H3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
HomeSupportRoutersSR6600-M SeriesConfigure & DeployConfiguration ExamplesH3C SR6608-M Router Configuration Examples All-in-One-R9141-6W100
Table of Contents
Related Documents
57-Authorized ARP Configuration Examples
57-Authorized ARP Configuration Examples 96.92 KB
H3C Routers
Authorized ARP
Introduction
The following information provides examples for configuring authorized ARP on routers.
This document applies to Comware 9-based routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of authorized ARP.
Example: Configuring authorized ARP on a DHCP server
As shown in Figure 1, configure authorized ARP on GigabitEthernet 2/0/1 of the router (a DHCP server). Then, only hosts with IP addresses assigned by the router can access external networks through the router.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9141P16 of the SR6608-M device.
Procedures
Configuring the router
# Specify an IP address for GigabitEthernet 2/0/1.
<Router> system-view
[Router] interface gigabitethernet 2/0/1
[Router-GigabitEthernet2/0/1] ip address 10.1.1.1 24
[Router-GigabitEthernet2/0/1] quit
# Enable DHCP.
[Router] dhcp enable
# Specify primary subnet 10.1.1.0/24 in DHCP address pool 1.
[Router] dhcp server ip-pool 1
[Router-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[Router-dhcp-pool-1] quit
# Enable authorized ARP.
[Router-GigabitEthernet2/0/1] arp authorized enable
Configuring the host
Configure the NIC of the host to obtain an IP address automatically.
# Verify that the NIC of the host obtains an IP address through DHCP.
C:\Windows\System32>ipconfig
Windows IP Configuration
Ethernet adapter ???? 3:
   Connection-specific DNS Suffix    :
   Link-local IPv6 Address           : fe80::d083:44cb:9d9b:71b7%21
   IPv4 Address                      : 10.1.1.2
   Subnet Mask                       : 255.255.255.0
   Default Gateway                   : 10.1.1.1
# Display authorized ARP entry information on the router.
[Router] display arp all
          Type: S-Static    D-Dynamic    M-Multiport    I-Invalid
IP address      MAC address    VLAN     Interface                Aging Type
10.1.1.2        000f-e123-4568 N/A      GE2/0/1                    18    D
The output shows that the router has recorded an authorized ARP entry.
# Disconnect the host from the switch and change the IP address of the host to a static IP address that resides on the same network segment as the router. Verify that the host and the router cannot communicate with each other after you reconnect the host to the switch.
C:\Windows\System32>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
Configuration files
 dhcp enable
interface GigabitEthernet2/0/1
 port link-mode route
Example: Configuring authorized ARP on a DHCP relay agent
As shown in Figure 2, configure authorized ARP on GigabitEthernet 2/0/2 of Router B (a DHCP relay agent) to ensure user validity.
Figure 2 Network diagram
Analysis
Configure recording of relay entries on the relay agent and authorized ARP so that only packets matching a relay entry can be forwarded by the relay agent. In this way, illegal hosts cannot access external networks through the relay agent.
Procedures
Configuring Router A
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] ip address 10.1.1.1 24
[RouterA-GigabitEthernet2/0/1] quit
# Enable DHCP.
[RouterA] dhcp enable
# Specify primary subnet 10.10.1.0/24 in DHCP address pool 1.
[RouterA] dhcp server ip-pool 1
[RouterA-dhcp-pool-1] network 10.10.1.0 mask 255.255.255.0
[RouterA-dhcp-pool-1] gateway-list 10.10.1.1
[RouterA-dhcp-pool-1] quit
#Configure a static route.
[RouterA] ip route-static 10.10.1.0 24 10.1.1.2
Configuring Router B
# Enable DHCP.
<RouterB> system-view
[RouterB] dhcp enable
# Specify IP addresses for GigabitEthernet 2/0/1 and GigabitEthernet 2/0/2.
[RouterB] interface gigabitethernet 2/0/1
[RouterB-GigabitEthernet2/0/1] ip address 10.1.1.2 24
[RouterB-GigabitEthernet2/0/1] quit
[RouterB] interface GigabitEthernet 2/0/2
[RouterB-GigabitEthernet2/0/2] ip address 10.10.1.1 24
# Enable the DHCP relay agent on GigabitEthernet 2/0/2.
[RouterB-GigabitEthernet2/0/2] dhcp select relay
# Specify the IP address of the DHCP server on the relay agent.
[RouterB-GigabitEthernet2/0/2] dhcp relay server-address 10.1.1.1
[RouterB-GigabitEthernet2/0/2] arp authorized enable
[RouterB-GigabitEthernet2/0/2] quit
# Enable the recording of relay entries on the relay agent.
[RouterB] dhcp relay client-information record
   IPv4 Address                      : 10.10.1.2
   Default Gateway                   : 10.10.1.1
# Display authorized ARP entry information on Router B.
[RouterB] display arp all
10.1.1.1        0cda-41c7-057e N/A      GE2/0/1                  15    D
10.10.1.2       0066-61e2-f7f2 N/A      GE2/0/2                         20    D
#Disconnect the host from Router B and change the IP address of the host to a static IP address that resides on the same network segment as Router B. Verify that the host and Router B cannot communicate with each other after you reconnect the host to Router B.
C:\Windows\System32> ping 10.10.1.1
Pinging 10.10.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.10.1.1:
Configuration files
·     Router A:
 dhcp enable
 combo enable copper
·     Router B:
 dhcp enable
interface GigabitEthernet2/0/2
 ip address 10.10.1.1 255.255.255.0
 dhcp select relay
Related documentation
·     Layer 3—IP Services Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     Layer 3—IP Services Command Reference in H3C SR6608-M Router Command References(V9)
·     Security Configuration Guide in H3C SR6608-M Router Configuration Guides(V9)
·     Security Command Reference in H3C SR6608-M Router Command References(V9)
