H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
29-PoE Quick Start Configuration Guide
29-PoE Quick Start Configuration Guide 69.93 KB
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring PoE
Introduction
The following information uses an example to describe the basis procedure to configure PoE.
The system reserves and supplies power to a PSE only after you enable PoE for that PSE.
You can enable PoE for a PSE if the PSE will not result in PoE power overload. If the PSE will result in PoE power overload, you can enable PoE for the PSE only when the PSE priority policy is enabled on the PSE.
You cannot execute the apply poe-profile or apply poe-profile interface command repeatedly to modify a PoE profile. To modify a PoE profile applied on a PI, first remove the PoE profile from the PI.
Enabling PoE for a single PI
# Enter system view.
< Device> system-view
# Enable PoE on GigabitEthernet 1/0/1.
[Device] interface GigabitEthernet 1/0/1
[Device-GigabitEthernet1/0/1] poe enable
# Save the configuration.
[Device] save force
Enabling PoE for PIs in bulk
# Create a PoE profile named abc, and specify its index number as 1.
[Device] poe-profile abc 1
# Enable PoE.
[Device-poe-profile-abc-1] poe enable
[Device-poe-profile-abc-1] return
# Apply PoE profile abc with an index number of 1 to PIs.
[Device] apply poe-profile abc index 1 interface gigabitethernet 1/0/1 to gigabitethernet 1/0/6
[Device] save force
# Verify that the device is supplying power correctly to the PIs, and the PIs are operating correctly.
Configuration files
·     Enabling PoE for a single PI.
poe enable
·     Enabling PoE for PIs in bulk.
poe-profile abc 1
 poe enable
 apply poe-profile index 1
save force
Related documentation
·     PoE configuration in the network management and monitoring configuration guide for the device.
·     PoE commands in the network management and monitoring command reference for the device.
