H3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
HomeSupportResource CenterQuick StartH3C Campus Fixed-Port Switches Web-Based Quick Start Configuration Guide-6W100
30-Configuration Backup, Export, Restoration to Factory Default
Configuration Backup, Export, Restoration to Factory Defaults Quick Start Configuration Guide
Procedures
Backing up the configuration
1.     From the left navigation pane, select Device > Maintenance > Configuration.
2.     Click Save Running Configuration.
3.     Select to save the running configuration to a file and set the file name to config.cfg.
4.     Click Apply.
Figure 1 Saving the running configuration
Exporting the configuration
2.     Click Exporting Running Configuration.
The configuration file will be downloaded locally.
The backup configuration file is in .cfg format. It is displayed at the bottom of the browser when it is downloaded.
Restoring the factory-default configuration
2.     Click the  icon for the Reset to factory defaults item.
3.     Click Reset.
Figure 2 Resetting to factory defaults
  • Become a Partner
  • Partner Resources
