- H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
- 01-AAA Configuration Examples
- 02-ACL Configuration Examples
- 03-MPLS over ADVPN Configuration Examples
- 04-ARP Attack Protection Configuration Examples
- 05-BFD Configuration Examples
- 06-Basic BGP Configuration Examples
- 07-BGP Route Attribute-Based Route Selection Configuration Examples
- 08-EAA Monitor Policy Configuration Examples
- 09-GRE with OSPF Configuration Examples
- 10-HoVPN Configuration Examples
- 11-IGMP Configuration Examples
- 12-IPsec Configuration Examples
- 13-IPsec Digital Certificate Authentication Configuration Examples
- 14-IPv6 IS-IS Configuration Examples
- 15-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 16-IPv6 over IPv4 Manual Tunnel with OSPFv3 Configuration Examples
- 17-IS-IS Configuration Examples
- 18-Combined ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 19-L2TP over IPsec Configuration Examples
- 20-Multi-Instance L2TP Configuration Examples
- 21-L2TP Multidomain Access Configuration Examples
- 22-MPLS L3VPN Configuration Examples
- 23-MPLS OAM Configuration Examples
- 24-MPLS TE Configuration Examples
- 25-Basic MPLS Configuration Examples
- 26-NAT DNS Mapping Configuration Examples
- 27-NetStream Configuration Examples
- 28-NQA Configuration Examples
- 29-NTP Configuration Examples
- 30-OSPFv3 Configuration Examples
- 31-OSPF Configuration Examples
- 32-OSPF Multi-Process Configuration Examples
- 33-OSPF Multi-Instance Configuration Examples
- 34-Portal Configuration Examples
- 35-POS Interace Configuration Examples
- 36-RBAC Configuration Examples
- 37-RMON Configuration Examples
- 38-IPv4 NetStream Sampling Configuration Examples
- 39-SNMP Configuration Examples
- 40-SRv6 Configuration Examples
- 41-SSH Configuration Examples
- 42-Tcl Commands Configuration Examples
- 43-VLAN Configuration Examples
- 44-VRRP Configuration Examples
- 45-VXLAN over IPsec Configuration Examples
- 46-Cloudnet VPN Configuration Examples
- 47-Ethernet Link Aggregation Configuration Examples
- 48-Ethernet OAM Configuration Examples
- 49-Outbound Bidirectional NAT Configuration Examples
- 50-NAT Hairpin in C-S Mode Configuration Examples
- 51-Load Sharing NAT Server Configuration Examples
- 52-BIDIR-PIM Configuration Examples
- 53-Control Plane-Based QoS Policy Configuration Examples
- 54-Scheduling a Task Configuration Examples
- 55-Client-Initiated L2TP Tunnel Configuration Examples
- 56-LAC-Auto-Initiated L2TP Tunnel Configuration Examples
- 57-Authorized ARP Configuration Examples
- 58-GTS Configuration Examples
- 59-Traffic Policing Configuration Examples
- 60-Traffic Accounting Configuration Examples
- 61-PBR Configuration Examples
- 62-TFTP Client Software Upgrade Configuration Examples
- 63-FTP Client Software Upgrade Configuration Examples
- 64-FTP Server Software Upgrade Configuration Examples
- 65-Routing Policy Configuration Examples
- 66-Software Upgrade from the BootWare Menu Configuration Examples
- 67-Mirroring Configuration Examples
| 37-RMON Configuration Examples | 130.51 KB |
Example: Configuring the Ethernet statistics function
Example: Configuring the history statistics function
Example: Configuring the alarm function
Introduction
This document provides an example for configuring RMON.
The following information applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
This document assumes that you have basic knowledge of RMON.
As shown in Figure 1, create an RMON Ethernet statistics entry on the device to gather cumulative traffic statistics for GigabitEthernet 2/0/1.
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
# Configure the IP addresses of the router interfaces.
<Router> system-view
[Router] interface gigabitethernet 2/0/1
[Router-GigabitEthernet2/0/1] ip address 10.0.0.1 24
[Router-GigabitEthernet2/0/1] quit
[Router] interface gigabitethernet 2/0/2
[Router-GigabitEthernet2/0/2] ip address 192.168.0.1 24
# Create an RMON statistics entry for GigabitEthernet2/0/2. The index is 10 and the owner is user1.
[Router-GigabitEthernet2/0/2] rmon statistics 10 owner user1
[Router-GigabitEthernet2/0/2] quit
# Display statistics collected for GigabitEthernet2/0/2.
[Router] display rmon statistics gigabitethernet 2/0/2
EtherStatsEntry 10 owned by user1 is VALID.
Interface : GigabitEthernet2/0/2<ifIndex.3>
etherStatsOctets : 21657 , etherStatsPkts : 307
etherStatsBroadcastPkts : 56 , etherStatsMulticastPkts : 34
etherStatsUndersizePkts : 0 , etherStatsOversizePkts : 0
etherStatsFragments : 0 , etherStatsJabbers : 0
etherStatsCRCAlignErrors : 0 , etherStatsCollisions : 0
etherStatsDropEvents (insufficient resources): 0
Incoming packets by size:
64 : 235 , 65-127 : 67 , 128-255 : 4
256-511: 1 , 512-1023: 0 , 1024-1518: 0
Configuration files
interface GigabitEthernet2/0/1
port link-mode route
ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet2/0/2
ip address 192.168.0.1 255.255.255.0
As shown in Figure 2, create an RMON history control entry on the device to sample traffic statistics for GigabitEthernet2/0/2 every minute.
