H3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
HomeSupportQuick StartsQuick Start Configuration GuidesH3C Campus Fixed-Port Switches CLI-Based Quick Start Configuration Guide -6W102
Table of Contents
Related Documents
23-Packet Filtering Quick Start Configuration Guide
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Configuring packet filtering
Introduction
The following information uses an example to describe the basic procedure for configuring packet filtering.
As shown in Figure 1, a company interconnects its departments through the device. Configure packet filtering to:
·     Permit access from the Admin Dept at any time to the Internet and servers and deny access from the Admin Dept to the R&D Dept.
·     Permit access from the R&D Dept to the servers and deny access from the R&D Dept to the Internet and the Admin Dept.
Figure 1 Network diagram
1.     Configure access to the Admin Dept.
# Create an IPv4 advanced ACL numbered 3000.
[Device] acl advanced 3000
# Configure a rule to deny packets from the R&D Dept.
[Device-acl-ipv4-adv-3000] rule deny ip destination 10.1.2.0 0.0.0.255
# Apply IPv4 advanced ACL 3000 to filter incoming packets on GigabitEthernet 1/0/4.
[Device] interface gigabitethernet 1/0/4
[Device-GigabitEthernet1/0/4] packet-filter 3000 inbound
[Device-GigabitEthernet1/0/4] quit
2.     Configure access to the R&D Dept.
# Create an IPv4 advanced ACL numbered 3001.
[Device] acl advanced 3001
# Configure a rule to permit packets from the Admin Dept.
[Device-acl-ipv4-adv-3001] rule permit ip destination 10.2.1.0 0.0.0.255
# Configure a rule to deny all other packets.
[Device-acl-ipv4-adv-3001] rule deny ip
# Apply IPv4 advanced ACL 3001 to filter incoming packets on GigabitEthernet 1/0/3.
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] packet-filter 3001 inbound
[Device-GigabitEthernet1/0/3] quit
Verify the configuration
# Display ACL application information for inbound packet filtering.
[Device] display packet-filter interface inbound
Interface: GigabitEthernet1/0/3
 Inbound policy:
  IPv4 ACL 3001
Interface: GigabitEthernet1/0/4
 Inbound policy:
  IPv4 ACL 3000
The output shows that GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 are successfully applied with ACLs for packet filtering.
# Verify that a website on the Internet cannot be pinged from a PC in the R&D Dept.
C:\>ping www.google.com
Pinging www.google.com [172.217.194.99] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 173.194.127.242:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\>
# Verify that a server can be pinged from a PC in the R&D Dept.
C:\>ping 10.2.1.10
Ping 192.168.1.60 (10.2.1.10): 56 data bytes, press CTRL+C to break
56 bytes from 10.2.1.10: icmp_seq=0 ttl=255 time=12.963 ms
56 bytes from 10.2.1.10: icmp_seq=1 ttl=255 time=4.168 ms
56 bytes from 10.2.1.10: icmp_seq=2 ttl=255 time=7.390 ms
56 bytes from 10.2.1.10: icmp_seq=3 ttl=255 time=3.363 ms
56 bytes from 10.2.1.10: icmp_seq=4 ttl=255 time=2.901 ms
C:\>
# Verify that a website on the Internet can be pinged from a PC in the Admin Dept.
Reply from 172.217.194.99: bytes=32 time=30ms TTL=50
Ping statistics for 172.217.194.99:
    Minimum = 30ms, Maximum = 30ms, Average = 30ms
C:\>
Configuration files
 port link-mode bridge
interface Ten-GigabitEthernet1/0/4
acl advanced 3000
 rule 0 deny ip destination 10.1.2.0 0.0.0.255
acl advanced 3001
 rule 0 permit ip destination 10.2.1.0 0.0.0.255
 rule 5 deny ip
Related documentation
·     ACL configuration in the ACL and QoS configuration guide for the device.
·     ACL commands in the ACL and QoS command reference for the device.
