H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
13-QinQ Quick Start Configuration Guide
13-QinQ Quick Start Configuration Guide 107.21 KB
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring basic QinQ
Introduction
The following information uses an example to describe the basic QinQ configuration procedure.
As shown in Figure 1, Site 1 and Site 2 belong to the same company and access the service provider network through access switches CE 1 and CE 2. VLAN 2 is used for internal network services of the company, and VLAN 200 is used in the service provider network. Configure QinQ on PE A and PE B to transmit traffic between Site 1 and Site 2 over the service provider network.
Figure 1 Network diagram
Before enabling QinQ on a port, specify the PVID tag as the SVLAN tag for packet encapsulation.
Configuring CE 1
# Create VLAN 2.
<CE 1> system-view
[CE 1] vlan 2
[CE 1-vlan2] quit
# Specify GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 as access ports to allow packets from VLAN 2 to pass through.
[CE 1] interface range gigabitethernet 1/0/2 to gigabitethernet 1/0/3
[CE 1-if-range] port access vlan 2
[CE 1-if-range] quit
# Specify GigabitEthernet 1/0/1 as a trunk port to allow packets from VLAN 2 to pass through.
[CE 1] interface gigabitethernet 1/0/1
[CE 1-GigabitEthernet1/0/1] port link-type trunk
[CE 1-GigabitEthernet1/0/1] port trunk permit vlan 2
[CE 1-GigabitEthernet1/0/1] quit
Configuring CE 2
Configure CE 2 in the same way CE 1 is configured. (Details not shown.)
Configuring PE A
# Create VLAN 2 and VLAN 200.
<PE A> system-view
[PE A] vlan 2
[PE A-vlan2] quit
[PE A] vlan 200
[PE A-vlan200] quit
# Specify GigabitEthernet 1/0/1 as a trunk port to allow packets from VLAN 2 and VLAN 200 to pass through.
[PE A] interface gigabitethernet 1/0/1
[PE A-GigabitEthernet1/0/1] port link-type trunk
[PE A-GigabitEthernet1/0/1] port trunk permit vlan 2 200
# Specify the PVID as VLAN 200 for GigabitEthernet 1/0/1.
[PE A-GigabitEthernet1/0/1] port trunk pvid vlan 200
# Enable QinQ for GigabitEthernet 1/0/1.
[PE A-GigabitEthernet1/0/1] qinq enable
[PE A-GigabitEthernet1/0/1] quit
# Specify GigabitEthernet 1/0/2 as a trunk port to allow packets from VLAN 200 to pass through.
[PE A] interface gigabitethernet 1/0/2
[PE A-GigabitEthernet1/0/2] port link-type trunk
[PE A-GigabitEthernet1/0/2] port trunk permit vlan 200
[PE A-GigabitEthernet1/0/2] quit
Configuring PE B
Configure PE B in the same way PE A is configured. (Details not shown.)
Verify that a PC at Site 1 and a PC at Site 2 can ping each other successfully and learn the MAC addresses from each other. CVLAN information can be transparently transmited between the two PCs over the service provider network.
# Ping a PC at Site 2 from a PC at Site 1 to verify the connectivity.
C:\Users\usera>ping 192.168.1.2
Pinging 192.168.1.2 with 32 bytes of data:
Reply from 192.168.1.2: bytes=32 time=28ms TTL=253
Reply from 192.168.1.2: bytes =32 time =27ms TTL=253
Reply from 192.168.1.2: bytes =32 time =26ms TTL=253
Ping statistics for 192.168.1.2:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% Loss),
Approximate round trip time in milli-seconds:
Minimum = 26ms, Maximum = 28ms, Average = 27ms
# View the MAC address table on CE 1 to verify that CE 1 has learned the MAC address of the PC at Site 2.
<Sysname> display mac-address vlan 2
MAC Address      VLAN ID    State            Port/Nickname            Aging
0003-2d00-5761   2          Learned          GE1/0/1                  Y
Configuration files
·     CE 1
vlan 2
 port trunk permit vlan 1 to 2
 port access vlan 2
 port access vlan 2
·     CE 2
vlan 2
 port access vlan 2
 port access vlan 2
·     PE A
vlan 2
Vlan 200
 port trunk permit vlan 1 to 2 200
 qinq enable
 port trunk permit vlan 1 200
·     PE B
vlan 2
Vlan 200
 qinq enable
Related Documents
·     QinQ configuration in the Layer 2—LAN switching configuration guide for the device.
·     QinQ commands in the Layer 2—LAN switching command reference for the device.