# Create an RMON history control entry to sample traffic statistics every minute for GigabitEthernet2/0/2. Retain a maximum of eight samples for the interface in the history statistics table.
[Router-GigabitEthernet2/0/2] rmon history 1 buckets 8 interval 60 owner user1
# Display the history statistics collected for GigabitEthernet2/0/2.
[Router] display rmon history
HistoryControlEntry 1 owned by user1 is VALID
Sampled interface : GigabitEthernet2/0/2<ifIndex.3>
Sampling interval : 60(sec) with 8 buckets max
Sampling record 1 :
dropevents : 0 , octets : 834
packets : 8 , broadcast packets : 1
multicast packets : 6 , CRC alignment errors : 0
undersize packets : 0 , oversize packets : 0
fragments : 0 , jabbers : 0
collisions : 0 , utilization : 0
Sampling record 2 :
dropevents : 0 , octets : 962
packets : 10 , broadcast packets : 3
Sampling record 3 :
dropevents : 0 , octets : 830
packets : 8 , broadcast packets : 0
Sampling record 4 :
dropevents : 0 , octets : 933
multicast packets : 7 , CRC alignment errors : 0
Sampling record 5 :
dropevents : 0 , octets : 898
packets : 9 , broadcast packets : 2
Sampling record 6 :
Sampling record 7 :
dropevents : 0 , octets : 766
packets : 7 , broadcast packets : 0
Sampling record 8 :
dropevents : 0 , octets : 1154
packets : 13 , broadcast packets : 1
Configuration files
As shown in Figure 3, configure the device to monitor the incoming traffic statistic on GigabitEthernet2/0/2, and send RMON alarms when either of the following conditions is met:
· The 5-second delta sample for the traffic statistic crosses the rising threshold (10000).
· The 5-second delta sample for the traffic statistic drops below the falling threshold (5000).
Analysis
· For the NMS to manage and monitor the router, configure the SNMP agent on the router.
· For the router to periodically monitor the traffic on GigabitEthernet2/0/2, first define an RMON statistics entry to collect traffic statistics.
· For the router to send traps to the NMS when the traffic on GigabitEthernet2/0/2 is abnormal, create an alarm entry on the router, and set the alarm threshold.
This configuration example was created and verified on R9141P16 of the router and iMC PLAT 7.0(E0202) and iMC UAM 7.0(E0202).
For correct communication between the NMS and router, make sure the following parameters are the same on them:
· SNMP version.
· Read community name.
· Read and write community name.
Procedures
Configuring the router
1. Configure the IP addresses of the router interfaces.
2. Configure the SNMP agent.
# Configure the SNMP agent (the device) with the same SNMP settings as the NMS at 10.0.0.100. This example uses SNMPv1, read community public, and write community private.
[Router] snmp-agent community read public
[Router] snmp-agent community write private
[Router] snmp-agent sys-info version v1
[Router] snmp-agent trap enable
[Router] snmp-agent target-host trap address udp-domain 10.0.0.100 params securityname public
# Create an RMON event entry and an RMON alarm entry to send SNMP notifications when the delta sample for 1.3.6.1.4.1.25506.2.125.1.1.1 exceeds 10000 or drops below 5000.
[Router] rmon event 1 trap public owner user1
[Router] rmon alarm 1 1.3.6.1.4.1.25506.2.125.1.1.1 5 absolute rising-threshold 10000 1 falling-threshold 5000 1 owner user1
Configuring the NMS
# Add a device.
2. Click the Resources tab.
3. From the navigation pane, select Resource Management > Add Device.
¡ On
the Add Device page, configure the following parameters:
Enter 10.0.0.1 in the Host Name/IP field.
¡ Set the device label to Router.
¡ Select Telnet from the Login Type list.
¡ Use the default values for other parameters.
Figure 4 Adding a device
# Expand the SNMP Settings section. Click Configure.
· Set the parameter type to SNMPv1.
· Set the read community to public.
· Set the write and read community to private.
· Use the default settings for other parameters, and then click OK.
Figure 5 Configuring SNMP parameters
# Display the RMON alarm entry.
AlarmEntry 1 owned by user1 is VALID.
Sample type : absolute
Sampled variable : 1.3.6.1.4.1.25506.2.125.1.1.1<etherStatsOctets.1>
Sampling interval (in seconds) : 5
Rising threshold : 10000(associated with event 1)
Falling threshold : 5000(associated with event 1)
Alarm sent upon entry startup : risingOrFallingAlarm
Latest value : 0
# Display statistics for GigabitEthernet2/0/2.
etherStatsOctets : 57329 , etherStatsPkts : 455
etherStatsBroadcastPkts : 53 , etherStatsMulticastPkts : 353
Incoming packets by size :
64 : 7 , 65-127 : 413 , 128-255 : 35
256-511: 0 , 512-1023: 0 , 1024-1518: 0
Configuration files
snmp-agent
ame public
Related documentation
· Network Management and Monitor Configuration Guide in H3C SR6608-M Router Configuration Guides (V9)
· Network Management and Monitor Command Reference in H3C SR6608-M Router Command References (V9)
