B and Router C has established an IBGP peer relationship.
# Display brief information about all BGP IPv4 unicast peers on Router C.
[RouterC] display bgp peer ipv4
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
The command output shows that Router B and Router C has established an IBGP peer relationship.
Configuring EBGP
1.     Configure Router A.
# Set the router ID of Router A to 1.1.1.1 in BGP view.
[RouterA] bgp 65008
[RouterA-bgp] router-id 1.1.1.1
# Create EBGP peer 3.1.1.1 in BGP view and set the AS number of the peer to 65009.
[RouterA-bgp] peer 3.1.1.1 as-number 65009
# Create and enter BGP IPv4 unicast address family view, and then enable Router A to exchange IPv4 unicast routing information with peer 3.1.1.1.
[RouterA-bgp] address-family ipv4 unicast
[RouterA-bgp-ipv4] peer 3.1.1.1 enable
# Add route 8.1.1.0/24 to the BGP routing table.
[RouterA-bgp-ipv4] network 8.1.1.0 24
[RouterA-bgp-ipv4] quit
[RouterA-bgp] quit
2.     Configure Router B.
# Create EBGP peer 3.1.1.2 in BGP view and set the AS number of the peer to 65008.
[RouterB] bgp 65009
[RouterB-bgp] peer 3.1.1.2 as-number 65008
# Create and enter BGP IPv4 unicast address family view, and then enable Router B to exchange IPv4 unicast routing information with peer 3.1.1.2.
[RouterB-bgp-ipv4] peer 3.1.1.2 enable
[RouterB-bgp] quit
3.     Verify the EBGP configuration.
# Display BGP peer information on Router B.
[RouterB] display bgp peer ipv4
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The command output shows that Router B has established an IBGP peer relationship with Router C and an EBGP peer relationship with Router A.
# Display the BGP routing table on Router A.
[RouterA] display bgp routing-table ipv4
 Total number of routes: 1
               Origin: i - IGP, e - EGP, ? – incomplete
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >  8.1.1.0/24         8.1.1.1         0                     32768   i
# Display the BGP routing table on Router B.
[RouterB] display bgp routing-table ipv4
* >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Router C.
[RouterC] display bgp routing-table ipv4
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
According to the command outputs:
¡     Router A has learned no route to AS 65009.
¡     Router C has learned a route to subnet 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
Configure Router B to advertise the routes to local networks
# Create and enter BGP IPv4 unicast address family view.
[RouterB] bgp 65009
# Configure BGP to advertise the routes to local networks, so that Router A can obtain route 9.1.1.0/24 and Router C can obtain route 3.1.1.0/24.
[RouterB-bgp-ipv4] network 3.1.1.0 24
[RouterB-bgp-ipv4] network 9.1.1.0 24
[RouterB-bgp] quit
 Total number of routes: 3
* >e 3.1.1.0/24         3.1.1.1         0                     0       65009?
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
The command output shows that route 9.1.1.0/24 has been added in Router A's routing table.
* >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
* >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
* >i 9.1.1.0/24         2.2.2.2         0          100        0       i
The output shows that route 8.1.1.0 becomes valid and its next hop is Router A.
# Use the ping command to verify that Router C can reach 8.1.1.1.
[RouterC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
The command output shows that Router C can reach subnet 8.1.1.0/24.
Configuration files
Router A
interface Loopback0
bgp 65008
 router-id 1.1.1.1
  network 8.1.1.0 255.255.255.0
  peer 3.1.1.1 enable
Router B
interface Loopback0
bgp 65009
 router-id 2.2.2.2
 peer 3.3.3.3 connect-interface Loopback0
  network 3.1.1.0 24
  network 9.1.1.0 24
  peer 3.1.1.2 enable
  peer 3.3.3.3 enable
ospf 1
 area 0.0.0.0
Router C
interface Loopback0
bgp 65009
 router-id 3.3.3.3
 peer 2.2.2.2 connect-interface Loopback0
  peer 2.2.2.2 enable
ospf 1
 area 0.0.0.0
Examples: Configuring BGP and IGP route redistribution
As shown in Figure 2, run EBGP between Router A and Router B, and run OSPF between Router B and Router C to allow communication only between subnets 9.1.2.0/24 and 8.1.1.0/24.
Figure 2 Network diagram
Analysis
To enable Router A to obtain the route to 9.1.2.0/24, configure BGP to redistribute routes from OSPF on Router B. To enable Router C to obtain the route to 8.1.1.0/24, configure OSPF to redistribute routes from BGP on Router B.
Procedures
[RouterA-GigabitEthernet1/0/1] ip address 8.1.1.1 255.255.255.0
[RouterA-GigabitEthernet1/0/2] ip address 3.1.1.2 255.255.255.0
# Configure IP addresses for Loopback 0, GigabitEthernet 1/0/1, and GigabitEthernet 1/0/2 on Router C.
[RouterC-GigabitEthernet1/0/1] port link-mode route
[RouterC-GigabitEthernet1/0/1] ip address 9.1.2.1 255.255.255.0
Configuring OSPF
# Configure OSPF on Router B.
[RouterB] ospf 1
# Configure OSPF on Router C.
[RouterC] ospf 1
[RouterC-ospf-1-area-0.0.0.0] network 9.1.2.0 0.0.0.255
Configuring EBGP
[RouterA] bgp 65008
# Add route 8.1.1.0/24 to the BGP routing table, so that Router B can obtain route 8.1.1.0/24.
[RouterA-bgp] quit
[RouterB] bgp 65009
[RouterB-bgp] quit
Configuring BGP and IGP route redistribution:
# Enter BGP IPv4 unicast address family view, and then redistribute OSPF routes to BGP.
[RouterB] bgp 65009
[RouterB-bgp-ipv4] import-route ospf 1
[RouterB-bgp] quit
# Enter OSPF view, and then redistribute BGP routes to OSPF.
[RouterB] ospf 1
[RouterB-ospf-1] import-route bgp
* >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
The command output shows that Router A has obtained route 9.1.2.0/24.
# Display the OSPF routing table on Router C.
[RouterC] display ospf routing
                   Routing Tables
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
 9.1.2.0/24         1        Stub    9.1.2.1         192.168.0.63    0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
The command output shows that Router C has obtained route 8.1.1.0/24.
# Verify that 8.1.1.1 can ping 9.1.2.1.
[RouterA] ping -a 8.1.1.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
# Verify that 9.1.2.1 can ping 8.1.1.1.
[RouterC] ping -a 9.1.2.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL_C to break
# Verify that 8.1.2.1 cannot ping 9.1.2.1 or 9.1.3.1.
[RouterA] ping –a 8.1.21 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[RouterA] ping –a 8.1.2.1 9.1.3.1
Ping 9.1.3.1 (9.1.3.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 9.1.3.1 ---
# Verify that 9.1.3.1 cannot ping 8.1.1.1 or 8.1.2.1.
[RouterC] ping –a 9.1.3.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
[RouterC] ping –a 9.1.3.1 8.1.2.1
Ping 8.1.2.1 (8.1.2.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 8.1.2.1 ---
Configuration files
Router A
interface Loopback0
 bgp 65008
 router-id 1.1.1.1
  peer 3.1.1.1 enable
Router B
interface Loopback0
bgp 65009
 router-id 2.2.2.2
  import-route ospf 1
  peer 3.1.1.2 enable
ospf 1
 import-route bgp
 area 0.0.0.0
Router C
interface Loopback0
ospf 1
 area 0.0.0.0
Related documentation
·     Layer 3—IP Routing Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     Layer 3—IP Routing Command Reference in H3C SR6608-M Router Command References(V9)
