H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
20-Basic RIP Quick Start Configuration Guide
20-Basic RIP Quick Start Configuration Guide 78.44 KB
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring basic RIP settings
Introduction
The following information uses an example to describe the basic procedure for configuring basic RIP settings.
As shown in Figure 1, enable RIPv2 on all switches so that Host A and Host B can communicate with each other.
Figure 1 Network diagram
Configuring Host A and Host B
# Configure IP address 30.1.1.2, subnet mask 255.255.255.0, and gateway address 30.1.1.1 for Host A. (Details not shown.)
# Configure IP address 40.1.1.2, subnet mask 255.255.255.0, and gateway address 40.1.1.1 for Host B. (Details not shown.)
Configuring Switch A
# Create VLANs and assign ports to them. Configure the IP address of each VLAN interface.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1
[SwitchA-vlan100] quit
[SwitchA] vlan 300
[SwitchA-vlan300] port gigabitethernet 1/0/2
[SwitchA-vlan300] quit
[SwitchA-Vlan-interface100] ip address 10.1.1.1 24
[SwitchA] interface vlan-interface 300
[SwitchA-Vlan-interface300] ip address 30.1.1.1 24
[SwitchA-Vlan-interface300] quit
# Configure RIPv2 settings.
[SwitchA] rip
[SwitchA-rip-1] network 10.1.1.0
[SwitchA-rip-1] network 30.1.1.0
[SwitchA-rip-1] version 2
[SwitchA-rip-1] undo summary
[SwitchA-rip-1] quit
# Save the configuration.
[SwitchA] save force
Configuring Switch B
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 1/0/1
[SwitchB-vlan100] quit
[SwitchB] vlan 200
[SwitchB-vlan200] port gigabitethernet 1/0/2
[SwitchB-vlan200] quit
[SwitchB-Vlan-interface100] ip address 10.1.1.2 24
[SwitchB-Vlan-interface200] ip address 20.1.1.1 24
[SwitchB] rip
[SwitchB-rip-1] network 10.1.1.0
[SwitchB-rip-1] network 20.1.1.0
[SwitchB-rip-1] version 2
[SwitchB-rip-1] undo summary
[SwitchB-rip-1] quit
[SwitchB] save force
Configuring Switch C
[SwitchC] vlan 200
[SwitchC-vlan200] port gigabitethernet 1/0/1
[SwitchC-vlan200] quit
[SwitchC] vlan 400
[SwitchC-vlan400] port gigabitethernet 1/0/2
[SwitchC-vlan400] quit
[SwitchC-Vlan-interface200] ip address 20.1.1.2 24
[SwitchC] interface vlan-interface 400
[SwitchC-Vlan-interface400] ip address 40.1.1.1 24
[SwitchC-Vlan-interface400] quit
[SwitchC] rip
[SwitchC-rip-1] network 20.1.1.0
[SwitchC-rip-1] network 40.1.1.0
[SwitchC-rip-1] version 2
[SwitchC-rip-1] undo summary
[SwitchC-rip-1] quit
[SwitchC] save force
# Display the RIP routing table of Switch A.
[SwitchA] display rip 1 route
              D - Direct, O - Optimal, F - Flush to RIB
 Peer 10.1.1.2 on Vlan-interface100
      Destination/Mask        Nexthop           Cost    Tag     Flags   Sec
      20.1.1.0/24             10.1.1.2          1       0       RAOF    27
      40.1.1.0/24             10.1.1.2          2       0       RAOF    27
 Local route
      10.1.1.0/24             0.0.0.0           0       0       RDOF    -
      30.1.1.0/24             0.0.0.0           0       0       RDOF    -
# Display the RIP routing table of Switch B.
[SwitchB] display rip 1 route
 Peer 10.1.1.1 on Vlan-interface100
      30.1.1.0/24             10.1.1.1          1       0       RAOF    0
 Peer 20.1.1.2 on Vlan-interface200
      40.1.1.0/24             20.1.1.2          1       0       RAOF    9
 Local route
      20.1.1.0/24             0.0.0.0           0       0       RDOF    -
# Display the RIP routing table of Switch C.
[SwitchC] display rip 1 route
 Peer 20.1.1.1 on Vlan-interface200
      10.1.1.0/24             20.1.1.1          1       0       RAOF    32
      30.1.1.0/24             20.1.1.1          2       0       RAOF    32
 Local route
      40.1.1.0/24             0.0.0.0           0       0       RDOF    -
# Ping Host B on Host A to verify that Host B is reachable (assuming Windows XP is installed on the host).
C:\Documents and Settings\Administrator>ping 40.1.1.2
Pinging 40.1.1.2 with 32 bytes of data:
Reply from 40.1.1.2: bytes=32 time=1ms TTL=126
Ping statistics for 40.1.1.2:
Configuration files
·     Switch A:
rip 1
 undo summary
 version 2
 network 10.0.0.0
 network 30.0.0.0
vlan 100
vlan 300
interface Vlan-interface100
interface Vlan-interface300
 ip address 30.1.1.1 255.255.255.0
 port link-mode bridge
 port access vlan 100
 port access vlan 300
·     Switch B:
rip 1
 undo summary
 version 2
 network 10.0.0.0
 network 20.0.0.0
vlan 100
vlan 200
interface Vlan-interface200
 ip address 20.1.1.1 255.255.255.0
 port access vlan 200
·     Switch C:
rip 1
 undo summary
 version 2
 network 20.0.0.0
 network 40.0.0.0
vlan 200
vlan 400
 ip address 20.1.1.2 255.255.255.0
interface Vlan-interface400
 ip address 40.1.1.1 255.255.255.0
 port access vlan 400
Related documentation
·     RIP configuration in the Layer 3—IP routing configuration guide for the device.
·     RIP commands in the Layer 3—IP routing command reference for the device.
